[ROM] OrDroid 3.5.0 | Jelly Bean | Fast & Stable | Battery Friendly | Sense UI 4+
  • 11 Antworten
Nocturne1984
Nocturne1984
Dauer-User
209
  • Based on 1.17.401.1 RUU.
  • Android 4.1.1 with Sense UI 4+.
  • Stock look, no visual changes.
  • Multi-language (WWE).
  • Deodexed, Recompressed & Zipaligned using SDK r21.0.1.
  • Unsecured boot.img.
  • SuperSU, Busybox.
  • Persistent ADB enabled.
  • Init.d scripts support.
  • Sysro/sysrw commands support.
  • Memory optimizations.
  • Ramdisk tweaks.
  • Option to remove apps (AROMA installer).
  • Option to install additional mods (AROMA installer).
  • Excellent battery life.
  • All applications updated to the latest version.
  • Support almost 24 hours a day.
  • ...and many more!
3.5.0
- Rebuilded the ROM from scratch.
- Updated Nova launcher.
- Updated Apex Launcher.
- Updated AdAway hosts file.
3.2.2
- Fixed android.process.acore FC.
3.2.1
- Optimized battery life.
- Fixed and improved camera.
- Updated Google Play Services.
3.2.0
- Reoptimized all apks and framework files using SDK r21.0.1.
- More free RAM, less battery usage.
- Faster loading of apps, and overall improved performance.
- Updated Google Maps.
- Fixed disable exchange security mod.
- Cleaned build.prop.
3.1.1
- Updated Google Plus.
- Updated Apex launcher.
- Added option to remove unneeded keyboards in AROMA.
3.1.0
- Fixed reboot binary.
- Improved APM icons.
- Updated Google Play Store.
- Updated Facebook.
3.0.0
- Rebased on 1.17.401.1.
- Updated Google Now.
- Updated SoundHound.
- Updated Flash Player.
- Fixed bug with sound set.
- All previous mods, tweaks and fixed included.
- Other minor changes and fixes.
2.3.0
- Fixed Advanced Power Menu.
- Updated YouTube.
- Updated Twitter.
2.2.0
- Added Advanced Power Menu.
2.1.2
- Fixed Rosie FC - Only for those who flashed ROM after a full wipe.
2.1.1
- Added Rosie with menu support.
- Updated Facebook.
- Updated Dropbox gallery fix - Thanks lyapota.
2.1.0
- Removed 3-dot menu.
- Remapped recent apps button to menu button.
- Updated Gmail.
- Updated SuperSU.
- Updated Dropbox.
- Updated Facebook.
2.0.0
- Rebased on 1.16.401.6.
- Improved scrolling performance.
- Increase WiFi connection.
- Fixed music player bug in car mode.
- Fixed inaccessible downloaded photos in Twitter.
- Fixed under map view crash.
- Updated Talkback.
- All previous mods, tweaks and fixes are included.
1.1.0:
- Fixed updater-script so it won't format sd card.
- Improved battery life.
- Added few missing apks.
1.0.0:
- Initial Release.
Hier Klicken zum OrDroid-Seite (XDA-Developer)
Achtung die OrDroid CustomROM ist mit den aktuellen OXP EliteKernel # 130116 Kernel kompatibel!
wie lange lauft der Akku bei dir und ist diese ROM gut zu zocken
Ich hatte OrDroid für HOX+ erst heute drauf geflasht, kann deswegen noch nichts dazu sagen zu die Akku. bisher lief die einwandfrei (kein errors) und sehr schnell (smooth) ich kenne OrDroid schon lange ehemals (CoinDroid für HTC Desire und HTC Sensation) ^^
Reaktionen: bubiwutha und 1stPrince
Läuft mit dem Elite Kernel 1300116. ;)
Ist der HTC Music Player standardmäßig dabei, oder habe ich den gestern vor lauter Übermüdung entfernt und erst heute bemerkt? :D
Reaktionen: Nocturne1984
Ich habe mir heute auch das OrDroid 3.5.0 und den EliteKernel1300116 Geflasht bisher Läuft alles super ,wenn nun auch noch der Akku verbrauch besser ist als beim ARHD 6.2 ist ja alles in Butter.
Hallo Nocturne1984,
kannsr du mir die Mail-Adresse von htcdev posten, leider ist mein Englisch nicht so gut. =)
@iShotZombies
Danke dass du mal EliteKernel getestet hast und einwandfrei funzt, habe selber jetzt auch nachinstalliert, da ich bisher nicht getraut hatte, weil was wäre wenn das Handy einfriert und nichts machen kann? da ja man die Akku nicht rausnehmen kann und fest eingebaut ist und hilflos da zu sieht wie die Akku entladen wird aus diesen Grund hatte ich gewartet bis jemand testet und was dazu sagt :)
@Crisspi
E-Mail von HTC Dev? die habe ich leider nicht und außerdem wozu brauchst du die? und ist außerdem OFFTOPIC, weil es geht hier um den Custom ROM von OrDroid!
Also das Rom Läuft 1A und zusammen mit dem Elite Kernel ist die Akkulaufzeit spürbar verbessert worden - ich hab nur ein Problem
Beim Flashen von OrDroid hab ich als Launcher den Nova verwendet - mir fehlt jetzt also Touch Wizard? und ohne diesen kann ich mir keine Displaysperren verknüpfungen anlegen - die ich aber gerne wieder hätte besonders für die Kamera APP
Kann ich Touch Wizard nachträglich noch Installieren?
TouchWiz ist von Samsung.
Ich glaube du meinst Sense. :D
Und nein, ich meine du musst reflashen.
@Topic
Ich glaube die Audioqualität ist schlechter, als die unter Insert Coin, kann das angehen?
Oder meine Kopfhörer geben den Geist auf...
Habe keinen Unterschied Feststellen können an der Audioqualität zwischen InsertCoin, maXimus und orDroid.
äh sorry natürlich Sense - aber beim Flash habe ich es angeklickt Oo ...
Also DeDroid mit dem Elite Kernel ist der Wahnsinn - gestern um 8 Uhr morgens vom Strom genommen und jetzt habe ich immer noch 30% Akku
Nutzung:
100 Gesendete und empfangene Whatsapp nachrichten
Exchange push mit Touchdown - ca 30 mails
20 Min Tel.
BT war die ganze Zeit an
Und sonst das übliche eben - hin und wieder Uhrzeit checken - Updates von App´s ...
Dann sind's wohl meine Kopfhörer.
Danke!
Sh0X31
schinge
schinge
blackline2008
Janta
schinge
LoveHTCdaky
LoveHTCdaky
