[ROM][KK][KRT16M][4.4]Unofficial CyanogenMod 11 Builds
  • 400 Antworten
So wieder mal ein Update xD
So schnell, weil es eine interessante Änderung gibt.
Superuser ist jetzt offiziell 4.3 kompatibel: https://github.com/CyanogenMod/Superuser/commit/0fc942f6c7ad216fd006cd850356896869fcec06
CM 10.2 12. Aug. 2013 V2 ~ 14:00
Changelog
Code:
commit fdc28d8d928a930e4f14d91a5c54b7ef2f4b328b
Author: Koushik Dutta
Date:   Sun Aug 11 21:23:11 2013 -0700
    always start daemon, as that is the default behavior.
    Change-Id: I0986d1eeef84a6866df100f40b55cb98167c4fc0
commit 0fc942f6c7ad216fd006cd850356896869fcec06
Date:   Sun Aug 11 18:43:47 2013 -0700
    update WHATS_NEW
    Change-Id: I3c3a6fe5d4e24e9688874605e31284bf3a5ccd59
commit ed2bc869896fefd4b7465da4d3ab578e6089b8b1
Merge: 6aba49a 1fc34f3
Date:   Sun Aug 11 18:37:57 2013 -0700
    Merge remote-tracking branch 'koush/master' into cm-10.2
commit 6aba49ae7f6e6f53842a3e85dfff7d6f50221979
Date:   Sun Aug 11 18:37:08 2013 -0700
    v1021
    Change-Id: Ie96206111f9bfc8b9c5a3247a2951082b09b7778
commit f9cee64fb2c33898fd0f55825670bbae977c2d14
Merge: 2c92504 72bebe6
Date:   Sun Aug 11 18:14:59 2013 -0700
    Merge remote-tracking branch 'github/cm-10.1' into cm-10.2
commit 2c9250467fe4678a042ffae6bd8d738913504437
Date:   Sun Aug 11 18:14:41 2013 -0700
    Fix potential trust issues by using SO_PEERCRED.
    Change-Id: I510fcabe3c2a7765684a31d0553ce73fa1e1ed56
commit 72d541291ef543eec7ab08fd9f3048a4efe2df2e
Date:   Sun Aug 11 18:05:11 2013 -0700
    sanitize inputs. verify mallocs.
    Change-Id: If5d7a51ca56c4dba6948d2f405f41721a15a16b6
commit c2e65a4c2468a2d607d1b32d7f60c10559091caf
Author: Steve Kondik
Date:   Sun Aug 11 18:53:05 2013 -0700
    libmedia: Featurize QCOM's VOIP feature
     * Not all targets will support this.
    Change-Id: I89a444c9ac8be3dfcaeedb599179e31383fdfec2
commit db78c5c76c596a20a6e4c751ff21c2cd2be09620
Author: Eddy Witkamp
Date:   Mon Aug 12 01:22:50 2013 +0200
    Core: NL translation
    Added percent during low battery (same as AOSP)
    Change-Id: I0027d26c015d35b0e7b566efe879d9ee8fb7eed5
commit 6cf886a8e0eed867ac7f140d07f5940a0c4b57fe
Date:   Mon Aug 12 01:21:33 2013 -0700
    msm8660: Add AUDIO_DEVICE_IN_COMMUNICATION to primary input
     * In case the app requests a high input samplerate, we need to bypass
       the MVS route.
    Change-Id: I413859be4794ee8f9c728a52aaf557954f6b7850
commit 72f2cb7373f0791f888469780b24754ea5c3fb59
Date:   Mon Aug 12 00:14:13 2013 -0700
    msm8660: Code cleanups, fix potential crashes
    Change-Id: I5e75d1fb459d1231279c511d35a0b5d51b5d10e0
commit ae4e4543bc491d735ee71887f53e8d628fa49216
Date:   Sun Aug 11 22:07:08 2013 -0700
    msm8660: Fix featurization of Samsung VOIP routing
    Change-Id: Ibf25278f5ba182f453309e1d1793d107004fe52b
commit a325d2906ed011dc09174c3b66b4f3641b851f0a
Date:   Sun Aug 11 21:36:57 2013 -0700
    mam8660: Cleanup makefile
    Change-Id: I3dee08537f860c4e82cc104ee47966011feedefd
commit 00b2903eaa35e50ac51d8ca8738370709793d780
Date:   Sun Aug 11 21:35:36 2013 -0700
    msm8660: Add msm8660 hardware config and routing calls
     * This code was lost in the upstream merge.
