[ROM][WIP][Android 4.4.3] CyanogenMod 11 with CAF 3.4.0 kernel [June 15, 2014]
  • 33 Antworten
HTC_Freak
HTC_Freak
Original Thread: [ROM][WIP][Android 4.4.3] CyanogenMod 11 with CAF 3.4.0 kernel [June 15, 2014] - xda-developers
Ich habe keinerlei Anteil an dieser ROM; ich habe nur den Thread ins Deutsche übersetzt!
Stand: 15.6.2014 - 8:40
CyanogenMod (pronounced /saɪ.'æn.oʊ.dʒɛn.mɒd/) is an enhanced open source firmware distribution for smartphones and tablet computers based on the Android mobile operating system. It offers features and options not found in the official firmware distributed by vendors of these devices.
Features supported by CyanogenMod include native theming support, FLAC audio codec support, a large Access Point Name list, an OpenVPN client, an enhanced reboot menu, support for Wi-Fi, Bluetooth, and USB tethering, CPU overclocking and other performance enhancements, soft buttons and other "tablet tweaks", toggles in the notification pull-down (such as wi-fi, Bluetooth and GPS), app permissions management, as well as other interface enhancements. CyanogenMod does not contain spyware or bloatware. In many cases, CyanogenMod may increase performance and reliability compared with official firmware releases.
CyanogenMod is developed as free and open source software based on the official releases of Android by Google, with added original and third-party code.
Source: CyanogenMod Wiki
Bemerkbare Features:
  • Benutzt den 3.4.0 Kernel basierend auf den puren CAF KitKat Quellen (∞ danke an Flemmard und shantur für ihre atemberaubenden Fehlerbehebungen; lies am Ende, was CAF bedeutet)
  • 607MB benutzbarer RAM
  • Benutzt den ION Speicher Allocator für alles: Sound, Display, Videowiedergabe, Kamera, etc.
  • CAF KitKat Display & Medien HALs
  • Hardware Vsync
  • Keine Grafikfehler in Google Maps 7, Google Chrome, Browser, Gmail usw.
  • SELinux (Security-Enhanced Linux = Sicherheitsverbessertes Linux) aktiviert und eingestellt für bessere Sicherheit
  • Benutzt die neusten Adreno (Grafik) Libs und Firmware, die für unser Handy verfügbar sind (Android 4.2/ MR1 Binärdatein)
  • MTP
  • Viele Hacks für alte Grafiken entfernt
  • Adreno Lib Version: AU_LINUX_ANDROID_JB_VANILLA_04.02.02.060.051
  • RIL aktualisiert zu 4.0.0056HMQ (danke an Noobel)
  • Wlan Regioncode Fix von HTCZ715E (Regioncode ändert sich nicht wieder auf USA nach einen Neustart)
Funktioniert:
  • Kamera
  • Camcorder
  • Videowiedergabe
  • Natives USB OTG
  • VoIP
  • VPN
  • Bluetooth
  • Screenshot
  • "Letzte Apps" Wechsel
  • MTP
  • Audio
  • Mobiles Internet
  • Alle Sensoren (Beschleunigungsmesser, Näherungssensor, etc.)
  • GPS
Große Fehler:
  • Keine großen Fehler :)
Kleine Fehler:
  • Einige Probleme mit VoIP bekannt (das passiert bei allen KitKat Roms fürs Sensation)
  • Verknüpfungen für Apps, die auf der SD-Karte gespeichert sind, verschwinden aus dem Homescrren nach einen Reboot (das passiert auch bei allen KitKat Roms fürs Sensation)
Installation:
Es ist sehr zu empfehlen einen vollständigen Wipe durchzuführen (Werkseinstellungen, System, Cache), wenn man von einer anderen ROM kommt und dann installiert man diese ROM und die Gapps für Android 4.4. Wenn man von einer CM10.2 ROM kommt, ist es möglich diese ROM zusammen mit den Gapps für 4.4 drüber zu installieren, ohne einen Wipe durchzuführen ("dirty flash"). JEDOCH, wenn man IRGENDEINEN Fehler dadurch hat, werde ich nicht helfen, diesen zu beheben. Ich werde nur deinen Problemen zuhören, wenn du vorher einen vollständigen Wipe durchgeführt hast. Wenn ein Update meiner ROM vorhanden ist, dann ist es okay dieses einfach drüber zu installieren und nur den Cache und Dalvik zu löschen.
