4tticuz
Stamm-User
- 114
Ja, finde leider nicht die entsprechende Einstellung, DIW dafür zuständig ist
atl4ntis schrieb:Hey everyone,
this update was meant for tomorrow with few more additions but unfortunately will be too much busy due to some unexpected events.
I didn't modify any core file so this update won't clear your cache and it'll be up and running in a couple of minutes only.
Download links are on OP.
MD5: 09cded0bfc4080116384c8398856ee24
SHA1: 89debcf2448d41d7fd1dc1f20dfd5eb138c1205c
Just install, don't wipe anything, don't mount /system.
Changelog:
Jan 03, 2015: Hide persistent alarm icon.
Jan 03, 2015: Close dialer on hangup.
Jan 03, 2015: Show menu on both sides.
Jan 02, 2015: Settings backup.
Jan 02, 2015: Hide brightness slider.
Jan 02, 2015: Quick Toggles: resize, hide labels, custom columns, unify, longclick.
Jan 02, 2015: Expandable volume panel.
Few notes on this update:
The persistent alarm icon i'm referring is the one always up, not the one when alarm is about to run.
I'm not sure which one you wanted to hide but i find more annoying this one.
Show menu on both sides just mirror the right menu on the left side aswell when is up, for simmetry or left handed. Keep in mind this won't force the menu to pop, to force it there's another option.
Quick toggles received a lot of love this update. You can do pretty much anything you want now.
Since you can disable the labels now, changed the network mode icon to something related to the mode itself, so you don't have to rely on the label to check it.
Unify will convert wifi and bluetooth toggles as others so you can rearrange them and have other toggles with them together.
Doing so you will loose the ability to click the label, so added a longpress behavior to every toggle to mimic the label behavior.
Most of the toggles longpress behavior is just a link to the relative settings.
Few exceptions are:
Network mode --> Smart radio.
Screenshot --> takes screenshot without collapsing the bar.
Rotation --> alternatively lock the phone in portrait and finally landscape mode aswell.
Many few tweaks here and there, notification stream volume got new icon to differentiate it from ringer in expanded volume panel.
Animations speed got sliders without dialogs. Animations speed in dev settings will reflect cata settings ones aswell.
OCD people screaming at me in PM got finally Nfc and Gps renamed to GPS and NFC.
The colorfade leak fix is here but i'm pretty sure it won't solve the big leak some people are experiencing.
etc etc etc.