    Change-Id: Idb4ee2ec752110a269f5204c736a1a6930d3f010
commit 0878d8af2f1ae115621aa552edfed4120f940d89
Author: Michael Bestas
Date:   Sat Aug 10 22:38:03 2013 +0300
    DSPManager: EL translations
    Signed-off-by: Michael Bestas
    Change-Id: Ie2191b551b1cfc8237625ee85dc47de67d1d6365
commit 7dcf2d6918a3152ab10125f3bf59f7f4b2e30473
Date:   Sun Aug 11 01:13:12 2013 +0300
    Dialer: EL translations
    Change-Id: I084b4317a72bbec6a17a988e77d1e8f576e7e98c
commit 3f13adfc78d455b2cc68fdda67feca38168a3883
Date:   Sun Aug 11 01:17:24 2013 +0300
    cLock: EL translations
    Change-Id: Iabcec4dde3e55382c2ddc1a72b724658b479ed52
commit 476aa7e2750fa2870cea1d1e901eb9e680212985
Author: DelphinPETER
Date:   Wed Aug 7 20:18:02 2013 +0200
    Phone : Fr translation
    -Patch set 1 : porting from cm-10.1
    Change-Id: Ieb09b90635ecbe9fe65e217bf158c3329957ba57
Reaktionen: reneph, bjoerniko, Slotte und 5 andere
Was denkt ihr wann wird es von Offizieller seite losgehen ?
Stabil kommt es mir vor,außer bei focal hab ich mal den ein oder anderen Absturz
Mhh mit Glück vielleicht noch diese Woche würde ich sagen.
Btw Superuser funktioniert top :)
Obi, dein neues build lässt sich bei mir nicht flashen... Bricht mit Fehler ab im twrp 2.6.0.0
Versuch mal nochmal runter zu laden. Hab das schon ein paar Sekunden gepostet gehabt bevor der Upload fertig war ;)
Hab es selber gerade mit TWRP 2.6 geflasht und hat funktioniert. Muss also am Download liegen.
Bei mir auch ohne Probleme geflasht mit twrp 2.6.00
Hat nach neuem download geklappt. Musste für superuser aber in den entwicklungs Funktionen ADB und apps auswählen...
Versteh ich nicht. superuser funktionierte doch die ganze zeit, wenn man es in den entwickleroptionen aktiviert hat :confused:
Der Unofficial Build von Obihörnchen ist jetzt ebenfalls in Post 1 zu finden.
(Sorry für die Verspätung, ich bin etwas wegen meiner CM10.2 Rom beschäftigt)
Reaktionen: Obihörnchen
Ja da hast du recht war etwas falsch formuliert ^^
Es unterstützt jetzt offiziell 4.3 gab nur kleinere Bugfixes.
Neuer Tag, neue Build ;)
Diesmal mit vielen Trebuchet changes.
CM 10.2 13. Aug. 2013 ~ 09:30
Changelog
Code:
commit 392d2cd535185b4013ae7279587aaae3972737d1
Author: Christopher Ferris <cferris@google.com>
Date:   Fri Mar 15 16:01:17 2013 -0700
    libc: Update to latest cortexa15 memcpy code.
    This uses the new code original submitted as memcpy.a15.S as
    the base. However, the old code handled unaligned src/dst better
    so that was spliced in. I optimized the original unaligned code by
    removing a few unnecessary instructions. I optimized the a15 code by
    rewriting the pre and post code. I also modified the main loop to add
    a pld so that larger copies would not stall waiting for memory.
    Test cases for the new memcpy:
    - Copy all sized values from 0 to 1024 bytes, using whatever alignment
      is returned by malloc.
    For each alignment case described below, the test copied from 0 to 128
    bytes.
    - Src and dst pointers are both aligned to the same value, starting
      at one going through every power of two up to and including 128.
    - Src aligned to double word boundary, dst aligned to word boundary.
    - Src aligned to word boundary, dst aligned to double word boundary.
    - Src aligned to 16 bit boundary, dst aligned to word boundary.
    - Src aligned to word boundary, dst aligned to 16 byte boundary.
    - Src aligned to word boundary, dst aligned to 1 byte from a word
      boundary.
    - Src aligned to word boundary, dst aligned to 2 bytes from a word
      boundary.
    - Src aligned to word boundary, dst aligned to 3 bytes from a word
      boundary.
    - Src aligned to 1 byte from a word boundary, dst aligned to a word
      boundary.
    - Src aligned to 2 bytes from a word boundary, dst aligned to a word
      boundary.
    - Src aligned to 3 bytes from a word boundary, dst aligned to a word
      boundary.
    Cases to verify the unaligned source code properly aligns to a 16 bit
    boundary.
    - Src aligned to 1 byte from a 128 bit boundary, dst aligned to
      4 + 128 bit boundary.
      8 + 128 bit boundary.
      12 + 128 bit boundary.
      16 + 128 bit boundary.
