[ROM][CM10][06.01.13] AmeriCanAndroid AOSP 4.1.2 CM10 kernel:ACA-V13
  • 48 Antworten
MulderXP
MulderXP
24
AmeriCanAndroid AOSP CM10 (Jelly Bean 4.1.2)kernel:ACA-V13
Android 4.1.2 + AOSP
Kernel: ACA-V11
Offizieller xda-Thread
Ich habe diese Rom nicht entwickelt und verlinke nur auf die offiziellen Downloads aus xda.
Downloads:
google-code: Download
Installationsanleitung:
  • Format Data beim ersten Installieren und Cache und Dalvik beim Update und ersten Mal löschen
  • Über euer Recovery installieren ("Install from sd card/choose zip from sd card")
Changelog:
  • 01.06.13
    • past 3 days of cyanogenmod code updates
    • new ACA-Alpha V13 kernel by warrenb213. (major battery life improvements)
    • Left to do: 3D Related stuff
  • 01.02.13
    • past 36 hours of cyanogenmod code changes
    • new ACA-Alpha V12 kernel by warrenb213.... beautiful
    • tested wifi tether for root users version: experimental 3.3 pre 2 (encryption off, change default SSID name, use 'Auto' profile) WORKING!
    • bluetooth streaming tested perfectly, avrcp commands working, pairing etc all worked perfect during testing
  • 12.29.12 - Initial Release - Fast alles bis auf 3D funktioniert
Nächste Schritte:
  • Systemoptimierungen
  • Systemerweiterungen
  • 3D Funktionen
Dank geht an:
google - obviously...
cyanogenmod team - for the great effort they put into their very high quality work. the ground floor to the roof and then some. Amazing Amazing.
copenhagen - I saw we needed to thank you too Mr Canadian.
haha. You rock.
warrenb213 - its great working with you... its way better to have an team mate for these projects. and you've brought alot to this build. thankyou so much
homerSP - so many fixes.. so much thanks!
agrabren - For your amazing contributions to the Android/Evo3D community
mdj - your continued work in the android field. major thankyou.
lithid - your guidance and straight forward tips have been most beneficial
shub - for the great builds till u nixed them.
mattfmartin, noellen, docent - xda bruthers from another mother.
michyprima - you started copes love for nightlies.. its your fault! and he thanks you.
diem - for the gps fix
linus torvald - for starting something so amazing!
pwhitrow(bootlogo), evo1rs(bootanimation), uzi2(support), docent14(support), playstation(support), krisdelisle(support), and the many other (sorry if i forgot u) users who have helped maintain the sanity.
xda - for the forums.. the info.. and the users
to everyone else we missed. Thankyou
working for a community on a community project; to those who came before us, thankyou for everything you have done.. Thankyou.
Wir, ich und die Entwickler, übernehmen keine Verantwortung für jegliche Schäden, die deinem Gerät passieren. Mit der Installation bestätigst du, dass du dem zustimmst und das Risiko übernimmst!
Reaktionen: derDaniel1999
Sehr, sehr schöne Custom-rom alles bis auf 3D und GPS bei Google Maps funktioniert.
Genau das, was ich gesucht hab.
GPS geht bei mir bei Maps
Gesendet von meinem EVO 3D GSM mit Tapatalk 2
Wenn ich bem Standorterkennung irgendwas änder dann zeigt es immer an: Maps wurde beendet.
Und wenn ich Maps öffne dann sagt es mir ich soll Standort für Google-Apps aktivieren.
Aber bei Navigon zum Beispiel funktioniert es.
Der ursprüngliche Beitrag von 19:24 Uhr wurde um 19:27 Uhr ergänzt:
OK alles klar hab Maps nochmal neu installiert jetzt funktioniert es.
wie ist es mit der videowiedergabe?
MX Player funktioniert. YouTube und Dailymotion auch. Die Galerie spielt nicht gut ab. Aber läuft.
Meine Daily Rom..nutze MXPlayer und PowerAmp ..die ersetzen die Videowiedergabe und den Musikplayer.
Also erstmal ist das hier meine absolute Favorite Rom...
wenn da nicht dieser eine kleine Fehler wäre..
also egal bei welchen Musikplayer (apollo,mixzing,miui music....) immer wenn ich ein Lied anklicke hängt sich der Player auf und stürzt nach kurzer Zeit ab!
Weiß jemand vielleicht ne Lösung?
Hmm flash es noch mal. Wichtig: format data und wipe dalvik
Hab poweramp geht alles
Gesendet aus dem All
Reaktionen: menger288
Hab ich schon 2 mal probiert bringt nichts :/
Poweramp hab ich noch nicht probiert, teste ich mal eben :o
/edit: funktioniert! Dankeee! :)
Hat vielleicht noch jemand tipps die Akkulaufzeit zu verlängern? :o
Hast du bereits JuiceDefender installiert?
Läuft die besser als CM10 gangnam style?
Bei mir ja. Ist flüssiger mMn.
Gesendet von meinem HTC EVO 3D X515m mit Tapatalk 2
Soll übrigens laut Changelog starke Verbesserungen der Akkulaufzeit enthalten. Mal sehen.
@menger288: Ich würde den Deep Sleep Battery Saver probieren, schaltet halt wenn das Display aus ist WLAN usw aus und nur jede Stunde (oder 30/45min) kurz an um z.b. auf Mails zu überprüfen. Da kann man paar Stunden Akkulaufzeit rausholen.
Hw-bewcleunigung tut immer noch nicht, ergo net la 720p mim MX player -.-
Gesendet von meinem Xoom mit der Android-Hilfe.de App
Hi,ich fand das Rom sehr gut ,aber bei meinem Spiel Drag Racing wurde der Bildschirm bei den Rennen immer schwarz.Hat jemand diesen Fehler auch ?Und gibts vielleicht ne Lösung?
Gruß Sonnenwolf
Gesendet von meinem HTC Evo 3D GSM mit der Android-Hilfe.de App
hat wer erfahrung mit dem akku verbrauch gegenüber dem american android rom?
das american hatte bei mir viel zu viel verbrauch.
Ähm das is die American Android Rom?
exkcir
  • Celmo
Necktrox
  • Pascal1919
mister-mo95
mister-mo95
