[Diskussion] BeatMod CyanSense| CM7 Base | Sensethemed | LordMod Kernel
  • 8 Antworten
zFr3eak
zFr3eak
Dauer-User
294
Basics:
Android OS version: 2.3.3
Device: Ace
Model: Desire HD
ROM Name: BeatMod CyanSense
Rooted (Superuser.apk + su): Ja
Rooted (unsecured boot.img): Ja
BusyBox installed: Ja
BusyBox run-parts support: Ja
Apps2SD (Apps to EXT) enabled: Du kannst wählen
/data/app enabled: Ja
Custom boot animation allowed: Ja
Nano text editor installed: Ja
Bash shell support: Ja
ROM will wipe all data: System
Features:
  • Cyanogenmod 7.0.2 Base
  • Fully Sense Themed
  • LordMod Kernel bis zu 1900 Mhz
  • Schnell und aufgeräumt :)
  • Data/App Support
  • Nano Bash shell
  • Viele Einstellungsmöglichkeiten
  • Speed Fixes
  • Nutzlose sachen entfernt
  • Multilanguages
  • Fly Effects
  • Guter Support ^_^
Kernel Info: (thanks to LordMod)
  • Based on James Zdziebkowski's port 2.6.35.10
  • It has parts from HTC Saga and HTC Incredible in it - James Zdziebkowski
  • Offcourse newest adreno drivers from CM7 - James Zdziebkowski
  • Included battery fix from teamdesire - James Zdziebkowski
  • OC to 1.5Ghz - James Zdziebkowski
  • Smartass included - James Zdziebkowski
  • CFS only by default
  • vvvvvvvvvvvvvvvv from here modded by me
  • Added Volume boost of 20%
  • Patched libsqlite.so to disable db loops – thanx to ownhere
  • Default UV
  • Smartass and CPU tables as in 4.4.1 ROM (smooth)
  • VDD user interface (by -snq, modified by LorD Clockan for 2.6.35)
  • Under volt editions, UUV edition might not work for all.. use -25mV edition
  • CPU freq going from 122MHz (230 default) to 1920MHz
  • Allocated more GPU memory
  • Added SLQB slab memory allocator
  • Tweaked read/write video buffer
  • Added TinyRCU Bloatwatch edition v8
  • Tweaked Interactve and Ondemand governors
  • Added V(r) I/O data scheduler
  • Added Tweaks and patches from latest CM7 kernel for Wlan chip and USB
  • Enable Deathray for flashlite
  • Ported BFQ v2 from 2.6.37 (by Thalamus) and patched to v2.1 and set as default I/O data scheduler
  • Patched kernel to 2.6.35.13 (by me)
  • Added USB mount support (James Zdziebkowski)
  • Added 2 way recording patch - all compliments go to avs333 (go to Call Recording app and disable recording if you don't use it)
Bugs:
  • Du nennst mir einen :)
Intruduction:
  • Download Rom
  • Full Wipe
  • Flash gapps
  • Reboot
  • Launcher pro einstellungen die sense ui einstellen oder
  • Mein backup nehmen und die bestmögliche einstellung verwenden
  • Spaß haben :)
Mirrors are welcome :)
BeatMod CyanSense V1.1 Mirror 1
Gapps from 2011.03.07
Credits:
  • CyangenMod Team
  • LordMod
  • Capychimp
  • NTSense
  • And allways the main developer here :) (capychimp, mike1986, etc)
  • Bergfex (Tester)
  • Jhinta (Tester)
If you like my work:
  • Bedanken und
  • Den Thread bewerten oder/ und
  • Donate me :)
  • launcherpro_backup.zip
*Reserviert
ist das die gleiche version wie die beim xda thread?
Hier heisst die Rom CyanBread und bei xda CyanSense.
Reaktionen: zFr3eak
Hobler86 schrieb:
oha danke für den Hinweis da hab ich mich glatt verschrieben. ja sie heißt Cyansense und ist die selbe.
bitte freut mich das ich helfen konnte^^
@Segelfreund: ich wollte darauf hinweisen, dass diese rom nicht unter sense roms gehört da sie ja nur eine sense like cm7 rom ist ;)
Nun hat doch aber eine Sense-Oberfläche oder?
Von daher würde ich die ROM schon als Sense-ROM ansehen.
ja schon aber eigentlich nur gethemed. und die widgets klappen ja dann auch nicht.
Achso Ok werde ich ändern
Reaktionen: zFr3eak
Jeezy97
WalterHartwellWhite
Lemmi
segelfreund
segelfreund
Jeezy97
Schubbie
Schubbie
