[ROM] ELEGANCIA|Sense 4.1|2.2.0
  • 520 Antworten
xXXSchokiXXx
xXXSchokiXXx
Dauer-User
386
Aktuelle Version : v7.4.0 [OTA]
Features:
♥ Android ICS 4.0.4 Rom base is from VilleC2 RUU 2.15.720.150 + VilleC2 RUU 1.11 including the latest HTC Sense 4.1
(Thx Memnoc for the permission and files)
♥ Aroma Installer
♥ Optional to ODEX rom in Aroma installer
♥ Custom OTA Support - Many thx to m0narx for the script
♥ MyElegancia (HUB) for Elegancia - Sense 4.1 (All credit go to Mikrosmile)
♥ Two rom in one zip (Stock and themed version)
♥ 80+ Restore packages are available in the interactive user installer
♥ Video of Elegancia_Sense_4: -> HERE and HERE <-
♥ Enhanced Audio Beats includes 21 eq settings
(Thx lyapota for the original mod)
♥ PYD-X v4.1.9 (beta) kernel - Link to XxXPachaXxX thread
♥ TMOus Wifi-Calling
♥ TMOus Wifi-tethering working 100% and free
♥ Enabled GPU UI rendering
♥ Blue highlights
♥ 3D appdrawer cube animation (Optional)
♥ Rosie rotation (Optional)
♥ HTC IME Trace Keyboard (Optional with arrows and without)
♥ HTC Matte skin set as default in stock themed version
♥ Sony Bravia Engine - HQ Image and Movie improvement (Optional)
♥ Xloud Sound Engine - Sound improvement (Optional)
♥ Disable Lockscreen totaly (optional) - Thx Jonny for the smali edit
♥ Hide apps in the appdrawer via menu
♥ Deodexed, zipaligned, tweaked
♥ Synchronization fully working
♥ Improved SD card read ahead
♥ Advanced Power Menu
♥ Zram enabled
♥ Sqlit3 and openvn support
♥ Tabbed Extra Quick Settings
♥ Busybox + runparts
♥ A lot of junk removed
♥ Screenshot by pressing Power and Home
♥ Elegancia tweaked Sound System
♥ Looking for Rom stability, outstanding battery life and smoothness? Welcome! You are at the right place!
♥ Trying this Rom once, is adopting it for always
N.B. See the changelog to know about the updates...
Known bug: HDMI Out
Changelog:
V7.4.0 [OTA] [09.06.2013]
Fixed BusyBox Installation which wasn't properly set and installed
Looks like the issue was there since a couple of version back
V7.3.0 [OTA] [08.06.2013]
Added TV-Out options to Settings->Display for HDMI users
Now possible to set Orientation or Outgoing format
V7.2.0 [OTA] [03.06.2013]
Small OTA
Updated Gmail to v4.5
Not globally available in Playstore yet
With Slide-Out Navigation And Brand New Inbox
V7.1.0 [OTA] [03.06.2013]
Added HDMI fix (Optional) Replaced Sense 4.1 libs with those from Sense 3.6 - It may cause some GUI lag
Updated SuperSU binaries 1.30
Updated RIL files 4.0.0037HMQ
Updated MyElegancia 2.4
Updated BusyBox
Updated Playstore 4.1.10
Updated SU binary file permission
New MyElegancia Tabs added
V7.0.0 [FULL ROm] [15.05.2013]
Reverted back to SebastianFM v1.5.2 as default kernel
Update APM recovery icon
Temporally reverted back TurboBoost v2.8.0 (v3 is available in MyElegancia)
Changed ADJ/OOM sleep value to 40sec instead of 65sec (Caused some issues - Delay to long)
Removed 4Ext Touch Recovery update from Aroma (Due to incompatibility with s-on users)
Fixed a lag issue due to wrong permissions and Zipalign
Updated WiFix to 1.32 (Fixed WiFi issues for Iranian users for example)
Changed OTA installation from cache to SdCard (Due to Swap on /cache incompatibility)
Updated Taiwanese language (Thx MelodicRainer for translation)
Updated MyElegancia (some bug fixes)
Elegancia (non colored) Phone and dialer icons updated
Beats icon should not disappear while getting a notification
Overall performance should be better
Zipaligned
Updated all Playstore apps
V6.0.0 [Full Rom] [08.05.2013]
Removed TurboBoost v3 from initial rom installation (Still available via modification menu)
Added new Start menu in Aroma (Saves some vague choices)
Fixed Aroma bug which caused a a second and empty build.prop
Added Xloud, Bravia and Fastdormancy to Additional install menu
ADJ/OOM Settings reverted back to old values
Added 4ext Touch Recovery version check to Aroma
Added 4ext Touch Recovery.img flash when recovery is outdated (Thx mike1986.)
