I
InEo
Nachdem die Entwicklung von mike nun in 2 Teile (einmal mit XE und einmal ohne) aufgeteilt wurde, dachte ich es wäre sinnvoll dies hier im Forum aufzutrennen, denn bei XDA ist das Thema nämlich inzwischen sehr unübersichtlich und durcheinander geworden.
Android Revolution HD based on HTC Sensation "non-XE" HTC base
Based on 2.08.401.1 HTC test leaked ROM with HTC Sense 3.5 for HTC Sensation
All images in this thread including screenshots, headlines, banners, etc. are copyrighted and you can't use it without permission
» Visit Team Revolution website now! «
» Join me & my Revolution Team on Freenode live chat! «
If you appreciate my work, you can buy me a beer
All my ROMs have great popularity and are a 100% success
About Android Revolution HD
- Android 2.3.5 (Gingerbread) - latest HTC RUU 2.08.401.1 TEST RELEASE SO MIGHT HAVE BUGS
- This is improved version of stock ROM - no visual changes!
- New kernel: 2.6.35.14 (under-volted & tweaked). Details below:
- CPU up to 1.56 GHz (1.51 GHz by default - original speed for MSN8660 chipset) - controlled automatically by built it O/C Daemon. How to use O/C Daemon?
- If you want to control CPU manually, you would need SetCPU from here: SetCPU
- In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery then SetCPU
- Many CPU governors (SmartAss, Ondemand, Performance, Conservative, UserSpace)
- GPU+ patch (Improved 2D & 3D Graphics performance
- 3D Engine overclocked from 266.6 MHz to 320 MHz
- L2 Cache Bandwidth Boost from 310MHz to 360MHz
- Synchronous L2 Cache
- V(R) I/O as default scheduler
- SLQB Memory Management
- CIFS, TUN & UTF8 support
- LZMA compression
- Wi-Fi module improved drivers
- Code cleaned up with custom voltages, tweaks & many more!
- You can find custom kernels here
- ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
- Full HTC Sense 3.5 Interface
- Fully optimized and tweaked
- Unsecured boot.img
- Newest BusyBox
- RAM optimizations
- Improved Andreno200 configuration for better quality and performance!
- Speed optimizations
- Enabled GPU UI rendering
- SD Card speed tweak
- Battery auto-calibration
- Data partition special speed tweak
- Very fast, clean & stable!
- Battery auto-calibration script (Thanks to seo)
- Bloatware applications removed (Amazon MP3, SoundHound trial, etc.)
- HTC Sensation 4G (US T-Mobile) support like Wi-Fi calling and Visual Voice Mail
- All system applications updated to latest available
- Improved camera performance
- Multilanguage (WWE)
- Advanced Power Menu and CRT Animation as extra add-ons
- Arabic and Hebrew languages full support!
- Zipaligned (Improved RAM management)
- Zipalign on boot (for user applications on data partition)
- Fully de-odexed
- init.d scripts (BusyBox run-parts) support
- NANO text editor & sysro/sysrw commands support
- Excellent battery life!
- Improved EXT4 performance by changing mounting method
- SD card EXT4 partition support
- ROM is ad-free. It means that you don't need any extra software to get rid of advertisements
- You can replace HTC boot animation with any custom boot animation.
- Support almost 24h a day
- ...and many more!
» Advanced Power Menu, CRT Screen-off Animation & other mods are in the second post!
