derRobin
Dauer-User
- 463
LeeDroid schrieb:
Presenting LeeDrOiD 3D
S-Off & a Custom recovery required
Huge thanks to Alpharevx+unrevoked for acheving S-Off
Android 2.3.4 - GingerBread & Sense 3.0... No gimmick's, no bullshit..
Just a Sensational Android experience from a very experienced developer
With thanks to: ChainsDD l snq- l Scar45 | Baadnwz | damo | Team RC | m-deejay | klquicksall | Alpharevx & Unrevoked | rmk40 | SteelH | Breinholst | j4n87 | daniels7 | Prateek | Scabes | ShowP-1984
Huge thanks to j4n87 & daniels7 for the creation of LeeDrOiD Tweaks
Official Support Links:
» Chat live now or join #LeeDrOiD-Roms on Freenode (irc.handhelds.org)
What you get!
- Bases on official HTC Shooteru RUU 1.20.401.2
- LeeDrOiD Shooter V5.4
- Max OC 1.89GHz! (Standard config 1.51GHz)*
- Adjusted CPU_VDD range 700mV_Min - 1400mV_Max (adjustable via system tuner)*
- SmartassV2 CPU governor as default (384Mhz-1512MHz)
- CIFS & OpenVPN Support
- Masses of cleanups additions & changes see My GitHub for the full change log!
- LeeDrOiD Tweaks V4.0.1 (Thanks to the Awsome j4n87 & daniels7)
- For a full list of "LeeDrOiD Tweaks" features visit j4n87 & daniels7 HERE
- Recompressed & ZipAligned entire ROM
- Rooted with the latest Superuser & binary
- Added init.d support
- Added Bash & Nano support
- Added Busybox
- Added Adreno220 GPU configuration
- Added zipalign on boot
- Lots of default config changes & cleanups
- Battery life improvments
- Added battery recalibration script
- Added ext4 filesystem tuneups
- Lots of speed tweaks and tuneups
- SD Card transfer speeds increased
- Added more agressive low menory killer config (home eliminated)
- Added advanced power menu
- Fixed keyboard open/close animations
- Added signature check hack (RC Team)
- Added CRT Screen on/off animation
- Added super extended quick settings pulldown
- Added transparent notif pulldown
- Added stock % battery
- Removed SurfaceFlinger alpha channel limitation
- Forced GPI UI Rendering
- Increased UI animation speeds
- Added FlyIn Animations as default
- Enabled 3D home toggle in settings
- Exposed additional browser settings & up to 15 tabs
- Added Backuip/restore & secure box to MMS/SMS
- Added beats audio mod
- Enables HDR, Panorama & Zoom in camera
- Added huge custom locales list
- OpenVPN Support - Tun included in the stock kernel
- Enabled larger MMS sizes
- Updated Android Market V3.1.3
- Added Stock Gingerbread keyboard
- Added screen calibration
- Added Spare parts with fixed battery history
- Added Rom Manager (ShooterU not fully supported yet)
- Added Titanium Backup
- Added ES File explorer
- Added AdFree & Updated Hosts
- Added Optional Launcher2
- Added Jbed
- All preinstalled apps updated
- Added LeeDrOiD Bios Bootanimation (needs a few tweaks)
- Removed - Bloat
- Custom LeeDrOiD Locales & Language support
- Supported Languages: English, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Korean, Greek, Turkish, Swedish, Danish, Portuguese, Finnish, Thai, Korean, Vietnamese, Chinese, Japanese, Portuguese, Croatian & More
- Too much to list - see the change logs
Final- Change Log
LeeDrOiD_3D_V5.4 2nd April FINAL GB ROM
Included LeeDrOiD_Shooter Kernel_V5.4 2nd April - FINAL GB KERNEL
- Full Kernel change log >>> HERE @GitHub <<<
- Added dynamic LED brightness
- Unlimited notifacation LED duration
- Lowered LED Voltages to save more power
- Fixed Camera/screen color inversion issues
- Enabled USB OTG support
- Rebase - removed fb:display changes (not required)
- Updated 2 Phase ondemand from Pyramin 3.0 source
- GPU OC code & scaling cleaned up and reworked
