Zekene
Enthusiast
- 2.239
- Features:
- Based on HTC Ville C2 latest RUU (1.11.401.109).
- Multi-language.
- Deodexed.
- Zipaligned.
- SuperSU, Busybox.
- Bricked Kernel.
- Option to remove HTC apps (AROMA installer).
- Option to install additional mods (AROMA installer).
- Fast, clean and stable.
- Bugs and Errors:
- WiFi Tether.
- HDMI out.
- Credits and Thanks goes to:
- baadnewz
- mdeejay
- TripNRaVeR
- sebastiaan15
- show-p1984
- nono2lozere
- j4n87
- amarullz
- idanfima
- ivicask
- m0narx
Changelog:
9.0.0:
- Rebased to 1.11.401.110.
- Fixed some icons in statusbar.
- Removed SGSIII Dropbox.
- Updated Facebook.
- Improved performance.
8.7.0:
- Fixed Google Talk video - Thx ivicask.
- Fixed device model script.
- Updated Google Maps.
- Updated Dropbox.
8.6.5:
- Fixed T-Mobile script.
- Fixed SystemUI layout - Thx m0narx.
- Fixed wireless adb quick setting - Thx m0narx.
- Increased WiFi re-scan timeout to 120 sec.
- Updated some libs - Thx ivicask.
- Added SGSIII Dropbox - You'll get 48Gb bonus for 2 years - Thx baadnewz.
8.6.0:
- Updated and replaced some libs.
- Updated and replaced some bins.
- Updated Sony Bravia.
- Updated Facebook.
- Changed OOM groupings.
- Fully rewrited autobrigtness and buttons backlight tweak - Thx m0narx.
8.5.2:
- Fixed WiFi for T-Mobile users.
8.5.1:
- Fixed brightness.
- Removed the option to install xLoud.
- Cleaned build.prop.
8.5.1:
- Fixed brightness.
8.5.0:
- Fixed auto brightness.
- Enabled up to 254 tabs in browser - Thx m0narx.
- Optimized sqlite3 database - Thx LeeDroid.
- Added option to choose device model in aroma installer - Thx m0narx.
- Added auto reboot option in aroma installer.
- Added tabbed EQS - Huge thx to m0narx and j4n87!
- Updated Tweaks app - Huge thx to m0narx and j4n87!
8.2.0:
- Fixed camera effects.
- Increased touch responsiveness- Thx XxXPachaXxX.
- Removed more unnecessary files.
8.1.1:
- Fixed HTC locations FC.
8.1.0:
- Fixed cut off statusbar icons.
- Removed software (CPU) rendering.
- Added option to remove TalkBack.
- Updated and cleaned libs - Thx ivicask.
- Updated Gapps.
- Updated ES File Explorer
8.0.0:
- Fixed video acceleration - Huge thx to mdeejay!
- Rebased to 1.11.401.109.
- Fixed battery capacity value - Thx m0narx.
- Added App Installer - Huge thx to m0narx.
- Re-added Youtube HD.
- Added options to remove more apps.
- Updated Google Plus.
- Updated AdAway.
- Cleaned some libs - Thx ivicask.
- Improved performance and battery life.
7.1.3:
- Disabled 3-dot Menu (For T-mobile users only).
7.1.2:
- Improved Beats audio sound.
- Fixed incall loudspeaker.
- Enabled 15 tabs in browser.
7.1.1:
- Fixed laggines.
- Fixed upside-down camera
- Thanks baadnewz.
- Fixed volume steps options in tweaks - Thanks nono2lozere.
- Fixed wakeup by volume key option in tweaks.
- Fixed MMS - Thanks Capychimp.
- Fixed build.prop.
7.1.0:
- Fixed unresponsive lockscreen - Thx baadnewz.
- Fixes gallery FC when trying to view Dropbox gallery - Thx baadnewz.
- Fixed FM radio.
- Fixed framework - Thanks mdeejay and baadnewz.
- Fixed updater script.
- Fixed, cleaned and tweaked build.prop.
- Enabled cubic transitions effect - Thx mdeejay.
7.0.1:
7.0.0:
- Rebased to latest Ville C2 RUU (designed for MSM8660) - Huge thanks to mdeejay, baadnewz, idanfima, ivicask, nono2lozere and pavelol.
- Fixed Bluetooth.
- Fixed FM radio.
- Fixed animations.
- Fixed updater script for OpenVPN support.
- Readded the option to install xLoud.
- Updated Facebook.
6.1.0:
- Fixed cut off status bar.
- Fixed friendstream.
- Fixed transition animations.
- Fixed camera.
