[ROM][STABLE][4.4.4] CyanogenMod 11 with 3.0.16 kernel [November 13, 2014]
  • 374 Antworten
HTC_Freak
HTC_Freak
Original Thread: [ROM][STABLE][4.4.4] CyanogenMod 11 with 3.0.16 kernel [November 13, 2014]
Ich habe keinerlei Anteil an dieser ROM; ich habe nur den Thread ins Deutsche übersetzt!
Stand: 13.11.2014 - 15:45
CyanogenMod (pronounced /saɪ.'æn.oʊ.dʒɛn.mɒd/) is an enhanced open source firmware distribution for smartphones and tablet computers based on the Android mobile operating system. It offers features and options not found in the official firmware distributed by vendors of these devices.
Features supported by CyanogenMod include native theming support, FLAC audio codec support, a large Access Point Name list, an OpenVPN client, an enhanced reboot menu, support for Wi-Fi, Bluetooth, and USB tethering, CPU overclocking and other performance enhancements, soft buttons and other "tablet tweaks", toggles in the notification pull-down (such as wi-fi, Bluetooth and GPS), app permissions management, as well as other interface enhancements. CyanogenMod does not contain spyware or bloatware. In many cases, CyanogenMod may increase performance and reliability compared with official firmware releases.
CyanogenMod is developed as free and open source software based on the official releases of Android by Google, with added original and third-party code.
Source: CyanogenMod Wiki
Bemerkbare Features:
  • Benutzt einen minimalistischen Kernel, patched für AOSP von Grund auf (Sultan Kernel Pure)
  • Kernel basiert auf SebastianFMs Overclocked Kernel v1.5.2 ([KERNEL] Overclocked kernel v1.5.2 - xda-developers)
  • 620MB verfügbarer RAM (mehr als in jedem anderen Kernel)
  • Self-Powered USB OTG
  • Benutzt den ION Memory Allocator für alles: Sound, den Bildschirm, die Videowiedergabe, Kamera, etc.
  • CAF KitKat Ion, Framebuffer, Videocontroller Treiber, Media HAL und Display HAL
  • CAF Jelly Bean GPU Treiber (vom CAF branch jb_2.5)
  • Hardware VSync
  • Keine Google Maps 7, Google Crome, Browser, Gmail etc. Grafikfehler
  • SELinux (Security-Enhanced Linux = Sicherheitsverbessertes Linux) aktiviert und erzwungen für bessere Sicherheit)
  • MTP
  • Neuere Adreno Grafikbibliothek (flüssigere Grafik): AU_LINUX_ANDROID_JB_2.5.5.04.02.02.092.059
  • 4.0.0056HMQ RIL
Größe Fehler:
  • Keine großen Fehler :)
Kleinere Fehler:
  • Einige Probleme mit VoIP bekannt (das passiert bei allen KitKat Roms fürs Sensation)
  • Verknüpfungen für Apps, die auf der SD-Karte gespeichert sind, verschwinden aus dem Homescrren nach einen Reboot (das passiert auch bei allen KitKat Roms fürs Sensation)
  • Videoaufnahmen des Bildschirms funktioniie
Video (danke an EZY-E)
https://www.youtube.com/watch?v=ljgs13jNZTw
Installation:
Es ist sehr zu empfehlen einen vollständigen Wipe durchzuführen (Werkseinstellungen, System, Cache), wenn man von einer anderen ROM kommt und dann installiert man diese ROM und die Gapps für Android 4.4. Wenn man von einer CM10.2 ROM kommt, ist es möglich diese ROM zusammen mit den Gapps für 4.4 drüber zu installieren, ohne einen Wipe durchzuführen ("dirty flash"). JEDOCH, wenn man IRGENDEINEN Fehler dadurch hat, werde ich nicht helfen, diesen zu beheben. Ich werde nur deinen Problemen zuhören, wenn du vorher einen vollständigen Wipe durchgeführt hast. Wenn ein Update meiner ROM vorhanden ist, dann ist es okay dieses einfach drüber zu installieren, ohne Wipe.
Detaillierte Installationsschritte :
  1. Downloade und installiere das neuste 4ext Recovery von HIER (du musst v1.0.0.6 RC2 oder neuer installiert haben)
  2. Downloade die ROM und die Gapps
  3. Neustart ins Recovery
  4. Führe einen Full Wipe aus (das musst du nur machen, wenn du diese ROM zum ersten Mal installierst)
  5. Flashe die ROM Zip
  6. Flashe die Gapps Zip
  7. OPTIONAL: Flashe den Kernel Aroma Installer, wenn du die Kerneleinstellungen ändern möchtest
  8. Neustart
  9. ???
  10. Profit
  11. Leg den Profit an eine Schweizer Bank an, um Steuern zu sparen
Quellen:
Sultan Kernel Pure (CM11.0 Zweig): https://github.com/sultanxda/sultan-kernel-pyramid-pure
Device Tree (CM11.0_3.0 Zweig): https://github.com/sultanxda/android_device_htc_pyramid
Vendor Daten (CM11.0 Zweig): https://github.com/sultanxda/android_vendor_htc
Mein lokales Manifest (CM11.0 Zweig): https://github.com/sultanxda/Android
Credits (in keiner besonderen Reihenfolge:
Das CyanogenMod Team
Alle CyanogenMod Mitwirkende
Steve Kondik (cyanogen)
CAF (Code Aurora Forum, das sind Qualcomm Ingenieure)
Michael Bestas (mikeNG)
Mike Grissom (mikeyman77)
David Ferguson (dferg)
Nick Reuter (elginsk8r)
Ricardo Cerqueira (rmcc)
Chirayu Desai (chirayudesai)
HTCZ715E
Dărescu Ionuț (johnnyslt)
dhacker29
Rudolf Tammekivi (Blefish)
professorpasta
Andrew Sutherland (drewis)
CRACING (für das Banner oben)
paulb-nl
bilalliberty
SebastianFM
Flemmard
shantur
ivanich
scverhagen
PA for the gapps
bastei
liquid64
Mark376
me :biggrin:
Downloads:
Bitte erst den kompletten Beitrag durchlesen, bevor ihr etwas postet.
