maikD
[ICS 4.0.3] Sense 4.0 [ALPHA v0.4] + HWA
Requirements:
- FATSYS Hboot (INT2SD-M) OR Stock Hboot (Stock recommended)
- SD-Ext 1GB recommended
Beim ersten Start werdet ihr mehrere FCs erhalten. Lasst das Handy 5 Minuten liegen und startet neu. Shaky weiß woran es liegt, es wird aber einige Zeit dauern bis die Fehler behoben sind.
Working:
- Boot
- Calls
- Sensoren
- SMS
- Teilweise SD Card (ext fs)
NOT Working:
- Audio
- Gps
- Bluetooth
- 3g/Data
- USB Mount
- SD Card (FAT32)
Code:
[SIZE="4"][B]Changelog V0.4[/B][/SIZE]
- No longer supporting Data++ & CM7R2 (Will consider supporting later)
- Very fast, faster than previous builds on Stock Hboot (Highly recommended) System boots up under a minute, (57.7 seconds to be exact )
- Fixed issues with Fatsys INT2SD-M - Fixed issues with Stock hboot
- Removed options of installing scripts (A2SDX, OXYGEN etc etc) this has been removed to provide accurate reports (will be supporting in future builds once main issues are solved)
- Fixed issue with installing Launchers (Stock launcher will always install (optional launchers still available)
- Now using odexed framwork & apps (Removed compressed & deodexed framework & apps)
- Moved apps to sd-ext for INT2SD-M (Space for any mods on system for future)
- More
[SIZE="4"][B]Changelog V0.3[/B][/SIZE]
- Fixed issue that prevented HTC Rosie Launcher & all other launchers showing
- Fixed issue with hboot stock
- (NEEDS TESTED) changed data++ & Cm7r2 to boot the system
- Fixed CPU Freq issue, where 1ghz was not selectable
- More
[SIZE="4"][B]Changelog V0.2[/B][/SIZE]
Multidevice script supporting the following
devices
HTC Desire
Nexus One
Droid Inc
(More devices to come, and I'll update Nexus One & Droid Inc tommorow)
Now using Aroma Installer ( I really like the UI on this (Sense themed )) thanks to sandvold for noticing my noob error on that.
Now supports the following HBOOTS/
Automatically detects
Fatsys
Stock
Data++ ( Currently not working)
Cm7r2 ( Currently not working)
(Installs on SD-Ext partition (Minimum of 512MB Recommended))
The following is available as cuztomizable
options in Aroma Installer:
Launchers:
Stock - HTC Sense
AOSP stock launcher (compiled by me )
Apex
Nova
Motorola
Scripts:
A2SD - Stock
A2SDX
A2SD - Regular (dalvik on NAND))
Dalvik to SD
Oxygen data2sd
Mods:
GPS Mod
Battery Mod
Sense 4.0 ROM:
SD Card partial working, SD-EXT reads, FAT32 still does not
init.d
Rooted (havent tested)
3G Working/Confirmed
VM Tweaks
Increased battery life
No hidden logging apps
Kernel:
Kernel developed on by me
No More BSODS
Changes in Ondemand
Added, smartass, smartassv2, lagfree
Added SIO/VR
Changes to do with camera
Changes to do with display
Changes on CPU FREQ
Increased ACPU Freq table
Clock inits @ Higher freq, (1ghz instead of 800/700mhz, resulting in faster boot times
Changes in I2C
Made kernel more stable
[B]v0.1 - Initial release[/B]
Downloads:
- v0.4
- v0.3
- v0.2
- v0.2 Mirror
- v0.1
- v0.1 Mirror
- FATSYS Hboot
Quelle: XDA
