[ROM][4.4.4] Dirty Unicorns v8.2
  • 338 Antworten
qu4nd
qu4nd
Ehrenmitglied
17.632
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem Gerät!
XDA Developers Thread
Code:
-- Built-in ad blocker (able to update hosts on the fly)
-- Ability to disable FC notifications
-- Enable pointer/user microphone options (screen record)
-- Download Center (Gapps, Xposed, etc)
-- Ability to force Expanded Notifications
-- Over 100 cloud based wallpapers
-- Facebook Sync Hack
-- Immersive mode
-- Hot Reboot In Power Menu
-- Appbar (app sidebar)
-- Customizable Quick Settings
-- Customizable power menu
-- Customizable lockscreen shortcuts
-- App Ops access in Settings
-- TRDS (built in theme in settings)
-- Statusbar Clock options
-- NavBar Options
-- Halo (multi-tasking tool)
-- Halo size/color changer
-- Hardware key remap mod (only for HW button devices)
-- Battery Bar / Circle batteries
-- Network speed indicators in statusbar
-- SuperSU (chainfire)
-- Build.prop mods
-- Init.d Tweaks
-- Active Display (Moto X notifications)
-- ListView Animations
-- Custom System Animations
-- Toast Animations
-- Custom BusyDialog
-- Advanced Low Battery Indicator options
-- ScreenShot QuickTrash
-- Color Changing PhaseBeam
-- Gesture Anywhere
-- Button Light Notification
-- Statusbar Color options
-- OmniSwitch (multi-tasking tool)
-- Driving Mode
-- Lockscreen theme options
-- Lockscreen notifications / options
-- System App Remover
-- Identicons
-- Suspend Actions
-- Wakelock Actions
-- SlimROM based recents
-- Contextual notification panel headers
-- SlimROMs privacy guard
-- Blacklist calls/sms
-- And much much more, just take a peek in Dirty Tweaks for yourself and ENJOY!!!
8.2 - https://github.com/DirtyUnicorns-KitKat/android_kernel_lge_hammerhead
Code:
- Akuelles Custom Revovery installieren
- Fullwipe durchführen
- ROM flashen
- GAPPS flashen
- Reboot
Code:
[B]8.2 - 11/04/14[/B]
- Kernel updates
- Disable/Enable screenshot sound
- Navbar: Custom Glow Time
- SystemUI: Fix crash during notification/theme change
- Bring back color changer for MIUI-like carrier label
- Fix carrier label not sticking after a reboot
- Fixed clear-all button bug
- Fix auto rotation/battery tile long press
- Double tap to sleep on navigation bar
- Add Voice Dialer back
- Support full size application screenshots
- Fix bootanimation cut off on HDPI devices
- NavRing: Last App
- Fix long press app circlebar QS tile
For a more detailed changelog, feel free to check out our Gerrit or Github.
STABLE ROM LINK - DU_hammerhead_4.4.4_20141105-0041.v8.2-OFFICIAL.zip
WEEKLIES ROM LINK - du_hammerhead_weeklies
GAPPS - PA_Gapps_4.4.4_signed.zip
DU GAPPS - DU_TBO_Gapps.zip
PS: DU DOES NOT SUPPORT ART
Google+ community
Bug Reporting
Reaktionen: Bödi
*Startpost des ehemaligen TO's
Reaktionen: MichelFell, Radagast, Berlino und 5 andere
Hey Leute,
ich habe die Rom erst einmal auf mein Nexus 7 geflasht: Und ich muss sagen, ich bin begeistert! Sehr smooth die Rom. Werde wahrscheinlich auch auf dem Nexus 5 auf diese Rom umsteigen. Die Rom bietet auch schon einige Features, obwohl es der erste Release dieser Rom ist.
Screenshots reiche ich gleich nach.
Reaktionen: Stöpsel29 und CVH
Na da bin ich mal auf deine Bilder gespannt.
Akeel1994, sind die Toggles etc orange wie beim XDA-Thread? Wenn ja, werde ich sie mal antesten...
sind stock gehalten, aber ich meine man kann die farbe ändern. ich schaue gleich mal nach für dich :)
Der ursprüngliche Beitrag von 19:47 Uhr wurde um 20:13 Uhr ergänzt:
So, hier sind die Screenshots:
https://www.dropbox.com/sh/ij0chso7aeq184y/edexuhoC5H
Farbe der QS kann man ändern, sieht man auch auf den Screenshots.
Reaktionen: El-Lobo68, razooor, CVH und 2 andere
Auf dem n7 macht sie schon mal einen guten Eindruck.... Morgen wird sie auf dem n5 versucht...
Läuft sehr gut. Art läuft nicht ist das richtig? Wenn ich es aktiviere hab ich eine Endlosschleife im Bootvorgang
ja genau, die entwickler werden es auch nicht unterstützen, da es noch experimentell ist und auch nicht jede app damit klar kommt.
aber die rom is so schnell, dass man art auch nicht braucht :D
Der ursprüngliche Beitrag von 23:14 Uhr wurde um 23:15 Uhr ergänzt:
auch schon auf dem n7 geflasht?
dann lass mal morgen hören, wie es auf dem n5 läuft
Naja ich konnte schon einen Unterschied feststellen. Werde jetzt aber mal ausgiebig testen. Gefällt mir bis jetzt wirklich super. Hat schon jemand Werte wegen des Akku Verbrauchs? Bin auf dem aktuellen Franco Kernel...
ne leider nicht, dafür ist die rom aber auch zu neu um da schon etwas sagen zu können.
BTW: Das erste Update der Rom samt neuen Features wird schon bald erscheinen.
Ok dann werde ich mal den ersten Zyklus bei mir abwarten
jop, aber der akku ist ja eh mehr vom kernel abhängig.
Da hab ich nun bei verschiedenen Roms unterschiedliche Erfahrungen gemacht muss ich sagen
ja ok, dann lass doch mal hören sobald du den akku einschätzen kannst.
Wo finde ich die Rom fürs Nexus 7?
schon jemand auf dem n5 geflasht?
Ja, ich gestern.
Läuft echt spitze und hat viele Einstellungen.
Bin aber wieder auf meine "Hausrom"
welche ist das? ^^
Grotta57
Sunny
Toronto
Toronto
qu4nd
androidmännlein
androidmännlein