Reverted back to P.Y.D v4.1.9 as default kernel (No mods available, Please use KernelTuner for you desired settings)
Updated MyElegancia to v2.3 (Thx MikroSmile) HUB downloads ain't working in beta due to old server config
Zipaligned
This release fixes the lag some users experienced with TurboBoost
To overcome this issue we temporally removed the Turboost MOD from main installation menu
It is available via the Additional mods menu
V5.1.2 [OTA] [04.05.2013]
Adjusted ADJ/OOM values for better response
There was a mistake somewhere in the OTA compile process
And the values didn't change, new OTA has different values
V5.1.1 [OTA] [04.05.2013]
V5.1.0 [Full Rom] [01.05.2013]
Incremental update from v5.0.0 is possible, no need for full wipe
Fix for Chinese input FC (ota & full rom)
Fix the themed Keyboard colors (Full rom only)
Added rounded launcher icons to MyElegancia - thx AnatolDv (ota & full rom)
Cleaned some unused system files (ota & full rom)
Updated T9 Libs - Thx ivicask (ota & full rom)
Each model version has his own bootanimation - thx Shnizlon (Elegancia is excl for colored version)
Fixed lockscreen clocks from only showing clock arms
Update MyElegancia to v1.3 (ota & full rom) Thx Microsmile &Jonny
Updated background for all tabs
Updated Refresh button
Added Vibration on items click
Added Jonny to About page
Added Settings page
Added Ability to disable auto loading of list on start application (All Tabs)
V5.0.1 [Full Rom] [16.04.2013]
Fix for setting mp3 as ringtone
V5.0.0 [Full Rom] [16.04.2013]
Full Wipe is mandatory
Don't try to do incremental, it will end up in system failure
Rebased the rom to 2.15.720.150 Asian Ville C2
Removed all Tweaks
Fixed Stock Elegancia default skin which was particly green (blue every where)
Added two new aroma menus: Additional App Restore & Additional IME T9 Restore
Added optional Indic IME keyboard
Added some User fail checks to Aroma for theming, additional apps
Removed Atom and Nova Launcher from DeSensing (They are available in Playstore)
Added Incremental Update fail check (Delete app which aint selected)
Added MyElegancia v1.2 (Elegancia HUB Store) thx to MikroSmile & Jonny
Added MyElegancia to Settings
MyElegancia has a new Temporally Banner by mdpgc & V6-Maniac
Added NoLockscreen to Settings -> Security
Ty updated his theme for Elegancia Sense 4.1 Colored version
Added new keyboard
Keyboard Arrows is now optional via keyboard settings
Updated PlayStore to the latest version
Set OTA Update to SDCARD as of expiriment to overcome the TurboBoost and OTA fail issue
Replaced Keyboard Theme for colored version(For testing purpose)
Fixed OTA Update non working progress bar
SebastianFM v1.5.2 Boot.img instead of zImage installation
Removed old and unused kernel modules
Update HtcDialer Elegancia stock to match stock installation (Set Green dialer button to blue)
Changed Dialer laucher icon from green to blue to match stock installation
Removed Kernel restore from aroma (Not needed anymore due to MyElegancia)
Added Dialer and Gmail to NavBar on fresh installation
Due to the new HUB i removed some additional features from the rom
Which will be available in the HUB or rom
Removed mods from Aroma:
Removed Keyboard arrow mod (Now available in Keyboard Settings page)
Removed Battery % icon mods (Now available in HUB)
Removed All kernels, set SebsatianFM v1.5.2 as default (More kernels available in HUB)
Removed skins from Aroma (Now available in HUB)
Removed HTC ONE sounds from Aroma (Now available in HUB)
Performance:
Overall performance is faster depending on you configuration of course
But the rom is more battery efficient and stable.
