[ROM][Lollipop 5.1.1][HAMMERHEAD]Cataclysm for Nexus 5[Sep 27- Stable Final]
  • 1.037 Antworten
Vielleicht hilft das neue nightly :)
atl4ntis schrieb:
Well this was unexpected, i guess this happened cause i didn't publish the release notes last time :o.
The dialer issue some experienced is fixed, in case you still have issue you may need to set your network mode in Settings-More-Cellular Networks, just once.
Swipe2Sleep is again optional now and Volume wake while calling is handled aswell.
New PT-(Brazil) and Korean translations are merged, thanks @brenopapito and _Aengjul.
Thanks for other translations/fixes to HTC mania community, @michaelz93, @jvbferrer, @mr-tical and everyone else who's still working on other languages.
MD5: 5a30f65e9a0c2e58ffd485e8c66c84f1
SHA1: 64de6b4f8c1134ae08c9e39d1d2f0c1efa30a59f
Flash over any Cataclysm release since Dec 24, no wipes are needed.
Changelog:
Jan 19, 2015: Swipe2Sleep is again optional.
Jan 19, 2015: Volume wake: while in call can adjust volume, press volDown and volUP at same time to wake.
Jan 19, 2015: Fixed possible dialer issue due to Smart Radio race condition even when disabled.
Jan 17, 2015: Swipe to sleep: misc fixes. Cataclysm Jan 17, 2015 Nightly Update (25MB)
Jan 17, 2015: Disable low battery blinking led.
Jan 16, 2015: Cataclysm settings: entries are now indexable and appear in Search bar.
Jan 15, 2015: SmartRadio: don't downgrade if wifiAp is active.
Jan 15, 2015: Per-app settings: force headsup, disable headsup if available.
Jan 15, 2015: Per-app settings: block lockscreen notifications, block ongoing lockscreen notifications.
Jan 13, 2015: Wider landscape notification panel/quick settings layout.
Jan 13, 2015: Volume cursor control (inverted).
Some old informations i couldn't post earlier:
Swipe to sleep should be perfect now, I've decided to drop the builtin swipe detector for my dedicated one and now all the issues are solved.
Landscape, whether the swipe started from a button, swipe getting triggered when far away from navbar, gnow possible issues etc.
Disable blinking led is temporarily in misc settings until i add full customization.
You may need to clear settings app data to have Cataclysm settings showing on search bar now.
It may happen to have two entries of same name, it's ugly but kinda "normal" (read how Google made it).
Same happens for example for "Other sounds". One entry is the listed one among others, the other is the "inside" of it.
Moved Hide brightness slider and the new Wider notification panel in quick toggles options which now serves for Notification panel aswell.
Decided to make the Notification panel just wider in landscape instead of full width as it wouldn't cover all anyway due to the navbar.
Expecially in lockscreen would've been ugly.
Smart radio change (the wifi ap one) is not optional, is default. I prefer to keep things as simple as possible and don't think having it optional would make any sense.
Per app settings now covers the notifications but is meant to have room for many other options aswell.
Is worth noting that now you can per-app disable already existing headsup other then forcing new ones aswell.
Und stable
atl4ntis schrieb:
New year, new stable. Old one was already stinking =].
Thanks everyone for the suggestions, feedbacks and translations.
As already said few posts ago, todo list is almost done so i'm gonna play it by ear from now on.
When i started recoding almost everything with Lollipop this goal was like a dream, but now almost everything has been done, improved, better.
No more reasons to look to KK with nostalgia.
I've added a little easter egg, this was something planned since ever and now finally got my hands on it.
It's just a small thing don't expect anything special, high five to whoever find it, it's not hard.
Downloads are up on AFH and DevHost (links on OP), will be uploaded overnight on BasketBuild aswell.
Should be safe to dirty flash it but, as always, consider a clean flash if you got any issue.
MD5: 57569fd1f30f5931d78907db53c81406
SHA1: 6322ea5d94089d2934117ccb75cca8175985d5ac
For nightly users there's an update zip here. The update zip will update any Cataclysm release since latest stable up to now, even latest stable users can use it.
Changelog (Only relevant changes from latest stable, in bold from latest nightly):
Jan 21, 2015: Show restrict mobile background data preference in Per-app settings.
Jan 20, 2015: Display the time elapsed since last full charge on battery stats.
Jan 20, 2015: Disable battery saver orange bars.
Jan 09, 2015: Navigation bar swipe to sleep.
Jan 09, 2015: Allow locking current landscape orientation with rotation toggle.
Jan 07, 2015: Longclick expanded clock/date for clock app.
Jan 07, 2015: 3G only/LTE only network modes.
Jan 07, 2015: QuickToggles: Volumes.
Jan 03, 2015: Hide persistent alarm icon.
Jan 03, 2015: Close dialer on hangup.
Jan 03, 2015: Show menu on both sides.
Jan 02, 2015: Settings backup.
Jan 02, 2015: Hide brightness slider.
Jan 02, 2015: Quick Toggles: resize, hide labels, custom columns, unify, longclick.
Jan 02, 2015: Expandable volume panel.
Very little changes since latest nightly as it's a stable.
- Decided to give users an option to disable the orange bars on battery saver. I don't see the point changing the color when you can just disable it. Bars transparencies will be respected while in battery saver and orange bars are disabled.
- Battery stats now shows the time on battery, like in KK but in a different spot. It's kinda easier now to know the total time on battery with a quick glance at it.
- Copied the preference where you could disable the background data for an app while on mobile in Per-app settings cause it fits very well there.
It also allows you to configure it even if doesn't show on the usage data charts.
Every change you make on the Per-app settings will show on the app listing as summary, they will nicely auto scroll to show all the details if too many.
- Many translations fixes and updates.
