[ROM][Ginger Sense][11 Mar]RCMix S v01 First GingerSense port! Test and report!
  • 225 Antworten
Homie1990
Homie1990
Stamm-User
120
RCMixS
Ace S 2.36.405.8 WWE Release base, 2.3.3 android.
I want to thank SNQ- for
Kernel, camera and camcorder, Icons on lockscreen,
weather animations, trackpad to wake and well... many many more stuff
Thanks man !!!
Graphics by MaxDroid
attachment.php
attachment.php
Read this before posting any question
READ THIS BEFORE POSTING NEW RCMix Guide/Tutorial/FAQ READ THIS BEFORE POSTING
RCMix small talk - Freenode #rcmix or #rcteam
You can use webchat if you dont have any irc client.
Here is a General thread about this rom
Features:
  • Base - Ace S 2.36.405.8 WWE Release base
  • Kernel - snq is still no 1
    v05 with all modules loaded
  • Compass is working
    thanks snq for that.
  • Camera and camcorder now is working, thanks snq for that !!!
  • EXT2/3/4 support, Thanks to snq for that
  • WIFI and WIFI Tether works
  • BT works
  • Virtuous autoinstall script by rmk, modded for our needs
  • Repacked all apks and zipaligned to improve memory footprint... now around 160MB+ free *New
  • Streaming SD/HD works
  • 720p video playback works
  • DivX playback works
  • Even more settings in "Quick settings" tab.
  • Enhanced power menu option
  • Touchpad to unlock
  • Touchpad to wake
  • DSP manager *New
  • Sense 3.0 Kingdom Lockscreen with buttons *New
  • New lockscreen wallpapers
  • Sense 3.0 SMS/MMS application
  • Sense 3.0 USB Menu
  • Sensation Live wallpaper (preview not working, apply directly)
  • Sense 3.0 Task manager (even in quick settings)
  • Quick Office replaced by far better Polaris Office
  • Chinese hand writing added should be fixed now
  • WIFI fix
  • Speed tweaks from baadnwz rom
    thanks man.
  • CM-style screen on/off animations
  • Option to enable stock android lockscreen
  • Desire S keyboard
  • Livewallpapers from Nexus S
Known bugs:
  • In X-A2SD version, normal wallpaper is not working :/ just livewallpaper, investigating
  • slow quadrant (feels very very fast tho)
  • you tell me...
Note:
Tips:
  • If you need much space and are s-off, flash the CM7 version and move dalvik to sd with included MCR script, check the app drawer for mcr scripts.
  • To save some battery change the wifi power settings.
  • To make the battery last longer, turn off pocket mode in settings/sounds.
  • How to install mail certificate, thanks to Flashmaniac
[URL="http://forum.xda-developers.com/showthread.php?p=12004449#post12004449"]Changelog:
v2.0[/URL]
  • Added fixed icons on lockscreen
  • Updated weather app to the latest
  • Added nice semitransparent rosie.
  • Added DSP manager
  • Added MCR scripts, check the app drawer for the MCR scripts app, the name of scripts says pretty much what the script do...
  • Big internal changes (mostly usefull for me
    ) full wipe needed.
Download:
  • RCMix S v2.0 Bravo and CM7, FULL WIPE NEEDED!
    MD5:
    - A2SD+ Bravo: 7b1bc2323b7348aa8a61ee3c4cd94abe
    - A2SD CM7: 1f130a17f1b81f7e1e5e775faba44e16
  • MIRRORS - Thanks to FatzzCat for those
For Data 2 EXT check this post *try at own risk
, if you do, flash on bravo version...
Kernels:
  • for now, there is no better then the one included
    thanks for that snq !!
Extras:
Thank you:
  • Capychimp
  • Seo
  • Snq-
  • rmk
  • Ownhere
  • Muxeu
  • HomerSP
  • Coolexe
  • Baadnwz
  • Imilka
  • Neo
Very special thanks for the donators
Please PM me if the name is wrong or if i forgot to add someone, so i can give proper credit.
