BorussenTobi
Neues Update
Hey everyone,<br />
i'm very happy for this update as it brings many fixes.<br />
Fixes are very welcome to me as i want everything to be perfect.<br />
<br />
The only reported issue not investigated fully is the nfc one as i tried to debug it with some users help but it's just not possible to do it via mail.<br />
Will buy some nfc tag to do some testing in the next few days. (Note that NFC default behavior works without issues, is the option to make it working when screen is off or locked that seems isn't).<br />
<br />
I've also started accepting translation requests, so if interested feel free to PM me.<br />
Some translations are already merged in this update, ES/PL/ZH-rCN.<br />
I wanna thank @bush911, @JOSNARO, @michaelz93, @mr-tical, and everyone else still involved now and in the future.<br />
For any translations issue,fix and suggestion please refer to the relative translator.<br />
<br />
<br />
Download is on OP and can be flashed on top of Dec 24 Stable release <b>and above</b>.<br />
No wipes are needed, don't mount /system.<br />
This time aswell cache won't be wiped so the overall update process will take a couple of minutes only, even less.<br />
<br />
MD5: 871df8fb7be97db6bf84445746f4843e<br />
SHA1: 8fe09f6a568032f05b3acca9bf9f8ff718e6f8bc<br />
<br />
Here's the changelog since latest nightly:<br />
<br />
Jan 09, 2015: Navigation bar swipe to sleep.<br />
Jan 09, 2015: Allow locking current landscape orientation with rotation toggle.<br />
Jan 09, 2015: Close dialer on hangup only if is foreground.<br />
Jan 09, 2015: Fixed disable QS on secure lockscreen still showing them under some conditions.<br />
Jan 08, 2015: Backup: correctly restore "Hide alarm icon" and "Close dialer on hangup" values.<br />
Jan 08, 2015: Fixed FC restoring backups with animations scale and/or smart radio never used.<br />
Jan 07, 2015: Longclick expanded clock/date for clock app.<br />
Jan 07, 2015: 3G only/LTE only network modes.<br />
Jan 07, 2015: QuickToggles: Volumes.<br />
Jan 05, 2015: Center toggle's icons (and glow) and regain wasted space when hiding labels.<br />
Jan 05, 2015: Fixed battery text not showing below 5% under certain conditions and styles.<br />
<br />
<br />
<br />
<br />
Thanks for the feedback on toggles labels, now it's indeed better (center the icon and regain label space when hiding them):<br />
<br />
<br />
<br />
Also added brightness control on flashlight longpress as it was the only one without longpress action.<br />
It comes handy if you disable the brightness slider.<br />
Keep in mind tho that the brightness dialog won't appear if lockscreen is secure, you need to unlock it like for every other activity.<br />
<br />
With the swipe to sleep feature i hope the requests for double tap to sleep will come to an end.<br />
This is optional so no problem if you already use it with your kernel, tho it *should* coexists even with both enabled.<br />
I've made it so a short swipe should be needed, and regardless of the start. i.e you can swipe just on top of home button , either left to right or right to left.<br />
This is also implemented at rom level so it will work regardless of the kernel used.<br />
<br />
LTE/3G only network mode is not working so didn't add it.<br />
LTE only and 3G only, when checked, are applied system wide, to Smart Radio and Network mode toggle.<br />
<br />
I've choosed to add (upon suggestion) a longpress action for clock app to expanded status bar clock and date.<br />
Since i think they're too close each other to make two different shortcuts, i made them so basically both link to calendar on click (this was already implemented), both link to clock on longclick.<br />
<br />
Rotation toggle used to lock and unlock rotation but had the awful behavior to not lock landscape and to revert the rotation to portrait when locked.<br />
This has been changed so you can lock whichever rotation you want.<br />
For a quick swap/rotation if for example you're locked on landscape you can longpress it to lock to the opposite rotation.<br/>
Hey everyone,<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