    In all cases, a two byte fencepost was placed at the end of the
    destination to verify that only the requested number of bytes were copied.
    Bug: 8005082
    Merge from internal master.
    (cherry-picked from commit 21ede92d794969f22cacbdb9f557818f1c5712b5)
    Change-Id: Ief70c9e6dc8c6473ae245b6570b2c266fed9618c
    Add missing branch in memcpy.S dst aligned case.
    (cherry-picked from commit 6ffaa931c362602a2b606a610c92326a425a876e)
    Change-Id: Ifdcf01fd122866cf0d4c5b5f7a997803561d7889
    Rewrite memset for cortexa15 to use strd.
    (cherry-picked from commit 7ffad9c120054eedebd5f56f8bed01144e93eafa)
    Change-Id: Ia67f2a545399f4fa37b63d5634a3565e4f5482f9
commit 11062bdb04bf7c7392db9785f6a30e42dfe0b358
Author: Ricardo Cerqueira <cyanogenmod@cerqueira.org>
Date:   Mon Aug 12 18:44:42 2013 +0100
    Add the CM DSP library to the device-specific effects table
    Change-Id: Iec434885dc30a6623556b9c0c132fef4a0201314
commit 43d82babaef529f8c75d68790c6db8f0bfa4c708
Author: Steve Kondik <shade@chemlab.org>
Date:   Mon Aug 12 16:10:25 2013 -0700
    Disable BTC by default, only WCN needs this.
    Change-Id: Ib8eb49d47529203863fbe742a226a34b50766b10
commit f7bcea60323a12f335ff8f11c870136d08331e87
Date:   Mon Aug 12 12:02:24 2013 -0700
    Disable interleaved scan feature by default.
    Change-Id: I9f8df38e32d30b4f2f38cd032cedf376151165b8
commit 7276846ba24aa79cf4ab069f53d3a2f5e76698cf
Merge: 7c3f127 2da8c26
Date:   Mon Aug 12 10:34:57 2013 -0700
    Merge branch 'jb_mr2' of git://codeaurora.org/platform/external/bluetooth/bluedroid into cm-10.2
    Change-Id: I796d1c3934f2ed3ce76e117154ee86616ff9d6a8
commit be9c080cbb689bfbb1665edf40784e36072ba718
Author: Ondrej Zima <keltuv.email@gmail.com>
Date:   Sun Aug 11 20:49:12 2013 +0200
    Superuser: SK translation
    - little help for our neighbors - SK translation
    Change-Id: I8818ad459bb76701a841dd4ad50cdc0712c35c88
commit 6048f74c242a936a76b87092fc9d2303b42ea137
Date:   Mon Aug 12 16:32:52 2013 +0100
    Fix the theme manager's context lookup
    Since it has a specific non-app UID, context lookup was failing and
    resulting in random behaviors, especially during app installs:
    E/SELinux ( 3170): seapp_context_lookup:  No match for app with uid 1300, seinfo release, name com.tmobile.thememanager
    Change-Id: Iaf1bb1b3ef9664db150896a29fc52df2ae5b3a4e
commit d3aa0584b0de53f5040a85fe1d77c7555fbd9900
Date:   Mon Aug 12 16:31:53 2013 +0100
    Give zygote execute access to ashmem
    Change-Id: Ie667f87a1facacb5df842697660bc58ca73336f8
commit 7043f6b59468f69e679f810d3d5c9871991f7fa5
Author: Pavel Kirpichyov <pavel.kirpichyov@gmail.com>
Date:   Sat Dec 29 15:11:56 2012 +0400
    Fix typo
    Change-Id: I179187b33f666dff88b57a4c24d7507eee0219cd
    Signed-off-by: Rohan Mathur <rohanmathur34@gmail.com>
commit e7507fef427ea5388a1ab2b7ef7a195c61986fb9
Author: Chaithanya Krishna Bacharaju <chaithan@codeaurora.org>
Date:   Tue Jul 23 16:19:42 2013 +0530
    audioflinger: Fix for race conditions in direct audio track
    -Issue: Mediaserver crash is observed in direct track functions.
    -Rootcause: Between write and flush functions, write and destructor
    effectpool buffers are accessed without any synchronization that
    might lead to operations on null buffers and cause crash.
    -Fix: Use mEffectLock to synchronize access of effectpool buffers.
    CRs-Fixed: 515107
    cherrypicked from Ib071361c65b390f9486c0a080a9391f176392b30
    Change-Id: Id9e14a054d699ec803e23619ef475696b0021d4f
Author: Eddy Witkamp <eddywitkamp@gmail.com>
commit f8aeb0c926c0540dc08ff8922962553447c8f697
Author: Pramod Sivaraman <spramod@codeaurora.org>
Date:   Wed Jul 31 19:14:02 2013 +0530
    Bluetooth: Security: Handle authentication rejected error status
    Handle authentication rejected error status in failure scenario.
