[ROM][Stock+][NPF26F-NBD91K]Debloated-Prerooted-Odex-Busybox-Fast & Stable
  • 20 Antworten
Sh0X31
Sh0X31
Enthusiast
852
-> XDA-Thread
-> Dev
Stock+: schnell & stabil mit aktuellsten Sicherheitspatch
Stock+ NBD91K features:
-Built from latest Factory Image for Nexus 6p.
-Layers native support.
-Only core Gapps included.
-Debloated.
-Odex.
-Zipaligned.
-Added root with SuperSU 2.78 R1 Credit Chainfire
-Added Busybox 1.25.1 Credit YashdSaraf
-Added su.d support.
-Added init.d support.
-Insecure boot image. (It is basically adb as root)
-Disabled forced encryption.
-Disabled dm-verity.
-Multi-Window native support.
-Enabled WiFi Tethering.
-Hidden adb notification icon.
-Added simple reboot app. (credit ffranco)
-Substratum legacy support.
Stock+ NPF26F features.
  • Built from latest Factory Image for Nexus 6p.
  • Layers native support.
  • Only core Gapps included.
  • Debloated.
  • Odex.
  • Zipaligned.
  • Added root with SuperSU 2.78 SR4 Credit Chainfire
  • Added Busybox 1.25.1 Credit YashdSaraf
  • Added su.d support.
  • Added init.d support.
  • Insecure boot image. (It is basically adb as root)
  • Disabled forced encryption.
  • Disabled dm-verity.
  • Multi-Window native support.
  • Enabled WiFi Tethering.
  • Hidden adb notification icon.
  • Added simple reboot app. (credit ffranco)
  • Substratum legacy support.
  • Added pixel boot animation modded by me
entfernte APK's:
system/app:
  • Books
  • CalendargooglePrebuilt
  • Chrome
  • CloudPrint2
  • Drive
  • EditorsDocsStub
  • EditorsSheetsStub
  • EditorsslidesStub
  • FitnessPrebuilt
  • GoogleEars
  • GoogleHindiiME
  • Google japaneseinput
  • GooglePinyiniME
  • Hangouts
  • KoreaniME
  • Maps
  • Music2
  • NewStandStub
  • Photos
  • Playgames
  • PlusOne
  • PrebuiltbugleStub
  • PrebuiltGmail
  • PrebuiltKeepStub
  • PrebuiltNewsWeather
  • talkback
  • Videos
  • Youtube
Installation:
- Bootet ins Recovery (TWRP empfohlen)
- führt ein wipe durch (Dalvik/ART, System, Data & cache)
- flasht das Radio & den Bootloader
- flasht das Rom
-> falls verschlüsselt:
per ADB: fastboot format userdata (löscht eueren Speicher, vorher backup eurer Daten erstellen)
per ADB: fastboot flash recovery TWRP
In den Recovery-Modus und ein wipe durchführen
flasht die Rom
flasht das Raido & den Bootloader
Downloads:
Downloads
-> Nougat 7.0 NBD91K
MD5:FED214BBBE2219E8DF22DDB5F2908418
-> NBD91K vendor
MD5:924FACE441F0B6C7BC52534C55159DAB
-> NRD90M Radio & Bootloader flashable zip
MD5: 094e546b8d67e2b3d30a61c94228ad8b
Developer Preview 2
-> Nougat 7.1.1 NPF26F
MD5:c6a52385e3d56793dca377b1ffc557a4
-> NPF26F Vendor
MD5:0c10000b349795d136e9c5473aaa79d9
-> NPF10C Radio & Bootloader flashable zip
MD5:25A1BEB5241B9E233C0C087291B73CBC
-> Mods Sammlung (NBD91K)
Mods Sammlung (NPF26F)
Wenn du dem Dev ein Bier kaufen willst :)
You can donate HERE
Reaktionen: AlicaFabienne
Schon jemand getestet?? Komme vom pure nexus.... Kann ich ganz einfach nach fullwipe drüber flashen??
Ja nutze es heute schon den Tag über und läuft sehr gut.
