[ROM 4.4.4][AOSP] MAHDI Rom v2.9 [25.10.2014]
  • 3.908 Antworten
Worst case scenario! xD
haha, ultimative weckmethode..
weckt die normale weckerapp denn normal und kann ausgeschaltet werden?
seit wann ist eigtl anstatt Google now beim hometaste nach oben wischen auf einmal "Bildschirm aus"? und wieso kann ich es nicht mit dem Google Logo wieder standardmäßig einstellen? :/
edit: hat sich erledigt, funktioniert wieder.. warum das nach einem clean flash so eingestellt war, bleibt wohl ewig ein Geheimnis ;)
Bonjour je sui Laurent
New build is up, changelogs have been updated and the build will be on the main server later today.
Thanks to everyone that used the test builds and gave feedback.
https://www.androidfilehost.com/?fid=95747613655040707
Changes
Theme chooser updates:
-Fix for chrome beta fc (also other apps)
-Only process themes that are applied during boot (speeds up boot times)
Slim pie:
-added options for fade-in delay and slice gap
-remove second layer config set by default
-only disable bottom trigger if were not in immersive
-fix up clock and sysinfo sizing
-NFC polling mode
-Added App sidebar and PA's pie
-Immersive mode: option to disable force navbar when ime shows
-Set default navring to screen off and long press to power menu
-Slimrecents card/text color
-EdgeGesture service: add more sensitivity steps
-Disabling power menu on lock screen only when secure
-Show devices connected to the WiFi hotspot
-Option to force expanded notifications
-Option to show statusbar clock on lockscreen
-Option to show miui style carrier text on statusbar
-Option to disable the + icon in status header
-Clean up quick settings tile code
-Flash-Friendly File System (f2fs) support (kernel still needs support)
-Silence the debuggers
-More clean ups in Settings
-APNs updates
-Fixed fc on call when using reverse lookup provider "Das Telefonbuch"
-Fixed constant systemui force close on boot for Arabic and Hebrew users
-Fix for "volume buttons change two volume steps per click" bug
-Fixed Lock screen notification settings not applying
-Progress bar now gets themed
Colors are set to default holo_blue_light which means themes should not need to be updated,
thanks to @blazze11 and [MENTION=4337046]rush25[/MENTION] for testing and ideas.
*Upstream Google bug fixes
-Disable SPDY pooling
-Stricter subject DN parsing for HTTPS hostname verification
-Fix world-readable permissions due to sqlite race condition
-SampleTable: check integer overflow during table alloc
-Add a way to get all values of an attribute of DN
-Tanslation updates thanks to [MENTION=4584270]The Tox[/MENTION], [MENTION=4487065]stmay30[/MENTION], [MENTION=5072873]Pixelase[/MENTION], @michaelz93, [MENTION=2596617]senses![/MENTION], @n-ctrl, @jbnitro, @blazze11, [MENTION=4554645]seilogeo[/MENTION] and @bankai03
These guys have put a lot of effort to translate for the community so big thanks to them
-Merged in translations from CM for Power menu, Quicksettings, AppOps and other stuff for all these languages
af, ar, ca, cs, da, de, el, es, et, eu, fi, fr, hr, hu, in, iw, ja, ko, ku, lb,
lt, nb, pl, pt, ro, ru, si, sk, sr, sv, th, tr, uk, zh-rCN, zh-rHK, zh-rTW
Hammerhead
-Removed proximity wake support
-New kernel based on stock with all the features mentioned in the op
-Intelli-plug hotplug driver by Faux123
-Fast charge
-Multi-Rom support
Reaktionen: yetixx, SoniQ, OHara und eine weitere Person
Reicht einfaches drüber bügeln? Kann ich auch Kernel direkt mit flashen in einem Zug? Oder erstmal System aktualisieren?
Hab einfach drüber gebügelt, mit Kernel in einem Zug, alles läuft.
Komme allerdings von der 0924 Test Version.
Reaktionen: SoniQ
Wollte auch bestätigen. Läuft alles gut. Dirty Flash und Kernel hinterher
Reaktionen: yetixx
Akku Statistik in den Einstellungen funktioniert in v.2.8 nicht. Lösung steht bei xda... Einfach auf den Papierkorb tippen, damit wird die Statistik zurückgesetzt, ab dann funzt es wieder.
Ist euch bekannt ob es eine Mahdi-Rom auf Basis der nächsten Android Version geben wird, laut xda soll die jetzige build final sein und evtl gibt es noch ne final final build
Ja. Wird es geben. Deshalb bleib ich bei Mahdi...;)
Sicher meint mahdi, das die Finale Version den Abschluss von kk bedeutet...bin mir fast sicher, das er auf Basis L auch wieder weiter macht
Reaktionen: DJTrickstar und freakout
Laut xda wird es die Rom auch mit Android L weiter geben, dann aber unter anderem Namen. Mahdi arbeitet bereits dran.
kann man dir Farbe der quick tiles nicht mehr einstellen? oder finde ichs nicht..
Darf ich fragen wie du das gelöst hast? Komm einfach nicht drauf...:confused:
hab die taste editiert, sodass ich auf diesem Wege die APP 'Google' starte mit dem systemsymbol 'g'
Bei mir zieht WLAN laut Statistik viel Akku, obwohl ich hier kein WLAN verwende. Ist das der WLAN bug? Jemand hier auch mit dem selben Fehler?
Einstellungen - > WLAN - > erweiterte WLAN Einstellungen - > Erkennungsfunktion immer verwenden = Haken raus.
Das sollte es beheben.
Reaktionen: rusak2
irgendwie habe ich mit der aktuellsten Version reboots und system ui crashes.. selbes setup, selber kernel.. erstmal zurück zur 24.09. testbuild