    Change-Id: Ibd59d161ee5481ced2cb078a6ee6f4a6b045bcd4
    CRs-Fixed: 516087
commit 195e30b7f06c0b93e62f9077c820c9e07e82176f
Date:   Mon Aug 12 17:56:19 2013 -0700
    alsa_sound: Allow dual-mic device to be used for VOIP calls
    Change-Id: I7a4a79a1c48bd082be8d5163fa8978bca4421390
commit cd26b13901178d5f6321135867ab59fe957c2605
Author: Amit Shekhar <ashekhar@codeaurora.org>
Date:   Wed Jul 31 16:03:11 2013 -0700
    alsa_sound: fix for out-of-order deadlock in AudioSessionOut
    -standby() and setParameters() acquire lock and parent locks in
     out-of-order fashion.
    -Moved lock acquisition in standby() after flush() call which
     fixes the order and aligns it as in setParameters()
    Change-Id: I0d1ad3d4b0cbf818a6fa2844024cd62aa882de22
    CRs-Fixed: 514367, 518682
    (cherry picked from commit 21ed4009199637a67419dc36131c68d44af5eb95)
commit 5f2d31855a1b391628952fd1ad2dbe8e68d27977
Date:   Mon Aug 12 17:22:55 2013 -0700
    alsa_sound: Untangle VOIP/voice speaker handling
    Change-Id: Ieedac3af120a08f567a6575fdb06e6e22946307d
commit 7c6f509bc4346af5b9b9d081aa1c97338b8029ec
Author: Srikanth Katta <skatta@codeaurora.org>
Date:   Tue Jul 9 20:31:18 2013 +0530
    legacy/alsa_sound: Return bytes written to HAL for tunnel playback.
    - Return bytes written to HAL on successful pcm_write for tunnel and
    lpa playback. Return error value returned by pcm write in other
    condition.
    Change-Id: I554df079e56fcbc8f24e5f50f4c7469ad3c2a686
commit b7d4839fff30b743458a6e62e94b9413dbbd4da8
Date:   Mon Aug 12 16:05:12 2013 -0700
    Revert "alsa_sound: Calculate proxy port latency"
    This reverts commit 6f72b5fba2f1020466d4a6531618331b8f8c0632.
    Revert "alsa_sound: Query BT/USB streams for audio latency"
    This reverts commit d46eca4d243daefb28fefbffdcb389070fd58c30.
    Revert "alsa_sound: Flush Proxy data at high water mark"
    This reverts commit a7e0ca0ab5f39c5840d25594f2a3d86a49aaa70f.
    Revert "alsa_sound: Fix buffer pointer mismatch in proxy"
    This reverts commit 6a6c9ec67be6375e00d42b12cbeb986ef5e121c3.
       the MVS route.
commit 3951c22074016482ec10394be86f514454554117
Author: Steven Luo <steven@steven676.net>
Date:   Tue Aug 6 04:04:10 2013 -0700
    wl12xx: fix unbalanced wakelock in IRQ-while-suspended path
    Change-Id: I2d9cf541884a7e2435865096796a3947439c0f4d
commit f11668eec5edab56d427bc102b0e45cbade4036e
Merge: 40d9e2f c5987d2
Date:   Mon Aug 12 11:46:23 2013 -0700
    Merge branch 'jb_mr2' of git://codeaurora.org/platform/packages/apps/Bluetooth into cm-10.2
Author: Michael Bestas <mikeioannina@gmail.com>
    Signed-off-by: Michael Bestas <mikeioannina@gmail.com>
Author: DelphinPETER <delphinpeter@gmail.com>
commit 9d9cfd033670b1d484160e8855027e002c5f3b6b
Merge: 02678cd 6a22997
Author: Jorge Ruesga <jorge@ruesga.com>
Date:   Tue Aug 13 06:22:25 2013 +0000
    Merge "Update sw600dp default_workspace_no_telephony for proper layout" into cm-10.2
commit 02678cd99a769320abc875ba53e28ecb5b09706d
Author: Michael Jurka <mikejurka@google.com>
Date:   Thu Apr 18 17:11:05 2013 +0200
    Don't set redundant content description for widgets
    TextView label already is used as label for
    accessibility
    Bug: 8185316
    Change-Id: Ic808cd1152cf6f0c6368cca769958147baad8fe5
commit bbd454dc5e11744bff15314daded23b0cdacdef1
Date:   Thu Apr 18 16:57:58 2013 +0200
    Trim widget names
    Bug: 8617506
    Change-Id: I2f7137b4b5255820af1fb2437caf3da0c163fff7
commit 89591fc2080c6da58ca91e12d9ec118eeace8a32
Date:   Thu Mar 7 13:15:10 2013 +0100
    Improve All Apps --> Workspace performance
    Fix bug where HW layers were not enabled for that
    transition
    Bug: 8323765
    Change-Id: Ifae4a17148ae0091b5f592e5150054b0c1269fb1
commit 1e9788c79f74effc3447d123762ffd5eb5775f79
Author: Romain Guy <romainguy@google.com>
Date:   Wed Mar 6 15:31:40 2013 -0800
    Prevent CellLayouts from making calls to saveLayerAlpha()
    Change-Id: I6fe1d9b39a765f4a960f7940c7afc94c784efa16
commit 00d82d3d5dd713b286fa7f58d38086089a981c28
Date:   Mon Feb 25 15:00:36 2013 -0800
    Disable clipping where unnecessary
    This change prevents the renderer from using a stencil buffer
    to render rotated CellLayouts.