- Fixed tweaks - Thx nono2lozere.
- Fixed es file explorer.
- Optimized all apps and framework files - Thx ivicask.
- Updated Gapps.
- Added ultra smooth rosie - Thx hamdir.
- Added option to install semi transparent statusbar.
- Added option to install rosie with 6X5&7X3 app drawer.
- Added option to install disable exchange security.
- Added options to remove HTC Car, Movie Editor and Dropbox.
6.0.0:
- Rebuild from scratch.
- Rebased to 1.78.401.2 release-keys.
- Added tweaks - Thx j4n87.
- Added CM brightness mod - Thx j4n87.
- Added Extended Quick Settings - Thx j4n87.
- Added QuickLaunch widget- Thx mdeejay.
- Enabled chinese IME & handwriting.
- Updated T-Mobile WiFi calling - Thx bigmoew.
- Updated Twitter.
- Updated ES File Explorer.
5.0.2:
- Disabled 3 dot menu bar.
5.0.1:
- Fixed cut off status bar icons.
- Fixed some libraries - Huge thx to ivicask.
- Disabled exchange security.
- Updated Gapps.
- Updated Google Play Store.
- Readded YouTube HD.
- Improved battery life.
- Completely removed tweaks.
5.0.0:
- Rebased to 1.78.401.2.
- Partially fixed bt (still WIP).
- Fixed lag after video - Huge thx to ivicask.
- Fixed build.prop.
- Updated Adreno GPU binaries.
- Updated SuperSu.
- Updated Facebook.
- Updated Google Maps and Street View.
- Removed tweaks.
- All changes from previous CoinDroid versions.
4.0.0:
- Added Google Drive.
- Added Facebook and Twitter.
- Added another OrDroid wallpaper.
- Added system wide volume booster.
- Added option to install sony xLoud system.
- Updated Bricked kernel to V1.05.
- Updated SuperSU binary.
- Updated Adaway.
- Fixed MMS app.
3.0.2:
- Zipaligned using newest SDK.
- Completely fixed Beats audio.
- Fixed MMS screen on.
- Fixed HQ camera mod.
- Added option to remove talkback.
- Added blue OrDroid wallpaper.
- Updated Dropbox.
- Updated SuperSu.
3.0.1:
- Added option to install Genie widget.
- Fixed sound volume.
- Fixed HTC keyboard and dialer haptic feedback.
- Fixed faceunlock.
- Improved Beats audio.
3.0.0:
- Rebased to 1.70.666.1.
- Updated Bricked kernel to V1.0.
- Fixed MMS signal drops.
- Fixed Beats audio and eq.
- Fixed gallery FC when view dropbox albums.
- Improved partition mounting via init.d script.
- Improved launcher render speed.
- Updated YouTube app to HD version.
- Removed more unnecessary apps.
2.2.0:
- Updated AROMA installer to V2.0.
- Updated Bricked kernel to V0.955.
- Fixed SD card issues.
- Fixed camcorder.
- Fixed social apps.
- Enabled 180 degrees rotation.
- Hacked voice search to allow direct access.
2.1.5:
- Zipaligned using newest SDK r20.
- Fixed Rosie lag. - Fixed T-Mobile small MMS issue.
- Lowered auto-brightness values.
- Added CM statusbar brighntess mod.
2.1.3:
- Added 4G icon for T-Mobile users.
- Fixed Beats audio.
2.1.2:
- Added sqlite3 support.
- Fixed build.prop.
2.1.1:
- Added option to install SIM tool kit.
- Fixed HTC Camera.
- Fixed HTC keyboard haptic feedback.
- Fixed HTC dialer haptic feedback.
- Fixed statusbar.
2.1.0:
- Updated Bricked kernel to V0.9.
- Updated tweaks app.
- Improved launcher speed.
2.0.8:
- Added fully working WiFi theater app.
- Updated Bricked kernel to V0.858.
- Updated build fingerprint to 4.0.4.
- Fixed usb transfer speed.
2.0.7:
- Zipaligned using newest SDK r19.
- Updated Bricked kernel to V0.856.
- Allowed all rotations.
- Disabled signatures checking.
- Fixed all /data apps.
2.0.6:
- Zipaligned using newest SDK r18.
- Updated Bricked kernel to V0.851.
- Added option to disable Sweep2Unlock.
- Added sysrw and sysro binaries.
- Fixed small MMS issue.
- Enabled up to 15 tabs in the browser.
- Enabled bass boost in framework.
- Added new APM icons.
2.0.5:
- Fixed lags.
- Fixed Instagram support.
2.0.4:
- Fixed tweaks app.
