[ROM][KK 4.4.4][CM-AOKP] CarbonRom for Nexus 5 [NIGHTLIES]
  • 168 Antworten
Bödi
Bödi
Philosoph
6.180
Thread bei XDA.​
:: Über die Rom.
Die Carbon Rom, die für viele verschiedene Geräte entwickelt wird, zeichnet sich einerseits durch hohe Stabilität, andererseits durch vielfältige Einstellungsmöglichkeiten mit vielen zusätzlichen Features aus (im Vergleich zu Stock Android Roms). Hierbei wird darauf geachtet, dass regelmäßig Updates erscheinen, die stets die aktuellste Hardware unterstützen. >> CarbonDev GitHub
We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
Please feel free to look at, build, and use our code on CarbonDev GitHub.
We would like to thank CyanogenMod for their device trees, framework/settings mods and their code that was incorporated into this project. We also extend our gratitude to the devs whose code that we have incorporated. Proper authorship has been maintained and can be viewed on our repository.
Special thanks also go to Slim Rom for some of their features, AOKP, and anyone else we may have borrowed commits from that hasn't been mentioned here. If you feel you have been unfairly left out, please - let us know.
While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device, family, pets, or perception of reality. We ask that you do your part to know your device and know how to recover from problems before you flash! If you have questions, ask your fellow users or ask us in #teamcarbon on freenode IRC.
:: Screenshots.
... siehe Anhang. :)
:: Installation.
  • Wipe cache partition
  • Advanced -> Wipe dalvik cache
  • Mounts and storage -> Format /system
  • install ZIP from SDCard
  • ZIP auswählen, Installation abwarten
  • Gapps flashen
  • dann Reboot system auswählen, abwarten
:: Danke an...
Thanks to Team Carbon.
Who is Team Carbon?
andros11
BigShotRob
Bionic Beast
dg4prez
Kejar31
mattmanwrx
morfic
nocoast
pixeldotz
slick_rick
winner00
PatrickC
gingofr
Andy Fried​
Reaktionen: sven78bln, Magiya, DMX und 7 andere
Danke fürs Einstellen!
Interessant wären aber schon auch eigene Erfahrungen, gibt es die?
(ich muss auf mein N5 leider noch etwas warten)
Gerade geflasht, bisher alles gut. Nach dem ersten Flashen und der Eingabe meiner PIN für die SIM-Karte stand ziemlich lange "SIM-Karte wird entsperrt" (ich glaube aber auf englisch) aber es tat sich nix. Habe dann neu gestartet und dann ging es auch. Beim Einrichtungsassistenten kam dann folgende Fehlermeldung:
Soweit läuft alles flüssig. Allerdings bekomme ich kein Root mehr. Seltsam. Ging mir eben mit SlimKat auch schon so. Kann es daran liegen, dass ich eben unter SlimKat den Franco Kernel geflasht habe?
Edit: Habe die SuperSU.zip von HIER im Recovery geflasht - jetzt geht's. :thumbsup:
Reaktionen: blur
Danke, das fängt ja schon mal gut an.
Es ist ein Segen wenn Pico nicht funktioniert, hört sich fürchterlich an :D
Lässt sich supersu manuell durchs Recovery flashen?
Ja, genau so habe ich es gerade gemacht (habe meinen Beitrag oben editiert).
Ok, dann ist ja wieder alles gut....
Reaktionen: Bödi
Gerade entdeckt, dass "Quiet Hours" mit drin ist (finde ich super! :winki: ). Habe gerade noch zwei Screenshots hinzugefügt.
Reaktionen: Radagast
geil!!!
bestes ROM auf dem s3 gewesen...und ich hoffe das auch schnell active display dazu kommt :)
Vergesst aber nicht, dass es sich hier um ein sehr frühes und dazu noch inoffizielles Build handelt.
Das Problem mit dem fehlenden Root nach dem flashen des Franco-Kernels auf der Slim wird auf XDA mehrfach diskutiert...aber Du hast die Lösung mit dem manuellen flashen von SuperSU ja schnell gefunden :)
by the way: Rom immer noch Stock. Ich warte auf die QuickSettings in der Slim ;-)
Bei mir hat sich die Systemsprache mittlerweile selbständig auf englisch umgestellt. :D Über den Tag lief die Rom aber gut.