- Zero memory and more efficiency in mm/percpu.c:
cpu_mem_alloc()
- fs: lower vfs_cache_pressure 100->25
- Updated LagFree Governor
- lower instantaneous bandwidth demand to save more battery in MSM/Devices
- Tripple buffering in Display and HDMI
- More config/code cleanups
- JOES RCU Backported from 2.6.38
- More Power managment updates
- DMA updates via CAF
- SMD updates via CAF
- Video enc/dec updates via CAF
- Numerous sched updates to improve performance
- Fixed proximity/light sensor wake identified in previous test kernel
- Re enabled MSM idle stats
- Enabled large TCP initial buffer
- Disabled "No Suspend"
- Accelerate last non-dyntick-idle CPU's grace periods
- Default MIN CPU Speed dropped to 192Mhz
- use the git implementation of SHA-1
- Improved boot times
- CRC32 updates via CAF
- SCM Fixups via CAF
- Deep sleep fixed
- Compass fixed
- ------------Rom Changes---------------
- Added Aroma installer!! Huge thanks to Amarullz
- All items marked with * are optional and selectable on install
- *Optional Orange UK Signal boost/WiFi calling selectable in Aroma
- *Optional X Loud Audio Engine (thanks to Nutzy & XxXPachaXxX)
- *Optional Stock HTC keyboard
- *Optional Remove Dancing droid
- *Optional stock HTC Camera
- *Optional HTC No Beats htc music app
- *Optional RTL Language pack
- *Optional AGPS fix thanks to crypted
- *Optional stock HTC boot animations
- *Optional boot sound removal
- *Option to remove HTC Locations, Stocks, Flickr & Watch
- *Optional HTC Sense removal option
- *Optional Samsung EGL Drivers
- Removed "Amaze" from the camera, mirror and album name strings
- Fixed system tuner init.d settings (System left RW until boot complete)
- Removed useless battery calibration script
- Fixed Keyboard with arrows size issues
- Updated Market to Google Play store
- Enabled 20 tabs in browser
- Enabled UBS storage (OTG) in settings
- Added additional info to "About"
- Included spiderman, NFS Shift & Sims 3 stock lib's
- Brand new Tweaks UI - Huge thanks to J4n87!!
- Reworked ScrollingCache code (100% Disabled)
- Several system cleanups & misc tweaks
- Default wallpaper corrected
- All pre-installed applications updated
- System Recompressed & ZipAligned
- Improved overall Speed & Stability
OLD - Change Logs
Code:[B]LeeDrOiD_Shooter Kernel_V5.3.8 11thMarch - FINAL [/B] Full change log [B][URL="https://github.com/LeeDroid-/Shooter-2.6.35-MR/commits/master"]>>> HERE @GitHub <<<[/URL][/B] [LIST] [*]Tweaked and tuned 2PhaseOnDemand governor as default (Modified to save power) [*]GPU OC code & scaling cleaned up and reworked [*]Zero memory and more efficiency in mm/percpu.c::pcpu_mem_alloc() [*]fs: lower vfs_cache_pressure 100->25 [*]Updated LagFree Governor [*]lower instantaneous bandwidth demand to save more battery in MSM/Devices [*]Tripple buffering in Display and HDMI [*]More config/code cleanups [/LIST] [B]LeeDrOiD_Shooter Kernel_V5.3.5 2nd March[/B] Full change log [B][URL="https://github.com/LeeDroid-/Shooter-2.6.35-MR/commits/master"]>>> HERE @GitHub <<<[/URL][/B] [LIST] [*]2PhaseOnDemand governor as default (Modified to save power) [*]JOES RCU Backported from 2.6.38 [*]GPU OC code & scaling cleaned up [*]CFS Sched autogroup V2 [*]More Power managment updates [*]DMA updates via CAF [*]SMD updates via CAF [*]Video enc/dec updates via CAF [*]Numerous sched updates to improve performance [*]Fixed proximity/light sensor wake identified in previous test kernel [/LIST] [B]LeeDrOiD_Shooter Kernel_V5.3.2 24th February[/B] Full change log [B][URL="https://github.com/LeeDroid-/Shooter-2.6.35-MR/commits/master"]>>> HERE @GitHub <<<[/URL][/B] [LIST] [*]Interactive governor as default [*]Max OC 1.89GHz (CPU0 only - CPU1 max 1.51GHz) [*]GPU OC [*]Fixed headset controls [*]Reduced power consumption [*]New ACPU table [*]Both CPU's undervolted [*]Reduced screen power consumption [*]RPC, Marimba & Pmem updates from Ruby source [*]File system improvments [*]Wireless improvments [*]I have kept the changelog brief.. look at gitgub an you swill see why ;) [/LIST] [B]LeeDrOiD_Shooter Kernel_V4.2.1 16th February[/B] Full change log [B][URL="https://github.com/LeeDroid-/Shooter-2.6.35-MR/commits/master"]>>> HERE @GitHub <<<[/URL][/B] [LIST] [*]Default IO sched VR [*]Re enabled MSM idle stats [*]Enabled large TCP initial buffer [*]Disabled "No Suspend" [*]Accelerate last non-dyntick-idle CPU's grace periods [*]Enabled RCU Fast No HZ [*]Default MIN CPU Speed dropped to 192Mhz [*]use the git implementation of SHA-1 [*]Improved boot times [*]CRC32 updates via CAF [*]DMA Fixups via CAF [*]SCM Fixups via CAF [*]Deep sleep fixed [*]Fixed Pounty mod compatability again :rolleyes: [/LIST] [B]LeeDrOiD_Shooter Kernel_V4.1.0 15th February[/B] - Changelog V3.8.0 > V4.1.0 Full change log [B][URL="https://github.com/LeeDroid-/Shooter-2.6.35-MR/commits/master"]>>> HERE @GitHub <<<[/URL][/B] [LIST] [*]Reworked ACPU table [*]Reworked CPU voltages [*]Increased CPU 1 max speeds [*]Lowered WiFi voltages [*]Lowered virtual key voltages (20mV > 2mV ) [*]Increased GPU 3D Max clock speed [*]Tuned Interactive & Ondemand governors [*]mmc: core: Prevent too long response times for suspend [*]Reset cpufreq permissions [*]thermal: tsens: Add suspend/resume [*]printk: Don't allow cpu to get console lock during hotplugging [*]Battery/Charging driver updates from HTC Ruby source [*]Fixed Ponury Gesture compatability [*]Fixed Compass & G Sensor [*]More configuration cleanups [/LIST] [B]LeeDrOiD_3D_V5.3.0 14th February[/B] [LIST] [*]LeeDrOiD Shooter Kernel V3.8.0 - 2.6.35.14 [*]Automated process group scheduling (CONFIG_SCHED_AUTOGROUP) [*]CPU-based alignment handling [*]Disabled lots of debugging routines [*]Disabled Kmemleak detector [*]Disabled numerous tracers [*]Kernel should be more efficient [*]Random reboots fixed [*]Screen wake on incoming call fixed (Tested several times) [*]Disabled Scrolling Cache (Smooter UI) [*]Improved HUGE locales (Languages) [*]Removed final HTC/Google usage loggers (libs) [*]Removed htc_edblogd [*]Recompressed & Zipaligned entire system [*]All pre-installed applications updated [*]Improved stability [*]Improved battery life (Please recalibrate) [*]Improved speed [/LIST] [B] LeeDrOiD_3D_V5.2.1 25th January [/B] [LIST] [*]Added LeeDrOiD Tweaks V4.0.1! (Thanks to the Awsome j4n87 & daniels7) [*]For a full list of [URL="http://forum.xda-developers.com/showthread.php?t=1334871"]"LeeDrOiD Tweaks" features visit j4n87 & daniels7 HERE[/URL] [*]Enabled Beats audio via Speaker out [*][B]LeeDrOiD_3D_V5.2.0 - 25th January[/B] [*]New Kernel - LeeDrOiD Shooter V3.6.0 - 2.6.35.14* [*]Tuned LagFree Governor* [*]Enabled Advanced Power Management Emulation* [*]Timpani codec updates (CAF)* [*]Fixed MHL to HDMI [*]And lots more! [*]For the full kernel change-log, visit [url]https://github.com/LeeDroid-/Shooter-2.6.35-MR[/url] [*]Beats audio 100% Fixed! [*]Thermald deamon thresholds reworked (Thanks to dmih for the info) [*]Fixed CPU FREQ Skipping to max freq [*]Random reboots 100% Fixed! [*]Fixed black screen on incoming call (I Hope:) ) [*]Fixed sysctl [*]Browser & connectivity optimizations [*]Updated Google Maps V6.1.1 [*]Updated Google Quick search [*]Updated