2.0.3:
- Updated Bricked kernel to V0.8.
- Fixed haptic feedback!
- Added OrDroid tweaks app.
- Fixed battery drain issue.
- Added optional stock battery precentage mod.
- Fixed T-Mobile build.prop.
- Fixed ZRAM.
2.0.2:
- Updated Bricked kernel to V0.7.
- Fixed random vibrations.
- Fixed bootanimation.
- Fixed framework icons.
- Fixed build.prop.
- Added Market Access.
- Updated Street View.
- Added optional auto rotate rosie.
2.0.0:
- Fixed Bluetooth!
- Added advanced power menu .
- Fixed mobile network icon.
- Updated Bricked kernel to v0.65.
- Added init.d script for automatic module insertion.
- Changed cmdline params to AROMA options.
- Added black boot and down animations.
- Added new OrDroid wallpaper.
- Updated HQ Camera mod to version 1.5.
1.9.1:
- Fixed cmdline_khz script.
1.9.0:
- Interactive Bricked v0.61 install.
- Fixed brightness values.
1.8.7:
- Fixed build.prop.
- Updated Gmail app.
1.8.6:
- Added multi-language support.
- Added amazing HTC Sensation bootanimation.
- Added improved HTC camera.
- Added OpenVPN support.
1.8.5:
- Added ultra smooth Rosie.
- Added option to remove Google Books and Movies.
- Fixed wakeup by volume keys mod.
- Updated Bricked kernel to V0.55-b7.
- Updated twitter app.
1.8.4:
- Long press home button for recent apps!
- Fixed T-Mobile addons.
- Added English dictionary to HTC keyboard.
- Updated Bricked kernel to V0.55-b6.
- Removed optional AOSP apps.
1.8.3:
- Removed debug info from apks and framework files.
- Added OrDroid wallpaper.
- Added optional Wakeup by Volume Keys.
- Added optional Sony Bravia Engine.
- Fixed build.prop.
1.8.2:
- Updated Bricked kernel to V0.55-b5.
- Added zram auto-enable script.
- Added option to install T-Mobile WiFi calling app.
- Added option to install ES File Explorer.
- Build.prop cleanups.
1.8.1:
- Fixed ZRAM.
- Updated Bricked kernel to V0.55-b3.
1.8.0:
- Fully fixed camera touch to focus.
- Enabled carousel after unlock.
- Other minor changes and fixes.
1.7.5:
- Added an option to install HTC keyboard without arrows.
- Added an option to install auto rotate Rosie.
- Added the latest Google Books and Movies.
- Fixed AOSP dialer.
- Updated Bricked kernel to V0.55-b2.
- Changed HTC One bootanimation to HTC Sensation bootanimation.
1.7.4:
- Fixed touch to focus.
1.7.3:
- Disabled scrolling cache
- Updated Bricked kernel to version 0.55.
- Updated SuperSU.
- Updated AOSP dialer.
1.7.2:
- Fixed homescreen lag.
- Fixed framework-res.
- Fixed brightness.
- Updated SuperSU.
1.7.1:
- Zipaligned using newest SDK r17.
- Updated Bricked kernel to version 0.5.
- Added ZRAM auto-enable script.
1.7.0:
- Rebased to 1.53.401.2.
- Changed kernel to Bricked v0.4.
- Updated Adaway.
- Updated Dropbox.
1.6.2:
- Fixed GPS.
- Fixed Browser.
1.6.1:
- Fixed USB connection dialog.
- Fixed WiFi-hotspot.
1.6.0:
- Fully fixed graphics glitches!
- Fixed GPS, Facebook, Rosie and more...
1.5.0:
- Added option to install AOSP apps.
- Added option to remove HTC apps.
- Rebased to 1.47.401.1.
- updated GPU drivers.
1.0.1:
- Fixed HTC Calendar.
- Added Adaway.
- Updated Facebook.
- Updated Twitter.
1.0.0:
- Initial Release.
Donations list:
- albatnawy91, suuugen, sirbilbo, MOVZX, v.kirilin, AddisG, Jaglicic, bippolinno X3, naailalzuhir, mazen34, jmcdonald58, Gaudi73, banderz777, rpmfc36, judsonmaag, ycayir X2, gramateas, mschipperheyn, HaJeeEs, TurtleFlip, tinker2000, zukа, V6-Maniac, l2icky, Steve0007, paul.f X2, X-DeAD, DrDeeZee, hairplayer, senia3.
HTC One X piggy bank supporters:
- gramateas, bippolinno, banderz777, brashmadcap.
I'm grateful for every donation you make.
Thank you very much!