    Change-Id: I0414f59ed45502323ab588820ceb4a5e3ec17140
commit 105fabe129cc6942bb8669694034f35ff6881082
Date:   Mon Jan 14 12:42:27 2013 +0100
    Use less HW layers in All Apps
    (saves memory)
    Change-Id: Ib2beda7549662a787437c7aa043e7858357c051f
commit 64cf2fdd4b1be239851b6242c9719516c1b3e754
Date:   Mon Jan 7 16:16:42 2013 -0800
    Don't use text shadows inside folders and all apps
    (saves memory)
    Change-Id: I405b7bf251dd055bde0666174003c4c80de09f4e
commit 4447d2a95d2cd7da1a71d08b641fab98c89a7280
Author: Winson Chung <winsonc@google.com>
Date:   Tue May 28 16:12:55 2013 -0700
    Fixing issue where FastBitmapDrawable is not scaling the drawing into the correct bounds. (Bug 9075810)
    Change-Id: I3a72f51d6b3c934a5fa42a3478dcb2c363047957
commit aea1117ffda7fb09020c9da4b9e012b7d2ae3c71
Date:   Thu Apr 11 11:32:45 2013 -0700
    Only postpone animations if app is visible
    Fixes bug where folders would remain open after
    returning to launcher
    Bug: 8681168
    Change-Id: I930616f2aa006c1e23298dbdb0a80a9390ea41af
commit 9f882cf8fc28055e1fcf7703d68ab1613326395c
Date:   Fri Apr 12 15:10:52 2013 -0700
    Fixing issue where accessibility was reporting items behind an open folder. (Bug 8331717)
    Change-Id: Ibaec4144ee911c6d784737cf56a4fc8a1dad2886
commit a0d9541218fe4becdeb88c79ea1faf559a90e58a
Date:   Fri Apr 12 12:36:56 2013 -0700
    Fixing issue with qsb icons not being sized correctly. (Bug 8543618)
    Change-Id: I807eaa8323e138c3ad13b6b923a3598c072c0588
commit bf79d513be562cdec61424336087cd0ddf8cdc12
Date:   Mon Apr 8 18:28:15 2013 -0700
    Fix bug where folder open animation gets finished early
    Also, sync FirstFrameAnimatorHelper with changes
    made in Recents
    Bug: 8530231
    Change-Id: Ibf1a43f67d91df89a2338f0f0c0fb52ee5496e57
commit e36bef0ca63bc81b4e131ef3054c87db8b52a8cb
Date:   Wed Apr 3 14:33:19 2013 -0700
    Fix occasional widget flashing
    Bug: 7619759
    Change-Id: Ic07ddfcc3ee76862691f940ad018f2c271d3614a
commit 8f25a8cafe1ac1dcfcf06e672a107a822bedfcba
Date:   Wed Apr 3 16:25:02 2013 -0700
    Fix crash in draw listener
    Bug: 8528246
    Change-Id: Ie3600bed58dc393fcf71f735213a32b51551b52d
commit fa2a20fd163f345974478eabdc0bf48a69492aaf
Date:   Mon Apr 1 18:21:28 2013 -0700
    Fixing issue where drag view is jumping when you scroll from hovering over an edge.  (Bug 8522679)
    Change-Id: Ie523e718bd1b558db9608aa66f6c353e4b8e1a14
commit 110df2a70eebad30bcbe04d34e85ebd7f02e3a6d
Date:   Thu Mar 28 13:39:35 2013 -0700
    Fix crash caused by unregistering animation listener
    Change-Id: I874ea6f077f593849deb28f723f2da52d018e7a5
commit 0ad71cd7c188bb29a9e4827efb92d45cb9a5d012
Date:   Wed Mar 13 12:55:46 2013 +0100
    Fix jumps in the beginning of animations
    If the first draw frame of an animation is
    expensive, which it often is, it causes a big
    jump. Added a helper class which automatically
    adjusts the animation start time if the first
    frame is more than 16ms.
