Slassh
Dauer-User
- 354
[*]Features:
- Based on OTA 3.14.401.600 release-keys.
- Android 4.1.1 with Sense UI 4+.
- Multi-language.
- Deodexed & Zipaligned using SDK r20.0.3.
- SuperSU, Busybox.
- Init.d support.
- Memory optimizations.
- Ramdisk tweaks.
- Option to remove apps (AROMA installer).
- Option to install additional mods (AROMA installer).
- Excellent battery life.
- Ultra fast, super clean and rock stable.
Changelog:
Code:
4.2.1
- Added fully working flash player - Thx wsleone.
- Added sysro/sysrw commands support.
- Removed more unnecessary files.
- Updated Nova launcher (desense).
- Updated Twitter.
4.2.0
- Updated gapps to V4.1.2.
- Cleaned updater-script and aroma-config.
- Readded option to disable exchange security (Full ROM only).
- Removed the option to install wakeup by volume keys mod (Full ROM only).
- Fixed bug with not properly oriented icons in camera.
4.1.1
- Fixed permissions and toolbox symlinks.
- Redisabled fast reboot by default.
- Added missing WPS binary.
- Improved full wipe part in updater-script.
4.1.0
- Reoptimized all apks and framework files.
- More free RAM, less battery usage.
- Faster loading of apps, and overall improved performance.
- Fixed and cleaned remove part in AROMA.
- Fixed reboot binary.
- Updated Nova launcher.
- Removed PDF viewer.
- Added option to remove AdAway.
- Aligned numbers in calculator app.
4.0.1
- Fixed battery percent mod.
4.0.0
- Rebased on 3.14.401.600 OTA.
- Complete rebuild from scratch.
- Improved WiFi quality.
- Updated Gmail.
3.1.2
- Fixed lags caused by modified OOM groupings.
3.1.1
- Changed /system mount to RW.
- Updated Google Play Store.
- Updated Dropbox.
- Improved battery life.
- Cleaned build.prop from all placebo effect tweaks.
3.1.0
- Added missing Nova and Apex icons to AROMA installer.
- Changed full wipe so it won't remove games data.
- Readded option to disable exchange security.
- Updated AdAway hosts file.
- Updated Apex launcher (desense).
- Updated Google Street.
- Updated Google Plus.
- Cleaned build.prop.
- Cleaned ramdisk.
- Improved performance.
3.0.0
- Reoptimized all apks and framework files using new png optimization tools.
- ROM is about 30MB lighter.
- Fixed lower benchmark score - please reflash boot.img.
- Removed 'Protected' from software information.
2.8.0
- Reoptimized all apks and framework files using latest SDK.
- Cleaned ramdisk.
2.7.6
- Readded option to install battery percent mod.
2.7.5
- Changed gps.confs ntp_server from north-america to europe.
- Increased MMS size limit.
- Cleaned ramdisk.
2.7.1
- Themed HTC Dialer call button.
- Fixed bootloop problem.
2.7.0
- Added option to disable 3-dot menu - Choose it only if you are using recent button as menu.
- Disabled fast reboot by default.
2.6.5
- Added more language support.
- Readded option to install camera plus mod.
- Readded option to added call recording support.
- Readded option to install lower autobrighntess mod.
- Readded option to install wakeup by volume key mod.
2.6.0
- Added missing device management app.
- Added missing drm plugin binary.
- Updated Google Movies.
- Moved Google Play services to /data and updated it.
- Moved Google Now to /data and updated it.
- Improved performance - should be even smoother now.
2.5.1
- Fixed installation error.
2.5.0
- Removed more debugged files - Clean as release-keys.
- Updated AROMA installer.
- Readded update only option.
- Readded Desense option.
- Readded option to improve multitasking.
- Readded option to force GPU rendering.
- Readded option to disable fast dormancy.
- Readded option to enable OpenVPN support.
- Readded option to enable SQLite support.
- Improved performance and battery life.
2.0.0
- Rebased on 3.09.401.100 OTA.
- Updated AROMA installer to V2.55.
Changes from Beta 1:
- Readded the option to remove apps in AROMA.
- Removed more debugged files.
- Cleaned more parts in ramdisk - Thanks mike1986.
- Disabled scrolling cache.
- Improved memory management.
1.7.0
- Fixed USSD security issue.
- Improved APM icons.
- Fixed and cleaned ramdisk.
1.6.3
- Fixed updater script.
- Updated camera plus mod.
- Updated musicbox mod.
- Updated YouTube.
1.6.2
- Fixed version number.
- Updated Nova launcher (desense only).
- Updated Apex launcher (desense only).
- Updated Google Books.
1.6.1
- Added missing powerhal - fixed & compiled from source - Thanks show-p1984.
- Fixed and cleaned aroma config and updater-script.
1.6.0
- Completely disabled HTC bug reports.