Rom size reduced by 70mb
Beware of the following major Aroma change:
One major change you have to be aware of.
Normaly you select apps to install.
When applying future v5 or above incremental flashes apps which aint selected are now deleted.
This does not apply for a fresh install.
v4.0.2 [OTA] [11.04.2013]
Added MyElegancia (file & mod store) thx ;icroSmile
v4.0.1 [OTA] [03.04.2013]
Recent app fix
v4.0.0 [Full Rom] [01.04.2013]
Full Wipe is recommended due to deep system changes
Removed Tweaks app
Removed Tweaks Smali codes
Added new feature to Aroma (not fully tested) - Additional modifications menu
Removed Elegancia Tweaks menu option from Settings.apk
Removed Elegancia Tweaks menu option from Rosie menu
Added some extra tweaks to build.prop
Added Keyboard Arrow mod as optional choice to aroma
Added some Batt icons mod as optional choice to aroma
Added keyboard arrow mod as optional choice to aroma
Added xloud and bravia mod as optional choice to aroma
Added additional rom ODEX menu option to Aroma (Thx Dublinz for the idea and Paul oBrian for a part of the script)
ODEXing has some advantages.
Most known ones are a faster rom, better app response and less memory footprint.
Disadvantages are longer boot time and harder to theme.
But you can ODEX Elegancia colored version on one condition.
You must have a fully running colored rom and then apply ODEXing.
v3.8.0 [Full Rom] [28.03.2013]
Revert services.jar OOM settings to default
Updated SuperSU
Updated Play Store Apps
Removed init.d call from init.post_boot.sh (init.d is working propperly)
Added HTC Z710e model Selection
Added HTC Z715e model Selection
Updated TMobile US model Selection
Added HTC Z710e Orange UK model Selection (Incl core files & signalboost)
Added HTC Z715e Orange UK XE model Selection (Incl core files & signalboost)
Added sdcard free space check for aroma theming option
Fixed DeSense Model selection
Added TurboBoost v2.8
Added extra TurboBoost feature (/system swap)
Added Added TurboBoost restore menu to Aroma
Added /System free space check to TurboBoost restore menu to check if there is enough free space
Added Added ADJ/OOM custom values restore menu to Aroma
Added Added SDCard Custom Speed Tweaks restore menu to Aroma
Added Added Undervolt Custom values restore menu to Aroma
Added Elegancia additional Theming menu option to Aroma for those who are bored of the Stock version
Added Sense 5 Notification sounds as optional in Aroma
Updated Aroma header notes, icons, ect
Updated /system/bin files and hope to solve some issues
Fixed Incremental update for colored version
Fixed custom background and custom color tweak for colored version
Added new Aroma menu option (Faster GPS fix)
Fixed Bricked kernel restore option(Typo in Aroma)
Fixed Faux Kernel restore option (Typo in Aroma)
Updated rom with Ty his fixed theme
Fixed color mismatch bottom menu bar (Thx Ty)
Fixed color for pin (Thx Ty)
Added centered Transparent Clock Widget (Thx Dublinz)
Added new theme to Aroma
Added Aroma Installer Theme selection
v3.7.1 [OTA] [11.03.2013]
Possible WiFi connection fix for regions with more then 13 channels (Not tested yet up to you )
Fix for Tmous user who desensed and have WiFi Calling issues.
