starbase64
Ikone
- 6.515
Me and rogro82 started to port Android 4.2 to the HTC One X
Working
- Wireless
- Phone calls
- GSM Data
- Audio
- Video Playback (including HD)
- Camera (no photosphere - blame google)
- GPS
- NFC
- Works with any HBOOT version
- Bluetooth
- BT and Wireless tethering
Not Working
- USB tethering (?)
Installation instructions
- BACKUP YOUR DATA (using CWM)
- Verify that your backup is complete - a backup of your sdcard may also be a good idea (see below)
- Verify that you are running hboot 1.39 or newer (hboot 1.2x may work (please send me feedback) - but any lower hboot version will NOT work for builds after rc13)
- Download the ZIP and the boot.img (see Downloads)
- Copy the .zip to your sdcard and reboot into fastboot
- fastboot flash boot boot.img, then boot into recovery
- WIPE your phone (this is not optional)
- Install the .zip and reboot
Upgrading
You can always upgrade to a newer version without wiping any data, formatting system or wiping the cache.
But keep in mind that you must always flash boot.img + re-flash gapps after upgrading
Changelog
RC16 (20130216)
- Added ro.adb.secure=1 to build.props. The phone will now only accept ADB connections from authenticated hosts. Note that you must upgrade your local ADB installation to the version included in the 4.2.2 SDK. Connecting with an pre-4.2.2 adb will not work
- Fixed quicksettings: longpress = toggle, press = settings
- Internal: Use CMs nicer audio-recording patch
- Upgraded to Android 4.2.2_r1
- Silenced vibrate kernel driver + removed unneeded pm_qos request
- First release with Linux 3.1.10. Note that you MUST upgrade your hboot to 1.3x (1.2 versions may work - any feedback is appreciated, but any version < 1.2 will NOT work - your phone will freeze during deepsleep!)
- Mounting USB-OTG devices on 4.2 is somewhat tricky as filesystems are not shared with 'parent' processes - using some userspace app like 'Nexus Photo Importer' is recommended
- Switched to ondemand govenor as the old 'interactive' is broken in HTCs Linux 3.1.10 source drop (doesn't make a big difference)
- Merged missing cam pull request
- Option to change the max frequency in settings (Developer Options -> CPU Frequency)
- Improved frequency management - say goodbye audio dropouts!
- More camera options (jpeg quality, burst mode, scenes) - thanks to seadersn
- Option to enable the overflow button
- New hardware button mapping profile: press = tasks / longpress = menu
- Support for encrypted /data partition. (see this post)
- Ability to limit the max CPU frequency (see this post)
- Enhanced included Camera App (thanks to herrvorragend23)
- Include SimToolkit
- Option to change the Home + Menu longpress behaviour (Settings -> Display)
- Support for big /data partition. This is experimental, see this post
- Mount /data with '-o discard'
- Added 'volume rocker' support (disabled by default -> settings -> sound)
- Bluetooth Audio (A2DP) is now working
- Stubborn BT devices should now be able to pair
- Fixed WIFI Tethering
- Changed halo background
- Bluetooth Tethering support (still a little bit flaky, try to re-enable bluetooth + tethering if the connection drops)
- Changed quicksettings behaviour: Short press = toggle / Long press = open settings
- Reboot + Screenshot options in Power-Off menu (thanks to lownoise2)
- Support for Bluetooth file transfer and HID (Again: thanks to rogro82)
- AUDIO AND INTERNET SHARING VIA BLUETOOTH ARE CURRENTLY NOT WORKING
- Audio recording fixed (Send your thanks to rogro82)
- Developer-Options enabled by default in Settings
- Display internal + sdcard storage in Settings
- Improved holo-background gardient
- Switching from/to 2G-Data-Only works without reboot
- 'Silent' GSM-Data drop is hopefully gone
- Camera support Install this if the camera icon is missing in your app drawer
- Paid applications can now be installed using Play Store
- Unity engine based games work correctly
- Hboot 1.3x support
- Multitouch fixed
- Based on Android 4.2.1 (December fixed)
- HD-Videos (OMX) working
RC1 (20121126)
- Include Email.apk
- Fix google location service provider (google now / gmaps)
Download links (always flash boot.img!)
Index of /static/android/endeavoru_42/latest/ (Primary host in Germany)
http://android.eqmx.net/android/endeavoru_42/latest/ (Mirror in Sweden)
Index of /xda/HTC_Endeavoru_JB_42/Latest (Mirror in US)
Gapps download
NEW Goo.im Downloads - Downloading gapps-jb-20121212-signed.zip
IRC Channel
Join us at #tg-endeavoru on Freenode irc
FAQ
I can not upgrade my hboot to 1.3x, help!
You can still run RC13:
This was the last release using Linux 2.6 and will therefore work on older hboot versions. RC13 is stable enough for everyday-use.
What kernel should i use?
Use the stock kernel from boot.img - there is nothing wrong with it. Using a different boot.img or/and kernel will just break stuff.
Even more links!
https://github.com/adrian-bl-hox-jb/android
https://plus.google.com/115564237657785223556/posts
