[ROM] [UNOFFICIAL] CyanogenMod 10.1 - 4.2.2 - 19-Feb-2013
  • 168 Antworten
DeLuXxE51
DeLuXxE51
| CyanogenMod 10.1 - Android 4.2.2 - Jellybean - Unofficial |
(WILD FOR THE NIGHT RESURRECTED)
CyanogenMod ist eine freie, von der Community gemachte, Aftermarket Firmware Verteilung von Android 4.2.2 (Jelly Bean), der dazu bestimmt ist, die Leistung und Zuverlässigkeit ihres Gerätes zu erhöhen.
Code:
#include
* Your warranty is now void.
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at us for messing up your device, we will laugh at you.
FEATURES
Built from CM source
Service
Text
Data
Calls
Audio
WiFi
Google Now
GPS
MMS
Qualcomm JB libs & firmware
Video playback
Audio playback
Camera
Camcorder
~Bluetooth~
NOT WORKING
3D
EMPFEHLUNG:
Recommended HBOOT : 1.49.1107
S-OFF
Radio : 11.77.3504.00P_11.25.3504.06_M get it from HERE
4ext recovery
Wenn du von einer anderen Rom außer CM10 kommst, dann solltest du wie folgt vorgehen:
1. Wipe data, cache, and system
("wipe all partitions except sdcard" falls 4ext recovery vorhanden)
2. flash neueste Version
3. flash neueste 4.2.2 GAPPS
4. reboot
Wenn du CM10 updaten willst, dann solltest du wie folgt vorgehen:
1. flash neuere Version
2. flash neuste 4.2.2 GAPPS
3. Wipe cache and dalvik-cache
4. reboot
Um Entwickler Option und Performance Einstellungen zu öffnen, unter Einstellungen in über das Telefon klicken und mehrmals auf Build Number klicken.
Thanks to:
Dastin1015 for doing most of the work
Agrabren
Chad Goodman for his awesome skills
Everyone who contributes to CM as this is based on their hard work!
Evervolv Team
ORIGINAL THREAD :[ROM] CyanogenMod 10.1 - WILD FOR THE NIGHT - Feb. 8, 2013 - xda-developers
As you all know Dastin said he couldn't make builds for the shooteru, because he doesn't have enough time, so I'm continuing from where he left out.
CHANGELOG & DOWNLOAD :
| 14 February | :
Kernel: Linux 3.0.64
Cm updates from upstream : here (new feature Automatic backlight adjustments)
DOWNLOAD : Dev-Host - cm-10.1-20130213-UNOFFICIAL-shooteru.zip - The Ultimate Free File Hosting / File Sharing Service MD5: 2421fd573abc8bfd17fe460ad7c0f3e8
| 15 February | :
JellyBean 4.2.2
DOWNLOAD : Dev-Host - cm-10.1-20130215-UNOFFICIAL-shooteru.zip - The Ultimate Free File Hosting / File Sharing Service MD5: 26dc60d586eb67b018729eb4d7752f07
| 19 February | :
Kernel 3.0.65 - compiled with linaro toolchain
Kernel : minMhz to 384, s2w ist als Voreinstellung deaktiviert
( Es kann durch Kernel Turner aktiviert werden )
Optimierungen der Rom
Fm radio ist aktiviert funktioniert aber noch nicht
Neue Features CyanogenMod (HDR Bilder, Advanced Reboot Menu)
gps.conf mit EU Server verbunden für schnelleres gps lock
DOWNLOAD : Dev-Host - cm-10.1-20130219-UNOFFICIAL-shooteru.zip - The Ultimate Free File Hosting / File Sharing Service MD5: 812856f4498e59c681749a274328465c
| 26 February | :
Fixed FC when Camera is opened by Camera button
Kamera macht jetzt Bilder in 16:9
Updated lowmemorykiller as CAF
Disabled adb security for now
Disabled FM Radio (not working)
Added VOIP support (still WIP)
Fixed adb root command
DOWNLOAD : HERE MD5: 353d044164236230fdf0183c54e1be3a
| 3 March |
Kernel : Update to 3.0.67
Updated some mount options, hopefully fixes the bootloop problems
DOWNLOAD : HERE MD5: a9038412dde7b761036590611fa6cdfd
{ 8 March }
Kernel : fixed Bluetooth
New CM superuser included
Camera : fix pinch to zoom
Build.prop : added some decoder settings
DOWNLOAD : HERE MD5: b8b9ab8578d0cd8c058820f742e77483
