[ROM][Lollipop 5.1.1][HAMMERHEAD]Cataclysm for Nexus 5[Sep 27- Stable Final]
  • 1.037 Antworten
Und update
atl4ntis schrieb:
Ok enough of waiting, as soon as i can make a fully 5.0.1 will update this again. Don't expect too much from it tho, took a look at the changes and i'd not be surprised if N5 factory images won't even be released.
Back on topic, i'm very happy about this update cause it brings Cataclysm in a state i wanted since started working on Lollipop version.
Of course this doesn't mean a stop in development, there are many other features to be implemented, like lockscreen shortcuts or incall blocker , some multiuser love and so on.
This update is HUGE, you read just few lines in changelog but if i'd write down everything was involved in every features i'd write dozens of pages.
Keep in mind i couldn't test it fully in this little time..
Few notes:
In a continued effort to provide a 100% google experience i've decided to make the last two non stock features optional:
Nov 29, 2014: Clear all recents button is now optional.
Nov 29, 2014: Reboot entry in powermenu is now optional.
Make sure to enable them if you used to use them. If you find some other non stock feature enabled by default just let me know.
Mem free on system stats will tell you your real free ram counting the cached apps as free, actually i think no app can do it.
Silent mode is back, google implemented a flag to prevent removing zen mode none by pressing volumes accidentally and i actually like it.
Silent mode is the same. TL;DR if you set silent mode with toggle, you gotta remove it from toggle.
Silent mode is the classic one, led goes through, alarms etc.
Ringer mode goes through your zen modes aswell so of course using ringer mode will overwrite your zen settings accordingly.
If you see a star "*" in the network mode toggle label, it means you're using smart radio.
Changing network mode with toggle disable smart radio or would create loop switches.
Network mode toggle isn't available for CDMA users.
For other features please refer to the changelog.
This zip will update any of your Lollipop Cataclysm installation to latest.
- No wipes needed
- Do not mount /system.
- Just boot into recovery and flash it.
- First boot may take a lot of time.
Nandroid backup before the update is recommended.
A full stable release will appear sometimes in the future, probably on 5.0.1.
If you don't have any Lollipop Cataclysm installation you can grab an older full release and apply this zip over it without rebooting.
The update zip is on usual directories on first post
MD5: d6581c73c303a910ce5cb44e007fe1ad
SHA1: cdaf06bf5169a661a7a3df5ecdb40e1965ed01a8
Here's the changelog:
(In bold the very latest changes, but zip contains all of them.)
Dec 03, 2014: Battery Styles: Stock / Stock + Inner Text / Text only / Gone.
Dec 02, 2014: Quick Toggles: Network mode (2G/3G/LTE) - Gps.
Dec 02, 2014: Quick Toggles: System Stats (CPU speed/temp - Network speed download/upload - Memory free (real, include cached).
Dec 01, 2014: Longpress reboot in powermenu for hotreboot (zygote restart).
Dec 01, 2014: Quick Toggles: RingerMode (normal/vibrate/silent/priority/none).
Nov 29, 2014: Quick Toggles: Screenshot - Nfc - Sync - Screen Timeout.
Nov 29, 2014: Longpress back to kill won't kill screenpinned apps.
Nov 29, 2014: Disable Quick Settings expansion on secure lockscreen.
Nov 27, 2014: Fixed switches in appops detail being out of the view sometimes (aosp bug).
Nov 27, 2014: Temporarily fixed animation when pulling directly QS without notifications and while not on lockscreen (aosp bug).
Nov 26, 2014: Lockscreen rotation.
Nov 26, 2014: AM/PM on statusbar clock.
Nov 26, 2014: Center statusbar clock.
Nov 26, 2014: Quick PIN unlock.
Nov 25, 2014: Volume rocker wake: correctly eat the volKey after waken.
Nov 25, 2014: Fixed sleep button overlap with QS Header switch when closing QS with showdetails.
Nov 24, 2014: Aggressively disable Play Services System Update causing wakelocks for some users.
Nov 24, 2014: Fixed sleep button overlap with QS Header switch.
Nov 24, 2014: Shortened longpress to kill to 1s (down from 2s).
Nov 24, 2014: Disable statusbar clock.
