DeLuXxE51
CyanogenMod 9
agraban hört auf an CM9 zu arbeiten und setzt seine tolle Arbeit an CM10 fort.
-> CM10
xda: [ROM/DEV][CM9][13.07.12] CyanogenMod 9 for EVO 3D (5+2 - 99%, 5+5 in work) - xda-developers
ROM:
neuste ROM:
02.08.2012 - Agrabren last build - 0.7.4 - changelog in second post - http://goo.im/devs/agrabren/cm9/shoo...4-shooteru.zip
Agrabren is doing huge camera fix job and his latest build can be considered as dailydriver. Also if you wanna experiment seek into agrabren dev dir on goo.im
0.7.2 Update via goo manager !
0.7.1
goo.im link: Goo.im Downloads - Downloading cm-9-DevilToast-0.7.1-shooteru.zip
Mirror (graciously provided by davis776): http://dl.nemec.co/agrabren/cm-9-Dev...1-shooteru.zip
No kernel change from 0.7, but has the USB Mass Storage fix, a touch screen fix, and the button backlight fix from johnnyslt
19.07.2012 - Agrabren last build - http://goo.im/devs/agrabren/cm9/shoo...7-shooteru.zip
Kamera bei 5+2 UND 5+5 soll laufen!
ältere ROMs:
13.07.2012 - Agrabren last build - Goo.im Downloads - Downloading cm-9-DevilToast-0.6.1-shooteru.zip
Mirrors:
Dev-Host: Dev-Host - cm-9-DevilToast-0.6.1-shooteru.zip - The Ultimate Free File Hosting / File Sharing Service
Mediafire: cm-9-DevilToast-0.6.1-shooteru.zip
Dropbox: http://dl.dropbox.com/u/26284017/cm-9-DevilToast-0.6.1-shooteru.zip
12.07.2012 - Last build - cm-9-20120712-UNOFFICIAL-shooteru.idkCam.zip
Camera isnt working. Check agrabren build.
Previous build (1) - cm-9-20120613-UNOFFICIAL-shooteru.YesCam.zip
Previous build (2) - cm-9-20120613-UNOFFICIAL-shooteru.NoCam.zip
Really old builds:
update-cm-9.0.0-RC0-shooteru-UNOFFICIAL-signed-b1-030612.zip
update-cm-9.0.0-RC0-shooteru-UNOFFICIAL-signed-b1.280512.zip
update-cm-9.0.0-RC0-shooteru-UNOFFICIAL-signed-b1.zip
update-cm-9.0.0-RC0-shooteru-KANG-signed-a2.zip
update-cm-9.0.0-RC0-shooteru-KANG-signed-a1.zip
Download gapps from goo-inside.me or RomManager.
Installation
0. Nandroid and/or Titanium backup.
1. Wenn du nicht upgradest oder deine derzeitige Rom nicht ICS ist, dann musst du vor dem flashen factory reset (data/cache wipe) machen.
2. Flash update.zip.
3. Wenn du bootloop hast, dann flash erst dein backup weider drauf, installiere 4EXT recovery, formatier alles mit ext4 und starte nochmal mit Punkt 0.
Bugs:
Car Dock (does not charge)
3D
WLan Tethering
Credits:
CyanogenMod, TeamEvo (agrabren, Kali-, cayniarb, toastcfh...).
Community - for test and debug efforts.
Current kernel branch - agrabren
Features:
Bleeding edge CyanogenMod.
+ Apollo
+ Theme Chooser
+ LockScreen shortcuts
+ LockScreen weather
+ Notification counter
+ Animated Lock
+ 3D Panel with agrabren builds.
Doesn't mean 3D games, videos, just proof of working. (Am I wrong?)
+ Chrome läuft perfekt
Alles auf eigene Gefahr!
-> CM10
ROM:
neuste ROM:
0.7.1
ältere ROMs:
Mirrors:
Really old builds:
Installation
Bugs:
3D
WLan Tethering
Credits:
Features:
+ Apollo
+ Theme Chooser
+ Animated Lock