{ 13 March }
Kernel : 3.0.68
Kernel : Updated VM & SYSCTL values
DOWNLOAD : HERE MD5: c0baa034ef64268b728e9cf5db558458
{ 16 March }
Fix sweep2wake by bug during call, fix by NameLessJedi
Sweep2wake is disable by default, it can be enabled via Kernel Tunner or cmdline
DOWNLOAD : HERE MD5: c99e579214cd42c1255d0d3a31fdd40a
{ 21 March }
Updated touchscreen values
Sweep2wake is enabled by default, it can be disabled via Kernel Tunner or cmdline
Kernel : Patch to 3.0.70
Kernel : Updated ROW scheduler(seems faster)
Kernel : Added Mpdecision from Buttered_toast ( credit Chad Goodman )
Kernel : Added Thermal monitor from Buttered_toast ( credit Chad Goodman )
DOWNLOAD : HERE MD5: cc10da99ec62f59d3d5fe9629f4e9fab
{ 22 March }
Fix VOIP calls
DOWNLOAD : HERE MD5: b6dbcb6e05c4a085fdb460e1f9d62478
27 März
• Neuester CyanogenMod Quellcode hier
• Kernelverbesserung: Verminderte WLAN Spannung
• Kernelverbesserung: Bluetooth und WLAN Problem im DeepSleep(Schlafzustand) behoben
• Neuste Updates ab sofort auch über die Applikation CMUpdater
DOWNLOAD : HERE MD5: 27aa9a84c8cd7c7af8f168077b35bb10
31. März 2013
• Neuester CyanogenMod Quellcode (vom 31. März um 15 Uhr)
• Kernelupdate auf 3.0.71
• Kernelupdate: qdspv6_v2 zu v3 aktualisiert (Multimedia System) "Besserer Klang???"
• Pie Bedienfelder von CyanogenMod hinzugefügt ("qemu.hw.mainkeys" in der build.prop muss auf 0 gesetzt werden [aktiviert die Navigationsfläche])
• Aktualisierte Mediencodecs
• Verminderter Intervall für WLAN-Suche
• VoIP funktioniert nicht vollständig
Download: HIER MD5: 0b00ff54bff7daacb3c798eaa77bdf0a
04 April
• Neuester CyanogenMod Quellcode (vom 03.04.2013 um 23 Uhr)
• Kern mit Linaro Toolchain 2013.03 kompilliert (verbessert die Leistung)
• Kernerneuerung: Entschlüsseler und Verschlüsseler aktualisiert
• Aktualisierte Anzeige (Bessere Videowiedergabe mit wenigeren Fehlern)
• Aktivierte Benachrichtigungs-LED/Batterie-LED Konfiguration in den Systemeinstellungen (Danke an tbalben)
• "Doppeltes Blinken"-Problem gelöst, wenn Handy geladen wurde und eine Benachrichtigung vorhanden war (Danke an tbalben))
DOWNLOAD : HERE MD5: 8257a8ea734cd4e7618ffa89c599174b
10.April
• Aktuellster CyanogenMod Quellcode (vom 10. April um 10 Uhr)
• Kernelupdate auf 3.0.72
• Kernel: SIO IO (Input Output) Scheduler (CPU Resourcenmanager) hinzugefügt
• Kernel: MHL GPIO hinzugefügt
• Kernel: Unterstützung für USB OTG/Host Modus hinzugefügt
• Kernel: iommu zu jb_chocolate aktualisiert
• Kernel: Adreno Treiber aktualisiert
• Kernel: Bluetooth Treiber zu jb_chocolate aktualisiert
• Kernel: Batterie Treiber aktualisiert (im Test)
• Zu audio-legacy Repository (Quelle) gewechselt, Gtlak funktioniert komplett (Audio & Video Anrufe)
• ROM mit cortex-a8 (CPU) Optimierungen erstellt
• NavBar Steuerknöpfe im Framework deaktiviert
DOWNLOAD : HIER MD5: 47ef1c382953bfc367a2c5d01e8e3441
19. April 2013
• Neuester CyanogenMod Quellcode (18. April um 23:00 Uhr)
• Kernelupdate auf 3.0.74
• Kernel: Änderungen vom HTC 2.95 Quellcode (CDMA) (Credits: CG)
• Kernel: Mpdecision: Unterstützung für maximale Display-off Taktung via sysfs (Credits: CG)
• Kernel: Erneuerte vidc Header (Quellcode)
• Kernel: GPU: genlock zu jb-chocolate aktualisiert (Credits: Albinoman887)
• Kernel: Kompilliert mit Linaro GCC 4.7.3-2013.04
• Zurück zu audio-caf Quelle gewechselt, Gtlak funktioniert immer noch komplett (Audio & Video Anrufe) (Credits: Albinoman887)
• display-legacy & media-legacy Quelle gewechselt, Videowiedergabe sollte etwas besser sein (Credits: Arco)
