bangsti
Gast
- Themenstarter
- #301
#Nightmare DU # TeamViewer #Hammerhead #Update
Nightmare DU Build 30.01.2014 ist online.
MD5: 4d0ead834d59316d32b72b57864d129d
Habe das Build aufgrund der zahlreichen Änderungen mit FullWipe geflasht, wer es dirty versuchen will sollte vorher ein Backup machen.
Repo Sync: 30.01.2014 - 14:30
NEW:
Camera Fixes
HFM APP in Dirty Dweaks HostFile Manager
TRDS Fixes
Privacy Guard Slim
Configurable Volume Panel Style
Bootanimation
BUGS:
Kosmetisches Problem mit Bluetooth Schieberegler noch nicht behoben.
CherryPicks
frameworks/base
Audio: SetForceUse config check in AudioService
Wifi: wifi not connecting, once the APN gets disabled state
alarm: add JNI interface for clearing alarm
Alarm: Add one more RTC alarm type for poweroff alarm.
Fix dest == src bugs in Matrix.cpp.
FLAG_PRIVILEGED disappears if privileged app is updated and rebooted
Appears black screen fix for a while
Don't confuse stat and stat64.
Fix to NullPointerException when activity is relaunched
Webkit: add to support file uploading
Fix incorrect name in eglSwapBuffers log wrapper
Perform NTP lookup at Mobile data connections
allow forcing HighEndGfx mode
National Data Roaming [3/3]
Telephony: Handle DATA_CALL_LIST in DCC.
frameworks/opt/telephony
DcTracker: verify preferred apn list is not empty before enabling
Verify apnContext is not null before it gets dereferenced
PhoneFactory: fall back to default RIL if custom RIL Class fails
National Data Roaming [2/3]
Handle DATA_CALL_LIST in DCC and update dataActivity properly
Fix for data and roaming icons
packages/apps/Settings
Enable Back-key when go to Emergency call
Bleed keyguard widget picker list into translucent bars
Show memory full text only for internal storage
Fix one NPE in tethering setting
Fixed battery stats app list
packages/services/Telephony
National Data Roaming [1/3]
packages/apps/Apollo
Artist name will now be displayed together with the album name for each song on a playlist screen
Apollo: Add option for sorting by filename into 'Sort by' menu
Apollo: handle possible exceptions
Add ACTION_PICK intent
Apollo: Lock when re-opening cursor
Fix seek bar lags for AudioPlayerActivity
packages/apps/Brwoser
Show a startup page in incognito mode
Implement client-side incognito mode
packages/apps/OmniSwitch
fixed onTouch handlers
added left/right margin for overlay
use rounded corner for overlay
added setting summaries
cleanup service manifest
change to halo light
overlay cleanup
packages/apps/DeskClock
DeskClock: Add back user-defined world cities
DeskClock: Add increasing volume option for alarm clocks
DeskClock: Fix aapt warning
trds: fixed bottom bar color
TRDS: Darker Clock
DeskClock: google please cleanup your translations....DeskClock cleanup
DeskClock: Do not reduce method visibility
packages/providers/DownloadProvider
Creates parent directories before creates file
DownloadProvider: Add transfer speeds in notification
Clear notifications for Deleted items from Download list
Open images with content://media/ instead of content://downloads/ URI.
NEW:
Camera Fixes
TRDS Fixes
Privacy Guard Slim
Bootanimation
BUGS:
CherryPicks
frameworks/base
overlay cleanup
TRDS: Darker Clock