Nov 24, 2014: Disabled dun required for Wifi tethering.
Nov 24, 2014: Volume rocker wake. Press both volUp and volDown to wake if music is playing.
Nov 24, 2014: Moved clear recent button up for pie users. Faster/smoother animation. Fix showing when not needed.
Nov 24, 2014: Vibrate on call remote pickup/hangup.
Und jetzt stable
atl4ntis schrieb:
Hey everyone.
This update isn't mean to be new feature filled but just a full stable release, basically the Dec 03 with last bugs ironed out.
A fresh stable start. Thanks everyone for the feedbacks. Couldn't have made it in two weeks without your help.
From now on updates will be compatible only with this release and onward.
This has been tested working so whathever issue you can have during flash it's your fault only, so just read carefully everything it's been already written and don't clutter the thread with always same questions., like /system resource busy.
Supersu is already included and updated to latest 2.37.
As soon as i get some time will release on OP a pack with strings if you're willing to translate them, but you really gotta do all the job so i can merge them directly, can't spend days like on kk, merging every single line from a simple txt file for every language.
Zip is on usual directories.
MD5: f320bba1cc3971bcd6687ec0dc832d7c
SHA1: 4d3fc61cafabbfabc885a91c959817ff026adb27
Don't wipe /system, zip will do
Don't mount /system, zip will do
I've uploaded an update zip for older relases. If coming from 03 Dec, update should be fast as it won't wipe your cache cause didn't change any core file. The download is available only with this link, as it's not visible on usual directories cause it may confuse people flashing it over the new stable release.
I've created a third mirror on BasketBuild, will appear on OP sometimes in the next hours.
Probably won't be much active this weekend as i have to attend some family things.
If you want a list of features already implemented just read the changelog, it's user friendly written.
Please don't ask everyone for active display, this looks like the pie/ribbon/halo all over again. There's an app for it, try it.
Here's the list of the still missing features from KitKat Cataclysm. Expect many to be implemented but not all of them, cause Lollipop changes or cause they don't fit anymore in my opinion.
Of course new ideas and features will come.
[HIDE]
QuickToggles: inCallBlocker - ScreenRecorder - Volume - Fast Charge - Wifi ADB
Cataclysm Settings - Hot Reboot - Ime switcher -
Usb tethering - Hide navbar - Immersive mode -
- Quick toggles 4 colums layout
- Disable ime switcher
- HSPA + support on statusbar
- InCallBlocker
- Softkeys Fade Mod
- One click app picker
- Adds 20 music volume steps, up from 15
- Custom Lockscreen Wallpaper
- Immersive mode
- Battery: Circle battery
- Nfc polling mode. Disable Nfc sounds
- Expandable Volume Overlay
- Unlink Notification Volume
- Force show menu
- Optional data activity overlay on statusbar
- Remember Headset Volumes
- Custom Lockscreen Targets
- Statusbar brightness control
- Screen recorder service
- Move phone app back after call
- AOSP Keyboard Customization
- Volume Rocker Music Control
- Lockscreen styles (hide statusbar/navbar/both)
- Full screen lockscreen
- Led notification support for missed calls.
- onClick and onLongClick actions to StatusBar Clock/Date
- Double line layout for statusbar date
- Rom settings backup support
- 3G Only network mode
- LTE Only network mode
- Go Home after a phone call
- Announce caller over earphones/headsets (tts).
- Hide phone number to unknown
- Optional CRT animation - Landscape animation
- Longpress lockscreen slider to unlock
- Disable lockscreen camera
- Disable Safe Headset volume warning
Some quick new ideas:
QuickToggles: Power Saving - Compass
Multiuser love
More appops
Hide brightness slider
MVNO roaming
Hide user icon
Reneable notification ticker
Hide search bar in recents
Better quick toggles landscape layout
[/HIDE]
Reaktionen: sakerhetz und Bödi
Guten Abend,
Ich habe eine frage bezuglich Cataclysm kann man da auch ein Dark Theme fur kriegen???? Dass Weiss gefallt mir nicht so.
