[ Kernel ] Flashable Camera fixed for Sense 4 Rom
  • 1 Antworten
OnkelDan
OnkelDan
Dauer-User
317
[Kernel] Flashable Camera fixed for
Sense 4 Rom
Hi Guys, we all knew that Virtuous Team
have released Virtuous Infinity v1.31 alpha2
FULL SENSE 4 ROM with working camera and
camcorder,because of their 3.0.16 kernel
sources. But when we do use that kernel on
other sense 4 rom it break wifi and other
stuff....but this morning from
ICESense_v5.1 forum, we do have camera
breakthrough! Big thanks to tgeorg If u like
to thanks him and see his original post click
on his name.....
Quote:
Originally Posted by tgeorg
The problem with the virtuous kernel is, the
module for wifi is renamed from bcm4329.ko
to bcmdhd.ko and also the firmware files are
changed.
So I take one of the virtuous kernel updates for
my camera chip and changed the name of the
module from bcmdhd.ko to bcm4329.ko but
this is not enough. If I insmod the name is still
bcmdhd , this must be changed in the module at
offset 582E4 from bcmdhd to bcm4329. then
lsmod shows "bcm4329 440166 0 - Live
0xbf000000" and also the firmware files from
the virtuous rom must be taken to fully
functioning. they are 7 files:
BCM4329B1_002.002.023.0589.0632.hcd
fw_bcm4330_apsta_b2.bin
fw_bcm4329_apsta.bin
fw_bcm4330_b2.bin
fw_bcm4329.bin
fw_bcm4330_p2p_b2.bin
fw_bcm4329_p2p.bin
If you put all this together and make an
update.zip then everything works. Camera and
Wifi.
have a nice day
here is a link to my working file for DHD with
Samsung Camera chip: d-h.st/CUh
Tested my self and couples other people
confirmed work for DHD/INSPIRE 4G with
SENSE 4 base rom ...
Full HD 8M camera work only with Flash
On....otherwise still have glitches....Video
work like a charm.....
Before u download make sure to check what
kinda camera sensor/chip that ur phone
use>Open root explorer>
sys>android_camera>sensor>open with
text so it will show u what kinda chip that ur
phone use and ENJOY....
DOWNLOAD SAMSUNG
SENSOR : https://dl.dropbox.com/
u/37405181/Vi...msung_chip.zip
DOWNLOAD OMNI SENSOR:
https://dl.dropbox.com/u/37405181/
Vi...V8810_chip.zip
http://forum.xda-developers.com/showthread.php?t=1826903
KNOW THE DRILL....BACK UP...FLASH
WITH UR OWN RISK....IF U LIKE IT HIT THAT
THANKS BUTTON...IF U DON'T....KEEP IT
CLEAN AND SIMPLE....JUST STAY AWAY FROM
THE THREAD....
Gesendet von meinem HTC Desire HD With Beats Audio mit Tapatalk 2
Funtz das auch mit Blackout ICS Xl /Sense 3.6?
AMCooper
MarM
MarM
  • Morci91
Chooksi
anjoku
