heikonet
Dauer-User
- 907
Der macher Alpha (hat auch das TNT Lite 0.1 gebaut) hat eine Mischung aus TnT Lite v0.2 and VEGAn rom gekocht.
Beinhaltet:
- Custom Zeam Launcher mit viel Platz für Icobns
- Stock android taskbar
- Stock android settings (fully working!)
- Android market
- Honeycomb music player
- Duomax's divx ac3 playback fix
- Volume appears considerably louder than TnT Lite
- Rooted
- Schnell und stabil!
Update: Wifi is set to never sleep, if you wish to conserve battery power go to wifi settings and press menu -> advanced and change wifi sleep policy.
Weitere Info:
Beinhaltet:
- Android market
- Rooted
Weitere Info:
Quelle: SlatedroidHannsTitan v0.3
Custom Android 2.2 (Froyo) rom for Hannspree Hannspad
Based on the work done in the following roms:
Tap 'n' Tap
Brilliant Corners
Mountain Laurel
Features
- Zeam launcher
- Hardware acceleration
- Full Android market (After market fix below)
- Volume louder than TnT Lite
- Rooted
- It's quick and stable!
Changelog
0.3.1
Fixed stretched default wallpaper
Updated Zeam to latest version
Zeam has its default file name market updates may work now (need to wait on a new release to test it)
Updated build.prop to walkerx's latest version
Added /sdcard2 and /usbdisk to mount points so all storage shows up in settings
Included Multi Mount SD-Card Lite widget to mount /sdcard2 as usb mass storage (must use its widget)
Internal sdcard nomedia fix - stops files on the internal sdcard from being deleted
Reverted bootanimation
Added gTabWallPaper app
0.3
Minor update to include market fix
0.2d
Initial public release
Known issues
- Status bar could do with being improved
- Google apps accounts can now sign in after signing in with a normal google account, however now sync options will be shown (normal google accounts working fine)
- Wifi light not working
- Some users report issues with the device being unable to wake from sleep while others seem unaffected
Install instructions
Assuming you have CWM already installed, make a backup of any installed apps you don't want to lose.
1. Copy to sdcard root
2. Reboot in CWM
3. Delete data/factory reset is recommended
4. Install zip the usual way
5. Reboot
Market fix
6. Set up wifi, add a google account
7. Go to Settings > Applications > Manage Applications > All > GoogleServicesFramework > Clear data > Force stop > hold power button > reboot
8. If market gives you an error, reboot again
Give it a few minutes to settle after the first boot as the media scanner runs straight away and might make it feel sluggish. It takes a second for Zeam Launcher to pop into life too.
Market Fix Only
0.3.1 includes the latest market fix
After setting up wifi and adding a Google account:
1. Go to "Settings -> Applications -> Manage Applications -> All -> GoogleServicesFramework" and press "Clear data" then "Force close"
2. You can do the same with the Market EXCEPT "Clear cache" NOT "Clear data" - although I never had to do this
3. Reboot straight away
4. Wait for WiFi to connect and open Market, if it gives you a server error, reboot again
Please try and keep this thread clear of honeycomb questions, there are others on the forums and no, I am not currently developing a honeycomb rom!
Special Thanks
roebeet + gojimi for their work on the original roms
Nosferatu Alucard for the honeycomb music player
duomax for the ac3 libs
boot animation from droidpirate.com
walkerx for help with the build.prop for the market fix/gazbert for his original findings
Everyone else who's reported issues or gave compliments, it all helps![]()
Downloads
Full ROM
0.2d: HannsTitan v0.2d - 105,414kb
0.2d HannsTitan v0.2d - 105,414kb
0.3.1 Update
You must have 0.2d installed first!
HannsTitan v0.3.1 Update
Important note if you are using an external SD card
Download and extract the file linked in this post to the root of your external sdcard. By root I mean not in any folders. You do not need to do this to the internal sdcard as the 0.3.1 update installs this automatically.