Du benötigst das 4ext Recovery v1.0.0.6 RC2 (oder neuer) oder das TWRP Recovery mit "by-name" Partition Unterstützung um diese ROM zu installieren. Ansonsten wirst du einen "status 0" Fehler während der Installation erhalten!
ROM: https://www.androidfilehost.com/?w=files&flid=16126&sort_by=date&sort_dir=DESC
Gapps: http://www.androidfilehost.com/?w=files&flid=15801
Ausschließlich Kernelinstaller: http://www.androidfilehost.com/?w=files&flid=16127&sort_by=date&sort_dir=DESC
Changelog:
November 13, 2014:
ROM:
*Neuste CyanogenMod Änderungen
*Ondemand Governoreinstellungen wurden beim Start nicht übernommen
*VoIP Fehlerbehebungen (credit: ivanich)
Kernel:
Sultan Kernel Pure v1.8.1:
*Akkutreiber Aktualisierungsrate wieder erhöht, für genauere Prozentangaben
*Vidc Treiber vom CM Samsung MSM8660 Kernel übernommen (sollte grüne Fehler bei Videoaufnahmen beheben)
*Eingabebeschleunigung bom Ondemand Governor entfernt
*Eingabebeschleunigung zum CPU-boost Framework hinzugefügt (CPU wird schneller, wenn du den Bildschirm berührst)
*CPU wird automatisch auf 1296 MHz beschleunigt für 2,5 s, jedes Mal wenn der Bildschirm berührt wird (sehr flüssig)
November 12, 2014:
ROM:
*LED wird nun erst grün, wenn 100% erreicht sind (statt vorher schon bei 90%)
*Adreno Grafiklibs aktualisiert (flüssigere Grafik und behebt die Asphalt 8 Abstürze)
*Power HAL entfernt
*Fehler behoben, dass gleichzeitig aus dem Lautsprecher und den Kopfhörern Töne kommen (behebt auch die Probleme mit "Ok Google")
*Bootzeit verringert
*Performance des Ondemand CPU Governors erhöht
*89z_kernel init.d Skript aufgeräumt
*Rauschentfernt deaktiviert (credit: ivanich)
*App zum Einstellen der Bildschirmfarbe hinzugefügt (credit; johnnyslt)
*ZSL (zero shutter-lag) in der standard Kameraapp aktiviert (credit: ivanich)
Kernel:
Sultan Kernel Pure v1.8.0:
*Thermal Treiber neugeschrieben (behebt viele Fehler)
*Akkutreiber Aktualisierungsrate wieder verringert
*CPU0 und CPU1 haben jetzt die gleiche maximale und minimale Frequenz
*Blitz LEDs brauchen weniger Energie, wenn der Akku weniger als 35% hat (das behebt Neustarts, wenn Fotos mit Blitz bei niedrigen Akku gemacht wurden)
*2D GPUs richtig deaktiviert
*CPU-boost Framework eingeführt (lies die FAQ für mehr Infos)
July 25, 2014:
ROM:
*GooManager entfernt
Kernel:
Sultan Kernel Pure v1.7.2:
*Behoben, dass der Touchscreen aktiv bleibt, obwohl das Display aus ist (z.B. während Telefonaten)
*S2W wird automatisch deaktiviert, wenn der Näherungssensor auslöst (z.B. während Telefonaten; beachte, dass das nicht S2W deaktiviert, wenn das Handy in deiner Tasche ist)
*Wlan Ländercode Table vom Google Nexus 5 kernel hinzugefügt (das sollte Probleme für Benutzer außerhalb der USA beheben)
July 18, 2014:
Nur Kernel:
Sultan Kernel Pure v1.7.1:
*GPU Treiber von CAF kk_2.7 zu CAF jb_2.5 gewechselt (das behebt die dauernden FC Probleme)
*Einige unnötige Treiber entfernt
*Kernel wird nicht mehr mit allen Symbolen erstellt (Kernel ist nicht betroffen von zufälligen Neustarts, deshalb kann ich das machen; der Kernel ist daher viel kleiner)
*Kernel basierende mpdecision entfernt
*Unterstützung für ROM basierende mpdecision hinzugefügt (ROM basierende mpdecision braucht weniger Batterie)
*Änderungen für einen maximalen Ladestrom von 1250 mA rückgängig gemacht
*Kernel parst nun TPA2051_CFG.csv
July 1, 2014:
ROM:
Kernel:
Sultan Kernel Pure v1.7.0:
*Self-Powered USB OTG hinzugefügt (keine externe Stromquelle mehr nötig)
*n_tty Schreibfehler behoben in bestimmten Situation ("echoching in raw mode"; Peter Hurley)
*Display underrun behoben, die Grafiken sind nun weicher (Steve Kondik)
*Seltene Grafikfehler behoben (Steve Kondik)
*Fastcharge entfernt
*AC Lademodus immer erzwungen über USB (man kann das nicht mehr ändern)
*Akkutreiber Aktualisierungsrate um das 12-fache erhöht, wenn im Akkubetrieb (Akkustatistiken werden nun alle 5 statt 60 Sekunden aktualisiert)
*Ladezustandsanzeige ist daher nun viel genuer
*Kleine GPU Treiber Updates von CAF kk_2.7-stable hinzugefügt
*Probleme mit GPUMMU in den Grafiktreibern behoben (Blefish)
*Maximale Stromaufnahme von rund 300mA auf nun maximal rund 1250mA erhöht
*Akku lädt nun schneller zwischen 10 und 30%, wegen dieser Änderung
*Eine Schleife in msm_thermal behoben
June 20, 2014:
ROM:
*Android 4.4.4
*Frontkamera: Abstürze im Videomodus behoben
*QVGA und QCIF Auflösung zur Hauptkamera hinzugefügt
*CIF Auflösung zur Frontkamera hinzugefügt
*Media Prozess Abstürze hoffentlich behoben
