[ROM] [UNOFFICIAL] CyanogenMod 10.1 - 4.2.2 - 19-Feb-2013
  • 168 Antworten
Das ist mir schon bewusst. Ich meine andere wie buttertoast oder arnyl oder so
Es gibt ein Buttertoast Build ohne Aroma. Diese sollten gehen (Bluetooth könnte vielleicht nicht gehen).
{ 30 June }
  • Cm updates from upstream (as of today at 12:00) : here
    Kernel:
  • ashmem: avoid deadlock between read and mmap calls
  • move ashmem.c to drivers/staging/android
  • Patch: Linux Kernel to 3.0.84
  • block: row-iosched idling triggered by readahead pages
  • mm: pass readahead info down to the i/o scheduler
  • Reduced Android Logger RAM usage
  • lib: avoid ICE on Linaro
  • sched: fix OOPS when build_sched_domains percpu allocation fails
  • scheduler: minor improvement to pick_next_highest_task_rt
  • ksm: apply tweak
  • timer: optimize apply_slack
  • sched_fair: Improve the -> group_imb logic
  • mmc: core: Fix possbile memory leak Fix possible memory leak detected by kmemleak:
  • AIO: Don't plug the I/O queue in do_io_submit()
  • ARM: decompressor: Enable unaligned memory access for v6 and above
  • msm: audio: qdsp6v3: Add size safety check to ACDB driver
    Rom:
  • Fix FCs when unistalling a app
  • Fix HOME button wake when sweep2wake was ON
  • Tweaked a bit autobrightness levels
  • Fix default notification LED color
  • Fix FCs in Setting>Storage
    If you experience any major problems, do a clean install before reporting it.
    DOWNLOAD : HERE MD5: 67c30c8c29d312857e454f73c1464533
{ 06 July }
  • Cm updates from upstream (as of last night at 01:00) : here
    Kernel:
  • shooteru: enable CGROUP_TIMER_SLACK
  • cgroups: introduce timer slack controller
  • ARM: 7173/1: Add optimised swahb32() byteswap helper for v6 and above ARMv6
  • sched: Clean up parameter passing of proc_sched_autogroup_set_nice()
  • shooteru: enable sched_autogroup
  • kernel: power: update from jb_chocolate (mrg666)
  • Patch: Linux Kernel to 3.0.85
  • ARM: decompressor: use better output sections
  • net: wireless: bcmdhd: Fix PEAP with dynamic WEP
  • Reduce WIFI wakelocks?
  • Revert "undervolt wifi card"
  • backport mach-msm/idle_stats_device.c from codeaurora msm-3.4
  • workqueue: backport from aosp-common/3.4 kernel
    DOWNLOAD : HERE MD5: 5b2fbd11bca098690464520dfd57b58f
{ 14 July }
  • Cm updates from upstream (as of today at 16:00) : here
    Kernel:
  • cpufreq: Kconfig option to sync scaling across CPU cores(CM Perfomance fix)
  • cpufreq: Retain only online cpus in managed_policy->cpus (mrg666)
  • bluetooth: update to caf msm-jb2.5
  • wakeup: Use irqsave/irqrestore for events_lock
  • sched: unthrottle rt runqueues in __disable_runtime()
    Rom:
  • Fix security issues (from upstream CM)
    DOWNLOAD : HERE MD5: 9c2070c40f12fa09af653f4276725c70
Hat einer auch das Problem,das sich die Mobile Daten garnicht aktiviert sobald man irgendwo hinfährt ? Bzw ich muss immer in den Kurzeinstellungen die Datenverbindung ausschalten und wieder einschalten damit ich mobiles internet habe....das ist echt nervig..Hat da einer ne lösung ? Ich nutze eine 4 Jahre alte Vodafone Pre Paid Simkarte,da lade ich jeden monat die Internetflat drauf....
