[ROM][4.4.2][CM][HALO] BS Harmony
  • 8 Antworten
Haeretik
Haeretik
Features:
  • CM based
  • HALO
  • Dark UI
  • Lockscreen background options (Color fill, Custom image, Transparent)
  • Customizable Lockscreen text color
  • Lockscreen rotation
  • Option to enable all widgets
  • Minimize lockscreen challange
  • Slider Shortcuts
  • Lockscreen button actions
  • LCD Density
  • Default App grip option
  • Status bar color and transparency
  • Clock and date options which includes color, location, style
  • Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
  • Breathing SMS option
  • Battery styles - Includes specific colors and styles. Also includes battery bar
  • Do not disturb option
  • Show notification count
  • Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
  • Quick settings color settings, tiles per row, Quick pulldown, text color
  • Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
  • Keyboard and input method options which include disable full screen keyboard and auto rotate
  • Kil app back button with customizable timeout values
  • AOKP animations
  • option to disable/enable vibrate on expand for notifications alerts
  • Recents RAM bar fully customizable with color styles
  • Clock widget for LockClock including extra options to fully customize every feature of the lockclock
  • Build.prop MOD options to enable/disable tweaks as preferred
  • Less frequent Notification sounds options
  • CRT screen off/on options
  • Enable/disable wake on charge
  • Superuser fully embedded
  • CM Performance options and features
  • edits/tweaks/fixes to make this build absolutely fly
  • fully themable MMS packages.
Installation:
Wichtig: Stellt sicher dass ihr die aktuellste TWRP Version installiert habt!
  1. Schiebt die Rom und die gApps auf euer Nexus 5
  2. Startet im Recovery Modus (Vol-Down + Power)
  3. es wird empfohlen einen full wipe auszuführen (system, davik, cache, factory data reset)
  4. flasht zuerst die Rom, danach wahlweise die Google Apps
  5. Reboot!
Download:
Source:
scott.hart.bti, matthew0776, BaNkS
Credits:
Screenshots:
folgen sobald ich die Rom getestet habe ;)
Changelog:
1/9
* Couple of fixes to Active Display
* Added option to view rambar in GB instead of MB
* Added Misc features under lockscreen menu which include the following:
- Lockscreen blur
- Lockscreen blur radius
- Lockscreen transparency
- Lockscreen rotation
* Option to set signal icon to either LTE or 4g
* Forward ported notification drawer brightness slider
* Added Gesture navigation
* Added longclick switchbutton
* Sleep Screen shortcut
* Option to set the phone to 2g while screen is locked to save battery
* Hidden 'android animation' planted somewhere secretely in the build
* Forward ported sound settings
* Forward ported power connect/disconnect
* Added Stylus gesture features
* Tons of UI fixes and improvements to better suite the 4.4 theme
* Tons of misc fixes and imrpovements throughout.
Reaktionen: CoreGaming, Radagast, CVH und eine weitere Person
In dem Screenshot sehe ich meinen geliebten Halo...is der schon auf 4.4? :) :) :) :) :)
Die Screenshots sind laut XDA noch von 4.3
Halo ist denke ich noch nicht dabei. Teste es aber heute oder morgen, dann kann ich mehr sagen
Neue Version verfügbar ... via Tapatalk, daher lieber keine Links ;)
Reaktionen: Goggle
Wieder ein Update:
12/19
-Fixed variable lock pattern issue. Works as it should now.
* Add lockscreen rotation as an optional rotation setting
* Forward ported power widgets - located in quicksettings and notification drawer menu.
* Ported fixes and additional power widgets
* Option to set active/inactive colors for power widgets
* Option to set headset to launch voice commands
* Allow to disable quicksettings completely
* fix for screenshot animation glitch in portrait
* new busy dlg animation from skyliner
* Quicksettings fliptile when clicking a tile
* AudioEffect: Add a stereo widener effect
* AudioFX: Add center frequency param to bassboost
* update icons and remove cm specific icons.
* allow disabling call end sound
* QS: make dynamic tiles configurable
* Custom lockscreen handle
* Beanstalk shortcut options (this is all slims work, just renamed to beanstalk)
* Custom carrier label
* Added brightness slider (swipe status bar to control brightness when enabled)
* Updated density changer to set density on the fly. No longer requires a reboot!
* Wake on connect/disconnect option
* Numerous fixes and improvements throughout the build
Reaktionen: Bödi, CVH, Berlino und eine weitere Person
Na toll das letzte :eek:
Neue Version von gestern ...
Refer there for a changelog
Harmony Download Links:
ROM- http://www.androidfilehost.com/?fid=23308990704255179
Mirror- http://d-h.st/0Sv
4.4 GApps- http://goo.im/devs/BaNkS/GApps/4.4.2/1-9_GApps_Standard_4.4.2_signed.zip
Changelog
1/9
- Lockscreen blur
Reaktionen: Goggle
Sunny
Toronto
Toronto
Nuitiodo
Nuitiodo
Nuitiodo
forb'S
SoniQ
SoniQ