*Fastcharge standardgemäß aktiviert im 89z_kernel Skript
Kernel:
Sultan Kernel Pure v1.6.2:
*Kleine Updates der GPU Treiber rückgängig gemacht, weil diese Probleme verursachten (out of memory)
*Display Undervolt deaktiviert standardgemäß
*Temperaturschwellwerte weniger strikt eingestellt
*Temperaturschwellwerte Optionen zum Aroma Installer hinzugefügt
June 15, 2014:
ROM:
*Manuelle Mobile Netzwerksuche behoben (shantur)
Kernel:
Sultan Kernel Pure v1.6.1:
*Kleine GPU Treiber Updates vom CAF
*GPU Speicher vergrößert (behobt FCs)
*Bildschirm Undervolt Code aufgeräumt
June 6, 2014:
ROM:
*Android 4.4.3
*Frontkamera Videoaufnahme Probleme mit Standardapp behoben
*Fehlende VGA/ 480p Frontkamera Videoauflösungen hinzugefügt
*Zum "by-name" Partition Schema gewechselt (Flemmard & Mark376)
*Unterstützung für FFMPEG Codecs hinzugefügt (Mark376)
Kernel:
Sultan Kernel Pure v1.6.0:
*Unstützung für "by-name mappings" hinzugefügt (flemmard)
*Mehr Speicher zum Ion SF Heap und zur RAM Konsole zugewiesen
*Framebuffer Treiber zu CAF kk_2.7-stable aktualisiert (danke an flemmard und intervigilium)
*GPU Treiber zu CAF kk_2.7-stable aktualisiert
*"Thermald mid trip point" behoben (danke an Tommyfirebird)
*Power-Management Architektur auf CAF jb_1.9.6 aktualisiert
*msm_rotator Bus Skalierung aktiviert
*Standard Display Undervolt erhöht von 250mV zu 400mV
May 11, 2014:
ROM:
*Lautsprecherlautstärke erhöht
*CIF Camcorder Profil hinzugefügt
*Force Close behoben, wenn man die Einstellungen in der Google Kamera aufruft
*Ständiger Autofokus deaktiviert in der Camcorder (es würde nicht fokussieren und Videos ruinieren)
*Camcorder Video Schnappschuss deaktiviert (Touch-to-Fokus während der Aufnahme ist zurück)
*CM Power HAL wieder hinzugefügt (erhöht überall die Performance)
Kernel:
Sultan Kernel Pure v1.5.2:
*Ständige Neustarts einiger Geräte behoben
*Veraltetes ION Kamera Heap entfernt
*620MB Ram, siehe in Übers Telefon ("About Phone")
*HTC MDP Farben Kalibrierungsprofil vom HTC One M7 hinzugefügt
*Bildschirmfarben verbessert (die Farben sind jetzt viel näher am richtigen RGB dran)
May 3, 2014:
ROM:
*Zurück gewechselt zur alten Tonkalibrierung (Rechte Seite bei Kopfhörern funktioniert wieder)
*Zu dem libacbloader von Flammard gewechselt (behebt Soundverzerrungen)
Kernel:
Sultan Kernel Pure v1.5.1:
*Camcorder in Apps wie Snapchat behoben
*MDP Footswitch aktiviert
*602MB RAM
May 2, 2014:
ROM:
*Zu ION Kamera Bibliotheken gewechselt - großer dank an Flemmard und shantur!
*Zu CAF KitKat Media Hal gewechselt (Videoaufnahme sollte nun in Apps wie Snapchat funktionieren)
*Tonkalibrierung von shantur hinzugefügt
Kernel:
Sultan Kernel Pure v1.5.0:
*WiFi Treiber und Wireless-Stack Upgrade von v1.4.0 rückgängig gemacht
*ION Kamera Treiber von SebastianFMs 3.4 Kernel zurück portiert
*Videocontroller Treiber vom CAF 3.4 Kernel (kk_2.7_rb1.35) zurück portiert
*Thermald strikter gemacht - Das Gerät bleibt sehr viel kühler
*Alles von PMEM entfernt
*Benutzter hat nun 608MB an RAM zur Verfügung, 6MB mehr als zuvor
Apr 13, 2014:
ROM:
*Zur CM Kamera App gewechselt (danke an AceEnablementProject für ihren camerawrapper)
*Verschlüsslung fehlgeschlagen auf /data beim Aushängen
Kernel:
Sultan Kernel Pure v1.4.0:
*GPU Treiber vom CAF kk_2.7_rb1.33 zurückportiert (danke an Flemmard)
*WiFi Treiber vom Google Nexus 5 zurückportiert (danke an Flemmard)
*Drahtloser Stack vom Google Nexus 5 Kernel zurückportiert
*Einige kleine Updates vom CAF den ION Treiber hinzugefügt
*Das der Touchscreen nicht reagiert, wenn das Gerät aufgeweckt wird behoben
*Einige CAF Patches zum Kameratreiber hinzugefügt
*Interactive und Lagfree Governors entfernt
Mar 25, 2014:
ROM:
*Laustärke beim Anrufen behoben
Kernel:
Sultan Kernel Pure v1.3.1:
*Lange Verzögerung bei der Videoaufnahme behoben (großen Dank an paulb-nl und CAF)
*Fehlende PMEM_CACHE_FLUSH Funktion hinzugefügt (danke an Johnnyslt)
Mar 24, 2014:
ROM:
*USB Probleme von der letzten Version behoben
*UMS (USB Massenspeicher) wieder hinzugefügt
*UMS als Standard Verbindungstyp gesetzt (Crapintosh unterstützt MTP nicht von Hause aus)
*Netflix Fix von liquid64 hinzugefügt
*Fastcharge Option im init.d Script hinzugefügt
Kernel:
Sultan Kernel Pure v1.3.0:
*Arbeitsspeicher viel effizienter eingeteilt, wodurch 78 MB frei wurden
*Der Benutzer hat nun 602MB RAM zur Verfügung (statt 524MB)
*Einige Bildschirmparameter angepasst, um einige seltene Grafikfehler zu beheben
Mar 20, 2014:
ROM:
*Ein Problem vom 18. März behoben, weswegen manche Geräte nicht starteten
*ivanichs Audio Fix hinzugefügt (Lautsprecher ist nun lauter bei weniger Verzerrung)
Kernel:
Sultan Kernel Pure v1.2.1:
*GPU Bus Bandweite reduziert auf Standardwerte
*FSB Bandweite reduziert auf Standardwerte
Mar 18, 2014:
ROM:
*Massenspeicher aus den Einstellungen entfernt
*MTP Probleme auf Windows Computern behoben
*Software Rendering wieder hinzugefügt
Mar 17, 2014:
ROM:
*Neuere ION Audio Libs
*Mark376s Fix gegen die Verzerrung bei hoher Lautstärke hinzugefügt
*Netzwerk Verkehrsanzeigen behoben
Kernel:
Sultan Kernel Pure v1.2.0:
*Zufällige Neustarts aufgrund der neueren ION Treiber behoben
*ION Audio Treiber vom Team-SennyC2 3.4 Kernel geportet (danke an SebastianFM für diese Treiber)
*ION qdsp6v2 Audio vom Team-SennyC2 3.4 Kernel geportet
*Altes PMEM Audio entfernt
Mar 15, 2014:
ROM:
Kernel:
Sultan Kernel Pure v1.1.0:
*Viel neuere CAF KitKat ION Treiber geportet (die gleichen ION Treiber wie im Team-SennyC2 3.4 Kernel)
*Neuere PMEM Treiber vom 3.4 Kernel geportet
*Neuere MSM Memory Treiber vom 3.4 Kernel geportet
*Ausschalten der Taschenlampe beim Ausschalten des Bildschirms behoben (danke an Johnnyslt)
Mar 14, 2014:
Nur Kernel:
Sultan Kernel Pure v1.0.6:
*Einige Displayparameter bereinigt
*Schwarzer Bildschirm beim Aufwecken des Bildschirms behoben
*Lange Verzögerung beim Bildschirm einschalten behoben
*Sehr kleine Aktualisierungen für die GPU Treiber von CAF hinzugefügt
*177MHz GPU Frequenz wieder hinzugefügt
*2D GPU Kerne deaktiviert
Mar 10, 2014:
Nur Kernel:
Sultan Kernel Pure v1.0.5:
*Behebt Bootprobleme in v1.0.4 (hängenbleiben beim HTC splash) bei einigen Geräten
*Zurückgewechselt zu Linux 3.0.16 (für bessere Stabilität, siehe xda-developers - View Single Post - [ROM][Android 4.4.2][HW VSYNC] CM11 with ION and 3.0 kernel [Mar 10, 2014])
Mar 9, 2014:
ROM:
*Qualcomm BSP aktiviert (bessere Grafik)
Kernel:
Sultan Kernel Pure v1.0.4:
*Neueren Framebuffer Treiber von CAF msm-kk_2.7_rb1.27 geportet (dieses sind genau die gleichen Framebuffer Treiber, wie im Team-Senny 3.4er Kernel)
*Alle Displayprobleme sollten jetzt behoben sein (z.B. die große Verzögerung beim Aufwecken des Handys)
*Fastcharge von Yank555 hinzugefügt
*qdsp6v3 Audio hinzugefügt
Mar 7, 2014:
ROM:
*Standard Bluetoothnamen von HTC MSM8660 zu HTC Sensation geändert
*Trebuchet entfernt und Launcher3 hinzugefügt
*Vibrationsstärke von 100% auf 80% verringert
*Gewechselt zu Dalvik-Cache Einstellungen für 512MB RAM Geräte (statt die Einstellungen für 1024MB RAM Geräte)
*Init.d Skript aufgeräumt
*Unnützen Müll an vielen Stellen aufgeräumt
*Qcoms Audio-Visuelle Verbesserungen aktiviert
Kernel:
Sultan Kernel Pure v1.0.3:
*WiFi Probleme sollten jetzt vorbei sein (Ich habe 10-20 mal neugestartet und WiFi funktionierte immer noch)
Mar 5, 2014:
Nur Kernel:
Sultan Kernel Pure v1.0.2:
*Fehler in v1.0.1, welcher das Handy einfrieren lies, beim Video schauen behoben (danke an Johnnyslt meinen Fehler zu finden)
*WiFi Signal Hack entfernt
*GPU Frequenzen aufgeräumt (177 MHz 3D GPU Frequenz entfernt)
*Versucht das Problem zu beheben, dass Wlan manchmal nicht startet nach dem Boot (Schalter bleibt auf der "Aus" Position)
Mar 2, 2014:
Nur Kernel:
Sultan Kernel Pure v1.0.1:
*Boot Probleme (stecken bleiben beim HTC Splash) auf einige Geräten behoben (danke an Ivanich)
*Touchscreen Probleme behoben (danke an bradsh1/SebastianFM)
*S2W standardgemäß deaktiviert
*Ondemand 2. Phase Frequenz verringert von 1134 MHz auf 1080 MHz
*Akkuverbrauch reduziert, welcher durch häufige Frequenzwechsel durch die MPdecision verursacht wurde
Mar 1, 2014:
ROM:
*Stummschlaten beim Telefonieren behoben (danke an Johnnyslt)
*Zurückgewechselt zum legacy Media HAL (da der besser angepasst ist für unsere vidc Treiber)
*Support für MTP hinzugefügt
*MTP standardgemäß aktiviert
Kernel:
Brand neuer Kernel: Sultan Kernel Pure v1.0.0:
*Basiert auf SebastianFMs 3.0.16 Sense Overclocked Kernel v1.5.2 ([KERNEL] Overclocked kernel v1.5.2 - xda-developers)
*Von Grund auf von mir gepatched, damit es mit AOSP funktioniert
*Enthält keine "Placebo Patches" oder dreckige "cherry-picks" (sehr minimalistischer Kernel)
*Aktualisiert zu Linux 3.0.101 mit allen Problemen per Hand gelöst für bessere Stabilität
*Bessere Performance als mein alter (r57) Kernel
*CAF msm-jb_chocolate Power-Management Architektur geportet
*CAF msm-jb_chocolate USB Gadget Treiber geportet
*Enthält mein KitKat Framebuffer Treiber Port, vidc Patches, etc.