Ja, full wipe, dann Rom und dann Radio + Bootloader. Vendor ist im Rom integriert.
Ich "hatte" das Rom auch drauf. Der Fingerprint hat etwas verzögert reagiert und nach dem Booten hat ich beim ersten Start der Kamera einen Fehler. Danach nicht mehr. Da SHealth nicht lief bin ich zurück auf Stock. Hier lief SHealth übrigens auch nicht. Ansonsten sehr tolles Rom.
Also mit dem Fingerabdrucksensor habe ich keine Probleme. Akkulaufzeit ist meiner Meinung nach wie bei Marshmallow. Wer noch die Uhr in der Mitte will, gibt es jetzt ein Mod (xda). Zum Rom gibt es nicht viel zu sagen, ist halt Stock Rom prerooted und debloated. Bin sehr zufrieden :)
Thread wieder aktuell
Davon würde ich wegen der Instabilität dieser TWRP-Version dringend abraten!
Bei 3.0.2.1 ist es "nur" der EFS Restore, der fehlerhaft ist.
Sind die Gapps schon in der Rom ??
Die wichtige Base und Libs sind da. Im OP steht ja was verglichen mit Stock entfernt wurde.
ja habs mir nicht durch gelesen
Weiß jemand, wie ich auf Nougat AdAway zum funktionieren kriege?
Zusätzlich dieses File flashen, dann sollte es gehen
  • AdAway_systemless_hosts_v2.zip
Reaktionen: Stöpsel29
Vielen Dank dafür.
Habe bei XDA nach einem Patch o.ä gesucht aber nichts gefunden.
Werde am WE mal neu flashen und ausprobieren. [emoji4]
Hättest Du den AdAway-Thread dort gelesen, hättest Du gefindet :flapper: - da hab ich den Patch nämlich auch her. Ist generell bei Nougat so, auch beim stock ROM.
Falls jemand die Developer Version (NPF10C) flashen möchte, hier eine kleine Anleitung :).
1. Downloadet das OTA-Update
INFO:
Das OTA-Update enthält das Bootloader, das Radio & das Vendor Image. Natürlich enthält das Factory Image das alles auch, jedoch ist das OTA flashbar und es wird kein "fastboot Format USERDATA" (wie beim Factory Image) benötigt.
*(Optimal) Sichert eure Apps z.B. mit Titanium Backup
2. Rebootet in das Recovery, führt ein "full wipe" durch und flasht die aktuelle Stock+ Version (NPD90X).
3. Im Anschluss flasht ihr per TWRP das OTA-Update und SuperSU v2.78.
4. Gedulden bis Android 7.1.1 gebootet hat und App Backup wiederherstellen.
*(Optimal) Könnt ihr folgenden Mod flashen
-> http://forum.xda-developers.com/nexus-6p/themes-apps/nougat-7-1-1-mods-t348663
Info:
Alle Mods beinhalten:
  • NavBar tuner
  • Night Light Mode - Unter Settings => Display
  • Pixel Nav Bar Icons
  • Battery Sparmodus ohne "Verfärbung"
Optimal
(Beschreibung bei Google Drive beachten)
    • StockModed -
      Night light, pixel buttons, uncolored battery saver mode, nav bar tuner
    • StockModed - 36DpiNavBar -
      Night light, pixel buttons, uncolored battery saver mode, nav bar tuner, Nav bar height changed to 36dpi
    • Tinted bars 3 tiles -
      Night light, pixel buttons, uncolored battery saver mode, nav bar tuner, Tinted nav bar , stock 3 tiles quick settings
    • Tinted bars 36Dpi 3Tiles -
      Night light, pixel buttons, uncolored battery saver mode, nav bar tuner , Nav height changed to 36dpi , stock 3 tiles quick settings
    • 6 Tiles 36DpiNavBar Tinted -
      Night light, pixel buttons, uncolored battery saver mode, nav bar tuner, nav bar height changed to 36dpi , 6 tiles quicksettings
    • FullStock -
      The original systemUI and Framework-res