    Change-Id: I100edbc41c2abe930a32d6bcf0a782ea9735f7f9
commit 3a397cbf7fcece384ac2d3a65f61058015b4db36
Date:   Wed May 8 20:15:28 2013 +0200
    Fix build breakage from syntax errors
    Change-Id: I415c5f8f17c4bad7de36d30a246bc758f0a5d806
commit 2231069888b53e6a88dab8001f33f66ff64824fb
Date:   Fri May 3 11:40:51 2013 +0200
    DO NOT MERGE Fix bug where folder was almost transparent
    Bug: 8775089
    Change-Id: I55d1bdf687e40017a10561f6bb20fc8920ab123c
commit 0cfc98f7359e0d0be77ff92fd17d8057f58075d1
Date:   Mon May 6 15:39:11 2013 +0200
    Get rid of duplicate backgrounds
    Bug: 8809491
    Change-Id: I9a7c2a4b18a64aed56ab693c8136f4689aa2ce05
commit c190f567f9e1cc5ee026cbfaa64d40641f7247cf
Author: pvolkov <marshmollow@gmail.com>
Date:   Fri Aug 9 13:58:27 2013 +0400
    Voice+: RU translation
    Change-Id: I836f7ba8c45eef8bce86eaac326820fa61ce3af4
    Patch set 2: Update translation
    Change-Id: If42b7dd636720b0ebf92b5f7d0d86e59a1732161
commit 45e6598078e3a919ec644b8ad22bf9ad2912e876
Author: Koushik Dutta <koushd@gmail.com>
Date:   Mon Aug 12 15:41:14 2013 -0700
    add a hook to add extra packages
    Change-Id: I1f955a59a18bda22c4431d05a426aab91764d20d
commit 5dcba3d6fcb5a480ccf2c21a00d3472a2419b8d6
Author: Pawit Pornkitprasan <p.pawit@gmail.com>
Date:   Mon Aug 12 20:57:00 2013 +0700
    New APN for DTAC Trinet
    DTAC has a new MNC 52005
    Change-Id: I5dd953ca6ea1503b980381861743385ffe7218b0
Reaktionen: Humpfre, XXMrHyde, Beneluxx und 3 andere
hi,
ich bekomme die 10.2 versionen leider nicht mit franco's kernel r174 zum laufen. beim neustart nach dem flashen des kernels bekomme ich sofort die meldungen "NFC-Dienst wurde beendet" und "com.android.phone wurde beendet". danach muss ich CM neu flashen um das nexus wieder benutzen zu können...
sind die versionen inkompatibel oder muss ich etwas beachten?
danke!
inspire
r174 ist nicht mit JSS build kompatibel nur mit dem offiziellen OTA von Google (JW..)
Mit r175 geht das dann aber :)
Reaktionen: inspire
Obi, wie ist das eigentlich, wirst du deine Rom weitermachen wenn die offiziellen CM's draußen sind? Oder ist dann der Reiz für dich weg?^^
Hab ein Problem. Wollte cm 10.2 testen.
Nach dem Einrichten wollte Play die ganzen Apps wiederherstellen. Nur leider wurde keine App installiert. Es gab kein Fehlerhinweis das es nicht funktionierte. Was mache ich falsch?
Komme von 10.1 und wipe vor dem Flashen.
Jo warum eigentlich nicht :)
Aber es wird immer 100% stock bleiben. (Außer ich hab irgendwann wirklich mal viel zu viel Zeit^^)
Also Nightly Alternative made in Germany sozusagen xD
Manchmal dauert es ja 1-2 Tage eh die nächste Nightly kommt und das ist immer genau dann, wenn gerade der Change des Jahrtausends gemerged wurde und es keiner erwarten kann :D
Welche Gapps hast du installiert?
Reaktionen: DasKnuffel112
Die PA 4.3
Die gibt es schon ;) Trotzdem gibts nochmal nen Build :D
CM 10.2 - 14. Aug. 2013 ~ 08:30
Gab kleinerer Performance Optimierungen und die Settings wurden neu angeordnet.
Und natürlich nen paar andere Changes...
Changelog
Code:
commit dcd730231a7d10f12ba412f9765e5a1bff5ccfc5
Date:   Mon Jul 15 13:55:45 2013 -0700
    Fix assembler errors in generic arm strlen.c.
    Tested using a static version of the strlen libc_test program
    on a nexus7 that uses the generic code.
