[ROM 4.4.4][AOSP] MAHDI Rom v2.9 [25.10.2014]
  • 3.908 Antworten
Bin ich ja mal froh, dass mich meine Kinder eben geweckt haben...ich sauge!
Reaktionen: bearclaw und Bödi
Wurde auch gerade von meinem Junior geweckt. Dann gleich mal runter laden bevor alle wollen.
Hier noch der Changelog:
22.03.2014
Slim Recents with all fixes and new options
-option to choose aosp or slims recents panel
-option to change the size and gravity (left/right)
-favirote mode (long press on app icon)
-clear all (big pinch)
-changes with TRDS On the GO Mode (Camera overlays the screen so you use your phone while walking and not bump into a light post)
-quicksettings tile
-power menu option Lockscreen colors and Lock custom image
-color dots, frame and lock handle
-choose a custom lock image Lockscreen Style options clean up
-now when See through option is diabled blur will also be disabled
Added people lookup settings
Immersive Mode: Fix black bar in some games fix SystemUI fc with Navrings fix lockscreen settings fc for tablets
Nexus 5 Experimental kernel
-added Sweep 2 Wake and Double tap 2 Wake
-change default max screen off frequency to 1190400
New Kernel app to replace performance settings
-added touchwake control (mako)
-added double tap 2 wake control (mako)
-control s2w, dt2w, powerkey suspend and waketimout (hammerhead)
-cpu governor and frquency control
-gpu control
-voltage control
-and lots more
KNOWN BUGS
-custom lock image doesn't crop properly using Gallery app so you should use Photos app
-when using custom lock image it takes a little longer for the screen to turn on
-at first boot brightness is lower what is set, after you turn the screen off the first time it will go back to normal. Not sure why its happening but it started when lockscreen style options were added, I'll take a look at this soon
-lockscreen blur setting doesn't take affect until the second time you turn the screen on after boot
Reaktionen: Flextrick und bearclaw
Die Väter unter sich. Bei mir war dasselbe :p
Sooo, Papa hat's drauf...schaun mer mal..m
Habe die neue Version jetzt drauf aber es wird die ganze Zeit der Design-Speicher beendet. Schon direkt beim ersten Start. Liegt das daran, dass ich einen anderen Kernel benutze? Oder liegt es an den PA Gapps?
Voll nervig.
Keine Ahnung ..bin noch beim stock.will gerade Hells drauf tun...
Gibt es den Download auch irgendwo in schnell? 40 min - 39%
Nö, gab's noch nie...der mirror ist genau so langsam. Private mirrors sind nicht erwünscht.
Reaktionen: Bödi und BorussenTobi
Bei mir gibt's mal wieder keine fcs. Schnurrt wieder wie ein Kätzchen :)
Aktuelle Mahdi und hells b2.
Meines auch...extrem smooth...
Weil zwar bei omni switch bleiben, mir aber mal diese Slim recent anschauen...wo finde ich das?
Voll nervig.
Denke Ja. Welchen kernel nutzt du?
Unter Anwendungsverlauf
Der ursprüngliche Beitrag von 09:32 Uhr wurde um 09:34 Uhr ergänzt:
Gibt es in den Slim recents keinen kill all button?
Pinch ist das Stichwort ;)
Ich probiere momentan den Arkenstone Kernel mit verschiedenen Roms aus. Allerdings habe ich den FC auch mit dem verbauten Kernel und auch mit anderen Gapps. Komisch.
@bearclaw
Zwei Finger zusammen ziehen...vertikal
Reaktionen: Ranzbock, BorussenTobi und bearclaw
Bin am Laden ... zwischen 1 und 3 Stunden werde ich wohl noch brauchen :unsure:
Das Changelog hau mich jetzt nicht um ... bin schon am überlegen diese Version auszulassen.
Kann mal jemand nen ScreenShot von diesem SlimRecent reinstellen? Hab das noch nie gesehen und somit auch keine Vorstellung ob sich das für mich lohnen würde zumal ich auch sehr begeistert von der aktuellen OmniSwitsch-Lösung bin.
Reaktionen: TH3Embarcadero
Bleibe auch bei omni, da dort die Favoriten belegt werden können
Habe beides aktiviert. Allerdings hatte ich ja auch bisher auch beides. Omni switch und "normale" recents. Optisch gefallen mir die neuen sehr.
Die Slim Recents ersetzen also die standard Recents, die werden also auch genauso aufgerufen wie die standard Recents?
... na die sehen schon echt nett aus ...
Aber wie vergilbt schon sagte ... die Favoriten machen machen die OmniVariante für den alltäglichen Gebrauch aber nützlicher. Na mal sehen ...