Hall of fame of donators
Peter, Joshyui, echbel, Antonios, THOMAS, Ettore, pasqualino, DTGbaby, Lowczyk x2, Roberto, Istvan,
arbitrary_punter, Ian, shadow79, mits, robert, d3m4noid, peter, byngo, Reef2009, jrxau, -DjipOner-, tomcat84, David, marcel, BEATRICE,
tinky1, michael, Daniel ,ravish_919, tsiftsism, dongerado, asterixmic, Stefan, skippy68220, kirschi, David, Henri, Simon
* * * THANK YOU VERY VERY MUCH !!! * * *
If you like this rom, give it a star
or/and
if you're planning to get dropbox for android,
please be one of the first 24 that use this link,
if you use that link both me and you will get 250mb space extra! (its free)
Vodka shots/donations appreciated
Quelle: http://forum.xda-developers.com/showthread.php?t=988570
Ich wusste es das es nichtmehr lange dauert
Reaktionen: slekk
Super Es geht voran!
Sent from my HTC Desire using Tapatalk
sorry, habe ich übersehe, muß an der Uhrzeit liegen :unsure:
Habs mal kurz drauf gehabt.
Ist noch sehr experimentell.
Ich habe es gleich wieder runtergeschmissen, da WLAN nicht funktionierte.
Vielleicht würde es mit etwas Geduld und der richtigen Kombination Kernel / Radio funktionieren.
Ja, natürlich funktioniert noch einiges nicht, ist eben die erste Version. Mal schauen, ich denke wenn WLAN funktioniert, bin ich dabei :D
ich hatte es heute auch kurz drauf. für den ersten release fand ich es sehr gut. lief eigentlich ziemlich flüssig. das nicht funktinierende wlan war für mich dann aber das ko kriterium, da ich zuhause nur edge habe. wollte einfach mal reinschauen. ich gehe aber davon aus, dass viele funktionen relativ zeitnah implementiert werden.
wie robo bei den xda´s schreibt, wollte er (und ist er drum gebeten worden) relativ früh eine version veröffentlichen.
Sehr fett. Ein Hoch auf unsere Rombastler!!
Vermisse Sense schon ein wenig :)
Geil, geil ich bin a scho ganz heiß drauf :D. Werde aber warten bis die ganzen Bugs gefixt sin, weil n Smartphone ohne Kamera und WLAN ist nicht wirklich smart!
So sehe ich es auch, es ist eigendlich nurnoch ein Phone :D
Das Rom hat verdammte Ähnlichkeit mit den Cool Z Roms vom Rommanager (hab ich schon seit ein paar Tagen drauf,gefällt mir sehr gut). Bei denen funktionieren auch Wlan u Kamera.
der unterschied ist, dass in diesem thread ein sense rom auf basis von android 2.3 (codename gingerbread) basiert.
das von dir angesprochene rom basiert auf android 2.2 und da gibt es etliche ports.
Reaktionen: Maysi2k
w-lan funzt inzwischen mit der neuen version "RCMix S v02 A2SD" :)
find das rom auch sehr nett, läuft für die ersten versuche echt schnell und auch stabil, wenn man nicht grade mit youtube der cam oder setcpu rumspielt^^
***aber bin seid der RCMixHD 3.4 eh schon ein fan von Robo seinen roms, sind recht gute arbeiten die er produziert. bin gespannt was mit diesem rom hier noch so passiert.
mfg
curf
Getestet: ich finde es schon jetzt genial!
meine rede :D
wird nicht lange dauern, dann funzt die cam auch ;)
die devs findes das rom selbst genial, die schlafen ja kaum noch weil se nur am werkeln sind um das rom stabil zu machen.
musst mal denn thread lesen bei xda :D
Also im original Tread steht WiFi immernoch als bug drin und der wurde gestern zuletzt aktualisiert...
Edit: hmm im Titel steht Wifi works - aber unter Bugs ist es noch drinn :/
Wie schon oben im thread erwähnt, mit der v02 funktioniert WiFi. Ich benutze selbst die v02 und scheibe grade über diese Verbindung vom meinem desi ;)
mfg
curf
Reaktionen: Maysi2k
Ich lade es gerade runter und habe gesehen das es 237MB:blink: sind.
Was ist denn da alles drin?
Sind glaube, wenn ich mich recht entsinne, die gleichen apps wie in jedem hd Rom drin.
spezi77
TonieZ
TonieZ
spezi77
spezi77
spezi77
Maysi2k
Maysi2k
Maysi2k
