[ROM][6.0][MRK58K]xTraSmooth[07.11.2015]
  • 140 Antworten
Hen Ry
Hen Ry
Enthusiast
1.672
xTraSmooth 100% Odex - First Real Optimized ROM Based on 100% Factory.img
100% Odex , xTraSlim only core minimal gapps , xTraBatteryLife , No Forced Encription , Native DT2W , xTraSmooth Sound Stereo Boost and more........
XDA
Drastische Erhöhung der Batterielebensdauer: Das System und der Kernel müssen einige Ladezyklen zur Anpassung absolvieren.
Batterieverbrauch xTraSmooth Rom reduzieren
CPU
3 benutzerdefinierte Profile, oder mit
manuell einstellen.
Delta Update: um zu vermeiden das immer die ganze Rom herunterladen werden muss wird der xTraSmooth Updater für beste OTA Ergebnisse empfohlen
Downloads: xTraSmooth Updater Free
Neue Version: MRA58R__Shamu.zip
631.1MB Nov 18, 2015 | 11:57PM
- Added xposed framework (only framework intall latest xposed apk)
Version: xTRaSmooth_MRA58R_Shamu_07.11.2015_V3.zip
630.1MB Nov 07, 2015 | 06:41PM
- Updated to latest factory.img MRA58R
- Updated Busybox 1.24.1 (V3)
Version: xTraSmooth_MRA58N_Shamu_04.11.2015.zip
656.2MB Nov 03, 2015 | 09:31PM
- Updated to new factory MRA58N
- Updated Supersu to 2.56
- Same Other Features, Dirty Flash Work 100% from old xTraSmooth
Version: xTRaSmooth_MRA58K_Shamu_29.10.2015.zip
630.5MB Oct 29, 2015 | 08:47PM
Neue Version: xTRaSmooth_MRA58K_Shamu_13.10.2015.zip
630.2MB Oct 12, 2015 | 08:58PM
Version: xTRaSmooth_MRA58K_Shamu_12.10.2015.zip
630MB Oct 12, 2015 | 03:48AM
- For Users request replaced Hells Core with EX Kernel 3.0 Stable
- Soft CPU OC +77 Mhz
- Great Performance Boost respect 06/10/2015 xTraSmooth , run a benchmark for test it
- DT2W enabled as Default
- Sweep To Sleep on navigation bar
- Enabled Launcher Rotation
- Enabled MW
- Enabled Led Notifications use light flow to controll it
Version: xTraSmooth_MPZ79M_Shamu_Final.zip
594.1MB Aug 12, 2015 | 05:41PM
- Rebuilded from 0
- Updated Hells Core Kernel To latest M2 Update
- Replaced Chrome Dev with Latest Stable Release with fully working synch
- Fixed all Bluetooh issue
- increased headphones boost
- Removed xTraSmooth Name from build number (this is 100% stock factory optimezed rom)
Version: xTraSmooth_MPZ79M_Shamu_26.07.2015.zip
597.1MB Jul 27, 2015 | 07:28PM
- Udated Hells Core Kernel
- Removed unnecessary init.d tweaks
- Mixed Cleanup in system
- Now very extreme battery life
- Based on latest android M2 MPZ79M system.img
- Fully Odex
- Kernel HellsCore B3 M
- No force unecrypt as default
- Unlocked tethering
- Enabled Double tap to wake
- Pre-Rooted with Latest Supersu 2.49
- Busybox
- OTA Update with xTraSmooth Updater
- Support Multi Rom
- Layer compatible
- Only xTraSmooth minimal gapps
- Reduced running services and improved ram usage
- Super Fast and Stable 4 Daily Driver
- xTraSmooth Sound Stereo Boost , boosted speaker and headphones with no distorctions , best stereo mod with MusicFX , no other equalizers are necessary.
- No ads
- Unlocked Android M Multiwindow
- Fully led control with LightFlow
- No boot error msg
Reaktionen: 99ACTION99, Max4000 und vergilbt
Hen Ry,
sehe eben deinen thread hier... Nutze die ROM auch schon länger und die läuft super... Nur deine automatische Google Übersetzung von daniel84cs seinem opener ist sehr verbesserungsbedürftig...
Da sind etliche Fehler dadurch entstanden...
Zum Beispiel bezieht sich der Satz "... FÜR LOLLIPOP BENUTZER GIBT ES ZU VIELE FEHLER..." eindeutig NUR auf das delta-update...