v3.7.0 [Full Rom] [10.03.2013]
Mail Exchange security disabled (Thx misiek_to_ja)
BT Wakelock fix
Elegancia Tweaks updated (Same as v3.6.1 ota)
Rethemed colored version (thx TY)
Streamplayer fixed
No wifi issue after first initial setup possible fix
Added Elegancia additional rosie & battery icons theme to Aroma
Fix for Facebook/Friendstream Livefeed contiues sync when not selecting friendstream in Aroma
No reboot possible fix
Autobrightness tweak fixed
Captive backlight tweak fixed
Elegancia Tweaks App new features
Infinite Rosie scrolling added
Wallpaper scrolling toggle added
Rosie image bg added
Added Long Press Search button remap options
Long Press Menu remap options fully working incl custom app
Logcat enable/disable toggle added
Rosie Icon theme
Added 4 kernels to Aroma
Change default wallpaper
Fixed non changing lockscreen icons on Rosie Icon Theme (Reboot needed to apply)
Added undervolt options to Aroma
Added (per request) Orange UK Signal Boost as optional in Aroma (not tested)
Added Turboboost restore menu to Aroma
Added Kernel restore menu to Aroma
Delete some apps which are available in PlayStore (Google+, Chrome beta, Sense3.6 sounds)
Fixed Desensing, Fully working now and now issues with stock or themed version
Changed default Matte skin to Elegancia skin (Default HTC with Matte part and bits)
Did not update Turboboost, had some issues with it which i first have to review
v3.6.1 [OTA] [02.03.2013]
Elegancia Tweaks app updated
Streaming video reboot issue fixed (Thx xXxPachaxXx)
Added Elegancia additional rosie & battery icons theme to Aroma (Thx ChrisBanks for the HD icons)
v3.6.0 [Full Rom] [16.02.2013]
Rebuild the rom from scratch
Inserted Hidden PowerSaving Settings in Settings.apk
Reintroduced the good old Elegancia 4ext Recovery theme
Adjusted ADJ/OOM (memory) settings to hopefully a average setting
Reverted Bravia Engine to v1
Edited android.policy.jar (Set ADJ/OOM back to default HTC Sense settings)
Deleted a hidden Tell HTC string
SuperSU Delay on Grant has been solved
Zygote sudden kill has been solved (should solve sudden lag and reboots)
Changed the init.d script folder behaviour
Added TURBO BOOST as experiment (Use at your own risk!!!) thx to delta-roh & Harbir
Added more TurboBoost option in Aroma (Swap to Cache,Data & System)
Fixed bootloop on DeSening Elegancia
Updated all Market app
Zipaligned with the latest SDK
Main concern is that the sudden reboot, lag and memory issues are over
V3.5.0 [Full Rom] [07.02.2013]
BT Download page is working (received files)
Captive backlight setting in tweaks app is working (Reboot needed to change)
Fixed MusicBox EQ, all sound eq's should be working now
Fixed poping sound when selecting next or previous songs in music app
Fixed some system errors and this means more battery life
Chrome working without glitches
WiFi Hotspot working on PYD 4.1.9
Fixed SuperSu issues
Batt calibration added to init.d script
Bricked kernel v1.4 added as optional
Faux 01b10 added as optional
SebastianFM v1.5.2 added as optional
Reintroduced the Aroma config backup (Needed testing)
Fixed wrong low mem config, kernel overrides init.d settings (thx axetilen for helping)
Fixed Spanish IME which wasn't installed, Aroma typo
Updated SuperSU to v1.0.1
Set fixed ADJ/OOM settings which should fix issues for some users
Updated all market apps
Added latest Chrome version to Aroma
And some stuff i may have forgotten about
By fixing the lowmemory config means a lot of users who play heavy games won't see reboots or reloading Rosie.
v3.4.1 [OTA] [23.01.2013]
Thermald.conf fix
Prevent your CPU from overheating
Elegancia - Sense 4.1 - V3.4.0 [Full Rom] - [Noch kein release Datum bekannt]
v3.4.0 [Full Rom] [22.01.2013]
(Full Wipe ist Nötig)
Warum eine volle Rom ?
Weil eine menge intern geändert wurde.
Einige Änderungen werden erst wirksam wenn sie mit einer Full Wipe geflasht wurde.
Das ist etwas was ich nicht ändern kann, das ist Android da einige Einstellungen tief vergraben
sind und das er einzigste weg ist es zu ändern (Full Wipe).
Update Links inside Tweaks app (wrong links due to OP layout changes)
Toggle Custom Boot & Down Animation is working
Toggle Custom Boot-sound is working
Fixed a other tmous fingerprint issue.
Fixed toggle Xloud Engine not working properly
Toggle Long Press Home button recent apps working
Zipalined with latest SDK
Updated build.prop
Removed Bricked kernel
Added P.Y.D v4.1.9 (Beta) kernel as default
Battery life improvements
Improved Memory Management
Reverted ADJ/OOM settings back to default (Should fix issues when user overrides the settings)
Rosie long delay should be fixed
SuperSU long delay should be fixed
Reverted Weather Provider from Sense 4 (should fix wrong forecast)
Improved overall speed
Cleaned unused bin, lib files
Transparent 3x2 clockwidget is now working in themed Sense 4.1
Added MusicBox (Thx lyapota for the original mod)
Reverted back stock font size (Download fontchanger from the PlayStore to change fonts)
Updated PlayStore apps
Just one hell of a performance boost
To Do:
Fix captivebacklight adjustment
Fix AutoBrightness adjustement
v3.3.3 [OTA] [17.01.2013]
Fix für v3.3.2 [ Colored & Stock] Tastatur.