    (cherry-picked from d8d10a8994472e40d19301b7087806630877b4d5)
    Change-Id: I88f7dc01dc5b5c3ac2d5580d92153bc1bc36c564
commit dd2150b68a0e00d130bcf9b3b4af68a93971ae00
Date:   Mon Jul 15 12:49:26 2013 -0700
    libc: Optimize strcat/strcpy, small tweaks to strlen
    Create one version of strcat/strcpy/strlen for cortex-a15/krait/scorpion and another
    version for cortex-a9.
    Tested with the libc_test strcat/strcpy/strlen tests.
    Including new tests that verify that the src for strcat/strcpy do not
    overread across page boundaries.
    NOTE: The handling of unaligned strcpy (same code in strcat) could probably
    be optimized further such that the src is read 64 bits at a time instead of
    the partial reads occurring now.
    strlen improves slightly since it was recently optimized.
    Performance improvements for strcpy and strcat (using an empty dest string):
    cortex-a9
    - Small copies vary from about 5% to 20% as the size gets above 10 bytes.
    - Copies >= 1024, about a 60% improvement.
    - Unaligned copies, from about 40% improvement.
    cortex-a15
    - Most small copies exhibit a 100% improvement, a few copies only
      improve by 20%.
    - Copies >= 1024, about 150% improvement.
    - Unaligned copies, about 100% improvement.
    krait
    - Most small copies vary widely, but on average 20% improvement, then
      the performance gets better, hitting about a 100% improvement when
      copies 64 bytes of data.
    - Copies >= 1024, about 100% improvement.
    - When coping MBs of data, about 50% improvement.
    - Unaligned copies, about 90% improvement.
    As strcat destination strings get larger in size:
    cortex-a9
    - about 40% improvement for small dst strings (>= 32).
    - about 250% improvement for dst strings >= 1024.
    cortex-a15
    - about 200% improvement for small dst strings (>=32).
    krait
    - about 25% improvement for small dst strings (>=32).
    - about 100% improvement for dst strings >=1024.
    (cherry-picked from d119b7b6f48fe507088cfb98bcafa99b320fd884)
    Change-Id: I296463b251ef9fab004ee4dded2793feca5b547a
    Conflicts:
    	libc/Android.mk
    	libc/arch-arm/generic/generic.mk
    	libc/arch-arm/krait/krait.mk
    Fix strcpy.c that should have been strcpy.S
    (cherry-picked from 1ce665416307628f4bcaced86faa64bdf9c489c3)
    Conflicts:
    Change-Id: I376b831df42248baadde7202a30a68112f752ff7
commit e19f1d8db8d6007318884272b4b04fcc97bab76f
Date:   Tue Aug 13 14:51:31 2013 -0700
    v6036
    Change-Id: I7e70d0e2e367f703fe420d4300eb5fecdc247099
commit 0c328c787c2eb6d2d3091710c588869f666ae332
Date:   Tue Aug 13 14:50:46 2013 -0700
    Shrink cid
    Change-Id: I00556341b746f186f424ebe46c94fd02f10e6536
commit 933c57dfe7ac7f86729c5df6171141b7e74faedd
Date:   Tue Aug 13 20:13:14 2013 +0100
    Updated CM release key for recovery
    Change-Id: I4aad710101cb6fbbd9df2a3137f9a5ae0e0432da
commit bc463b5f2745d1711e6fa3de73413652abf69ec2
Author: Nick Kralevich <nnk@google.com>
Date:   Fri Jul 12 13:49:49 2013 -0700
    goldfish: use fstab.goldfish
    Don't rely on init.rc to mount our filesystems for us.
    Do it ourselves from fstab.goldfish.
    Change-Id: I80ba51f34e8d34b24bc7b14f527ac507d2d819e1
commit 4615de63ea7d346198107c2b1e78b3f542297a9a
Merge: 11062bd d81b3aa
Date:   Tue Aug 13 15:43:23 2013 +0100
    Merge branch 'jb-mr2-release' of https://android.googlesource.com/device/lge/mako into cm-10.2
commit d1e3a1bc3a01e363dd4f61fbb8706bc29c2e99f5
Merge: 8039d6b c971f22
Date:   Tue Aug 13 22:36:01 2013 +0000
    Merge "Fix ordering of home keypress handling" into cm-10.2
commit c971f2218620ecc789692138b80bd28e05d3d395
Author: Ethan Chen <intervigil@gmail.com>
Date:   Tue Aug 13 14:38:59 2013 -0700
    * Home keypress handling was done out of order, causing an extra go home
      action to be executed.
    Change-Id: Ieb2f6ffbf6d1e18a5d4602975f48717089e5c9dc
commit 8039d6b2bf1316670bea1d0440ddc5e6409cd88d
Author: Danny Baumann <dannybaumann@web.de>
Date:   Wed Aug 7 12:41:00 2013 +0200
    Improve resolver layout in case package name is shown.