» You can easily customize my ROM and make it LITE by removing some components with ROM Cleaner by Patrics83
» If you want to flash different custom kernel, you can do it easily using Kernel Update Utility made by jkoljo
Code:[CENTER][SIZE=4][COLOR=Blue]Android Revolution HD 4.1.3[/COLOR][/SIZE] [SIZE=2]--- [I]release date: 09 October 2011[/I] ---[/SIZE][/CENTER] [LIST] [*][B]New kernel from faux123 version 2.1 Final[/B] [*] - ZRAM bug fixes and latest patches (up to latest greatest beyond Linux Kernel 3.1) [*][B]ZRAM is enabled in the ROM by default[/B] [/LIST] [COLOR=Red]- You can download custom kernels from [URL="http://tinyurl.com/3uudmh2"]here[/URL][/COLOR] [COLOR=Red] - Remember to remove SetCPU or any other CPU tuner in order to have O/C Daemon working[/COLOR] [COLOR=Red]- Read [URL="http://tinyurl.com/6aps74e"][B]this post[/B][/URL] to learn about O/C Daemon[/COLOR] [COLOR=Red]- No need to use Super Wipe if you have 4.1.x already![/COLOR] [SIZE=1] [CENTER][SIZE=3][COLOR=Blue]Android Revolution HD 4.1.2[/COLOR][/SIZE] [SIZE=2]--- [I]release date: 06 October 2011[/I] ---[/SIZE][/CENTER] [LIST] [*][B]Disabled ZRAM because it was a cause of some strange issues[/B] [/LIST] [CENTER][SIZE=3][COLOR=Blue]Android Revolution HD 4.1.1[/COLOR][/SIZE] [SIZE=2] --- [I]release date: 06 October 2011[/I] ---[/SIZE][/CENTER] [LIST] [*][B]New kernel from faux123 version 2.1[/B] [*] - Added XZ Compression support to 2.6.35 kernel [*] - Added XZ Compression support for kernel image [*] - Added XZ Compression RAMDisk support (boot time) [*] - Added SquashFS support based on new XZ Compression (very high compression ratio File System) [*] - Updated Camera Driver FPS to 120 (mdeejay) [*] - Used the git implementation of SHA-1 to reduce boot time by 11% [*] - Updated to use CRC32c with slicing-by-8 algorithm to improve EXT4 metadata performance [*] - Updated qdsp6v2 to block write until buffer is full [*] - Updated trivial bug fix for SMP macro [*] - Introducing ZRAM (compressed RAM == MOAR RAM) [*][B]ZRAM is enabled in my ROM by default, no need for additional scripts[/B] [*][B]SuperUser updated to latest 3.0.2[/B] [*][B]Restored mistakely removed Facebook for HTC Sense[/B] [*][B]Removed HtcLoggers.apk[/B] [*][B]Removed libhtc_loggers.so, libhtc_netlogger.so and libhtc_ramdump.so[/B] [*][B]Different method of init.d scripts execution[/B] [*][B]Google Maps updated to latest 5.10.1[/B] [*][B]Maxthon updated to latest 2.3[/B] [*][B]Adobe Flash Player updated to latest 11.0.1.152[/B] [*][B]ES File Explorer updated to latest 1.6.0.7[/B] [*][B]Android Market updated to latest 3.1.6[/B] [*][B]Facebook updated to latest 1.7.2[/B] [*][B]Gmail updated to latest 2.3.5.2[/B] [*][B]Other minor changes and fixes[/B] [/LIST] [CENTER][SIZE=3][COLOR=Blue]Android Revolution HD 4.1.0[/COLOR][/SIZE] [SIZE=2]--- [I]release date: 27 September 2011[/I] ---[/SIZE][/CENTER] [LIST] [*][B]New HTC base 2.08.401.1[/B] [*][B]First HTC Sensation ROM with true Sense 3.5 for HTC Sensation[/B] [*][B]Android 2.3.5[/B] [*][B]SuperUser updated to latest 4.0 Final version[/B] [*][B]su binary updated to latest 4.0 Final version[/B] [*][B]hosts file updated to latest[/B] [*][B]Thermal configuration file tweaked[/B] [*][B]Zipaligned using new SDK v13[/B] [*][B]Android Market updated to latest 3.1.5[/B] [*][B]Adobe Flash Player updated to latest 10.3.186.7[/B] [/LIST] [B]Previous changelog is[/B] [URL="http://tinyurl.com/3wanlaa"][B]here[/B][/URL] [/SIZE]
You need:
- HTC Sensation S-OFF - Guide to S-off, Installing ClockWork, PermRoot, SuperCID & Flashing
- ClockworkMod Recovery 4.0.1.4 from AlphaRev or 5.0.1.0 from ROM Manager
How to flash:
Don't use ROM Manager! Flash ROM following the steps below:
- Download ROM and place it on your SD card
- Download "Super Wipe" script & place it on your SD card (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
- Boot your phone in recovery mode (vol down + power)
- In main menu, select "install zip from sdcard"
- Select "choose zip from sdcard" and browse to the location of "Super Wipe" script
- Once again select "choose zip from sdcard" and browse to the location of Android Revolution ROM
- After flashing process is complete, reboot the device
*** Please do not post any mirrors. We are currently using fast servers, so there is no need for extra mirrors. Thank you! ***
Remember to check MD5 Checksum before flashing !!!