In anderen threads haben user jetzt schon Angst vorm installieren[emoji24] [emoji24] [emoji24] [emoji24]
Als Vergleich anbei das original von xda
Danke für das bearbeiten deines openers[emoji6]
Somit betrachten alle bitte Beitrag 2 als gegenstandslos
@vergilbt
Was hast Du für einen Kernel drauf? Ich nutze diesen Despair.M.Shamu.R4.4, läuft ohne Probleme.
WiFi und Ortung sind bei beiden aus.
Bin auf Arbeit kein Wifi, nur Daten an.
WiFi nochmal ein aus, jetzt wird es nicht mehr angezeigt. [emoji1]
Welchen weg der Installation habt Ihr genommen? Muss ich wirklich erst die M Preview per Toolkit flashen oder reicht nur Bootloader und Radio?
So war meiner -> [N6] Android M - Developer Preview Installation nach M2
diese ROM: xTraSmooth_MPZ79M_Shamu_18.07.2015.zip auf internen Speicher kopieren und auch gleich die SuperSU Download mit
  1. adb reboot bootloader
  2. fastboot oem unlock
  3. fastboot flash bootloader bootloader-shamu-moto-apq8084-71.11.img
  4. fastboot flash radio radio-shamu-D4.01-9625-05.16+FSG-9625-02.94.img
  5. fastboot reboot-bootloader
  6. TWRP: fastboot flash recovery Nexus_6_openrecovery-twrp-2.8.5.0-shamu.img oder twrp-2.8.7.1-shamu.img
  7. fastboot recovery
  8. im TWRP habe ich alles formatiert - system - data - cache - dalvik cache
  9. TWRP Install xTraSmooth_MPZ79M_Shamu_18.07.2015.zip
  10. Reboot System...
... fertig.
Kernel für TWRP:
http://renderserver.net/devs/DespairFactor/shamu/kernels/Despair.M.CFS.Shamu.R4.4.zip sehr mit Einstellmöglichkeiten - App dazu Kernel Adiutor (ROOT)
oder
hells-Core kernel blog: Nexus 6: b9 / b3-M2
hC-b3-M2
hC-b3-M2-mako
z.B.
kein Sweep2sleep, Sweep2wake und doubletap2wake
max, min und Bildschirm aus Freq.
mit adiutor
mit Kernel Toolkit
mit Trickster
Reaktionen: vergilbt und Angus
Ich habe nur im twrp das radio und den Bootloader aktualisiert und danach direkt die ROM geladen...
Hatte das aber schon Ende Mai mit der preview 1 gemacht
So, neues build ist on...
Bin gerade am laden.
Laut Daniel mit noch besseren Batterie-werten... Und sein post mit antutu über 55k ist auch mega (ich habe mit dem letzten build "nur" 49k)... Auch wenn eigentlich völlig irrelevant
Link zu seinem post:
[ROM][M2][MPZ79M-LVY48C][28.07.2015]xTraSmoo… - Pg. 133 | Nexus 6 | XDA Forums
PS: der jetz letzte hells-kernel ist auch drin
Reaktionen: Hen Ry und Angus
Was ist mit dem Updater, der zeigte nichts an?
Habe die updater-APP nicht drauf... Mache ich manuell[emoji6]
Ja ich auch, ist heute früh gleich passiert.
Ich finde es aber gut, das der updater nicht mit in der ROM ist wie bei anderen... So kann ich entscheiden
Sweep2wake geht mit diesem Kernel nicht?
Diese Funktion finde ich ganz praktisch, schont die Taste.
Geht schon, nur deaktiviert...
Lade die "kernel adiutor" aus dem store und aktivierte es dann dort...
Reaktionen: Hen Ry
Hatte ich schon drauf, zeigt tap2wake an. Im Kernel Toolkit und Trickster ist nichts davon zu sehen. Ich meinte sweep2wake.
Oh, Sorry, verlesen...
Wenn du sweepen willst musst du @flar2 seinen elemental kernel verwenden... Der kann das
Reaktionen: Hen Ry
Hatte ich auch schon getestet, stimmt.
Despair.M.Shamu ist auch nicht schlecht, da geht noch mehr.
Sunny
Sunny
Sunny
SaschaKH
Netbook
Netbook
Hen Ry
Toddel1966
Toddel1966
