mrlollog
!! WEDER ICH NOCH DER ENTWICKLER SIND FÜR JEGLICHE SCHÄDEN AUF EUREN GERÄTEN VERANTWORTLICH! JEDER HANDELT AUF EIGENE GEFAHR !!
Sound
-DSP Manager
-Ascending ringtone
-Quiet hours
-Less frequent notification sounds
-Control volume adjust sound
-Launch music app on headset connect
-Control safe headset volume
-Power connect notification control
-Apollo as Default Music App
Display
-Advanced auto brightness control
-Full rotation control including lockscreen
-Screen record with audio
-CRT options
-Notification LED Control
-Battery LED Control
-Wake up device on plugin/unplug
Security
-Variable size pattern unlock
-Lockscreen Vibrate
-Slide Lock Delay
-Home Unlock
-Toggle dots/error pattern visibility
-Pin keypad shuffler
-Lock before unlock
-Privacy guard
-Blacklist
Languages & input
-Auto keyboard rotation
-Disable fullscreen keyboard
-Selector notification
-Volume key cursor control
Developer options
-Advanced reboot
-ADB over network
-Development shortcut in recent apps list
-Show cpu info
-Change device hostname
Theme chooser
-CM's theme chooser
Status bar settings
-Clock and date customisation
-Battery customisation
-Network speed indicator
-Statusbar brightness control
-Double tap statusbar to sleep
Quick settings
-Full quick settings control
-Color settings
Notification panel
-Shortcuts
-CM's ribbons
-Hide carrier label
-Notification background
-Notification transparency
Recents panel
-Clear all button options
-Circular memory indicator
Buttons control
-Navbar & navring settings
-Power menu settings
-Lock screen settings
-Volume rocker wake
-Volume music control
-Volume adjust preference
Power menu
-Profile switcher
-Immersive mode
-Screenshot
-Screen record
Lock screen
-Active display
-Targets customisation
-Battery level on lock ring
-Maximize widgets option
App sidebar
Halo
Included kernel
-Linux v3.4.74
-Gamma control (thanks to faux123)
-Sound control (thanks to faux123)
-Voltage control (thanks to faux123)
-Touch wake (thanks to Stratosk)
-DT2W (thanks to Stratosk)
Experimental kernel features
-Linux v3.4.76
-CPU overclock (thanks to showp1984)
-CPU voltage control (thanks to faux123)
-GPU overclock (thanks to faux123)
-MSM mpdecision/thermal (thanks to showp1984)
-Tuned Ondemand governor
-Supports Multi-Rom (thanks to Tasssadar)
-DSP Manager
-Ascending ringtone
-Quiet hours
Display
-CRT options
Security
-Lockscreen Vibrate
-Slide Lock Delay
-Home Unlock
-Lock before unlock
-Privacy guard
-Blacklist
Languages & input
Developer options
-Advanced reboot
-ADB over network
-Show cpu info
Theme chooser
-CM's theme chooser
Status bar settings
Quick settings
-Color settings
Notification panel
-Shortcuts
-CM's ribbons
-Hide carrier label
Recents panel
Buttons control
-Volume rocker wake
Power menu
-Profile switcher
-Immersive mode
-Screenshot
-Screen record
Lock screen
-Active display
App sidebar
Halo
Included kernel
-Linux v3.4.74
-Linux v3.4.76
AUSFÜHRLICHES REVIEW
[ ROM REVIEW ] Mahdi Rom 2.5 | KitKat 4.4.2 [ DEUTSCH | HD ]
1. Mahdi-Homepage
2. Goo.im
INSTALLATION
Beim ersten Mal bzw. wenn von einem anderen Rom kommend:
1. Gapps und Rom Zip auf das Gerät kopieren
2. In die Recovery booten
3. Rom Zip flashen
4. Gapps flashen
5. Full Wipe durchführen! (Wipe Data/Factory Reset)
6. Neustarten
Von einer älteren Version kommend:
1. Rom Zip auf das Gerät kopieren bzw. via OTACenter herunterladen
3. Rom Zip flashen
4. Gapps flashen
5. Neustarten
A special thanks to my friends:
Moose0704 who maintains the Nexus 5 thread and also done the graphics
dsmitty166 for OTA and helping build this amazing ROM when needed
Manelscout4life
Also thanks to:
Cyanogenmod
Slim ROM
Omni ROM
ChameleonOS
ParanoidAndroid
showp1984
Stratosk
faux123
Thanks to all the donaters, I appreciate it alot.
Casperi, Troy, Torsten, Javier, Matteo, Scott, Robert, Francisco, drdoulittle, Stefano and Stella
Und auch ein herzliches Dankeschön von mir an den Entwickler Mahdi786, der einen wirklich fantastischen Job gemacht hat! Also wenn ihr das Rom wirklich gut findet, dann geht doch bitte auf den folgenden Link des Original-Threads und bedankt euch dort: KLICK MICH!
GITHUB: HIER
DETAILIERT: HIER
KURZ: HIER