v3.3.2 [OTA] [16.01.2013]
In der Rom .zip ist die Falsche Tastatur die dazu führt das man in der Tweaks app
arrow umstellen konnte, Fehler aber mit dem Update behoben und die richtige Tastatur ist eingefügt worden.
V3.3.1 [OTA] [16.01.2013]
Kleine init.d Patch um das DeepSleep Problem zu beheben.
Einige Phones wurden nicht in denn DeepSleep versetzte.
Und Sollte jetzt die Lebensdauer des Akkus verlängern.
V3.3.0 [Full Rom] [09.01.2013]
Full wipe ist nötig
- Included 3.2.1 OTA
- Jumpy updating icon and text in colored mail fixed (Thx Vicai & Ty5982)
- Added YouTube 4.2.16 (v2b), 720p HD over WiFi & 3G (Thx theos0o) - Stock version
- Added YouTube 4.2.16 (v2b) inverted color, 720p HD over WiFi & 3G (Thx theos0o) - Theme version
- Fixed Sweep2Wake issues for good
- Fastdormany toggle in Tweaks should work now
- Simplified Aroma installer to reduce error when theming
- Fixed non sticky freq's and governors for Bricked installation
- Possible WiFi Calling fix for Tmous users when they do a incremental
- Reduced overall font 10% smaller (makes it look slicker and better readable incase of oversizing language sentence
- Update links in the about tab in EleganciaTweaks (False links due to reordering the OP)
- Possible fix for 4G icons in themed version for Elegancia Colored Version
- Fixed fc when selecting custom background for notification pull down in Tweak app
- Fixed Tmous script which didn't insert the right Device fingerprint
- Edit ADJ/OOM setting to more multitasking friendly
- Change default wallpaper for stock version (Thx juancubo)
- Font size issue in Blue_Glass skin widgets fixed (Many Thx to saugbaer)
- More to Come
V3.2.1 [OTA] [05.01.2013]
OTA are meant to fix something but in some cases when a user modded the rom manually it can screw the rom up so no guarantee given
- Added new Tweaks app and ported almost all tweaks over to Elegancia (Many thx to m0narx for permission)
- New culprit found when installing kernel (Seems 70% of the scripts aint running) Maybe cause of some user issues.
Now the scripts are working and the rom flies...
- Removed Additional MOD menu from Aroma, Not needed anymore since all mods can be controlled via the new tweak app
- Added some custom batt % mods in the new tweaks app (Many thx to JerryTan for permission) and added Juan Elegancia Batt icons
- Improved some speed enchantments
- Added tabbed EQS (coming from LD Tweaks 4.3.0)
- Fixed bricked kernel issues for colered themed users
- Added zipalign on every boot
- Added rom version detection to the OTA (Saves you from user error)
- Added rom carrier detection to the OTA (idem)
Changelog v3.2.0 [OTA] [22.12.2012]
Rewrote Aroma
Found kernel culprit and fixed in Aroma
Found culprit for battery % mod and fixed in Aroma
Added ADJ/OOM fix from v3.1.1 OTA
Added option for full wipe or incremental installation
Added option in Aroma to save chosen/checked options for the next flash
Added Phone Model choice in Aroma
Added TaKeControle (thx Pacha) script for Bricked Kernel (More battery life without performace decrease)
Changed the way how the theme is flashed. (Should overcome issues like no batt % and Tmo 4 icons)
Removed some stuff from the build.prop this should give some speed improvement
Removed sysctl.conf from the rom which was one of the reasons causing kernel issues
Also init.d is controled by the rom/kernel no need for sysctl.conf
Removed thermald and vold from /bin folder (most kernel have them aboard)
Fixed frontcam left/right inverted pics
Fixed frontcam vid upsidedown for good
Fixed Chrome GFX Glitches for good now (Status bar chrome shine true aint fixed yet)
Fixed some Bluetooth issues for some users
Transparent 3x2 clockwidget should now be working for all users
Saving MMS should be working for all users now
Rom speed improved (not for bechmark apps, don't give F about them)
Fixed LD Tweaks brightness issue causing reboot
Fixed phone vibration in call
Removed additional MOD restore from Aroma since incremental update is possible
Removed kernel menu from aroma for now and maybe will return in the future (if you want a other kernel then flash it manually)
Arabic Keyboard is working (at my side)
Incremental update from v3.1.1 or older seems possible but no guarantee
Changelog v3.1.1 [OTA]
- Adjusted ADJ/OOM settings.
