Andre123
Features:
Based on HTC WWE 1.35.401.1 RUU
LeeDrOiD Pyramid Kernel V1.1 - 2.6.35.13
Patched to linux upstream 2.6.35.13
Interactive governor as default 193MHz-1180Mhz
Added OC Support up to 1728MHz
OpenVPN & CIFS support
SLQB Memory allocator
WiFi PM=FAST in standby
WiFi minrssi increased (88 > 98)
Allocated un-cached video buffers as write combine (GPU+)
VR I/O Scheduler as default (Deadline, Noop, SIO, CFQ & BFQ Optional)
Built using LZMA compression
Huge code & config cleanups
Heavily optimized
Lots of debugging info stripped
Root & Un-secured boot.img
Deodexed & ZipAligned
Init.d support with zipalign on boot
/data/app/ zipaligned on boot (Improved RAM performance)
Ram Optimizations
Lots of speed tweaks
Improved battery life
File system (EXT4) tuneups
Several script cleanups
Busybox 1.19.0
Nano command-line text editor support
Bash command shell support
Advanced power menu
Overscroll animations
Stock % battery display
CRT TV screen on/off animation
Signature check hack by RC Team
Smooth Keyboard open/close animation
LeeDrOiD Custom lock ring
Included apps - AdFree, Titanium backup & Astro file manager
Voice Dialer (working with Bluetooth)
Dalvik VM heap size increased to 40mb
SD Card speed tweak
Clean, Fast & Stable
Forced GPU UI Rendering
Huge APN list
Custom LeeDrOiD Bios Boot animation
R2D2
Removed - Bloat
Custom LeeDrOiD Locales & Language support
Supported Languages: English, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Korean, Greek, Turkish, Swedish, Danish, Portuguese, Finnish, Thai, Korean, Vietnamese, Chinese, Japanese, Portuguese, Croatian
Download & weitere Infos
[ROM]LeeDROiD Sensational V1.1 [Kernel] V1.2 -2nd August | APM | CRT | FAST & STABLE - xda-developers