- Cleaned Ramdisk.
- Fixed personalize rotate.
- Updated Facebook.
- Updated Google Maps.
- Updated Adobe Reader.
1.5.0
- Added DeSense option in aroma.
- Added option to install lower autobrighntess mod.
- Enabled landscape mode in personalize.
- Updated Twitter.
1.4.2
- Cleaned AROMA installer.
- Fixed updater-script.
- Other minor changes, updates and fixes.
1.4.1
- Updated Camera Plus mod.
- Fixed Israeli APNs.
1.4.0
- Improved project butter hacks.
- Added option to install lyapota camera mod.
- Updated busybox.
1.3.4
- Added project butter hacks for better performance.
- Improved battery percent icons.
- Updated SoundHound.
1.3.3
- Updated SuperSU.
- Updated Facebook.
- Updated Tunein Radio.
- Fixed and cleaned updater-script and AROMA config.
1.3.2
1.3.1
- Fixed update only option.
1.3.0
- Added 'Update Only' option to AROMA installer - saves and restores all your selections.
- Added option to enable call recording support.
- Fixed and cleaned updater-script.
- Updated MusicBox Mod.
1.2.1
- Added option to install MusicBox - Thx lyapota.
- Added option to enable NFC also on screenoff and lockscreen.
- Other minor changes and fixes.
1.2.0
- Added option to force GPU rendering.
- Added option to tweak minfree values for better multitasking.
- Updated Adobe Flash Player.
- Updated TalkBack.
1.1.5
- Fixed updater-script - now you can install keyborard w/o arrows and wakeup by volume keys mod.
- Added landscape Rosie.
- Updated Facebook.
1.1.3
- Fixed HTC keyborard w/o arrows.
- Fixed HTC keyboard auto completion.
- Updated Dropbox.
1.1.2
- Updated TuneIn Radio.
1.1.1
- Removed the option to install rosie w/ 6X5&7X3 app drawer.
- Updated SuperSU to version 0.95.
- Fixed boot and down animations.
- Fixed local timezone.
1.1.0
- Added option to install semi-transparent statusbar.
- Added option to install rosie w/ 6X5&7X3 app drawer.
- Added option to install keyborard w/o arrows.
- Added option to install wakeup by volume keys mod.
- Updated Dropbox.
1.0.1:
- Fixed Gallery Dropbox FC.
- Updated Google Play Store to V3.8.16.
1.0.0:
- Initial Release.
Download V4.2.1 - Full ROM
Mirror - Android File Host
[Full wipe is not mandatory, but highly recommended!]
MD5:
C7109EDCE41395575C878EA1B91B7F4E
Download boot.img
[13.10.12]
MD5:
6AE90817B57F87CB9EB39FA9B2EA7CE3
MD5:
Download boot.img
[13.10.12]
MD5:
- Installation Instructions:
1. Laden Sie die ROM und legen Sie auf Ihre virtuellen SD-Karte.
2. Relock Ihren Bootloader über HTCDev.
3. Gehen Sie in den fastboot-Modus und geben Sie "fastboot oem rebootRUU '.
4. Flash neue Firmware mit diesem Command: "fastboot Flash zip PJ46IMG.zip 'oder mit Y-Kabel.
5. Reunlock Ihren Bootloader über HTCDev.
6. Flash Custom Recovery mit nur loben: "fastboot Flash Recovery recovery.img '.
7. Laden boot.img und flash es mit dem commend: "fastboot Flash Boot boot.img '.
8. Use 'fastboot erase cache', um Boot-Probleme zu vermeiden.
9. Gehen Sie in die recovery und installieren Sie das ROM.
10. Starten Sie Ihr Gerät an und genießen von JB!
- Firmware Supported CIDs:
cidnum: HTC__001
cidnum: HTC__E11
cidnum: HTC__203
cidnum: HTC__102
cidnum: HTC__405
cidnum: HTC__Y13
cidnum: HTC__A07
cidnum: HTC__304
cidnum: HTC__M27
cidnum: HTC__032
cidnum: HTC__016
cidnum: HTC__J15
Überprüfen Sie Ihre CID mit dem Command: "fastboot oem readcid '.
Wenn Sie ihre CID nicht in der Liste erwähnt ist, können Sie leider die JB-Rom nicht Flashen und müssen erstmal auf ICS bleiben.
Donations list:
- bippolinno X2, jeryx X2, ShyamSasi, amirage, levelone, wsleone, tmotard X2, audaxrandonneur, Dranz, dani_nec, tanwg, salman saso, sirbilbo, sesan, 1immortal, audaxrandonneur, Laurentius26, sphuyal, Champman, scela7.
HTC One X+ piggy bank supporters:
- bippolinno X3, goldragon, martinfs.
I'm grateful for every donation you make.
Thank you very much!
[/QUOTE]Thank you very much!