Häufige Probleme und Lösungen:
1. Problem: Musik springt und/ oder wird über den Lautsprecher wiedergegeben, immer wenn ich zum Homescreen gehe!
Lösung: Man muss die "Ok Google" Worterkennung deaktivieren. Gehe zu Google Einstellungen -> Suche & Now -> Stimme -> "Ok Google" Worterkennung -> Deaktiviere Worterkennung
Source:
Sultan Kernel Pure CAF 3.4 (cm-11.0 branch): https://github.com/sultanxda/sultan-kernel-pyramid-pure-CAF-3.4
Device tree (cm-11.0 branch): https://github.com/sultanxda/android_device_htc_pyramid
Hersteller Datein (cm-11.0 branch): https://github.com/sultanxda/android_vendor_htc
Mein Manifest (cm-11.0 branch): https://github.com/sultanxda/Android
Credits (in no particular order):
Das CyanogenMod Team und alle Mitwirkende
Flemmard (für seine bewundernswerte Fixe)
Shantur
CAF (Code Aurora Forum, das sind Qualcomm Ingenieure)
Michael Bestas (mikeNG)
Mike Grissom (mikeyman77)
David Ferguson (dferg)
Nick Reuter (elginsk8r)
Ricardo Cerqueira (rmcc)
Chirayu Desai (chirayudesai)
HTCZ715E
Dărescu Ionuț (johnnyslt)
dhacker29
Andrew Sutherland (drewis)
CRACING (für das Banner ganz oben)
paulb-nl
bilalliberty
SebastianFM
ivanich
scverhagen
PA for the gapps
bastei
liquid64
ICH :cowboy:
Downloads:
Bitte lies erst den kompletten Post, bevor du etwas schreibst!
ROM: Goo.im Downloads - Browsing Pyramid_CM11_3.4
Gapps: Goo.im Downloads - Browsing gapps-micro
Kernel-only updates/kernel Aroma installer: Goo.im Downloads - Browsing Sultan_kernel_Pyramid_Pure_3.4
Mirror:
ROM: Dev-Host - The Ultimate Free File Hosting / File Sharing Service
Gapps: Dev-Host - The Ultimate Free File Hosting / File Sharing Service
Kernel-only updates/kernel Aroma installer: Dev-Host - The Ultimate Free File Hosting / File Sharing Service
Changelog:
June 14, 2014:
ROM:
*Neuste CyanogenMod Änderungen
*Android 4.4.3
*Manuelle Mobile Netzwerksuche behoben (shantur)
*Frontkamera Videoaufnahme behoben mit der Standard Kameraapp
*Fehlende VGA/480p Frontkamera Auflösungen behoben in Google Camera
*Unterstützung für FFMPEG Codecs hinzugefügt (Mark376)
Kernel:
Sultan Kernel Pure CAF v1.0.4:
*Aktualisiert mit dem CAF kk_2.7-stable Zweig
*eMMC Hintergrundoperationen wieder aktiviert
*GPU Speicher vergrößert (benötigt für die GPU Treiber Updates)
*Kernel Startadresse verschoben nach 0x40400000
*Noch 3 mehr Speicherbänke hinzugefügt um noch mehr RAM freizugeben
*620MB RAM
*Wlan Treiber mit dem von der Nexus 5 KitKat 4.4.3 Kernel Veröffentlichung aktualisiert
May 25, 2014:
ROM:
*Zur alten Soundkalibrierung zurückgewechselt
*Bootprobleme behoben, die durch Änderungen in der fstab Datei verursacht wurden
Kernel:
Sultan Kernel Pure CAF v1.0.3:
*Powermanagement Architektur aktualisiert von Flemmard und CAF
*Soundkalibrierungsdatei korrigiert (behebt geringe Lautsprecherlautstärke)
*Ruckelige Animationen behoben, wenn man die Bildschirmhelligkeit ändert (danke an intervigil)
May 24, 2014:
ROM:
*Zum "by-name" Partition Schema gewechselt (Flemmard & Mark376)
*Beinhaltenes 89z_kernel init.d Skript aktualisiert
Kernel:
Sultan Kernel Pure CAF v1.0.2:
*S2W entfernt
*Framebuffer Treiber mit dem CAF kk_2.7-stable Zweig aktualisiert
*Unbalancierter dsi Takt in Framebuffer Treiber behoben
May 23, 2014:
ROM:
*Bemerkbare Cyanogen Änderungen: Abstürz beim Herunterziehen der Statusleiste behoben
*Hoher Leuchtkraftmodus in der Taschenlampe hinzugefügt
*Soundkalibrierung von Shantur hinzugefügt
Kernel:
Sultan Kernel Pure CAF v1.0.1:
*S2W hinzugefügt
*Viel übertriebenes Debugging und anderern Müll entfernt
*Mit dem CAF kk_2.7-stable Zweig aktualisiert