ROM MD5 Checksum: 2DF63181AAA2A6B188169578303A1F8E *Android_Revolution_HD-Sensation_4.1.3.zip
--- Direct link to 6 fast server that will randomly use one of our sources ---
--- With thanks to Mavy170, Whiskey103, MarcoHD, Pili21181, Lizard & Denngie ---
>>> Super Wipe <<<
--- This script will erase and format your data, system and cache partition ---
--- Your SD card will remain untouched FAT32 and it's recommended to leave it like that ---
Android Revolution HD 4.1.3 on DropBox
--- Create your own DropBox account, if you see notification about too much traffic ---
Radio MD5 Checksum: B804DBC6484915C5A710EB630A353F6F *radio.img
With 4.1.x ROMs I strongly recommend flashing 10.58.9035.00U_10.15.9035.02_2 radio
--- Using a "non matched" radio could have a negative effect on performance, battery life & signal strength ---
--- You don't have to flash RIL files for recommended radio. It's already in the ROM ---
--- You would need S-OFF in order to do it properly ---
Radio_10.58.9035.00U_10.15.9035.02_2
--- Don't flash RADIO from ClockworkMod recovery! Extract downloaded file and read the guide inside! ---
Quelle: xda-developers - View Single Post - [ROM] Android Revolution HD 3.6.0 XE | 4.1.0 | High Quality & Performance | Sense3.5
Q 1: After flashing Android Revolution HD my battery drains much faster. What can I do?Q 2: My Premium Navigation doesn't work correctly. What should I do?
A: Please charge your battery to 100%, boot your device in ClockworkMod Recovery and go to Advanced ---> Wipe Battery Stats. Also see Question 7.
Also please read this ---> [GUIDE] Enlarge your battery life : an attempt to fix the battery drain
And this ---> [How to] Brilliant Battery Life 100% working!
For more details about wiping battery stats please read this
A: Your Premium Navigation may not work correctly for many reasons. Most of them are not ROM related. You can try the following things:
- reinstall your Locations under "Settings" ---> "Locations"
- remove /sdcard/.data/navigator/Data/Temporary from your SD card
- re-download Google Maps from the Android Market
- clear data from Google Maps in system software managementQ 3: When recording HD video, the playback of the clip keeps freezing. How to fix it?Q 4: After I reboot my device, mp3 ring-tone is back to default. What should I do?
A: This is probably SD card problem. Format your SD card (FAT32 recommended) to gain silky smooth playback.
A: Go to Ringtones > Menu > More Ringtones > Create new ringtone > Select the one you want (Thanks to kill4l)Q 5: Is there any alternative for SetCPU? I think it slows downy my phone.Q 6: After flashing Android Revolution HD my SD card is being mounted as ready only. What should I do?
A: You can application called No-frills. Remember to check "Allow on boot" option.
A: Connect your SD card to your PC and do defragmentation process. If you still have some problems with SD card, please read this.
Mac users can use the repair function of the MacOS disk utility to solve the read only problem (Thanks to Calimero1205).Q 7: My CPU load is all the time nearly 100% and in most part it's used by system. What is the reason of that high CPU usage and how can I fix it?Q 8: Do I need to wipe data partition when upgrading from old version of Android Revolution HD?
A: Delete your htcsense.com account. It takes A LOT of your battery and CPU usage.
A: I always recommend wiping data partition but it's absolutely necessary only if I mention that in the changelog. But normally you can live without it.
Wipe data partition if you experience any issues.Q 9: I have some strange issues with my ROM that nobody reported before. What should I do in first place?Q 10: I had SetCPU installed on Android Revolution HD, then I flashed new version of AR HD and SetCPU doesn't work any more. How to fix it?
A: In first place you should check, if the MD5 Checksum is correct. Then flash ROM again and see if the issue is gone. A lot of strange issues can be solved this way.
A: Please reinstall SetCPU.Q 11: I can't send/receive MMS or I can't connect with mobile data connection. How can I fix it?Q 12: My phone got random freezes or reboots. How can I fix it?
A: Please check your MMS settings or mobile data connection APN settings.
A: Every CPU is different. It seems that your CPU doesn't like OC or UV (undervolt). Set your CPU to default 1GHz.