*Sehr solide (sehr viel stabiler, als mein alter r57 Kernel)
*Auswerfen und erneut Einhängen der SD Karte benötigt keinen Neustart mehr
Feb 17, 2014:
ROM:
*Neuste CanogenMod Änderungen
*Frontkamera Auflösungen aufgeräumt
*Bildschirm HAL zu CAF KitKat display-caf aktualisiert (danke an CM, Blefish, paulb-nl, ivanich und an mich)
*Media HAL zu CAF KitKat media-caf aktualisiert
*Hardware VSync aktiviert
*Sync Framework aktiviert
*MDP retiere fence aktiviert
*Grafikperformance STARK verbessert
Kernel:
Kernel Version r57:
*CPU Tabelle von SebastianFMs 3.4 Kernel hinzuegfügt (geringere L2-Cache Frequenzen)
*Geportete CAF KitKat Framebuffer & MDP Treiber (Danke an CM, bilal_liberty, SebastianFM, ivanich und an mich)
*Sync Treiber aktualisiert zu CAF KitKat
*msm_rotator aktualisiert zu CAF KitKat
Feb 15, 2014:
ROM:
*Fehlende SD 480P (VGA) Auflösung bei der Frontkamera hinzugefügt
*Fehlende QCIF Auflösung bei der Frontkamera hinzugefügt
*QVGA Auflösung der Frontkamera behoben
*Option aktiviert in Einstellungen > Display zum Ändern der Screen-Off Animation
Kernel:
Kernel Version r56:
*Kryptografie Treiber vom Standard 3.0.16 Pyramid Kernel hinzugefügt
*Kernel wird nicht mehr mit Linaro kompiliert
*Kernel wird jetzt mit Googles AOSP GCC 4.7 Toolchain kompiliert
*Alle Custom Optimierungsflags entfernt
*2-Phasen Feature für Ondemand aktiviert
*Standard maximale CPU Frequenz auf 1512 MHz erhöht
*ION Writeback Heap Größere vergrößert
*ION Mfc Heap Größere vergrößert
Feb 8, 2014:
ROM:
*Kamera: Force Close behoben beim Wechsel zur Frontkamera im Camcorder Modus (danke an CM)
*Kamera: Touch-to-Focus im Camcorder Modus hinzugefügt (danke an CAF und CM)
*Weniger strikte minfree Werte (die Werte entsprechen jetzt den standard Werten im Kernel)
*Verschlüsselung behoben (danke an bastei)
*Verzerrter Ton bei hoher Lautstärke reduziert
*Aufgeräumt und Display Undervolt zu dem 89z_ Kernel init.d Script hinzugefügt
Kernel:
Kernel Version r55:
*Aroma Installer aufgeräumt
*Kryptographie Treiber von CAD jb_chocolate hinzugefügt
*UKSM: CPU Nutzung auf 25% begrenzt (statt 95%)
*ION Treiber mit dem CM Samsung MSM8660 Kernel abgeglichen
*Android Treiber (LML, binder, etc.) aktualisiert vom Google KitKat Grouper Kernel
*Standard Touchscreen Buffergröße vergrößert (mal sehen, ob das die Touchscreen Probleme behebt)
*Simple GPU Governor entfernt
*Gewechselt von JRCU zu dem Preemptible Tree RCU
Jan 29, 2014:
ROM:
*Schwarzer Bildschirm bei Subway Surfers und anderen Apps behoben in Kombination mit den neuen MR1 Adreno Libs (vielen Danke an Google und Johnnyslt dieses Problem zu finden)
*Cache Partition Verbesserungen entfernt (diese könnte die Ursache für den hohen Akkuverbrauch in der letzten Version sein)
Kernel:
*MEMTYPE_SMI_ION range behoben
Jan 27, 2014:
ROM:
*Gewechselt zu den Scorpion CPU Optimierungen + Bionic Optimierungen
*Cache Partition Verbesserungen vom CM d2-commen fstab hinzugefügt
*CRT Animation ist zurück (es aktiviert sich selber)
Kernel:
Kernel Version r54:
*Komplett neu eingeteilter RAM, um viele Stabilitätsprobleme zu behoben
*Alle Kamerastbilitätsprobleme behoben, wegen der Neueinteilung
*Alle Videowiedergabe Probleme behoben durch die Neueinteilung
*Stabilitätsprobleme im Videocontroller behoben
*UKSM standardgemäß deaktiviert (wegen den hohen Akkuverbrauch)
*mpdecision Aktualisierungen von mrg666 hinzugefügt
*CPU Spannungen erhöht
*Kompiliert mit dem Januar 2014 Linaro GCC 4.7.4 Toolchain von Christopher83, optimiert für Cortex-A8 CPUs
*Userspace hat jetzt 530MB RAM
Jan 16, 2014:
ROM:
*Neuste CynogenMod Änderungen
*Krait CPU und Bionoc Optimierungen aktiviert
Kernel:
Kernel Version r53:
*545MB RAM (um 17MB vergrößert)
*Audio Heap Größe vergrößert
Jan 9, 2014:
ROM:
*Fehlende Bluetooth Erlaubnis hinzugefügt
Kernel:
Kernel Version r52.5:
*Kernel ist jetzt mit GCC 4.7, statt GCC 4.8 kompiliert
*Kernel ist jetzt sehr, sehr viel stabiler wegen GCC 4.7
*Kernel ist jetzt mit der Dezember 2013 Version von Christopher83's Cortex-A8 optimierten Linaro GCC 4.7 Toolchain kompiliert worden
*Standard Displayspannung von 2,7V auf 2,85V erhöht (nur noch 250mV Undervolt, statt 400mV)
*CRT Hack entfernt, welcher für Android 4.1 gebraucht wurde
