[ROM]LeeDROiD SuperSensational 6.0.0 ICS
  • 16 Antworten
Tyrion
Tyrion
Enthusiast
405
Chenge Log
Presenting LeeDrOiDs SuperSensational ICS Edition
S-Off & a Custom recovery required
Huge thanks to Alpharevx+unrevoked for acheving S-Off
Android 4.0.3 - Ice Cream Sandwich & Sense 3.6... No gimmick's, no bullshit..
Just a Sensational Android experience from a very experienced developer
Pun intended!
With thanks to: ChainsDD l snq- l Scar45 | Baadnwz | damo | Team RC | m-deejay | klquicksall | Alpharevx & Unrevoked | rmk40 | show-p1984 | hamdir
Official Support Links:
Chenge Log
LeeDrOiD SuperSensational V6.0.0 - ICS - 25th January
  • Rebased on RUU_PYRAMID_ICS_HTC_Europe_3.24.401.1 - 4.0.3 ICS
  • Sense 3.6!
  • Stock HTC ICS Kernel 3.0.16-g9788208
  • Added nls_utf8 support (New kernel module thanks to me)
  • Added CIFS Support (New kernel module thanks to me)
  • Added CIFS Manager
  • Lots of bugfixes!
  • Several script updates
  • All previous mods included
  • All preinstalled applications updated
LeeDrOiD SuperSensational V5.0.1 ICS - 31st December
  • Fixed missing fonts
  • Removed DRM_omz & Dice
  • Reworked framework-res (Cleaner build with no errors)
  • Updated AdFree hosts
  • Updated superuser binary
  • Updated - Adobe FlashPlayer Reader, ES Explorer, FaceBook & Titanium Backup
  • Added Android Market V3.4.4
  • Updated YouTube
  • Trimmed bootanimation audio
  • New High-Res LeeDrOiD Wallpaper
LeeDrOiD SuperSensational V5.0.0 ICS - 30th Dec - FULL WIPE REQUIRED
  • Based ON - RUU PYRAMID LE (XE) 3.06.401.101 (test) Thanks to RC Team!
  • Rooted with the latest Superuser & Binary
  • unsecured boot.img
  • Init.d run parts support
  • Deodexed, Recompressed & Zipaligned
  • The ususal - sysrw/sysro, bash, busybox, nano
  • All user apps zipaligned on boot
  • Permissions fixed on boot
  • SQlite3 DB Vacum on boot
  • Caches cleaned on boot
  • Fixed Market identifacation
  • Added OpenVPN
  • EXT4 Tuneups
  • Battery calibration script (seo)
  • Huge XML Cleanups
  • NEW LeeDrOiD Custom Boot Animation & Welcome
  • Lots of default configuration cleanups
  • Allow non market apps, disable "pocket mode", "flip to speaker" & "be polite"
  • Disable "fastboot" (auto hibernate on shutdown)
  • Enabled 3D Home screen support in display settings
  • Enabled "Display processor info"
  • Removed CIQ services from framework
  • Removed HTC & Google loggers
  • Added Overscroll (Green)
  • Added Stock % Battery
  • Added Fancy keyboard Enter/Exit animation
  • Added Spare parts, The lates Market, Dice, Voice Dialer & Launcher2
  • Added RomManager, Titanium Backup, ES Explorer, AdFree
  • All pre-installed apps updated
  • Removed some Bloat
INSTALLATION
1. Boot to recovery
2. Nandroid
3. Flash the below mentioned firmware package
4. Boot back to recovery
5. Wipe data/factory reset (Optional if coming from another ICS build)
6. Flash the ROM.zip
7.Reboot & enjoy your Ice Cream Sandwich
Optional FULL WIPE to EXT4 patch (FTP)
This is an optional patch that can be applied prior to flashing the ROM, please note, this zip will wipe your device and format all partitions to EXT4 (Highly recommended)
3.24.401.1 Revolutionary patched firmware package(FTP)
The above firmware package is as per THIS THREAD by Mike and patched for S-Off by the awsome ieftm
Original hier :http://forum.xda-developers.com/showthread.php?t=1419278
Ehm, basiert das noch auf der 3.06, statt auf der 3.12? :confused2:
japp, schaut so aus
Dann ist die ROM ja nur noch halb so interessant. Hoffentlich kommt bald ne 3.12, Lees ROMs sind nämlich klasse.
Juhu, es geht weiter
[ROM]LeeDROiD SuperSensational 6.0.0 ICS | 25th Jan| Sense 3.6 | FAST | STABLE | CIFS
Pun intended!
Chenge Log
  • Sense 3.6!
  • Lots of bugfixes!
  • Updated YouTube
  • Added OpenVPN
  • EXT4 Tuneups
  • Huge XML Cleanups
INSTALLATION
1. Boot to recovery
2. Nandroid
ROM Download links
>> Please note, 1st boot may take up to 10 minutes as every application in /data will be ZipAligned, the time it takes depends on how many applications you have installed.. DO NOT PULL THE BATTERY <<
hier gehts zum Original: [ROM]LeeDROiD SuperSensational 6.0.0 ICS | 25th Jan| Sense 3.6 | FAST | STABLE | CIFS - xda-developers
Hans drauf, und es läuft sehr gut
Gesendet mit LeeDroid 6.0.0
Hallo zusammen.