If it doesn't help, then you need to flash default kernel from the second post.Q 13: My proximity sensor doesn't seem to work anymore. How can I fix it?Q 14: My GPS signal is very weak or GPS is not working at all. How can I fix it?
A: Please check this thread for further help.
A: There are some solutions:
1. You can download and install FasterFix to improve your signal strength.
2. You can download and install GPS Status & Toolbox to manage your GPS settings.
3. Turn off "Fast boot" under "Settings" ---> "Power" and reboot your phone.
4. Wipe the EFS data in your device. Read this for further instuctions. This is very effective solution.
5. Read this, this and this
6. [Trick] Speed Up Satelite Fix for GPS on AndroidQ 15: My clock/weather widget doesn't show my location. How can I fix it?Q 16: My Quadrant score is not as high as on different ROM. What does it mean?
A: Please clear data from Google Maps, Clock Widget, Weather, HTC weather sync provider and Weather Provider.
A: It means absolutely nothing. Benchmarks on Android System are more or less lottery and they are not showing the real system performance.
There are many settings that can force Quadrant to show more then 3000 points but it's faked performance, that actually can slow down your phone in some circumstances.
What I always emphasize is a real performance, the one you can feel under your fingers. Remember that I/O has some limit and surpassing it shows just a numbers without true ratio.
Also keep in mind that Quadrant has support for Android Gingerbread only in version 1.1.7 and higher.Q 17: I have com.htc.bgc process force close few times a day. How can I fix it?Q 18: My screen-lock sound and keypad sound while dialing numbers is very low. How can I fix it?
A: It's because you have removed HtcTwitter.apk (HTC Twitter application). Please restore it.
A: Download "Quick Settings" application from Android Market and check system volume slider.Q 19: When I open up the call screen (where I see the recent calls and callers), the calls won't appear in the list. What to do?Q 20: What can I do to prevent few seconds call delay Gingerbread issue?
A: Probably you are using 3rd party launcher. Remove the dialer shortcut and re-add it.
A: Install "Call Delay Patch" from the Android Market.Q 21: How can I change VDD level in this ROM?Q 22: My Wi-Fi doesn't reconnect automatically after boot. How to fix it?
A: First of all, custom kernel must support possibility to change VDD level dynamically.
Secondly, you would need -vipermod- binary that is already inculded in my ROM if included kernel supports it.
If it does, you would only need terminal app (I use Android Terminal Emulator) and type:
su
vipermod
Be careful with setting to low or to high VDD. In case of bootloop flash VDD reseting tool.
A: Disable fastboot in settings or check this solution.Q 23: When I listen to music from HTC stock player it accidentally pauses for short time and then keep playing.Q 24: Why my "4G" icon is gone from the status bar?
A: Turn OFF fastboot in settings.
A: My ROMs are based on WWE HTC ROMs. It means that there is no "4G" icon but you have HSPA+ connection with "H" icon anyway.Q 25: How can I enable built it screen-shot feature on Sense 3.0 < based ROMs?.
A: Edit your build.prop file in /sytem and change:
ro.htc.framework.screencapture = false
to
ro.htc.framework.screencapture = true and clear dalvik-cache or install ShootMe from the Android Market.
Credits and thanks goes to:
---- Android Revolution Team: ----
- Bumble-Bee aka Apache14 (Kernels developers & Linux expert)
- Dude360 (Mods developer)
- Euphorie (Site support)
- HyperCriSiS (Beta-tester & Homepage administrator)
- jkoljo (Beta-tester & unlocking Android devices expert)
- Lizard (ROMs hosting)
- lukogriffioen (Beta-tester)
- madmaxx82 (Recovery developer)
- Mavy170 (ROMs hosting)
- Patrics83 (Beta-tester)
- seandk (Beta-tester)
- Whiskey103 (Beta-tester & ROMs hosting)
I also thank to seandk, TWioE, Moe|Joe, jonata, kill4l & MultiCulti for being in the team in the past.
Thanks goes also to themes developers - he_stheone64, Vistagamer, liamstears and kalagas.
---- Others: ----
- faux123 klquicksall for amazing kernel
- Krzysiec for amazing logo graphic projects
- adsamcik, erikstar & KID_1194 for graphic support
- dsixda for his Android Kitchen
- Everyone who made a donation
Donations list
Click here to view
--- Please remember to mention your forum nick-name in the donation ---