Jan 6, 2014:
Kernel:
Kernel Version r52:
*Bildschirmspannunganpassungs Interface hinzugefügt
*Display bis zu 700mV Undervolt möglich
*Display Undervolt Option in Aroma hinzugefügt (nur im Erweiterten Konfigurationsmodus)
*Zurückgewechselt auf die alten Pyramid Framebuffer Treiber (Ich bin kein magisches Einhorn; Ich habe kein AUO Panel und so kann ich auch nicht die neuen Framebuffer Treiber für AUO Panels fixen)
*ION Writeback Heap Größe um 5MB erhöht
*ION Multimedia Heap um 5MB erhöht (das sollte alle Videowiedergabe Probleme beheben)
*Userspace hat jetzt 528MB RAM zur Verfügung
Jan 4, 2014:
Kernel:
Kernel Version r51.5:
*mipi Überprüfung sollte funktionieren bei AUO Geräten
Jan 4, 2014:
Kernel:
Kernel Version r51:
*SmartassV2 Governor entfernt
*CFQ und V(R) I/O Schedulers entfernt
*Neuere Framebuffer Treiber vom CAF msm-ics_chocolate Zweig geportet
Jan 4, 2014:
Kernel:
Kernel Version r50.5:
*Kleine Ruckler in Camcorder und Videowiedergabe behoben
*Fehler beim aufwecken des Geräts behoben
*Framebuffer Treiber mit den Standard HTC VilleC2 Kernel synchronisiert
*Rotator Treiber aktualisiert zu CAF msm-jb_chocolate
*Kernel sollte jetzt auf Geräten mit AUO Display starten
Jan 4, 2014:
ROM:
*Zurückgewechselt zu den neuere MR1 Adreno Libs (erforderlich um die Browserfehler zu beheben)
*Hacks für MR0 Adreno Libs entfernt
*Gremlin im Display HAL behoben (jemand hat sich entschieden eine Kopie von ion.h dort hineinzupacken und sie ion_msm.h zu nennen, statt ion.h vom Kernel zu vererben :mad:)
*gralloc: Benutzt 3 Framebuffers
*Scorpion Bionic Optimierungen aktiviert
Kernel:
Kernel Version r50:
*Framebuffer Treiber vom VilleC2 hinzugefügt
*Grafikfehler vom VilleC2 Framebuffer Treiber behoben (die Fehler in der Version vom 25.12)
*HTCs MDP Gamma-Farbverbesserung mit den neuen Framebuffer Treibern beibehalten
*Verbesserter Bluetooth Stack vom Nexus 7 2012 KitKat Kernel (tegra-android-tegra3-grouper-3.1-kitkat-mr1)
*ION Surfaceflinger Heap Größe um 5/8MB vergrößert
*WiFi Spannung wieder auf die Standard 2,9V erhöht (vorher waren es 2,6V)
12/30/2013:
ROM:
*Wieder alte MR0 Adreno Bibliotheken verwendet (das behebt Blackscreens in Spielen wie Subway Surfers)
*Alte Hacks für MR0 Adreno Bibliotheken wieder hinzugefügt
*(Gapps Link oben aktualisiert zu den PA mini-modular)
Kernel:
Kernel Version r49:
*Memory-Map Neustarts behoben
*Userspace hat jetzt 540MB RAM (die 10 zusätzlichen MB sollten wir nie haben)
*Bildschirm um 400mV undervoltet (mein Handybildschirm kommt mit bis zu 700mV UV zurecht, also sollten 400mV für jeden funktionieren. Danke an scverhagen für diese Idee)
*VPN repariert
12/29/2013:
ROM:
VilleC2 Audio Bibliotheken entfernt (dies behebt den verzerrten Ton)
Immer 3 Frame Buffers bereit halten (macht die Grafiken weicher, Credit: cyanogen)
VOIP funktioniert (danke an ivanich)
Beinhaltene Kamera App funktioniert jetzt (dafür habe ich den alten Kamera Code verwendet, als es das letzte Mal funktioniert hat)
Kernel:
Kernel Version r48.5:
Zurückgewechselt zu den alten Framebuffer und Panel Treiben (dies behebt die Display Fehler)
HTCs MDP Gamma-Farbverbesserung wurde wiederhergestellt
ION Multimedia Heap Größe wurde um 1MB vergrößert
MDP Kern Taktrate auf 267MHz festgelegt
WiFi Spannung erhöht von 2,4V zurück auf 2,6V (jemand hatte berichtet, dass sein WiFi nicht mehr funktioniert hat nach Version 12/10)
12/25/2013:
ROM:
Proprietäre Audio Bibliotheken vom VilleC2 hinzugefügt
Lautsprecher ist daher viel lauter und die Tonqualität ist besser
Kernel:
Kernel Version r48:
Neue Framebuffer Treiber vom VilleC2 hinzugefügt (x999 danke an dominos_liberty und SebastianFM dafür)
Viel weichere Grafiken wegen den neuen Framebuffer Treiber
Einige Fehler in der Speicher Map behoben
Niedriger RAM Fehler behoben; Userspace hat nun 550MB RAM, statt 515MB
12/24/2013:
ROM:
Latest upstream CyanogenMod changes
Android 4.4.2
Media HAL: Use ION for video decoder
Don't use modular bcmdhd (bcmdhd is built into the kernel image now, like it is on Nexus devices)
Kernel:
Fixed video playback without breaking camcorder (thanks to help from johnnyslt and paulb-nl :) )
Implemented ION multimedia heap