Ich wollte mir das ROM zum testen mal flashen. Allerdings bootet es einfach nicht. Habe allerdings nicht die Firmware aus diesem Thread genommen sondern die, welche ich auch für ARHD nutze, welche allerdings gleich ist. Ich bleibe aber in einem bootloop leider stecken. Habe super wild gemacht und noch davlik + cache gewiped. Irgendjemand eine Idee ?
eiskalte Grüße Sebastian
sent with my HTC Sensation Z710e using Tapatalk
Welche Firmware hast du denn bzw welche Bootloader-Version hast du denn genau?
mfg Marcel
HBOOT ist 1.23.0000
Firmware ist 3.24.401.1
Eisbrecher schrieb:
HBOOT ist 1.23.0000
Bei fw 3.24 müsstest Du aber den 27 hboot haben.
Ich habe mir gestern elegancia gestern installiert. Hboot ist gleich firmeware ist nur auf 3.25.401.1
ARHD ist einfach laggy bei mir
/ edit kann mir niemad weiterhelfen wieso jetzt leedroid nicht bootet ?
Guten Morgen,
habe mir gestern die 6.0.0 draufgespielt,nun bekomme ich nach dem starten (also nach pineingabe) die Meldung "Sound Set" wurde beendet.Ansonsten läuft alles bis jetzt wunderbar,die meldung kommt 2 mal hintereinander. Hat da jemand ein Tipp? Dachte erst es läge an der Wetter App aber wenn ich den Sound abstelle kommt das gleiche.
Hat sich erledigt ist wieder runtergeflogen
Installiere den Donwload-Manager und du hast keine Probleme mehr, sondern eines der stabilsten ROMs überhaupt. Im Übrigen benutzen so einige der anderen ROMs die Skripte von LeeDroid (manchmal mit manchmal ohne Credits) und da ist es doch besser gleich das Original zu verwenden.
  • HtcSoundSetDownloadManager.apk
Reaktionen: Shadowevil
Danke für den Tipp,da ich ja ein Neuling bin muss ich da noch schauen...
Aber nutze gerade das InsertCoin Android 4.5 muss sagen damit bin ich sehr zufrieden...mach das aber mal drauf kann ja nicht schaden.
Wollte Lee auch mal wieder aktuell halten :rolleyes2:
Chenge Log
LeeDrOiD SuperSensational V7.2.0
  • Added LeeDrOiD Tweaks V4.2 (huge thanks to m0narx! >> THREAD << )
  • Kernel Bricked V1.0 -Low OC build (Thanks to show-p1984 >> THREAD << )
  • Browser link glitch fixed
  • Added HTC Sense removal option to aroma (Uses Nova Launcher)
  • Added stock bootanimation option to Aroma
  • Added Crypted enhanced GPS fix option to Aroma
  • Added Option to remove bootsound to Aroma
  • Default XML and locale cleanups
  • System sounds & ringtones from the One X
  • Altered default GPS config for Europe
  • Cleaned up and re-wrorked init.d scripts
  • Hacked Voice Search/HTC Speak to allow direct access
  • Voice Search renamed to speak with new icon
  • Updated all pre-installed applications
  • Updated to the latest google play store
  • New LeeDrOiD SuperDroid Boot animation
  • New LeeDrOiD SuperDroid Wallpapers
You will require the 3.32.401.5 Revolutionary patched firmware package
from this thread by Kohr-Ah
Hosting Thanks to
LeeDrOiD ICS Kernels
Wirklich sehr coole Rom, Mann kann auswählen ob SENSE oder Nova installiert wird. Ich teste es mal und melde mich später wieder.
Keine unnützen Apps dabei bzw. Bei Installation abwählbar......
Gute Performance, Akku muss ich noch testen :)
Gesendet von meinem HTC Sensation Z710e mit der Android-Hilfe.de App
Chenge Log
LeeDrOiD SuperSensational V7.3.0
  • Updated to LeeDrOiD Tweaks V4.3! Final (Huge thanks to J4n87 & Richmondo! for all they have done >> Full Thread << )
  • Updated Kernel Bricked V1.1 (Thanks to show-p1984 >> Change Log <<
  • Merged LMW & Settings.apk form the latest RUU
  • Wifi issues fixed
  • Added optional stock HTC IME option to Aroma
  • Fixed sense stripper option in Aroma
  • Nova launcher replaces sense in the above scenario
  • When sense is stripped, only Rosie & its widgets are removed
  • Added individual social networking removal options to Aroma
  • Added HQ Camera V1.5 (Thanks to NODO-GT >> Thread << )
  • Fixed Fancy keyboard animations
  • Increased boot audio volume
  • Smoother boot animation
Hammer rom aber leider etwas laggy :-(