{ 25 July }
    Kernel:
  • Patch: Linux Kernel to 3.0.87
  • implement JOE'S RCU
  • cpuidle: backport driver from 3.1
  • workqueue: backport from Linux 3.6.11
  • lib/lzo: huge LZO decompression speedup on ARM by using unaligned access
  • block: row: change hrtimer_cancel to hrtimer_try_to_cancel
  • Revert CGROUP_TIMER_SLACK commits ( battery drain )
  • Patch: Linux Kernel to 3.0.86
    Rom:
  • Includes new app VoicePlus
    DOWNLOAD : HERE MD5: 27c9d984bb2e3e59e1916480372a10aa
Mittlerweile ist ja das Update vom 05.08 da. Läuft bei mir gut, bis auf ein kleines Problem, das ich seid CM habe.
Mein Business Calendar macht Probleme, habe da im Bereich [OFFURL="https://www.android-hilfe.de/kalender-apps/457427-business-calendar-vergisst-lokale-kalender.html"]Kalender Apps[/OFFURL] mal ein Thema eröffnet, ich will das mal hier erwähnen, vielleicht hilft das ja. :smile:
Wo finde ich das update? :/
Bei mir startet die Rom alle 20-30 min das Evo komplett neu. Jemand ne Idee woran das liegen könnte?
Habe HBoot: 1.49.0007 und S-OFF
Welche Firmware? Also was steht in deinem Bootloader oben?
Gesendet von meinem Nexus 4
Meint ihr ich tue mir hiermit einen gefallen, wenn ich viel Wert auf Stabilität lege?
Naja als ich mein Evo noch hatte, da hatte ich Monatelang Slimbean drauf und hatte keine Probleme. Scheint auch so, als hätte man die längste Akkulaufzeit auf Slimbean (natürlich ist sie besser auf Sense 3.6 Roms)
Also stabil läuft es bei mir, deshalb kann ich es empfehlen. Das einzige Problem was ich habe ist der Business Calendar, habe ein paar Beiträge früher von geschrieben.
Ich werde aber heute wahrscheinlich mal das 10.2 testen.
Da mein Problem mit dem Kalender höchst wahrscheinlich mit dem Play Store zusammen hängt, mal noch eine Überlegung. Ist das möglich die neuesten GAPPS, also die für 4.3 hierauf zu installieren?
Bisher nur ein Absturz, das finde ich noch akzeptabel. Habe allerdings auch die Probleme mit dem ruckelnden/flackernden Google Maps.
Aktuell ist jetzt die Version vom 13.08.
Die GAPPS sind auch im XDA Thema in einer neueren Version.
GAPPS for 4.2.2 12.08.2013
Hallo
nachdem mein EVO reibungslos mit CM 10.1 lief - nach dieser Anleitung gerootet und S-Off gestellt- hatte ich einen Hardwareschaden. Nachdem ich es aus der Reparatur wiederbekommen habe, war zwar noch CM 10.1 drauf, es hängt jedoch in der Bootschleife. HTC hat im Reparaturauftrag geschrieben, dass eine neue SW aufgespielt wurde. - Habe ich jedoch nicht festgestellt.
Zuvor habe ich selbst noch den Fehler gemacht, die Rommanager Recovery 5.0.2.0 zu flaschen. Nun kriege ich beim flashen der alten 4ext recovery folgende Meldung:
Sending recovery ..... okay
Writing Recovery .... . Failed < remote not allowed >
Im Bootloader steht
**** Locked ****
sHOOTER_u put ship s-off rl
Hboot 149.007
emmc boot
Jul 12 2011, 15:29:51 (Version aus der Signatur von Necktrox)
Hat jemand eine Idee, wie ich mein Evo wieder zum Laufen kriege.
Der Bootloader muss entsperrt sein damit du eine Custom-Recovery flashen kannst. Mit einer Modifizierten HBOOT Version braucht man auch keinen Unlock, du hast aber das Stock-HBOOT drauf. Mit einer .zip kann man, wenn man S-OFF hat den Bootloader wieder auf Locked stellen.
Reaktionen: volli18
Habe das Problem gestern abend selber noch gelöst.
Bootloader habe ich entsperrt und alles geht wieder.
Im Bootloader steht jetzt Unlocked, aber was soll`s.
Ist es ratsam den Bootloader wieder auf Locked zu setzen - mit Necktrocks Signatur- ?
Root und S-off hatten die nicht angerührt.
Faruk.O vielen Dank für die schnelle Anwort.
