[ROM] [AOSPAL] Paranoid SaberDroid + REMIX ::: PA 4+ Based ROM ::: odex & deodex
  • 129 Antworten
Bödi
Bödi
Philosoph
6.180
Paranoid SaberDroid | (REMIX & VANILLA BUILDS)
SABERMOD LINARO OPTIMIZED AOSPA ( Paranoid Android ) WITH A TWIST | (HAMMERHEAD EDITION)
Screenshots
Lockscreen
Screenshots Remix Settings
298220d1397131624-rom-aospal-paranoid-saberdroid-remix-pa-4-based-rom-odex-deodex-downloads.png
[ROM][AOSPA 4+][SaberMod 4.8 + 4.9][GRAPHITE][O3][AOSPAL][Paranoid SaberDroid]
Latest release odex
Download AOSPSM from SourceForge.net
Latest release deodex
http://173.234.148.50/upload/hammerhead/psd_hammerhead-Beta-Remix-V3-20140409.zip
Features
Double Tab to sleep Status Bar & Brightness
Navigation Bar size
All current PA features PIE
Lockscreen notifications (AOSPAL) [Security > Lockscreen Notifications]
Lockscreen blur (AOSPAL)
Lockscreen transparency
Lockscreen background
Battery around lockring
Custom lockring tool
Hide initial page hints
Start lockscreen maximized
Enable/Disable camera widget
Enable portrait widget carousel
Quick Setting V3+ [PA]
Disable safe headset warning
Power connectivity alert
Recents RAM Bar (kufikugel and christianomatos)
ListView animations (Omni, AOKP)
Custom system/app animations (AOKP)
NavBar shortcuts (CM, AOKP)
Quick pulldown (CM)
Smart pulldown (PA)
Status Bar Network Traffic (ChameleonOS)
Swipe between Notification Bar and Quick Toggles
Custom Toggle: LTE, Network, NFC, Sleep, Lightbulb, etc.
Custom battery icons (circle, circle w/ 1%, etc) [Battery > Top-Righthand Corner]
Volume key cursor control [Settings > Language & Input > Advanced Options]
0.25 animation speed increments [Developer Options (hidden until you go to Settings > About Phone > and tap Build Number 7 times)]
SO MUCH MORE!
Go Social
https://plus.google.com/communities/102198405383748159411
Reaktionen: Bödi, Halo4Android, datt-bo und 2 andere
Ehemaliger TE.
Antutu
Kurz mal zum Verständnis, PA ist die Basis und es werden Sachen von so gut wie fast allen ROMs (Cm, Omni, etc) gekanged?
Und wie unterscheiden sich die Versionen Remis und Vanilla genau?
Wie oft gibts Updates und auf welcher Basis? Immer bei neuen PA - Versionen?
Suche gerade ein Rom auf PA-Basis das mir mehr Features bringt als PA plain...
Es wird nicht nur gekanged, das ist der Unterschied... Zumindest einer der Devs hilft bei PA und schreibt zusätzlich Features für das Rom. Vanilla ist Saber optimiert , aber ohne zusätzliche Features und somit auf dem Level wie die Betas. Remixed hat zusätzliche wie die Lockscreen etc.
Reaktionen: stocks bollocks
Danke! Ich versuch sie mal...
;) habe von dem und dem originalen PA immer aktuelle Backups, so kann ich in der Recovery schnell switchen, da ich Multirom nicht installieren will... Momentan aber ganz klar mein Favorit...
Der ursprüngliche Beitrag von 12:13 Uhr wurde um 12:14 Uhr ergänzt:
Mal schauen was morgen passiert...
Selbe Vorgehensweise bei mir ;)
Läuft fehlerfrei und gut!
Ich bleib erstmal, nur leider keine OTA Updatefunktion wie ich das sehe...? Ich teste das jetzt mal unter Art
Franco F34 TEST übertaktet.... Einstellungen folgt
Reaktionen: FlolB
Im Arkenstone Thread wird sogar 6 hrs SOT gesprengt... Also für mich mehr als zufriedenstellend
nachdem du als Einzelkämpfer den Thread so schön am leben hälst, werde ich die Rom jetzt doch mal testen.
War die ganze Zeit mit SlimKAT sehr zufrieden, aber meine WLAN-Geschwindigkeit ist auf einmal seeeeehr langsam. Deshalb bin ich jetzt mal kurz auf CM, aber da fehlt mir doch einiges.
Werde dann mal weiter berichten, wenn ich diese heute Abend eingerichtet hab.
Noch kurze Frage: Welche Icons verwendest du, sehe cool aus - so paranoid :)
Reaktionen: FlolB
Goolors und HomeMade ... Ich designe ein wenig für das Team... Cooles Rom und nette Devs und absolut stabil... Muss halt jeder entscheiden, was er braucht und mag...
Reaktionen: Rallyharry und FlolB
Mal ne doofe Frage, aber heißt die Datei
pa_hammerhead-4.0-BETA6-20140222.zip
Bin ein bisschen verwirrt weil da nix von sabermod oder so steht
Ja. Passt..
Finde das ROM immer noch sehr gut! Ich schau mir jetzt auch mal das neue Build an :)
Wo ist das online? finde es nicht...
Weil steht ja irgendwie überall 02.22.14
Der ursprüngliche Beitrag von 12:07 Uhr wurde um 12:16 Uhr ergänzt:
Ah hier.
sparksco schrieb:
I know everyone has been itching for a new update. I have a update but it's odex. Should be fine dirty flashing over aospal rom but if you run into issues you may want to wipe data. This is a person build so don't ask for deodex. Fresh ROM repo sync today. Quite hours removed by PA (should be re-implimented with newer version at some point).
Kernel STS: Intelliactive new default governor thanks to [MENTION=3332811]faux123[/MENTION]
ROM: http://sourceforge.net/projects/aospsm/files/AOSPAL/pa_hammerhead-eng-20140314-sparksco.zip/download
MD5: 83c1b6a1902f6afcbde1294ff2e7cd83
I've been told normal PA gapps work but I still use the odex
PA ODEX GAPPS (hammerhead only)
http://sourceforge.net/projects/aospsm/files/AOSPAL/gapps-pa-odex-4.4.2-20140309.zip/download
MD5: 18d02bd1d4fdd890ae1ac3f22d2a82f7
Sunny
Toronto
Toronto
forb'S
SoniQ
SoniQ
Nuitiodo
Nuitiodo
Nuitiodo