Implemented separate ION SMI region for video playback
Video playback uses ION SMI memory and camcorder uses PMEM SMI memory (memory type is switched on-the-go depending on what is requested)
Allocated ION heaps with static base addresses for greater stability
Amount of RAM for userspace has gone down from 575MB to 515MB due to implementation of ION SMI
Ported newer video controller from upstream CAF msm-jb_chocolate
Removed all modules (WiFi and CIFS are now built into the kernel image)
Removed module-loading support (greater security, Google does this, and no need for modules anymore)
Added back 192MHz frequency step
Decreased default max CPU frequency from 1566MHz to 1404MHz
Decreased default min CPU frequency from 384MHz to 192MHz
Decreased WiFi voltage from 2.6v to 2.4v
Increased MDP core clock rate from 200MHz to 267MHz
Increased MSM rotator clock rate from 160MHz to 200MHz
12/10/2013:
ROM:
Android 4.4.1
Proximity sensor working again
Notable upstream change: screenshot preview fixed
12/04/2013:
ROM:
Implemented PMEM SMI into gralloc
Fixed camcorder (NOTE: playing back a video still causes a soft reboot)
Added a proper fix for the media provider force closes (credit: drewis from Evervolv)
Fixed Google Now voice commands
Kernel:
Kernel version r46:
Cleaned up memory mapping
Userspace now has 575MB of RAM (roughly a 30MB increase from the previous build)
Switched vidc to PMEM
12/03/2013:
ROM:
Fixed camera (9999x thanks to Blefish for the gralloc fix, and to professorpasta for the help on getting the gralloc fix to compile)
(Camcorder is still broken)
11/24/2013:
ROM:
Fixed accelerometer
Fixed proximity sensor (credit: kejar31)
Fixed all other sensors (except for camera of course)
Kernel:
Built with the November release of Christopher83's Cortex-A8 optimized Linaro GCC 4.8.3 toolchain
11/17/2013:
ROM:
Fixed audio bugs (credit: johnnyslt)
Implemented HTCZ715E's WiFi region code fix (region code will no longer reset to USA after a reboot)
Fixed USB mass storage mode
Removed many hacks for old graphics (we are using newer graphics libraries ;))
Graphics are significantly smoother as a result of the above change
11/16/2013:
ROM:
Initial build
Kernel:
Kernel version r45:
Enabled SELinux
Enabled ION
Reverted some input driver imports from CAF (to hopefully fix the freezes)
FAQ (Frequently Asked Questions = Häufig gestellte Fragen):
Was ist das CPU-boost Framework?
Antwort: Ich habe einen neuen Treiber erstellt, der die CPU Geschwindigkeit automatisch erhöht, kurz bevor CPU intensive Aktionen starten. Der CPU-boost Treiber erhöht dabei vorrübergehend die minimale CPU Geschwindigkeit und stellt diese wieder zurück, wenn die Arbeit abgeschlossen ist. Nutzer können dieses Feature nicht configurieren. Das CPU-boost Framework ist zur Zeit wie folgt konfiguriert:
  • CPU minfreq wird auf 1296 MHz für 2,5 Sekunden gesetzt, wenn der Bildschirm berührt wird
  • CPU minfreq wird auf 1512 MHz für 5 Sekunden gesetzt, wenn der Bildschirm eingeschaltet wird
  • CPU minfreq wird auf 594 MHz gesetzt, wenn man ein Video aufnimmt (das bleibt so bis zum Ende der Aufnahme)
Reaktionen: escud80, Piveer, DevilD51 und 5 andere
Hi, habe die Version vom 29. Dez grade angetestet... Folgende Bugs hab ich entdecken können...
- Kalender App lies sich nicht mit Google verknüpfen
- Kamera stürtzte ab, nachdem ich mit der Frontkamera ein Video aufnehmen wollte
- Lesezeichen im Broser werden nicht vom Google Account importiert
Gehe wieder zürück zu Albinoman's 10.2
Greetz Stinger
Das mit dem Kalender war vorher schon. Einfach nochmal den Kalender aus dem Playstore laden. Dann klappts wieder!
Reaktionen: Androidsuchti
Ich find die Version. richtig geil und stabiler als von Albinoman
HTC Sensation XE with CM11 [4.4.2]
4 EXT Recovery
Ist die Version schon Altagstauglich? Oder sollte man noch lieber warten und auf 4.3 bleiben?
Also ich benutze die Version jetzt seit einigen Tagen im Alltag und ich kann mich wirklich nicht beschweren. Es läuft eigentlich alles ziemlich smooth.
Kamera funktioniert. Wobei ich da auch nur Schnappschüsse probiert habe. Ansonsten hatte ich zwar schon ein/zwei Freezes, aber die hatte ich mit nahezu jeder Custom Rom immer mal wieder.