- System speed increase.
- Possible fix phone vibrate when calling.
- Possible fix reboot issue when set backlight to lowest in LD tweak
Changelog v3.1.0 [Full Rom]
- Gmail to stock
- Fixed Arabic FC IME
- Fixed no reboot after selecting faux kernel (missing line in aroma)
- Fixed no text in mail widget
- Added extra clock into the Clockwidget which were requested by some users
- Fixed sudden reboot issue when SebastianFM kernel is installed
- Added Xloud fix which came via OTA
- Removed music app from Aroma and implanted it into the rom (no music app means no custom mp3 sounds)
- Removed Gmail colored theme
- Fixed Tmous colored 4g icons
- Changed Aroma IME installation, Now you can select more languages to install instead of one
- Possible fix for chrome GFX glitches
- Fixed no txt in the mail widgets
- Fixed Aroma colored MOD additional restore packages not installing batt % icons
- Added Juan batt % mod (thx mate)
- Fixed Calender not syncing without having Calender installed
Changelog v3.0.1 [OTA]
- Gmail to stock (Optional)
- HtcClockwidget fix (Optional)
- HtcMailWidget fix (Optional)
- SuperSu grant fix
- Xloud sound issue fix (Optional)
Changelog v3.0.0 [Full Rom]
Full Rom: FULL/SUPER Wipe is IS REQUIRED if coming from Sense 4.1 v.2.3.1 or older version
(recommended for better performance)
- Rewrote the entire Aroma Installer (7000 new lines)
- Fixed Flashlight popup menu (Issues for some users)
- Fixed Flashlight button push (Issues for some users)
- Fixed stability issue that some users were facing with some kernels
- Fixed Beats icon not showing for some users
- Fixed the Overscroll color
- Added Full Wipe in Aroma Installer
- Added Custom OTA System - OTA via rom it self (Thx m0narx for the guide, files and permission)
- Added two roms in one zip (Stock look and Colored look are cooked together)
- Added advanced Aroma menu
- Added /system files restore to Aroma
- Added kernel restore to Aroma
- Added Change Log menu item to Aroma
- Added Additional HTC apps restore menu to Aroma
- Added Additional mods restore to Aroma
- Added Leedroid Tweaks (Thx j4n87,Leedroid and Romanb)
- Added 4 kernels and all as optional (Faux, Bricked, SebastianFM and PYD)
- Added Leedroid Tweaks to Settings and Rosie (Thx j4n87 for the permission)
- Added Matte Skin as default skin on Elegeancia Stock themed version
- Added TVout (in settings)
- Added new Graphical drivers from 2.15 VilleC2 RUU
- Added EQS (thx to J4N87)
- Added APM (thx to J4N87)
- Added option to disable HTC lockring in Security Settings (Power up your phone with out unlocking it) thx Jonny
- Added new restore packages to Aroma installer
- Added xLoud option during Aroma installation
- Cleaned rom - removed unnecessary files
- Improved performance
- Increased overall speed
- Disabled NFC Support (No hardware to support)
- Changed Stock Wallpaper on Elegancia stock version
- optimized and debugged all applications and framework files
- Updated some libs for more stability
- Updated SuperSu
- Updated SU bin file
- Updated HTC-RIL_4.0.0037HMQ ril files
- Updated Google Play to 3.10.9
- Updated all PlayStore apps
- Zipaligned with the latest SDK
- Others updated & changes
ELEGANCIA Sense 4.1 v7.0.0 Full Rom[Theme & Stock Look in einer .zip]
Mirror 1 - Morror 2 - Mirror 3
MD5Sum : 4e54506c5bb3a24e514a35a58d407c8b
Add-Ons
Elegancia Theme
Elegancia Battery Blue %Mod
Elegancia Battery Blue ohne %Mod
Stock Blue Battery %Mod Small
Stock Blue Battery ohne %Mod Small
Stock Green Battery %Mod Large
Stock Green Battery ohne %Mod Lage
XDA Thread
Reaktionen: eltasmanico, Vincent V., Mr.Mario und 4 andere
Läuft gut, nur gefallen mir die Themed Versionen nicht so gut wie die Stock Versionen. Bis auf HDMI hab ich keine Probleme feststellen können, Tweaks wie bei ViperS fehlen aber leider(in dem Umfang
Bei der 2.2.0 (Sense 4.1 Stock) will das WLAN immer root haben? Wofür? Saugt meinen Akku leer :(
mksh um genau zu sein
Das ist für denn WLAN um genau zu sein spuckt SuperSU mir das aus "ip route add 224.0.0.0/4 dev wlan0" was genau das ist kann ich dir leider auch nicht sagen.