DOWNLOAD : HIER MD5: 3a4f0b39a4ba2204b2c718e13f556796
1. Mai 2013
• Aktueller CyanogenMod Quellcode (30. April um 23 Uhr)
• Kernel aktualisiert auf 3.0.75
• Kernel: Unterstützung für Frandom
• Kernel: Teil-Update von msm_rotator zu jb_chocolate (Credits: arco)
• Kernel: Teil-Update von msm-framebuffer zu jb_chocolate (Credits: arco)
• Kernel: Qualcomm-crypto-engine hinzugefügt (Credits: arco)
• Kernel: Erhöhter L2-Cache (Credits: CG)
• Kernel: Leicht verminderte CPU Spannung
• Kernel: autogroup Scheduler verbessert (Credits: mrg666)
• Videowiedergabe repariert (Wiedergabe & Bildschirmfehler) (Credits: arco)
• Sweep2Wake ist standardmäßig ausgeschaltet (Konfigurierbar mit Kernel Tuner [Play Store])
• Android-Update zu JDQ95E
11. Mai 2013
Aktueller CyanogenMod Quellcode (11. Mai um 12 Uhr)
Kernelupdate zur Version 3.0.77
Swap Unterstützung
Gemini JPEG Engine von VilleC2 aktualisiert (ION Unterstützung)
msm-FB: ION Framework hinzugefügt
Kamera: ION Unterstützung hinzugefügt (PMEM vorerst noch in Verwendung)
Batterie-Treiber-Patch zurückversetzt
ROW Scheduler etwas aktualisiert
Sync Framework hinzugefügt
android binder aktualisiert (Credits: mrg666)
Interactive Gov. aktualisiert und zum Standard gemacht (Credits: mrg666)
Viele Updates von der CAF Liste (Link: http://tinyurl.com/cmtehwy)
Download: HIER MD5: a5d3af6ada668ffb71514a0b6e48f99d
19. Mai 2013
• Aktueller CyanogenMod Quellcode (vom 18. Mai um 23 Uhr)
Kernel:
• Update auf 3.0.78
• Governor Interactive: Update von aosp/kernel/common/android-3.4
• Backport von Android ramconsole von Google 3.4 common Kernel (Credits: mrg666)
• Backport von Android binder von Google 3.4 common Kernel (Credits: mrg666)
• Wiederaufsetzung vom Batterie Treiber Patch
ROM:
• CM Power HAL hinzugefügt
• Hoffentlich keine Bootloops mehr
Download: HIER MD5: 9e0526d0c164598079043cd5552c9075
{ 29 May }
Cm updates from upstream (as of today at 11:00 am ) : here
Kernel:
Updated to 3.0.79
Disable gentle fair sleepers
Add Dynamic read-ahead
Added optimized ARM RWSEM
lib/string: use glibc version(better perfomance)
Backport lowmemorykiller from Google android kernel 3.4 (mrg666)
Kernel compiled with -O2 flag
Kernel compiled with Linaro GCC 4.7-2013.05 (4.7.4)
Full list of commits here : http://tinyurl.com/cmtehwy
DOWNLOAD : HIER MD5: 02eb0c5512cccfa2c6e0826a1b10e835
{ 31 May }
Cm updates from upstream (as of today at 10:00 am ) : here
Fixed force closes
DOWNLOAD : HIER MD5: 48b75e8c6d04597b98fb87889e9704a5
{ 11 Juni }
Kernel:
3.0.80 Update
3.0.81 Update
bcmdhd Treiber zu jb_mr1 Teil-Update
Kernel kompressiert/dekompressiert mit IZO
lowmemorykiller verbessert
Minimale Helligkeit von 30 auf 3 reduziert
dynamic fsync deaktiviert (vielleicht weniger Bootloops und Data-Drops)
RWsem Update
Rückgängig: "block: add REQ_URGENT to request flags"
ROM:
Verbesserte TouchScreen Empfindlichkeit
Automatische Helligkeit verbessert
Download: HIER MD5: c422d9f622ce2fc0951d66e5566b7585
Neueste ROM:
{ 14 July }
  • Cm updates from upstream (as of today at 16:00) : here
    Kernel:
  • cpufreq: Kconfig option to sync scaling across CPU cores(CM Perfomance fix)
  • cpufreq: Retain only online cpus in managed_policy->cpus (mrg666)
  • bluetooth: update to caf msm-jb2.5
  • wakeup: Use irqsave/irqrestore for events_lock
  • sched: unthrottle rt runqueues in __disable_runtime()
    Rom:
  • Fix security issues (from upstream CM)
    If you experience any major problems, do a clean install before reporting it.
