[ROM][Android 6 - MM] 13/02 ViperOneM8 5.0.2◦ Tweaks | HUB | Sidebar | OTA
  • 1.891 Antworten
Hast Du vor der 1.4.1 die Version 1.4.0 per OTA oder als Full Rom geflasht?
Ich hab von der 1.3.1 per OTA als Download auf die 1.4.0 geupdated und wegen dem Nav-Problem gleich im Anschluss im TWRP die 1.4.1 hinterher geflasht.
Läuft tadellos und die Venom Navbar ist klasse :thumbup:
Die 1.4.0 hatte einen großen Changelog (Quelle xda):
ViperOneM8 1.4.0 (April 27)
  • Added
    • All Venom apps now observing theme colors
    • Added ability to long press some Native HEQS
    • Increased NEQS limit from 12 to 20
    • Added Tweaks, Hub and Flashlight NEQS titles
    • Added stock navbar customization
      • Ability to toggle Edit/Search navbar buttons
      • Ability to change the button colors
      • Ability to change the glow colors
    • Added Venom Navbar
      • Ability to change the background color
      • Ability to autohide navbar after a specific timeout
      • Ability to setup activation area color/width and height
      • Ability to swipe up to show navbar
      • Ability to touch to hide navbar
      • Ability to touch anywhere to hide navbar
      • Ability to press button to hide navbar
    • Added option for color weather icons
    • Added option for color blinkfeed
    • Added option to hide labels in app drawer and folders
    • Added option to change app drawer actionbar background
    • Added option to use Prism menu icons
    • Added option for Prism menu icon overlay color
    • Added option for menu background
    • Added option for menu text color
    • Added screen on time + wifi time to power usage
    • Added weather animations back
    • Added unlocked native tethering for all carriers (full rom/use at own risk)
  • Fixed
    • NFC icon is now hidden
    • Fixed NEQS icon color and indicator overlay
    • Fixed HTC bug when deleting the last picture in a folder in gallery
    • Fixed default mappings for motion gestures
    • Fixed text size in 5x6 app drawer
    • Fixed app drawer icon size and paddings (custom, icon pack,..)
    • Fixed gallery to crop wide image for scrolling wallpaper
    • Fixed white space in dialer when hiding the native navbar
    • Fixed AT&T VVM (full rom)
  • Updated
    • All keyboards (full rom)
    • All user apps
Reaktionen: kalibri
menfisher schrieb:
Basil hat im xda forum ein update seines dark themes bereits hochgeladen
Kannst du bitte mal den Link zum Black Theme posten? Daaanke
bei mir funktionieren die Motion Gesten zum Aufwecken des Screens nicht, wenn ich den ASOP Lockscreen auswähle. Beim Standardlockscreen funktioniert es. Kann das jemand bestätigen?
Funktioniert bei euch die LED Anzeige wenn Nachrichten reinkommen ?
seid dem update geht die Stock navbar schlecht. Symbole sind weg und handy hängt sich auf. auf vendom settings geht alles :(
Hast du das ota Update hinterher geflasht dort wurde das Problem mit der navbar behoben
@Zino Hab jetzt 1.4.0 noch mal Dirty drüber geflasht, dann ging das Update OTA auf 1.4.1 auch und die Version wird richtig angezeigt.
Die NavBar "glüht" aber immer noch nicht in der richtigen Größe, ist aber nicht so schlimm.
Weiß jemand wie man bei z.B Motion Down einstellt, das man gleich auf den Homescreen kommt?
:thumbup:
Tweaks -> Lock Screen -> Motion Up -> Unlock
wobei du, fals vorhanden, in der Sicherheitssperre landest
Reaktionen: kalibri
So weit weiß ich auch, nur möchte ich auf dem Homescreen landen und nicht einfach nur entsperren
Wenn du nicht den Blinkfeed als Home hast, dann landest du doch nach dem Entsperren auf dem Homescreen, sonst im Blinkfeed.
Oder meinst du etwas anderes?
Also wenn ich Unlock auswähle lande ich in der App, die ich zuvor geöffnet hatte.
Okay, verstehe. Ich befürchte das kann so (noch) nicht eingestellt werden.
bei mir funktioniert die LED-Benachrichtigung einwandfrei (für SMS, E-Mail, Whatsapp)
Bei mir kommt es bei der LED auf die App an: SMS und Facebook z.B. geht, mein E-Mail Programm erst, nachdem ich es in den Einstelungen der App aktiviert habe.
Benutzt eigentlich jemand von euch mit dieser ROM XBlast Tools und funktioniert es? Ich bekomme eine Bootloop.
Also bei mir hängt die Rom seit dem Update auf 1.41 sehr stark und stürzt oft ab. Bei 1.31 hatte ich keinerlei Probleme.
Gesendet von meinem HTC One_M8 mit der Android-Hilfe.de App
@nocturne
Hast du etwas eingestellt ?
Wo stellt man die LED in der App ein ? :-(
Bei mir geht keine Benachrichtigungs LED
Ausser verpasster Anruf
Technoolli
Technoolli
Technoolli
  • begana6
begana6
Technoolli
Technoolli
Technoolli
