[ROM] Miui Sensation US Multilanguage
  • 55 Antworten
Sylus
Sylus
Presents the Official
MIUI 1.12.23
Big Thanks Twin Dragons and pimpmaneaton !!! they made this happen!
This is a community support ROM only!
The developers do not provide much support for this ROM on these forums
Support is mostly provided on forums.MIUI.us
New release comes every Friday.
If you haven't heard about this ROM yet then check out the videos in the 2nd post to see it in action!
This is an excellent ROM if for no other reason than it introduces the first non-CyanogenMod/carrier/manufacturer framework overhaul of Android 2.3.7​
Changes from base ROM
Removed: MIUI App Sharing | MIUI.us OTA Updater | MIUI Bootscreen | SIM Toolkit
Added: Custom Bootscreen | English Translations | MIUI.us Forum app
If you want ADW.Launcher or LauncherPro install them from Market.​
Proceed To Download
Download Here
Ported by pimpmaneaton and Twin_Dragons
Please contact scott951 if you plan on using this rom as a base.
Change Log: 1.12.23
Working
  • Phone Calls
  • Audio/Sound
  • SMS/MMS Large MMS
  • Data: 3G/GSM
  • Wi-Fi
  • Bluetooth
  • GPS and AGPS
  • Touchscreen
  • Vibration
  • Charging
  • All sensors
  • Wired earphone/headphone
  • Data usage
  • Hardware Acceleration OpenGL
  • Software video codecs
  • Gallery
  • YouTube
  • MIUI Backup (don’t backup contacts)
  • Bluetooth In-Call
  • Screenshot (menu+down volume)
  • Multi-Touch
  • MIUI Themes
Not Working:
  • A2DP (Car dock, Audio Streaming)
  • Video Camera recording bad Quality
Made Possible by: Thanks so Much
  • Kmobs (persiansown)
  • CyanogenMod
  • Twin Dragons
  • XBoarder56
  • MIUI.us
  • pimpmaneaton
  • scott951
MIUI.us HTC Sensation 1.11.25 by Twin_Dragons
  • Android Version : 2.3.7
  • CPU : Dual Core 1,6 Ghz
  • Ram: 768 MB
  • Interner Speicher : 1,15 GB
  • Kernel Version : 2.6.35.14 by faux123
DOWNLOAD:
HOW TO:
  • Ladet euch den Rom,Kernel und den Multilanguage Pack
  • Alles auf eure Speicherkarte kopieren ( Am besten alles in einen Ordner)
  • Handy ins Recovery Modus einschalten
  • Wipe Data/Factory reset & Cache
  • Install zip from sdcard
  • choose zip from sdcard
  • Ordner wählen wo euer rom , kernel & sprachpacket sich befindet.
  • Miui.us.pyramid_1.11.18_Eng installieren
  • Kernel installieren
  • Mounts and Storage
  • Mount /system
  • Ordner mit der sprachdatei wählen und installieren
  • Neu booten
Reaktionen: Zekene und oma
frei...
Klasse beschreibung und eig alles easy to do, doch Deutsch ist das nicht oder?
Denn ich habe das Packet installiert wonach du meinst Multilanguage doch Chinesich und Englisch sind nicht soviele sprachen^^
Ok dann erst sprachdatei installieren dann kernel :D muss ich ändern
Ich habe erst den Kernel, dann die Update.zip geflasht und es war sofort auf deutsch.. :blink:
Ich habs anders gemacht und ist trotzdem auf deutsch. ;)
Momentan rennt mir die Battery noch ein bisschen viel und verdammt heiß ist es teilweise gewesen. Warte aber noch 2-3 Ladezyklen ab.
Bisher einen Absturz beim Auslösen der LED beim Foto schießen gehabt.
Sent from my Sensation using Tapatalk
Das heißt eigentlich das meine beschreibung so klappt wie beschrieben und auch anders rum
Hat es von euch noch jemand laufen und kann ein bisschen was berichten (FC's, Bugs, Battery)?
Also bisher hatte ich einen Komplett-Absturz, welcher sich nur rausnehmen des Akkus lösen lies,,, (Keine reaktion auf garnix... ;o) )
FC hatte ich noch keine...
Akku: Habe heute Morgen um 5.30 Uhr das Sensa vom Ldegerät genommen. Bin jetzt bei 69% --> Hintergrunddaten sind immer aktiv. Email, Wetter und Xbox-Live werden regelmäß abgerufen. Habe zwei Telefonate geführt (ca. 5-7 Min.) und ca. 10 Min. im Netzt gesurft (3g).
Bin im großen und ganzen recht zufrieden mit dem ROM.
Habs mir grad draufgezogen und bin schon mal sehr erfreut !!!!!
Läuft geschmeidig und bis jetzt sehr sauber.Mit dem Verbrauch kann ich erst nach ein paar Ladungen urteilen.Bis jetzt die beste Miui!
Danke-Anleitung funktioniert super so!
17.30h.Seid heut Morgen ab 07.00h. vom Lader genommen und nun noch 82% Batt. bei ganz normaler Nutzung.......nicht schlecht,Herr Specht,nicht schlecht.....lächelleis
ich wollte auch mal das MIUI ausprobieren. Leider verliere ich immer das Signal, sobald ich den Bildschirm ausschalte. Vorher geht eigentlich alles, Netz erkannt, eingebucht usw., aber einmal lockscreen und ich habe nur noch "no signal".
Ich habe schon den hier verlinkten faux kernel, neuestes Radio, bricked kernel, einen anderen faux kernel probiert und immer das gleiche. Weiß jemand noch einen Tipp?
Hast du den update auch installiert?
kann mir hier mal bitte einer idiotensicher erklaeren, wie ich das sprachpacket zu installieren hab ??? ich kann nur english und chinesisch einstellen ...
das rom ansich ist hammer =D schaut gut aus und hat auch nette features wie den datenzaehler etc... auch superviele moeglichkeiten zum einstellen.. =)
noch n problem hab ihc mit den themes... bei den meisten funktioniert der lockscreen dann nicht mehr.. das obwohl die ja iwie vorgeschlagen werden, was mach ich falsch ???
regrads Anit
regrads Anit
Hast du die Update datei installiert vor den Kernel? So wie ich hier gelesen habe muss man bei manche erst kernel dann update installieren
Zu den Themen bzw lockscreen manche sind verbugt, ist dann ein bug von den theme macher / hersteller
Das Problem mit dem Sprachpaket kann ich nicht nachvollziehen. Wenn man es anhand der Beschreibung im ersten Post macht, sollte das funktionieren.
Das mit den Lockscreens ist so eine Sache. Die meisten sind nicht für die doch recht hohe Auflösung des Sensation gedacht bzw. noch nicht angepasst. Da wird dir wohl nur übrig bleiben zu warten, dass die Entwickler der Themes ihr Lockscreens anpassen.
Greetz
Ja, genau nach Anleitung, war auch deutsch.
Und signal ist da?
Ja, allerdings nur bis ich den Bildschirm einmal ausschalte, danach "no signal". Hilft nurnoch ein reboot, auch Airplane-mode An/Aus hilft nicht. Wlan habe ich auch schon auf never sleep gestellt.
Welche Version hast du runtergeladen?
  • minecraft2014
Ruftac
michael861
O
OneGamer
O