    DOWNLOAD : HERE MD5: 9c2070c40f12fa09af653f4276725c70
Nachdem Update müsst ihr unter "Systemeinstellungen" auf "Über das Telefon" gehen und unter "CyanogenMod" den "Überprüfungsintervall" einstellen auf so oft wie ihr eben wollt.
Update Typ müsst ihr auf "Alle Versionen (inkl. Nightlies)" setzen.
(Vielen Dank für die Übersetzung Necktrox ;))
GAPPS for 4.2.2: GAPPS
REPO: https://github.com/johnnyslt/
Quelle: XDA
Reaktionen: Necktrox und surferla
Läuft verdammt gut! Wer auf 3d und Bluetooth verzichten kann, unbedingt mal ausprobieren !!!
Gesendet von meinem Evo 3D GSM mit der Android-Hilfe.de App
Danke, dass du den Thread herbringst. Aber wäre nicht eine Übersetzung hier im deutschen Forum besser am Platz :/ ?
Reaktionen: Nimrod
Ist die Akkulaufzeit hier auch so unterdurchschnittlich wie beim Rest der JB-Roms?
War das k.o.Kriterium bei bisher allen JB-Roms, die ich getestet habe :crying:
Hab sie jetzt auch drauf. Erster Eindruck sehr gut.
Zur akkulaufzeit kann ich dir dann morgen mehr verraten.
Reaktionen: Moritzinho
Das wichtigste ist jetzt auf deutsch ;)
was muß ich denn machen wenn ich dieViper3D instaliert habe ? so einfach bekomme ich sie nicht auf mein evo drauf ....bleibt bei der instalation hängen ... wollte auch die CyanogenMod 10.1 gern mal testen ... danke im voraus:unsure:
Full Wipe und dannach normal flashen sollte funktionieren.
surferla schrieb:
was muß ich denn machen wenn ich die Viper3D instaliert habe ? so einfach bekomme ich sie nicht auf mein evo drauf ....bleibt bei der instalation hängen ... wollte auch die CyanogenMod 10.1 gern mal testen ... danke im voraus:unsure:
Bitte lass doch diese grässliche Farbe weg. ;)
Du brauchst S-OFF und das 1.49er HBoot.
@ Nimrod: Kannst du schon was zur Akkulaufzeit sagen? Bisher hatte der Vorgänger "Wild for the night" die mit Abstand schlechteste Akkulaufzeit - das Telefon ist kaum in Deep Sleep gekommen.
Überhaupt haben alle JB Roms eine ziemlich geringe Reichweite; meinem Empfinden nach hat sich das auch nochmal von 4.1.2 auf 4.2.x verschlechtert.
Also ich kann nur von der Erfahrung meines alten Evos bzw vom Evo meiner Freundin sagen das die Akkulaufzeit im Schnitt auf 1-1,5 Tage kommt, bei ein paar SMS, Whatsapp, Telefonieren (15min ca) und Gmail Sync sowie ab und an mal surfen und Facebook per App (2G+3G + WLAN an (uni und zuhaus))
Stock kernel, soweit alles in Ordnung bis auf Bluetooth eben...
Akkulaufzeit ist nach bisheriger Einschätzung "okay", also nicht unterirdisch schlecht.
Für eine genauere Einschätzung braucht es noch ein paar Tage ;)
RYoUKdIvpsa9VN+c7K+rovUQ7SNGjBhxI7Jx+j9vrHXg968VUQAAAABJRU5ErkJggg==
Kann ich so bestätigen. Deep sleep funzt übrigens.
wie bekomme ich das 1.49er HBoot aufs handy ohne pc ? oder geht das garnicht ?:sad:
Naja, mit einem Datei Explorer und meiner PG86IMG.zip aus der Signatur könnte es gehen.
Downloaden, ins Root-Verzeichnis der SD-Karte verschieben (aus dem Download Ordner). Und das Smartphone in den Bootloader booten. Update machen und schon hast du 1.49.0007
Reaktionen: surferla
Auf XDA ist eine neuere Version von 03.03.2013, kann mir jemand über diese berichten (Akku laufzeit, welche Kernel darauf passen usw) ? :cool2:
Akkulaufzeit geht so einigermaßen, im Schnitt knapp 1 Tag bei geringer Nutzung. Meiner Erfahrung nach typisch für eine ROM ab 4.1.x.
Kernel habe ich nur den von Anryl getestet, der geht auch geht, allerdings musst zur Wiederherstellung die libvoenc (o.ä.) ausgetauscht werden. Das steht aber im Thread von Anryl auf xda.
bei mir geht aber die kamera garnicht ....
Seit dem update vom 08.März ist die Akku Laufzeit deutlich besser geworden !
Das muss ich doch gleich mal überprüfen. :)
exkcir
Rainman013
mister-mo95
mister-mo95