Könnte aber gut der WLAN fix sein der dabei ist, bin mir aber nicht so ganz sicher.
Wofür das ist weiß ich, hab ich doch geschrieben, würde nur gerne wissen wieso mein akku bei eingeschaltetem wlan auf einmal in drei stunden leer ist, das handy ist ständig aktiv.?!?!
Man sieht auf dem Bild im ersten Post, das die kleinen Buttons so hell beleuchtet sind. Ist ein Fake, oder sind die wirklich hell? Denn sowas suche ich!!
P.S.
Sense 4.1 v.2.2.0 (Theme Look) Link ist down?
das kann man Manuel einstellen mit kernelTuner
ja der ist platt schaue mal eben
Der ursprüngliche Beitrag von 12:20 Uhr wurde um 12:24 Uhr ergänzt:
So Links gehen wieder Grund warum sie nicht mehr gingen war das die v2.3.1 jetzt raus ist so alles Aktualisiert und viel Spaß damit ;)
Kannst Du mir denn sagen, wie genau man die Buttons hellermachen kann?
P.S. Ich habe die Blitz 3.6.0 drauf.
schau mal in deinem Postkasten
Kannst Du mir evtl. sagen, wie ich bei der Blitz 3.6.0 den Ton für eingehende Mails ändern kann? Finde nirgends eine Einstellung dafür. Bei anderen CFW geht es.
1 ) Das gehört hier glaube ich nicht hin !
2 ) Muss du in denn Einstellungen der Mail app schauen dort geht es soweit ich weiß.
sagt mal, bin ich blöd, wo ist denn die sms funktion?
Super Akkuverbrauch, endlich eine Sense 4.1 Rom die vom Akkuverbrauch an ARHD mit Sense 3.6 ran kommt.
Super Arbeit Goodbye Viper ....
:thumbup:
Der ursprüngliche Beitrag von 20:34 Uhr wurde um 20:41 Uhr ergänzt:
Ach ja SMS ist Symbol unten neben Foto :D
Kann ich nur bestätigen!
Habe dieses ROM jetzt einige Tage drauf und läuft alles super.
Gestern Abend voll geladen. Über Nacht (in 12 Stunden) eine Akkuverbrauch von nur 4%, dass finde ich wirklich SUPER!!!!
Kurze Frage, das Stock look ist komplett stock oder ist das auf dem Bild im Startpost der Stock look ?
Stock look ist Stock look... Und das Bild im Startpost ist nicht Stock....
Mfg
Danke poeddie ;)
nichts für ungut, im bild im startpost steht dick und fett "Themed Sense" :biggrin: das ist die optisch modifizierte version... vom stock look sense 4 gibts selbst im original thread auf xda kein bild, sieht ja halt aus wie das original...
Reaktionen: Heckschleuder
:thumbup:
also viper hat ja nun auch bei mir nen super akkuverbrauch. lohnt sich der wechsel (versuch) zum elegancia /themed doch evtl?
nur mal so zum testen....
Lohnt sich 100%!
Ich habe viele ROMs getestet und dies hat eindeutig den wenigsten Akkuverbrauch!
Kein anderes kommt hier ran.
Und Bugs habe ich auch noch keine festgestellt.
Bei mir läuft alles.:thumbsup:
  • candlebox
daniel9180
O
OneGamer
O
ger_kar
Bench
Bench
