qu4nd
Ehrenmitglied
- 17.632
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem Gerät!
XDA Developers Thread
ROM LINK - index · powered by h5ai 0.26.1 (http://larsjung.de/h5ai/)
WEEKLIES - http://download.dirtyunicorns.com/files/hammerhead/Weeklies/
GAPPS - index · powered by h5ai 0.26.1 (http://larsjung.de/h5ai/)
Source
Gerrit
Google+ community
Bug Reporting
Kernel Source
Code:
- Akuelles TWRP Revovery installieren
- Fullwipe durchführen (von anderer Rom kommend)
- ROM flashen
- GAPPS flashen
- Reboot
Code:
Version 9.7
- Update to Android 5.1.1_r18 (LVY48F)
- Add Hot Reboot to Power Menu
- Fix 3-finger Gesture
- Slimified Nav Ring targets
- Ability to ignore interruptions while active media playback
- Add OmniSwitch as Recents
- Add Gesture Lockscreen
- Ability to hide Power Menu on the Lockscreen
- Ability to have notification lights while screen is on
- Bring back the Battery Bar
- Allow lockscreen elements to be themeable via color changing
- Ability to disable Privacy Guard notifications
- Add Volume Panel QS tile
- Disable extended statusbar weather by default
- Add ability to rotate the lockscreen
- Haptic feedback for QS tiles
- Time Contextual Headers
- Fix NFC tile disappearing
- Volume panel timeout ability
- Long press lockscreen lock icon to sleep or activate Torch
- Add menu action to OmniSwitch
- Fix Ad Blocker
- Re-organize Dirty Tweaks to make things more streamlined
- Further optimizations and bug fixes
- CMTE fixes
- Updated translations
For detailed change log, check http://gerrit.dirtyunicorns.com/#/q/status:merged,n,z
Source
Gerrit
Google+ community
Bug Reporting
Kernel Source