Reaktionen: konsumhaus und Radagast
Das macht mir Angst :scared:
Die Maschinen leben :lol:
OT Ende
Bödi, gute Arbeit, Post 1 gefällt mir echt gut von der Aufteilung :thumbsup:
Reaktionen: Bödi und konsumhaus
Neues Build vom 16.11.2013 is out :flapper:
CARBON-KK-UNOFFICIAL-20131116-1021-hammerhead.zip
CARBON-KK-UNOFFICIAL-20131116-1021-hammerhead.zip.md5sum
-- 16-11-2013 project device/motorola/qcom-common/ | Commit: 2400c78 | Title: Don't set TARGET_ENABLE_QC_AV_ENHANCEMENTS for msm8960 devices | By: dhacker29 project external/koush/Superuser/ | Commit: 1a03a36 | Title: require that --daemon is uid/gid 0 execv invocation fixes | By: Koushik Dutta | Commit: b6b13f2 | Title: Fix superuser when using ART. | By: Koushik Dutta | Commit: d5def08 | Title: Merge pull request #198 from cernekee/version-v1 | By: Koushik Dutta project frameworks/opt/telephony/ | Commit: 59ff8c5 | Title: Merge "SamsungExynos3RIL: fix sim PIN handling" into cm-10.2 | By: Ricardo Cerqueira project packages/apps/BluetoothExt/ | Commit: caefb48 | Title: Merge "BluetoothExt: HU translation" into cm-10.2 | By: Marco Brohet | Commit: 0a71edd | Title: Merge "BluetoothExt: SK translations" into cm-10.2 | By: Marco Brohet | Commit: 2b93d13 | Title: Merge "BluetoothExt: ES translations" into cm-10.2 | By: Marco Brohet project packages/apps/CMFileManager/ | Commit: 27c7941 | Title: Merge "CMFM: Fix deadlock" into cm-10.2 | By: Ethan Chen | Commit: be1aa63 | Title: Merge "CMFM: Remove orphan bookmarks" into cm-10.2 | By: Jorge Ruesga | Commit: 2d1fcca | Title: Merge "CMFM: Re-enable swipe to delete" into cm-10.2 | By: Jorge Ruesga project packages/apps/DeskClock/ | Commit: b317302 | Title: Merge "DeskClock: FR translation" into cm-10.2 | By: Marco Brohet project packages/apps/SoundRecorder/ | Commit: 4f19c87 | Title: Merge "SoundRecorder: FR translation" into cm-10.2 | By: Marco Brohet project packages/wallpapers/PhaseBeam/ | Commit: d42f480 | Title: Merge "PhaseBeam: FR translation" into cm-10.2 | By: Marco Brohet -- 15-11-2013 project external/koush/Superuser/ | Commit: 6d95bf5 | Title: execv invocation fixes | By: Koushik Dutta | Commit: b8d17bf | Title: README: Update required SDK and NDK versions | By: Kevin Cernekee | Commit: 91ceab6 | Title: update-binary: Fix 4.3+ version check | By: Kevin Cernekee project frameworks/opt/telephony/ | Commit: a8a61e0 | Title: SmsUsageReceiver : Check if ur is null | By: Danesh M project packages/apps/CMFileManager/ | Commit: f0ff624 | Title: Select content uris vs file uris when open or send files | By: Jorge Ruesga | Commit: ce337ec | Title: CMFM: Fix deadlock | By: Jorge Ruesga | Commit: f8a247d | Title: CMFM: Remove orphan bookmarks | By: Jorge Ruesga | Commit: 1621cdf | Title: CMFM: Re-enable swipe to delete | By: Jorge Ruesga -- 14-11-2013 project bootable/recovery/ | Commit: d336807 | Title: Merge "Add Andy's ear wiggle to recovery" into cm-10.2 | By: Nathan Grebowiec project external/koush/ion/ | Commit: cacde0d | Title: remove orientation spam | By: Koushik Dutta project external/sepolicy/ | Commit: ba5a6e0 | Title: sepolicy: Add some permissions for nfc and wifi | By: Steve Kondik | Commit: 98cfaa4 | Title: sepolicy: Allow zygote to read system properties | By: Steve Kondik | Commit: d5adaf4 | Title: sepolicy: Vold needs to deal with external sdcards | By: Steve Kondik | Commit: 9908e8c | Title: sepolicy: Give appdomain read/open on ASECs for theme support | By: Steve Kondik | Commit: b203689 | Title: sepolicy: Support for clatd | By: Steve Kondik project hardware/qcom/display-caf/ | Commit: 7de069e | Title: Merge branch 'jb_2.6' of git://codeaurora.org/platform/hardware/qcom/display into caf | By: Steve Kondik | Commit: 8e458e3 | Title: libhwcomposer: Optimize layer crops when possible. | By: Prabhanjan Kandula project kernel/samsung/d2/ | Commit: 32e69bc | Title: ApexQ: cap at 1458 MHZ | By: Dave Daynard project packages/apps/Apollo/ | Commit: f198209 | Title: Apollo: update Last.fm api | By: Kyrylo Mikos -- 13-11-2013 project external/koush/AndroidAsync/ | Commit: 364d299 | Title: add some exception tracing | By: Koushik Dutta | Commit: f0875c7 | Title: SimpleFuture: cancels should trigger callbacks | By: Koushik Dutta | Commit: 73a205f | Title: Fix test | By: Koushik Dutta | Commit: 985f582 | Title: Fix test | By: Koushik Dutta | Commit: ab932d9 | Title: Revert "SimpleFuture: cancels should trigger callbacks" | By: Koushik Dutta | Commit: 98bef8d | Title: Fix test for adjusted cancel behavior | By: Koushik Dutta | Commit: 18e4d76 | Title: Revert "Revert "SimpleFuture: cancels should trigger callbacks"" | By: Koushik Dutta | Commit: 9de5c15 | Title: SimpleFuture: calling setCallback on a cancelled SimpleFuture should invoke the callback. | By: Koushik Dutta project external/koush/ion/ | Commit: 4fbf211 | Title: Bitmaps: fix how bitmap load errors are cached. Fix NRE that occurs when a errored out bitmap is retrieved from cache. | By: Koushik Dutta project external/webkit/ | Commit: 6004ce0 | Title: GPU canvas optimizations | By: Veluppillai Arulesan | Commit: 899ba49 | Title: GpuCanvas re-arch | By: Veluppillai Arulesan | Commit: 7038571 | Title: Fix canvas double rendering issue. | By: Veluppillai Arulesan | Commit: 91ee315 | Title: Bug fixes for gpu canvas | By: Veluppillai Arulesan | Commit: 4b7d011 | Title: Recording canvas bug fix | By: Veluppillai Arulesan | Commit: ae187b1 | Title: Add reset to default shader and states | By: Veluppillai Arulesan | Commit: 6febb34 | Title: webkit: Fix for memory corruption in computing css value of MediaQuery | By: Kishore Srivenkata Ganesh Bolisetty | Commit: 7cd8a82 | Title: Webkit: Fixed fuzzy word font issue in browser | By: Abhimanyu Garg | Commit: 9cf9efd | Title: Webkit: Null check in CanvasTexture::uploadImageBuffer | By: Kishore Srivenkata Ganesh Bolisetty | Commit: 50f2220 | Title: Webkit: add to detect China phone number | By: kaiyiz | Commit: 58d1c93 | Title: Revert "Fix canvas double rendering issue" | By: Veluppillai Arulesan | Commit: ca108e4 | Title: webkit : canvas bug fix. delay canvas paint till its context creation | By: Kishore Srivenkata Ganesh Bolisetty | Commit: 72d0c76 | Title: webkit : canvas bug fix 2.exclusively setNeedsDisplay for canvas elements | By: Kishore Srivenkata Ganesh Bolisetty project packages/apps/BluetoothExt/ | Commit: f6b3468 | Title: BluetoothExt: SK translations | By: MatoDroid project packages/apps/DeskClock/ | Commit: bd38d80 | Title: DeskClock: FR translation | By: DelphinPETER project packages/apps/LockClock/ | Commit: 2166b4a | Title: Lock screen layout fixes. | By: Danny Baumann | Commit: c26ad6a | Title: Go back to weather RSS parsing instead of using YQL. | By: Danny Baumann | Commit: 3355cbf | Title: LockClock: FR translation | By: DelphinPETER project packages/apps/SoundRecorder/ | Commit: e72f156 | Title: SoundRecorder: FR translation | By: DelphinPETER
Reaktionen: fred2346, blur, Dirk64 und 3 andere
Danke, @T-REX600. Glatt verpasst. :blushing:
OP aktuell.
Neues Build online, Changelog steht noch nicht ....
Download
Reaktionen: Bödi
Ich wiederhole:
neues Build online ...
Dev um 10.10h bei XDA:
New build out, see post #2
Added battery icon control (thanks SlimRoms), date/hour customize on status bar (thanks SlimRoms), low battery indic. (thanks Omni), and many other changes, for details see changelog on gerrit @ post #3.
Reaktionen: fred2346 und Bödi
Reaktionen: Goggle, CVH und Radagast
