CyanogenMod 10 - GANGNAM STYLE - Dec. 18, 2012
  • 62 Antworten
I
install.exe
Gast
dastin1015 schrieb:
| CyanogenMod 10 - Android 4.1.2 - Jellybean |
tZvd
Code:
#include <std_disclaimer.h>
 * Your warranty is now likely void.
 * I am not responsible for bricked devices, dead SD cards,
 * spontaneous combustion, or any other host of cosmic penalties
 * which may befall you, your family, or your phone.
vb0s
  • Built from CM source
  • Service
  • Text
  • Data
  • Calls
  • Audio
  • WiFi
  • UMS
  • Google Now
  • Bluetooth
  • GPS
  • MMS
  • Qualcomm JB libs & firmware
  • Video playback
  • Audio playback
  • Camera
  • Camcorder
5fA5
  • 3D
  • Occasional data drops
2JMJ
  • Do not use superwipes
  • S-OFF
  • 4ext recovery
  • Do not use ICS bootloader
  • Wipe data, cache, and system (wipe all partitions except sdcard if on 4ext recovery) if coming from any ROM except CM10
  • Wipe cache and dalvik-cache if flashing new version from previous installation of CM10
  • Flash ROM
  • Flash GAPPS
  • Reboot
  • Profit
  • The kernel zip in the second post is for reflashing the stock kernel if you had flashed a third party kernel.
wqd8
  • First and foremost my girlfriend Monica for supporting me and encouraging me along the way as well as being the best girlfriend I could ask for!
  • Everyone who contributes to CM as this is based on their hard work!
  • NineInchNails for being an awesome dev partner, moral support and friend!
  • Chad Goodman for the help and support along the way as well as his awesome Anthrax kernels!
  • BigWillyG for his awesome Buttered Toast kernel which I pull kernel updates from!
  • Agrabren for device repo which I based off of and expanded upon!
  • All my supporters!
dastin1015 schrieb:
8EF3
| Jan. 13, 2013 |
  • Much better and stable video playback
  • Fix audio playback
  • CM upstream: Here
| Jan. 11, 2013 v2 |
  • Add Roam Only option (shooter/shootervm)
  • Try fixing camera (shootervm)
  • Kernel: Linux 3.0.58
  • CM upstream: Here
| Jan. 11, 2013 |
  • Revert ramdisk changes
  • CM upstream: Here
| Jan. 8, 2013 v2 |
  • Update ramdisk
  • Fix camera (shootervm)
  • Kernel: revert kernel additions including s2w
  • CM upstream: Here
| Jan. 8, 2013 |
  • Fix voicemail (shootervm)
  • Remove prebuilt libv8
  • Full device tree for shootervm (should fix camera)
  • Virgin Mobile eri (shootervm)
  • Kernel: fix for s2w, add overclocking, other updates
  • CM upstream: Here
| Jan. 5, 2013 |
  • Add half press camera button to focus
  • Correct operator numeric (shootervm)
  • Model name change to Evo V 4G (shootervm)
  • Add shooter and shootervm ota assert (shootervm)
  • CM upstream: Here
| Jan. 3, 2013 |
  • Add shootervm support.
  • Kernel: Add sweep 2 wake, fast charge, other updates
  • CM upstream: Here
| Dec. 31, 2012 |
  • Kernel: Linux 3.0.57, add UHID
  • CM upstream: Here
| Dec. 18, 2012 |
  • Readd Flash Player
  • Kernel: gfx2d_clk1 stuck at off issue fixed (Chad Goodman/bigwillyg)
  • CM upstream: Here
| Dec. 16, 2012 |
  • Kernel: Linux 3.0.56, multitouch fix, lots of kernel updates
  • CM upstream: Here
| Dec. 5, 2012 |
  • Remove Linaro optimizations
  • More video playback fixes
  • Enabled FM radio
  • Fixed LED notifications
  • Kernel: common HTC msm8660 kernel, Bluetooth wakelock fix, Linux 3.0.54, bcmdhd wifi
  • CM upstream: Here
| Nov. 20, 2012 |
  • Linaro optimized build
  • Enable flashlight toggle
  • Update lights (broke flashing LED)
  • Kernel: Updated to latest Buttered Toast and compiled with Linaro 4.7.3 toolchain
  • CM upstream: Here
| Nov. 19, 2012 |
  • Camera updates
  • More WiFi tether commits
  • 4G WiMAX Settings no longer FC's when turning off
  • Better video playback
  • CM upstream: Here
| Nov. 11, 2012 |
  • Buttered Toast kernel
  • Camcorder
  • Bluetooth
  • YouTube and video playback
  • LEDs should now properly work
  • Capacitive lights on without auto brightness
  • CM upstream: Here
| Nov. 4, 2012 |
  • Camera!
  • Bluetooth broken with stock kernel
  • CM upstream: Here
| Sep. 7, 2012 |
  • Some audio recording fixes
  • 4G is a WIP. Turns on and searches (I don't live in a 4G area) (kushdeck/toastcfh)
  • Storage menu in Settings no longer FC's
  • WiFi tether fixes (jmztaylor)
  • USB tether fixes (jmztaylor)
  • Splitting of SMS enabled
  • LPA (Low Power Audio) enabled
  • Music playback should work now
  • CM upstream: Here
| Sep. 6, 2012 |
  • Initial Release
yqic
| Jan. 13, 2013 |
| Jan. 11, 2013 v2 |
| Jan. 11, 2013 |
| Jan. 8, 2013 |
| Jan. 5, 2013 |
| Jan. 3, 2013 |
| Dec. 31, 2012 |
| Dec. 18, 2012 |
  • Kernel:
  • md5sum:
yu1K
Name of this ROM comes from the Korean rapper PSY's newest and most popular song GANGNAM STYLE.