Reaktionen: sakerhetz, Tamro und BorussenTobi
könnt ihr mal bitte schauen was bei euch passiert wenn das Telefon per pin gesperrt ist und ihr auf Notruf geht, dann die hometaste drückt? Bei mir ist das Telefon dann entsoerrt?!
Hatte temporär smartlock ausgeschaltet
Bei mir bleibt es gesperrt...
Reaktionen: mrorange2108
nach einem Reboot ist auch wieder alles wie es sein sollte... konnte es aber vorhin ständig reproduzieren
hatte auch smart lock nicht deaktiviert, sondern nur den unter Zuhause gespeicherten Ort ausgeschaltet. Da kam dann erwartungsgemäß auch die Pinabfrage, ließ sich aber eben umgehen
Neue beta
atl4ntis schrieb:
Thanks to all the alpha testers.
While still in needs of some tweaks here and there i've come to a conclusion that this update is mature enough to be released "officially", at least as nightly/beta.
MD5: 5334ed4e3fa3c90ab699e2e97e3fb927
SHA1: f8dfac87a81ffcbf4412b3c05c106547aa875281
Changelog:
Feb 05, 2015: Per-app settings: custom LED color.
Feb 04, 2015: Volume controls always music stream.
Feb 04, 2015: Battery saver scheduler.
Feb 01, 2015: Per-app settings: custom Locale.
Feb 01, 2015: Per-app settings: custom DPI.
Jan 31, 2015: Per-app settings: allow background data while on battery saver mode.
Jan 31, 2015: NFC polling mode: fix screen on locked.
Jan 26, 2015: Per-app settings: AppOps.
Jan 25, 2015: Softkeys Fade Mod.
So i've added the Led customization. I've decided in favor of it cause the per-app bones were already there so the whole thing took very little time/resources.
Since it uses the per-app settings currently the charging led is still not customizable.
I didn't add any fancy color picker, the led can barely show the primary colors so added only them.
While will add some visual color picker in the future i think a 16 million one is utterly pointless for a led.
Please keep in mind that the missed call notification comes from Phone process, not Dialer. So if you want to change the led color for it you have to pick the Phone not Google Dialer. The opposite for the headsup call, etc. Not hard to figure it out yourself.
EDIT:
Still figuring out the best led priority, currently i gave prio to the last notification, ( you got a red notification , arrive a "blue" one, you see the blue).
I'm open to suggestions.
Custom DPI may still have some glitch but nothing disruptive. Most of the apps should work fine.
It probably won't ever be perfect without loosing efficency and there are some situation where the issues can't really be addressed (notifications) so will closely look at it in the following nightlies and evaluate the pros and cons.
If it's a keeper or not.
To reset custom DPI to default just leave the field blank.
To reset custom Locale or LED to default just select the first "Default" entry.
I've added the battery saver scheduler, without entering deeply into details keep in mind that can take up to one min to actually fire it up and the same to shut it down.
Moved the "Disable orange bars" from misc to the new Battery saver options.
Rest of features are pretty self explanatory.
Translations are still on hold so please have patience if i don't answer to your PM.
Upon requests here are a couple of broadcast intents some experienced users may find useful.
Made them simple without extras and such as i don't know what you use, how, and your knowledge.
If you don't know what they are you shouldn't use them.
Code:
android.cataclysm.intent.action.BATTERY_SAVER_ON
android.cataclysm.intent.action.BATTERY_SAVER_OFF
android.cataclysm.intent.action.SMART_RADIO_ON
android.cataclysm.intent.action.SMART_RADIO_OFF
About the RRO support, since apparently those commits are already merged in AOSP i'd just wait for the next android update.
They will probably be in the 5.1 release that ships this month.
I prefer this way cause would be a problem to provide the usual incremental update with them.
Wie funktioniert das genau? Was muss ich da einstellen das die led z.b. für Whatsapp grün blinkt?
Es gibt in den Per-App-Settings dafür eine Option. Weiß aber nicht ob sie funktioniert.
Bei mir tritt bei der Funktion Wake on Notification der Fehler auf, dass das Display immer wieder aktiviert wird und nicht nur einmalig.
Ich denke, dass das so nicht gewollt ist.
In der Per-App-Settings sind bei mir nur die Apps zur Auswahl. Wo soll ich da was einstellen. Also ich Blick es nicht wirklich ;-) würde mich über Hilfe freuen
Ja, und wenn du dann die gewünschte App auswählst, erhältst du die entsprechenden Optionen. uploadfromtaptalk1424537732918.png
Reaktionen: marcodj
Danke aber das funktioniert nicht. Hab da jetzt ne Farbe ausgewählt aber es leuchtet nichts beim Eingang einer Nachricht.
Evtl sowas wie light Manager installiert?
Reaktionen: marcodj
Jetzt geht es. Hatte noch Lightflow drauf aber deaktiviert. Nachdem ich es deinstalliert hatte geht es jetzt. Danke euch
Gestern wurde eine neue stabile Version veröffentlicht.
Reaktionen: Ranzbock
Sagt mal, ich bin auf der letzten Nightly und habe immer noch das Problem, dass sich des öfteren die Lautstärketaste während des Kopfhörerbetriebes selbständig macht. Seit dem ich auf Catac bin besteht dieses Problem. Auf Euphoria hatte ich dieses Problem nicht. Wisst Ihr woran das liegen kann?
Ich habe auch eine Frage. Bin auf der stable von gestern.
Kann ich das power Menü erweitern?
Und wenn ja wie?
Siehe Screenshot
Nein, nur die erweiterte Reboot Funktion kannst du über Miscellaneous hinzufügen.
Mit der Lautstärketaste habe ich kein Problem.
Okay danke
Dann kann man ja gespannt sein wann die erste Version basierend auf 5.1 kommt....