Ich finde sie Alltagstauglich ja.
HTC Sensation XE with CM 11 [4.4.2] Kit Kat
4 EXT Recovery Touch
Der ursprüngliche Beitrag von 14:22 Uhr wurde um 14:54 Uhr ergänzt:
Hab grad bemerkt das diese Version mein WLAN gar nicht findet.... is doch blöd!Noch jemand?
Der ursprüngliche Beitrag von 14:54 Uhr wurde um 15:00 Uhr ergänzt:
Nehme alles zurück!Wer auch nicht WLAN nutzen kann muss bei WLAN im Handy auf Erweitert gehen und dann auf Ländercode und Deutschland anklicken dann wird dein WLAN angezeigt ;)
So gibt schon wieder neue Version. Damit sollten noch mehr Reboots/Frezzes behoben worden sein und alle Spiele sollten wieder problemlos funktionieren. Leider allerdings auf Kosten der Performance :/
Wünsche euch allen übrigens einen guten Rutsch :D
Kann schon jemand was zur Laufzeit sagen. Würde mich sehr interessieren da ich meist so über den Tag komme mit Albinos CM10.2
@HTC_Freak: Was heißt denn "auf Kosten der Performance genau"? Ich fand cm11 nen Tick flüssiger als 10.2. Is das jetzt Geschichte?
Naja, wegen den Problemen mit den neueren Adreno libs, musste er wieder auf die alten wechseln. Also die selben wie bei CM10.2
Somit ist der Performance im worst case gleich wie bei CM10.2 bzw durch Optimierungen etc immer noch größer. Muss man halt selber mal ausprobieren.
Hat noch jemand Probleme mit der Uhr? Immer wenn ich nen Wecker umstellen will, dann beendet sich die Uhr. Lässt sich aber gut über Appstore kompensieren.
Muss ja sagen, ich war nicht sonderlich angetan, obwohl ich ein großer Freund des Sultan Kernels bin. Aber bei mir gings es während des Einrichtungsassistenten schon los mit der Fehlermeldung "android.process.media wurde beendet". Kam teilweise gleich etliche Male hintereinander. Keine Ahnung was da los war.
Zudem wurde das Gerät beim Einrichten der ROM verdammt warm und es wurde massiv am Akku gezogen. Konnte zuschauen, wie die Prozente gepurzelt sind. Ich weiß, ich weiß, man soll einer neuen ROM immer erst ein paar Ladezyklen geben, bevor sich das einpendelt, aber in dieser Massivität habe ich das bisher noch bei keiner einzigen ROM beobachten können, und ich flashe grundsätzlich IMMER mit full wipe (auch bei Versions-Updates!). Das spricht also schon irgendwie für sich.
Zudem war die ROM spürbar weniger performant als die aktuellste CM10.2 mit dem aktuellsten Nicht-ION-Sultan. Letztere Kombi rennt bei mir einfach wie die Sau.
Beide Erscheinungen sind jedoch eigentlich unverständlich, da ich beim Einrichten des Kernels im Aroma genau die gleichen Settings wie sonst auch beim Sultan im Zusammenspiel mit CM10.2 von Albino verwendet habe.
@DroydFreak
Also ich muss sagen, dass ich CM11 wesentlich smoother finde als CM 10.2.
Nach dem letzten Update hat es etwas nachgelassen, aber dennoch bin ich super zufrieden. Das mit dem Akku kann ich bestätigen. Am Anfang hat die Rom echt den Akku leergesaugt wie nichts Gutes. Aber mittlerweile ist es echt super geworden. Ne ganze Menge hilft es auch wenn man den WLan Ländercode auf Deutschland einstellt.
Ach ja: Also bei mir werden bei Goo keine Updates mehr angezeigt, auch wenn ich nicht die aktuellste Verion installiert habe. Kann das noch jemand bestätigen?
@Mad_King
habe auch die Version vom 29.12 und im Goo zeigt er mir kein Update an.
@DroydFreak
Hast du die Version vom 30.12? Ich würde die vom 29 nehmen, läuft seid 2 Tagen ohne große Probleme. Soweit hatte ich noch keinen Absturz o.ä.
Akku kann ich auch nicht genau sagen, dazu benutzte ich die Version noch nicht lange genug.
Ich hab gar nichts mehr von beiden, ich bin jetzt wieder auf CM10.2 weil es wie gesagt läuft wie geschmiert. Da wüsste ich nicht, warum ich auf Teufel komm raus CM11 haben muss... Werde es sicher irgendwann nochmal testen aber ich glaube ich warte da erstmal bis was neues von Albinoman kommt.
^ Laut einigen XDA Usern gibts da wohl teilweise Probleme mit der neuen Version. Bootet teilweise gar nicht oder wenn doch dann muss man SEHR lange warten, bis es hochgefahren ist... also mit Vorsicht zu genießen.
Kann ich bestätigen.. Auch bei mir rebootschleife.
Bin wieder zur vorletzten Version zurück.
Mal ne Frage..welche kernelversion nutzt ihr mit Sultan seiner Rom?
Also wo ichs das erste und einzige mal drauf hatte (mit der Version vom 30.12.) hatte ich halt den r49 Kernel.
Ich mach es aber so: ich flashe erst ganz normal ROM und Gapps und dann nochmal den Kernel für sich, damit ich zum Aroma Installer komme. Da kann man dann ganz bequem alle Settings vornehmen, die man sich so einbildet. Das Geile am Sultan Kernel sind ja m. M. n. die vielen Einstellungsmöglichkeiten im Vergleich zum Kernel in der Albino-ROM, wo man finde ich zu wenige Möglichkeiten hat.
HTC_Freak
GokuSS4
GokuSS4
O
OneGamer
O
TomTim
TomTim
TomTim