Und ich sage Danke Schon:)
Reaktionen: razooor
Hab Cataclysm mal als zweit Rom aufgespielt und etwas getestet mit dem ElementalX Kernel. Läuft auf jeden Fall gut, wenn man bedenkt wie schnell hier gearbeitet wird. Muss mir noch überlegen ob ich sie als Daily Driver benutze oder weiterhin erstmal bei Kit Kat bleibe, denn es fehlen mir persönlich doch noch sehr viele Sachen.
Ich habe heute die ROM geflasht.
Bei mir wird die SD karte auch nicht mehr erkannt.
Wenn ich TWRP recovery starten will dann bricht es ab und bootet das System?!?
Jetzt kann ich nichtmal mehr mein backup einspielen.
Jemand ne idee wie ich das wieder hinbekommen kann?
in den FAQ steht:
My files on "sdcard" are missing.
- From adb shell when on recovery run this command without quotes "restorecon -FR /data/media/0".
aber ich komme nicht mehr ins recovery:(
Nutze CWM, kann deshalb nix dazu sagen, hatte allerdings auch das Problem, dass die Daten weg waren... Weiß aber nicht, was ich falsch gemacht habe ;)
ich würde ja auch gern CWM flashen. das problem ist nur, dass ich die .img nicht einmal laden kann da das nexus die Datei nicht speichern kann.
habe echt keinen plan wie ich aus der nummer wieder rauskommen soll
Zuerst: Keine Panik. ;) Kannst du in Fastboot starten und von da aus ins Recovery?
Reaktionen: paol0
ich versuch das mal... muss mich mal einlesen in das tut
OK, das hättest du natürlich schon viel früher tun sollen.
Drück Power Button + Volume Down für etwa 7 Sekunden. Das Handy startet neu und wird im Fastboot Modus gestartet. Hier kannst du mit der Lautstärke Wippe auswählen und mit Power bestätigen. Da dann Recovery wählen und bestätigen.
sorry hatte dich falsch verstanden. ja das habe ich getan. fastboot startet auch. wenn ich ins recovery möchte dann kommt kurz der teamwin bildschirm. dann wird er schwarz und das system wird direkt gestartet
Ich würde tippen, dass du aus irgendeinem Grund dein Recovery verloren hast. Das kannst du aber über Fastboot neu flashen, ohne Datenverlust. Eine Anleitung und die befehle dazu findest du hier im Forum.
Und zu dem Problem mit der SD-Karte: ich hatte das neulich auch und auch bei verschiedenen Roms. Bei mir hat ein Full Wipe geholfen, und zwar folgendermaßen (alles unter TWRP, was übrigens meiner Meinung nach das bessere Recovery ist, weil aktuell und weiterhin in Entwicklung):
1. Reboot ins Recovery
2. Nandroid Backup inkl EFS anlegen
3. Mounts >> Haken bei "System" rein
4. Wipe >> Advanced >> alles außer "Internal Storage" anhaken und wipen
5. Schritt 4 weitere 2x ausführen
6. Mounts >> Haken bei "System" wieder raus
7. Install >> Rom + SuperSU flashen
8. Reboot >> Recovery (manchmal kommt hier eine Warnung, dass kein OS (Operating System = Betriebssystem) installiert ist; kann man ignorieren und trotzdem starten
8. Install >> Gapps flashen
9. Wipe >> über den Schieber unten direkt bestätigen
10. Nach Bedarf Alternativen Kernel flashen und was man halt sonst noch so braucht
Reaktionen: paol0 und CVH
in den FAQ steht:
Lade dir terminal emulator aus dem Store https://play.google.com/store/apps/details?id=jackpal.androidterm
Dan gib den Code ein der unten steht.
Das hat bei mir bisher immer funktioniert. Sd wurde erkannt und alle Daten waren immer da.
su
Reaktionen: paol0
Ja, ist dem so, dass es nicht mehr weiter entwickelt wird? Ich bin seit meinem S2 damals auf CWM und immer zufrieden. Hab hin und wieder TWRP ausprobiert, kam damit allerdings nicht wirklich klar :)
@OnkelDan vielen dank dafür !
Ich kann endlich wieder auf die Karte zugreifen.
Allerdings startet twrp immer noch nicht obwohl ich es über fastboot neu geflasht habe.
Cwm startet aber
Danke für den link. Ich dachte schon ich bin der einzige mit dem Problem.
