[ROM][BETA] TrickDroid 10.0.0 | Jelly Bean | Sense UI 5 | Fast | Battery Life | HQ
  • 1.394 Antworten
torxx
torxx
Enthusiast
1.891
Proudly present you TrickDroid for the HTC One S
This ROM is based on the HTC Europe and works on every One S with S4 processor!
  • Rooted with SuperSU
  • Deodexed
  • Zipaligned
  • UI Optimization
  • Unsecured boot.img
  • Newest BusyBox
  • Excellent battery life
  • GPU UI Rendering
  • RAM Optimization
  • sysro/sysrw permission
  • Better CPU Performance
  • init.d scripts support
  • Improved EXT4 System
  • Removed 3-dot menu by blubbers
  • Removed bloatware
  • Custom Bootanimation
  • 1% stock battery
  • Advanced Power Menu
  • Extended Quick Settings
  • Many other tweaks!
  • Unlocked Bootloader
  • CWM Recovery (or any other which works)
  • Full tutorial
Make sure to use TWRP Recovery or you have to flash the boot.img of the ROM with fastboot in case you use CWM.
  1. Downloade das ROM
  2. Boote in das Recovery
  3. Wipe cache and dalvik cache always (wipe data, wenn ihr von einer anderen Base kommt)
  4. "install zip from sdcard"
  5. "choose zip from sdcard"
  6. Flasht das ROM
  7. Flasht das tweak package nach einem vollen Reboot
  8. Flash das boot.img mit dem Boot_Flash_Script direkt nach der ROM, falls ihr nicht auf dem neusten Kernel seid, sonst kriegt ihr nen Bootlop!
  • Known solutions for cache issues:
  • If you have issues accessing Sense Widgets, just clear HTC Sense data in app settings. Make sure you backup your Desktop in Titanium Backup, before you clear Sense data.
  • If you temporarily loose access to contacts in dialer, reboot in recovery and wipe cache.
Flow-Wolf made a video how to install a ROM with the boot.img, just look here! and you will also find a review of this ROM there!
..You will get latest news of my developement and other stuff on twitter and also download links a few hours earlier than on xda..
Before downloading it would be nice to visit my rootzwiki thread and leave a nice comment and rep there, so you could give me something back with this gesture.- Thanks!
  • j4n87 and everyone who supports him (amazing guy, make sure to give him a donation)
  • Especially he_stheone64, he helped me a lot here, thanks!
  • DroidXAce.- For the banner
  • LeeDroid for being a cool guy
  • Virtuous team (mdeejay especially for the kernel and chrisch for being the first porting APM to the One S)
  • Paul O'brien
  • koush
  • Chainfire
Hitting the thanks button and rating 5 stars would motivate me to continue! So please do the two click's if you download.
A small donation is highly appreciated!
Reaktionen: VegetaJr, Daihogo, Hai96 und 10 andere
Changelog
v4.3
Best build until now
Fixed root issue, finally :D
Fixed car app, finally :D
v4.2
Fixed that they are not all language's
Other fixes
Improvement's in battery
Speed fixes
v4.1
Fixed SuperUser issue
Optimized a bit
Wipe is highly recommended!
v4.0
Based on 1.78
Improved a lot
Removed all visible tweaks and added tweak package
Some graphic fixes
Other basic stuff
v3.1
Fixed everything
Rebased on 1.70
v3.0
he_stheone64 version because of his much appreciated help!!!
Added 1% by he_stheone64
Removed 3-dot menu by he_stheone64
Added APM (advanced power menu) by he_stheone64
Added battery tweaks
Added Wi-Fi / 3G tweaks for better signal
A lot of other stuff!
v2.0
Based on 1.78 Update
Tweaked a lot
Improved battery life :)
other basic stuff like .apk's updating
v1.0
Release
Hoffentlich gefällt euch die Rom.
Reaktionen: gonzo110288, crunchtime85, ukAce und eine weitere Person
Habe auch mal die TrickDroid geflasht.
Hatte voher die Black Dragon von Speedy drauf.
Da fehlte mir der Lockscrenn von HTC, und die Möglichkeit direkt einen Anruf entgegen zunehmen ohne den Lockscrenn zu entsperren.
Habe nun bei dem Mod den Apex-Launcher im Gebrauch und da wird der Lockscrenn entstspechend HTC voreingestellt, Super!
Ansonsten läuft die Rom sehr gut und Engerieeffizient.
Habe dazu die Patches
  • Auto Brightness
  • GPS Fix
installiert, und bin soweit zufrieden, Klasse Arbeit an Alle!!
Ja bei mir läuft die auch sehr flüssig und kann mich echt nicht beklagen, was die Akkulaufzeit angeht. Endlich kann ich auch wieder AdBlock gescheit nutzen ;-)
Genau die zwei Patches habe ich auch nachgezogen..
super rom,nur irgendwiekann ich keines der htc widgets auswählen..
Inwiefern auswählen?
hat sich zwar nach einer neuinstallation erledigt :),aber ich meinte beim zum desktop hinzufügen menü im sense launcher.
Achso okay :) dass hatte bei mir einwandfrei funktioniert ;-) naja zum Glück funktioniert es jetzt wieder.
Hallo, wo kann ich die Version 2.0 herunterladen? Es sollm sie laut eines anderen Forums bereits geben ...
Kommt heute Abend :)
Reaktionen: ukAce
Reaktionen: torxx
Hey super, hatte die v1.0 auch drauf und war völlig zufrieden.
Bin lediglich für das htc-Update auf die 1.78 zurück zur Stock.
Meine Frage, muss ich den Fastboot_Kit trotz Update auch installieren?
Ich denke mal, die boot.img bezieht sich auf die 1.78
Bringt mir das fastboot kit den neuen Kernel wenn ich noch kein Update gemacht habe ?
Also mein English ist nicht der hit
aber so wie ich es verstanden habe hat die Fastboot exe ja was mit dem Boot img zu tun
muss man das wieder umstellen wenn man ein Stock rom Restoren möchte?
Was heißt eigentlich "Removed 3-dot menu"?
Ist jetzt auf dem rechten Soft-Key die Menü Taste?
Oder wurden nur die drei Punkte im Display entfernt?
Beides, 3.0 ist online
Reaktionen: ukAce und askoline
ich habe den v1.0 drauf... wenn ich nach einem wipe usw v2.0 drauf haue, kommt der neue base automatisch mit drauf, wenn man s-off hat??
nein, du musst Fastboot-Kit auf jeden Fall flashen
Man heut ist nicht mein Tag
Das Flahen der 3.0 samt Fastbootkit funktioniert leider nicht
hab nun schon 15 min den Bootscreen und es geht nicht weiter
Reaktionen: haubinho
Klappt hier problemlos. Danke nochmal fürs ROM.
Kann der Autor bitte noch den Titel anpassen?
Gesendet von meinem HTC One S
DonWaJuLi
  • DonWaJuLi
m0nn3
m0nn3
  • s4mb
s4mb
Morphi
steeven
steeven
