Djanik
Fehler gefunden! Es lag an der DoubleTab2Wake Funktion. Nachdem diese ausgeschaltet ist, wurden keine der 5 Testanrufe beendet.
Some short info regarding state of development:
Mako seems to be good to go, flo is afaik also in good shape, only HH gives us some headache as it immensely drained battery while screen was on (way more then usual) also chad currently tries to implement custom hotplug into HH, so all psk have the same functions (way easier to support). I made a test kernel for HH to hunt the drain, hope testers will report after some testing...
As we have also problems with the toolchains (mako+flo build fine with cfx, HH gave problems) we also implemented a function to our build system for kernels to allow to build each kernel with a different toolchain (we're the only ones that have such)...
Gesendet von meinem Nexus 5 mit Tapatalk
I need a working hh kernel that I like to release v3
- den faux kernel wird er ja kennen, oder ??
ironie/sarkasmus off
Hey leute, es gibt noch ein weihnachtgeschenk für euch!