*n_tty_write Absturz behoben, wenn Echo im Rawmode (peterhurley)
*Wlan Probleme behoben
*Verbessertes Powermanagement
*607MB RAM
May 15, 2014:
ROM:
*Anfangsveröffentlichung mit CAF Kernel
Kernel:
*Anfangsveröffentlichung mit dem 3.4.0 Kernel basierend auf den puren CAF KitKat 2.7_rb1.38 Quellen
*Ermöglicht durch die Treiber und Fehlerbehebungen von Flemmard
Kernel Features und Einzelheiten
Das ist ein 3.4er kernel basierend auf den puren CAF KitKat (kk_2.7-stable) Kernelquellen mit folgenden Features:
  • Fastcharge
  • 607MB RAM
  • Wlan Treiber vom Google Nexus 5
  • Display Undervolting
  • Grudlegende Farbkontrolle (wähle zwischen Standard und kälteren Farben)
  • Vieles an Debugging Müll entfernt
  • CPU übertaktbar bis 1.836GHz
  • GPU übertaktbar bis 320MHz
FAQ
Was ist CAF? Was meint du damit, wenn du sagst, du hast einen puren CAF Kernel erstellt?
CAF = Code Aurora Forum. CAF ist der Ort, wo Qualcomm Ingenieure arbeiten, um den Linuxkernel exklusiv für die Qualcomm Geräte zu optimieren. Die Gerätehersteller benutzen die Kernelquellen vom CAF um die Kernel für ihre Qualcomm Geräte zu erstellen, aber der Quellcode ist dann immer schon mehrere Monate älter, als der neueste verfügbare im CAF. Durchs Benutzten der neusten Kernelquellen vom CAF und durchs Hinzufügen von Flemmards Sensation Treibern und Fehlerbehebungen, habe ich einen neuen Kernel erstellt, der die neusten Verbesserungen und Optimierungen von Qualcomm besitzt.
Reaktionen: DevilD51
Sweep2Wake entfernt wie es scheint laut log.
Dann brauche ich die Rom erstmal nicht mehr.
Das wollte ich schon benutzen.
Funktioniert denn jetzt wohl Skype ?
In der version von gestern gab es ja das Ton Problem das man nur wenn man auf Lautsprecher umschaltet Ton erhält.
Bzw erst dann weil wenn man dann wieder zurück schaltet hatte man Ton am Ohr.
Kann das einer der gerade die Rom testet mal versuchen dann brauche ich sie nicht extra nur dafür wieder zu installieren.
Zufiel hin und her geflashe ist auch nicht gut.
Reaktionen: 1HSV
Ja, S2W bringt schlicht viele Probleme mit sich, deswegen arbeitet SebastianFM auch schon seit längeren (wenn er denn mal zum Programmieren kommt) an einer anderen Lösung, die nicht so viele Probleme verursacht.
Aber wenn dir so viel an S2W liegt, kannst du auch einfach die neuste ROM installieren und den älteren Kernel 1.0.1 installieren, siehe hier Goo.im Downloads - Browsing Sultan_kernel_Pyramid_Pure_3.4 Ist natürlich auf Dauer keine Lösung, da immer wieder neue Änderungen dazukommen. Alternativ könntest du natürlich immer deinen eigenen Kernel kompilieren mit S2W hinzugefügt!
Skype habe ich jetzt nicht selber getestet, ist aber sowohl bei dieser, als auch bei der anderen ROM unter den kleineren Problemen aufgeführt ("Einige Probleme mit VoIP bekannt") und dazu zählt Skype.
Bei der andern CM11 Rom funktioniert Skype aber mit dem Ton.
Was die da mit VoIP Probleme meinen weiß ich nicht.
Ich habe nur kurz getestet einmal beim Skype Test anrufen.
S2W lief gestern auch.
Ich verstehe nicht warum man das gleich entfernt denn man muss es ja eh selber im Code einschalten.
Ich habe aber auch da nur ganz kurz getestet.
Mein Problem diese ROM kam mir sehr schnell vor und die andere recht langsam und braucht meine ich auch mehr Strom.
Wobei meine Strom Tests nicht ganz sicher sind da hier auch gestern Stunden lang Handynetzausfall war. (Stand auf der Handyanbieter Seite)
(Auf dem Land in de nur ein Masten für das ganze Dorf)
ich brauch mal einen Tipp. Während der installation kommt eine Auswahl wo man sich für ei cyanogen Zugang anmelden kann.