Twitter [*]Upodated Rom Manager [*]Re-added CIFS Manager [/LIST] [B]LeeDrOiD_3D_V5.1.0 [/B] - 9th January [LIST] * = Kernel [*]New Kernel - LeeDrOiD Shooter V3.5.0 - 2.6.35.14* [*]Updated audio drivers from muliple sources (Chad.Goodman, HTC(Rezound) & Faux123) [*]Add a new API - pm8901_preload_dVdd - CAF (reduced voltage fluctuations @boot time)* [*]Adjusted voltage constraints 700mV > 1450mV* [*]Increased GPU Memory allocation [*]Tuned interactive governor (Some more)* [*]Interactive governor set as default* [*]Reverted PM Wakelock patch (black screen on incoming call should be fixed, testing required)* [*]Additional minor config changes * [*]overall speed @ stability increased as a result of the above changes* [*]Allow flashlight to operate @ %10 power* [*]Tweaked RSSI thresholds for longer range WiFi (98dB min)* [*]Lowered voltages for timpani and eMMC (Author - faux123, Cherry-picked from Show-p1984)* [*]Adjust read ahead buffer (increased min & max)* [*]cpufreq: interactive: fix possible Division by zero.* [*]Removed all CIQ(Chad.Goodman)* [*]lots of code cleanups* [*]Lots of CPU code updates & fixups [*]Added LagFree Governor (Thanks to Ziggy) [*]Modified mpdecision for full dual core support! [*]Fixed stutters in audio playback [*]Added Beats audio! (Music options - HTC Sound Enhancer or Beats Audio) [*]Added Beats Notify [*]Audio/Beats configuration files from RunnyMede ICS [*]Added LeeDrOiD Tweaks V4! (Thanks to the Awsome j4n87 & daniels7) [url=http://forum.xda-developers.com/showthread.php?t=1334871][Poll added - pls vote] Leedroid Tweaks GSM v4.0.1 - EVEN MORE PURE AWESOMENESS! - xda-developers[/url] [*]-New awesome UI by daniels7 [*]-Autosync quicksetting [*]-Reworked recent apps toggle: If activated it is shown always, if deactivated still toggable by longpress [*]-Miui Batterybar with different height color [*]-Show/hide battery, show battery text with dynamic colors [*]-Color picker for clock [*]-Toggle am/pm [*]-Signal Tweaks: 6 different static colors for wifi/signal bars/data, 2 DYNAMIC color sets for wifi/signal bars, hide data/signal bars [*]-Menu unlock works now with sense lockscreen! [*]-Show/hide date in notification pulldown, toggle to center it, toggle to show clock instead of date!! [*]-Toggle items on lockscreen on/off (carrier/clock/date) [*]-Included ics animations [*]-Reworked autobrighnes values [*]-screen on quicksetting longpress works now [*]-fixed empty statusbartext on initial install [*]-wrong text when disconnecting usb storage [*]And lots more! [/LIST] [B]LeeDrOiD_3D_V5.0.0 1st January 2012![/B] [LIST] * = Kernel [*]New Kernel - LeeDrOiD Shooter V3.2.0 - 2.6.35.14 [*]Removed CIQ* [*]Added BCM bluetooth "Low power mode" (Ziggy & Chad.Goodman)* [*]Lots of compression updates & Fixes* [*]Optimized build passing -02's* [*]Added CleanCache* [*]sched_fair: lower granularity* [*]FIX: irq_time - CAF* [*]Reworked ACPU Table* [*]Cleaner CPU Freq scaling* [*]Max OC 1.94GHz! (Standard config 1.51GHz)* [*]Adjusted CPU_VDD range 700mV_Min - 1400mV_Max (adjustable via system tuner)* [*]Tuned Smartass governor for new ACPU Table* [*]Fixed ext4 disk write performance regression* [*]Lots of config & Debugging cleanups* [*]CIFS & TUN Modules are now built in [*]All new Bootanimation for 2012 (Hope you dont miss the Bios :D ) [*]Removed Notes & Dice [*]Reworked tweaks scripts [*]Caches cleaned @Boot [*]SQlite3 database vacum @Boot [*]Force pm SetInstallLocation = 1 @Boot [*]Fixed HTC IME (Arrows in all modes) [*]CPU Freq stats mBuffer increased 256 > 1024bytes [*]Incresed MAX_SPEEDS = 20 > 100 (New CPU table