[YOUTUBE]9bZkp7q19f0[/YOUTUBE]
Nice.Wird wohl meine Favorit Rom .
Erster Eindruck: könnte es bei mir auch werden.
Wird übernommen in der Liste :)
Gesendet von meinem Nexus 7 mit der Android-Hilfe.de App
Rom ansich Ist Sehr sehr hübsch. leider läuft außer der default kein anderer kernel
Hab die jetzt auch drauf. Abgesehen von dem grausamen Name der Rom bin ich bisher echt zufrieden, mal sehen wie gut der Akku hält, da hat mich leider noch keine cm10 Rom überzeugt...
Der Anthrax Kernel läuft bei mir ohne Probleme, hab den zwecks Sweep2wake geflasht.
Gesendet von meinem Evo 3D GSM
den hatte ich nicht getestet. aber insgesamt läuft das Teil gut, aber mir noch etwas zu ruckelig im Moment. bin wieder zu Yoda V6. SuperAkku sauschnell....
Na ruckeln tut bei mir eigentlich absolut nix.
So ausgereift wie ne Sense Rom isse sicher noch nicht, aber mit Sense (vorallem 3.6) kann ich mich nicht mehr richtig anfreunden...
ich habe bei cm immer das Problem, das wenn man zu schnell die Homescreens wechselt es zurückbringt oder hackt. lässt sich Scheiße erklären. weiß nich ob du verstehst was ich meine
kannst du mir den Kernel mal schicken. Per pn oder so. Der Ist ja In nen Forum wo ich nicht Reg bin
Kann schon jemand was zum Akku sagen?
Also bisher würde ich sagen, wie bei jeder anderen CM10/JB ROM auch, akzeptabel.
Ich habe es gerade mal ausprobiert.
Läuft soweit ganz gut.
Ich als Entwickler habe nur leider ein Problem damit.
Sobald ich den Rechner anschließe und meine App installieren will, startet das Evo neu.
Teilweise nicht sofort, aber dann kurze Zeit später. Solange das USB Kabel noch angeschlossen ist hänge ich auch in einem Bootloop.
Erst wenn das Kabel abgezogen wurde, startet das Rom wieder.
Aber da nicht jeder Entwickelt, betrifft dieser Bug auch nicht jeden.
Die Geschwindigkeit ist gut. Ich habe aber direkt den NovaLauncher installiert.
Kamera funktioniert in 2D ebenfalls gut.
WLAN konnte ich noch nicht testen. HSDPA geht.
Ich habe es auch getestet mir gefällt es nicht. Mir hat bisher keine Rom gefallen die es für htc evo gibt und entäucht bin ich auch vom angebot.
ich hatte die ROM ebenfalls drauf habe sie aber gleich weg gemacht, wegen der video wiedergabe. Bei jedem vorspullen von ein video hängte sich das video auf und daraufhin stand "Video kann nicht wiedergegeben werden".
Ist es bei jemanden sonst dieses problem aufgetreten oder nur bei mir ?
Nimm einfach den MXPlayer, der funzt problemlos.
Nein der tut auch nicht. Nur mit der YouTube APP gehts halbwegs
Gesendet von meinem Evo 3D GSM mit der Android-Hilfe.de App
Dann macht es Sinn, sich vom Evo 3D zu trennen. Ich bin begeistert und Danke jedem, der am Projekt HTC Evo 3D mitgearbeitet hat. Für dieses "Spartenhandy" finde ich es toll, was es gibt.
Wow, ich bin beeindruckt, bei mir war das Evo wegen wirklich mieser Performance immer stärker in den Hintergrund gerückt, es war nie wirlkich schneller als das Desire HD und meist sogar langsamer. Doch diese ROM gibt neue Hoffnung, das Evo ist WESENTLICH schneller als mit den Sense ICS ROMs und öffnet Apps deutlich schneller. Egal wie gut ein Handy ist, am Ende entscheidet IMMER mein Unterbewusstsein, ob ich zum iPhone oder zum Evo greife, wenn ich das Haus verlasse. Aber das Evo macht wieder so Spaß, dass das iPhone wieder zuhause bleibt. War schon kurz davor ein Samsung zu kaufen, aber diese ROM läuft so schnell, dass sich das kaum noch lohnt. Nur die Probleme mit der Videowiedergabe trüben das Gesamtbild. Aber noch kein Reboot oder FC gehabt, echt super!!
Und wem das ausgelutschte Aussehen von ICS/JB langsam auf den Sack geht, dem kann ich wärmstens empfehlen die Designs-Funktion zu nutzen. Im Play store gibt es Dutzende gratis und Bezahl-Themes, die (vorallem die bezahlten) wirklich sehr qualitativ sind.
Komisch hab alles so gemacht wie in der Anleitung, aber als das CyanogenMod Logo kam ist es ausgegangen und neu gestartet und immer so weiter. Ich hab dann ne andere Rom geflasht die funktioniert hat. Ich will aber unbedingt Jelly Bean haben, da es von HTC ja leider keine Updates mehr fürs EVO 3D gibt. :(
Nochmal runterladen und neu flashen, dabei vorallem system und data wipen in der recovery!
  • basbus
mister-mo95
mister-mo95
mister-mo95
mister-mo95
Rainman013