Wo finde ich die Möglichkeit nach dem einrichten des Telefons? Ich habe mir schon einen Wolf gesucht.
MfG
latte
Einstellungen/Konten/Konto hinzufügen
Danke, manchmal sieht man den Wald... :)
MfG
latte
Bin ich der einzige der beim Laden nicht über die 99% kommt ? :DD
Hmm hatte ich jetzt nicht das Problem, aber das Problem gab es schon öfters und immer wieder. Akku sollte trotzdem voll sein :D
So, neues Update ist raus, Thread ist aktualisiert! Erstmal das letzte Update der Woche (laut Sultan)
Das letzte Update der Woche :biggrin:
(Am Sonntag) der ist gut. Er meint wahrscheinlich die folgende Woche auch kein Update.
in ;) jemand schon erfahrung zur akku laufzeit zur vorherigen Rom?
Problem:
Bei der Installation der Zip per 4EXT bricht die Installation ab mit Error in der ZIP status 0.
(habe keinen Fullwipe durchgeführt)
Lösung:
Liegt am veraltetem 4EXT-Recovery nach dem update auf 1.0.0.6 rc2 läufts ;)
Hab es ja nun schon eine Weile drauf und muss sagen das es richtig flott läuft die ROM.
Einzig der doch merklich größere ACCU Verbrauch im Vergleich zu anderen ROM´s stört mich schon.
Dabei ist "Mobilfunk Standby" und "Ruhezustand" warum auch immer die schlimmsten mit jeweils fast 30%.
Hoffe das da noch was unternommen werden kann, denn ansonsten bin ich am überlegen mich nach einer anderen ROM um zu schauen.
Bei mir wird wenn ich das Handy per USB an den PC anschließe kein Massenspeichermedium mehr erkannt. Hat jemand das selbe problem oder lösungen?
Hallo zusammmen, ich habe ein Problem bei der Installation.
Nach den drei Wipes (Partition, Cache, Facrory) sagt mir mein HTC Sensation bei der Installation des CM11 (Version vom 25.05.2014) folgenden Error:
E:Error in /sdcarc/cm-11-20140525-Sultan-pyramid.zip
(Status 0)
Installation aborted.
Status 0 habe ich nachgesehen, wurde aber daraus nicht schlau. Kann mir jemand helfen?
Möchte ungern wieder zurück auf 4.3.1...
@Ponenta, guck mal 3 Beiträge weiter oben, bzw gleich der erste Post auf der zweiten Seite^^
Ups, ja genau das meine ich. Es muss also 4ext rc auf 1.0.0.6 gebracht werden.
Dazu stelle ich per "fastboot getvar version-main" meine Firmware-Version fest: 3.32.206.51
Per "fastboot getvar cid" meine Region: cid02_102 = Deutschland
Ich suche also die [RUU] fürs Sensation =[Pyramid] [Firmware Base.Provider/Location code] => RUU Pyramid 3.32.102
Und ab hier weiß ich nicht weiter. Wo finde ich die ? Oder ist das garnicht vonnöten ?
Also, wenn du deinen 4ext updaten willst benutzt du einfach den updater http://www.4ext.net/get.php?apk.
Runterladen, installieren und einfach Einleitung folgen
Danke dir, es hat jetzt geklappt :D Wer richtig ließt ist klar im Vorteil.
Meine Beiträge können gelöscht werden ;-)
Hallo zusammen
Da S2W nicht implimentiert zu sein scheint, ich aber gerne damit arbeite würde ich gerne wissen ob geplant ist das noch mit einzubauen:confused2:
Nein, Sultan hat S2W in einer Version drin gehabt, aber in der nächsten sofort wieder entfernt. Es bringt schlicht sehr viele Probleme und Fehler mit sich. Zudem waren viele "unsaubere" Veränderungen im Kernel nötig, welche alle zu lasten der Stabilität gingen. Sultan hat deshalb recht deutlich gemacht, dass er dieses Feature nicht wieder einbauen will.
Gleicher Meinung ist übrigens auch SebastianFM (der Kernelentwickler, der für die Portierung des VilleC2 Kernels aufs Sensation verantwortlich ist und die Kamera ohne den HTC Quellcode zu haben, zum Laufen bekommen hat). Deshalb arbeitet er auch schon eine ganze Weile an einer anderen Möglichkeit, kommt jedoch aus Zeitmangel nur langsam voran.
O
OneGamer
O
Brunki
HTC_Freak
yosenami
Y
