jeykee
@adee Bei mir ist das Problem doch wieder aufgetreten. Lag also nicht an einem vermeintlichen youtube Update. Schade.
https://forum.xda-developers.com/showpost.php?p=70564323&postcount=1104 schrieb:Update:
purenexus_hammerhead-7.1.1-20170115-HOMEMADE.zip | by GtrCraft for Nexus 5
-Just an updated to follow up the official 13-01 update, nothing more
Klick auf die Google App.Thakis schrieb:So, habe gerade die version vom 15.01. geflasht.
Wie bekomme ich denn Google Assistint zum Laufen?
Laut den Patchnotes müsste es doch nun dabei sein.
Download | Changelog | PN
- Change: update phone and calculator icons to circle icons
- Change: expose quick settings tuner switch bar for themers
- Change: expose settings switch bar for themers
- Change: expose settings dashboard category padding for themers
- Change: expose framework-res manifest styles for themers
- Change: sync statusbar battery style with quick setting battery
- Feature: Contextual Header images and image packs
- Feature: ability to change amount of rows in quick settings
- Feature: ability to disable quicksettings tile titles
- Feature: added one handed mode and toggle
- Feature: added double tap to sleep on navbar option
- Feature: added ability to hide vpn and data saver icon in statusbar icons
- Fix: speakerphone bug on nexus 6
- Fix: ok google everywhere on all devices even Pixels
- Fix: backup/restore functionality on Pixels
- Fix: home button force close issue with pixel animation enabled
- Fix: pixel animation toggle it now works instantly
- Fix: grayscale in ambient display inversion on dark themes
lulli schrieb:Was passiert denn wenn du ok Google sagst?
Was funktioniert konkret nicht? Wenn wir helfen sollen, brauchen wir bitte Infos.
