[ROM 4.4.4][AOSP] MAHDI Rom v2.9 [25.10.2014]
  • 3.908 Antworten
Bödi
Bödi
Philosoph
6.180
XDA-Thread
Features:
Settings menu:
Sound
-DSP Manager
-Ascending ringtone
-Quiet hours
-Less frequent notification sounds
-Control volume adjust sound
-Launch music app on headset connect
-Control safe headset volume
-Power connect notification control
-Apollo as Default Music App
-Volume rocker music controls
-Volume default
-Volume adjust sound
-Reorient volume buttons
-Safe headset volume
Display
-Advanced auto brightness control
-Advanced wallpaper control
-Full rotation control including lockscreen
-Screen record with audio
-Notification LED Control
-Battery LED Control
-Wake up device on plugin/unplug
Security
-Variable size pattern unlock
-Pin keypad shuffler
-Lock before unlock
-Privacy guard
-Blacklist
Languages & input
-Auto keyboard rotation
-Disable fullscreen keyboard
-Selector notification
-Volume key cursor control
Developer options
-Advanced reboot
-ADB over network
-Development shortcut in recent apps list
-Show cpu info
-Change device hostname
Customization menu:
Themes
-Dark-UI
-T-Mobiles theme engine
Status bars & more
-Clock and date customisation
-Battery customisation
-Network speed indicator
-Statusbar brightness control
-Double tap statusbar to sleep
-Pie navigation
-Navbar customization
-Immersive mode
Quick settings panel
-Full quick settings control
-Color settings
Notification drawer
-Shortcuts
-Quick access ribbon
-Hide carrier lable
-Contextual notification panel header
-notification reminder
Recents panel
-Slim recents
-AOSP recents
-Clear all button options
-Circular memory indicator
App circle sidebar
-Included apps
Power menu
-Profile switcher
-Immersive mode
-Screenshot
-Screen record
-On-The-Go Mode
Lock screen
-Lock Screen Notifications
-Targets customisation
-Battery level on lock ring
-See through settings
-Style customizations
-Maximize widgets option
Animation control
Driving mode
-Incoming call
-Read new message
-Battery full indicator
-Connect charger
-Disconnect charger
-Clock
-Date
-Music Track
-Notification
-Read new notifications
-Included apps
-Less frequent speak notificatons​
Installation:
  • Wipe cache partition
  • Wipe dalvik cache
  • Format /system
  • install ZIP from SDCard
  • Rom-ZIP auswählen, Installation abwarten
  • Gapps flashen
  • optional: alternativen Kernel flashen
  • dann Reboot system auswählen, abwarten, freuen.
Download:
Rom:
offizielle Mahdi-Homepage
oder...
AndroidFileHost.com
Gapps:
Vom Dev empfohlen:
Slim Gapps
PA Gapps
Banks' Gapps
Kernel (AOSP, kein CAF!) könnt Ihr nach Wahl flashen (Stock ist integriert), der Dev nutzt diesen Kernel (Beta!)!
Credits:
-Manelscout4life
-Mahdi-Rom
-Cyanogen Mod
Reaktionen: ElmTunes, datt-bo, JulienD. und 15 andere
Hab im Moment cataclysm Rom drauf, aber die hier scheint auch recht interessant zu sein. Bestimmt nicht so viele Einstellmöglichkeiten wie cataclysm, aber ich hätte gerne die Profile von cm und die gibt's bei cataclysm nicht.
Etwas OT: Hat schon mal jemand versucht, diese Profile mit Tasker zu steuern?
Ach ja, Tap to wake wäre auch was tolles. Kenn das von der Viper Rom vom HTC One.
Der ursprüngliche Beitrag von 19:13 Uhr wurde um 19:48 Uhr ergänzt:
Download geht im Moment nicht.
Wollts gerade bei XDA posten, da ist bereits ein Mirror:
HIER
und nun auch im OP
Reaktionen: bearclaw
Mal schauen, vielleicht probier ich die Rom noch aus. Der Mirror ist echt schnell :)
Der ursprüngliche Beitrag von 20:09 Uhr wurde um 21:09 Uhr ergänzt:
Ok, kurz angetestet. War ok, aber die cataclism gefällt mir im Moment besser. Deshalb erst mal wieder zurück. Mir fehlen auch hier noch ein paar Dinge, die ich auf meinem N4 mit Rootbox hatte, deshalb bleigbe ich erst mal bei der catalism.
Reaktionen: Radagast
Neue Version von heute ist raus, pflege ich morgen früh ein, via Tapa funzt das ja nicht so ...
Changelog:
11/25:
-Framework changes
-Default kernel is now n3oHammer_v11.
-Use TricksterMod to set CPU, speed and or S2W and DT2W.
-Use Fanco's app to increase speaker Vol.
11/23:
-Initial Release...
Wieder neue Version verfügbar, wird heute Abend eingepflegt ...
-Added Fix for Sprint Users (LTE) - *Needs to be tested by Sprint user*
-Added MultiDPI Play Store for those with Compatibility Issues
-Back to stock kernel due to reboots trying to get several kernel features in same ROM - *Use Kernel of your choice, other Kernels may cause issues*
-NavBar Addon
Reaktionen: Bödi
Die Rom klingt vielversprechen. Werd sie morgen mal testen :)
Find die Rom gar nicht mal schlecht. Aber ist da die dpi anders? Sieht so klein alles aus. Und kann es deswegen sein dass whatsapp das Hintergrund Bild nicht behält?
anstatt 480 ist hier 440 dpi eingestellt.
ro.sf.lcd_density=420
Ist das dieser Eintrag in der build.prob? Und was ist jetzt wirklich der Standard wert?
hmm bei mir steht da
ro.sf.lcd_density=440
OK, Habs mal auf 440 geändert. Jetzt merkt sich whatsapp auch mein Hintergrund Bild.
ich bleib jetzt wohl bei dieser ROM bis CM rauskommt.
Das einzige was mir hier fehlt ist, wenn ich meinen PIN richtig eingebe, dass er direkt einloggt und ich nicht noch enter drücken muss. Weiß gerade nicht wie das richtig heißt.
Fast unlock glaube ich. Hat mir beim Testen auch gefehlt.
Dafür gibt es nur dem heutigen Update weitere Features, pflege ich nachher ein.... u.a. einen Netspeed-Indicator :thumbup:
Gefällt mir immer besser. Müsste man fast noch ein 2. Nexus kaufen ;-), damit man 2 Roms parallel testen könnte :-D
Der Netspeed-Indicator ist doch schon drin!?!
K.A., steht als neu drin, stand heute morgen gegen 02h noch nicht drin... egal...
Neue Version, frisch gebacken --> siehe OP
Reaktionen: Bödi