has 56 freqs!) [*]Fixed DRM Engine & HTC Watch [*]Reworked low memory killer levels [*]Dalvik VM Tuneups & JIT [*]Removed remaining HTC Loggers [*]Added lots of additional locales/language options [*]Improved battry life! [*]Huge XML & System Cleanups [*]Updated AdFree Hosts [*]Updated SuperUser & Binary [*]Android Market V3.4.4 [*]All pre-installed applications updated [/LIST] [B]LeeDrOiD_3D_V4.0.0 [/B] [LIST] [*]Integrated LeeDrOiD Tweaks V3.0.1 (Thanks to the Awsome j4n87 & daniels7) [*]For a full list of [URL="http://forum.xda-developers.com/showthread.php?t=1334871"]"LeeDrOiD Tweaks" features visit j4n87 & daniels7 HERE[/URL] [*]Several "LeeDrOiD Tweaks" Rom specific tweaks [*]Additional audio enhancments (Partial Beats - Headphones only.. More to follow!) [*]Fixed single audio channel issue [*]HTC IME (Keyboard) with arrows [*]New Fancy IME in/out Animation [*]Added Amaze Cam 1920x1080 V0.11 (thanks to bio) [*]Implemented permissions Script (Perms fixed at boot time) [*]Added Transparent App Drawer & Personalize menu [*]Reverted to FlyIn Transition Animations [*]Entiresystem recomressed & Zipaligned for optimal performance [*]All Pre installed applications updated [*]Added Android Market V3.4.4 [*]And lots more! [/LIST] [SIZE="1"] [B]LeeDrOiD_3D_V3.0.0 - 8th December 2011[/B] [LIST] [*]New Kernel LeeDrOiD Shooter V3.0.0 [*][URL="https://github.com/LeeDroid-/Shooter-2.6.35-MR/commits/master"]Changelog - GIT[/URL] [*]Reworked and cleaned up ACPU Table [*]Default governor Ondemand @ 384MHz-1512MHz [*]Huge code & Configuration cleanups [*]Added official beats audio drivers from Sensation XE source [*]Increased readahead buffer sizes [*]VM Tweaks [*]SMP & WakeLock fixups/improvments [*]Random reboots fixed! [*]Added LeeDrOiD Tweaks V2.0.0 [URL="http://forum.xda-developers.com/showthread.php?t=1334871"](Thanks to the Awsome j4n87 & daniels7)[/URL] [*]Tweaks - Custom lockscreen Sense, Honeycomb or Android [*]Tweaks - Choose which buttons wake the device [*]Tweaks - Hold vol up or down to skip tracks [*]Tweaks - Custom carrier caption [*]Tweaks - Customize quick settings [*]Tweaks - Hide recent apps [*]Tweaks - Sense - toggle unlock anim, paginated app drawer, smooth rosie selection, custom personalize button, 5 column app drawer [*]Tweaks - Toggle screen on/off CRT animation [*]Tweaks - Key backlight options [*]Full HTC beats Support [*]LeeDrOiD welcome on language selection [*]Updated BootAnimation to fit Evo 3D [*]Added Ice Cream Sandwitch animations (Android 4.0) [*]Reverted to stock lock ring for now [*]Fixed display issues on serveral widgets [*][B]Added dancing droid incoming call screen[B] [*]Added Sony Bravia Engine [*]Lots of system opimizations [*]Faster application loading times [*]Added support for Orange UK WiFi calling [URL="http://leedroid.ftp.rshost.eu/share/SignalBoost.apk"](Just install THIS apk)[/URL] [*]Removed HTC Loggers [*]Updated Google Maps [*]Updated Android Market [*]Updated Adobe Flash Player [*]Updated all custom pre-installed apps [*]And more that I forgot! :-/ [/LIST] [B]LeeDrOiD_3D_V2.0.0 [/B] [LIST] [*]Reworked CPU Configuration [*]Added CIFS Support & manager [*]Added optional SmartAss CPU Governor [*]Fixed Super extended quick settings [*]Fixed minor graphical glitches [*]Fixed several android related security flaws [*]Disabled scroll by page in app drawer [*]Several system cleanups [/LIST] [B]LeeDrOiD 3D V1.0 - 2nd September[/B] [LIST] [*]Initial release [/LIST] [/SIZE]
Weitere Infos & Download:
[ROM]LeeDrOiD 3D V5.4[KERNEL] V5.4 2nd April |Aroma|Tweaks|Fast|Stable|Beats - xda-developers
