Bödi
Philosoph
- 6.180
- Themenstarter
- #3.681
Es gibt ein neues Test Build.
Mahdi786 schrieb:New test build is up, I haven't got time to do a full release and I want to test some stuff before hand as the next release build will be the final.
I'll push everything to github later today.
-For those having issues with emoticons, test if its fixed
-Sprint users, test if you still have data issues
-Test if Puzzle and Dragon game now works
https://www.androidfilehost.com/?fid=95747613655043294
-Theme chooser: Let ThemeService handle all theme processing
-Immersive mode: options to disable navbar or statusbar gesture
-WiFi: show devices behind a firewall that are connected to the WiFi hotspot
-Fixed keyboard emoticons issue
-APNs updates
-Other stuff, read the detailed changelog
-Tanslation updates thanks to [MENTION=4487065]stmay30[/MENTION], [MENTION=5574921]blazze11[/MENTION] and [MENTION=1621200]bankai03[/MENTION]
Hammerhead kernel
-Added backlight dimmer option
-reverted some i2c commits and fastcharge
Detailed changelog
[HIDE]
Mahdi-Rom Project name: android_vendor_mahdi
- black - Update APNs for b-mobile (440,10,Japan)
- Merudo - added Truphone UK apn
- Merudo - added TeleCable/Truphone/Mtel, fixed Lyca/Orange
- Merudo - added Voiceworks Mobile BV / MVNO NL APNs
- Merudo - Added missing line for Verizon APN (mcc 311 mnc 480)
- black - Update APNs for docomo and SoftBank (MCC:440 Japan)
- Tony Layher - Stop allowing other APNs overriding Sprint LTE.
- Merudo - added 13 Lycamobile APNs, combined TMI APN, added 48months APN
- Merudo - corrected Smarts RU APNs
Project name: android_hardware_qcom_camera
- Tom Marshall - camera: Use project pathmap
Project name: android_hardware_qcom_gps
- Ethan Chen - gps: Expect build system to always have a default QCOM variant
- Tom Marshall - gps: Use project pathmap
Project name: android_bionic
- Pracheer - libc: Add cortex-a53 bionic code
Project name: android_build
- Ethan Chen - build: Set QCOM variants for non-QCOM_HARDWARE defined targets
- Steve Kondik - build: Add "dtbs" target when building the kernel
- Tom Marshall - build: Introduce project pathmap and use it for qcom variants
Project name: android_kernel_lge_hammerhead
- franciscofranco - backlight: scale max current when the brightness level is below 15 instead of using always 0.
- franciscofranco - backlight: add minimum backlight brightness module param.
- franciscofranco - backlight: clean the code.
- franciscofranco - backlight: fix a bug where the screen would be completely dark or near darkness with backlight_dimmer enabled when the display dimmed. The brightness level can't be any lower than dev->min_brightness and previous code allowed that to happen, so fix it.
- flar2 - Backlight dimmer mod: more gradual transitions
- flar2 - More gradual levels for backlight dimmer mod (based on [MENTION=340133]MZH[/MENTION]ou module)
- flar2 - Add backlight dimmer option
- Mahdi-Rom - Revert "fastcharge: initial Nexus 5 adaptation"
- Mahdi-Rom - Revert "defconfig: add force fast charge"
- Mahdi-Rom - Revert "i2c-qup: Verify that mem resource exists prior to redirection"
- Mahdi-Rom - Revert "qup_i2c: Handle scenario if runtime PM is disable"
- Mahdi-Rom - Revert "i2c_qup: Improve implementation of PM callbacks"
- Mahdi-Rom - Revert "qup_i2c: export qup_i2c_init_driver"
- Mahdi-Rom - Revert "i2c_qup: Fix for unhandled IRQ"
- Mahdi-Rom - Revert "qup_i2c: Initialize I2C resource before registering."
Mahdi-Rom Project name: android_frameworks_base
- Ricardo Cerqueira - Add a HAF access permission
- Matthias Yzusqui - wifi: show devices behind a firewall that are connected to the WiFi hotspot
- Abhisek Devkota - Revert "SystemUI: Fix missing top task in recent panel."
- Mahdi-Rom - Disable forced navbar: reworked
- Clark Scheff - Themes: Let ThemeService handle all theme processing [1/3]
- Danny Baumann - Code cleanup.
- Mahdi-Rom - [1/2] Immersive mode: options to disable navbar or statusbar gesture
Project name: android_frameworks_opt_telephony
- Adnan - Telephony: Scrub debug messages for identifiable information.
Mahdi-Rom Project name: android_packages_apps_TouchControl
- Renaud - TouchControl: update French translations
- blazze11 - TouchControl: update German translations
Mahdi-Rom Project name: android_packages_apps_ThemeChooser
- Clark Scheff - Themes: Let ThemeService handle all theme processing [2/3]
- Michael Bestas - Automatic translation import
- Michael Bestas - ThemeChooser: Remove unused string
Mahdi-Rom Project name: packages_apps_Settings
- Xacom - Updated Italian traslations
- Altaf-Mahdi - Disable forced navbar: reworked
- Adnan - Settings: Update button backlight summary always.
- Altaf-Mahdi - [2/2] Immersive mode: options to disable navbar or statusbar gesture
- Altaf-Mahdi - Button settings: add enabled/disabled summaries for all navigation options
- Altaf-Mahdi - Settings: update Spanish translations thanks to [MENTION=500756]Senses[/MENTION]Xda
- blazze11 - Settings: update German translations
- Renaud - Settings: update French translations
Mahdi-Rom Project name: android_packages_apps_Dialer
- Andrea Fagiani - Add reverse lookup provider "PagineBianche" (IT).
- Adnan - Dialer: Scrub debug logging for identifiable information.
Mahdi-Rom Project name: android_packages_apps_Mms
- Adnan - Mms: Scrub debug logging for identifiable information, fix codestyle.
Mahdi-Rom Project name: android_packages_apps_MahdiCenter
- Renaud - MahdiCenter: update French translations
Mahdi-Rom Project name: android_packages_providers_ThemesProvider
- Clark Scheff - Themes: Let ThemeService handle all theme processing [3/3]
Mahdi-Rom Project name: android_packages_services_Telephony
Project name: android_external_sqlite
- arter97 - Upgrade to SQLite 3.8.6
- Steve Kondik - Revert "Fix world-readable permissions due to sqlite race condition"
- arter97 - Regenerate Android.patch
Project name: android_external_stagefright-plugins
- Steve Kondik - stagefright-plugins: Handle 32-bit floating point sample formats
Mahdi-Rom Project name: external_cyanogen_cmhomeapi
- Matt Garnes - Synchronize access to pending updates to Cards.
- Matt Garnes - Add null check for CardDataImage on insert.
- Matt Garnes - Add documentation for sort order of published cards.
[/HIDE]