    Change-Id: Ib2bd0c19727194205b6e4114c34bf96663030d5f
commit 5294630b5efadb96c4e87150765e8f8b2c7c4fc7
Author: Rajshekar Eashwarappa <reashw@codeaurora.org>
Date:   Wed Jul 31 12:45:34 2013 +0530
    webkit: Manage video playing state properly when browser goes to background
    Issue: Browser App Video streaming not pausing while pressing home Button
    Fix : When the Browser goes to the background while the video is playing
          in the fullscreen, the fullscreen mode is exited. While exiting
          the full screen mode the video state is handled properly. So that
          there is no playback in the background.
    CRs-Fixed: 509225
    Change-Id: I32c306923d2638731d34d216cf006050ce4ad825
commit 903eee459536779620337b570d94f37f8d74073a
Author: huiy <huiyQuic@codeaurora.org>
Date:   Thu Jul 18 19:23:32 2013 +0800
    Add 2 APIs (suspend and resume) in MediaPlayer
    - API:suspend() will just pause the player and release all the decoders
    - instead of release the whole player
    - API:resume() will just init the decoders again
    - Add a check in onVideoEvent()
    - to make sure the first seek operation will seek the next i-frame
    Change-Id: Ia4716f7fb3a412eb19c6ded9c0f3056d0490546c
    Implement the suspend/resume operation in VideoView
    - Using the new APIs in Mediaplayer
      to implement the suspend/resume operation in VideoView
    - Add a new status "SUSPENDED"
    Change-Id: I00f9daa2d34b3b125b8c3b968bc581708ab2cdf4
    HTML5 VideoView change to use the new APIs: suspend/resume
    - While suspend and resume, using the new APIs in Mediaplayer
    Change-Id: I8530b533501607f681145853d7923fdf2009150b
commit 9a20a522919d6e7e31a728abbee426b387a7daa3
Date:   Tue Aug 13 00:53:21 2013 -0700
    Generalize vectorization of Bitmap operation
     * All NEON-capable processors can support this.
    Change-Id: I13d448e5864ea804f66cd1bbb93360cb8c0f0806
commit 2c29b43b0f5348d0142a3a2fcebb3e0627aa3721
Date:   Tue Aug 13 22:09:55 2013 -0700
    alsa_sound: Improve USB device detection
     * Samsung's proprietary dock was hijacking the routing when a USB audio
       device such as a DAC was connected in host mode.
     * Instead of blindly shoving stuff down a route that doesn't work for
       the dock case, check the switch in sysfs for the proprietary dock
       first.
     * Remove the DOCK_USBAUDIO define entirely and just wrap it up with
       everything else that SAMSUNG_AUDIO includes.
    Change-Id: Id9ea2641b67c68a8b38d24aae88b186ee6e991f0
commit b0d6db5bfa364e83ad08bd78b07d683e3715270a
Merge: 3951c22 1ec41c2
Date:   Wed Aug 14 00:50:56 2013 +0000
    Merge "wlconf: Fix compilation" into cm-10.2
commit 85920acd8f8bccc89462f23dbba98dd0ea42e15a
Date:   Tue Aug 13 16:35:00 2013 +0100
    lm3530: Add a toggle for the CABC PWM
commit e9263f41182bfadde6b0573d43c578b39bfb157d
Merge: 0878d8a 4506575
Date:   Tue Aug 13 14:47:37 2013 +0000
    Merge "Don't sign DSPManager with the platform certificate." into cm-10.2
commit 82754311d06dc847652ffbb352fea68ccd69e40d
Date:   Wed Aug 14 03:46:44 2013 +0100
    Camera: Fix the dimensions for 13 Mpx
    Change-Id: Iea85b642c5599ffefcddb82c10c56903db0cdab5
commit 862f0a9d2285dc060fb6edea3926e515cb72c09b
Merge: fe1982d f99368f
Date:   Wed Aug 14 02:00:21 2013 +0000
    Merge "Gallery2: Port additional camera resolutions from CM10.1" into cm-10.2
commit fdeff4724da426182671ff8038e52e9a04cc431d
Merge: 8e04903 a2c8beb
Author: David van Tonder <david.vantonder@gmail.com>
Date:   Tue Aug 13 21:24:35 2013 +0000
    Merge "FLAG_ONE_SHOT is not guaranteed to update the extras." into cm-10.2
commit 8e04903452f923b6ffb43b02452b700e9e92f14e
Author: Danesh Mondegarian <daneshm90@gmail.com>
Date:   Fri Aug 9 20:55:54 2013 -0700
    Settings : Re-organize menu structure
    Change-Id: I7e03f1a8e1da4545d933b91c1a50e5cf72ab4ab0
commit a2c8beb61e94a75bada08d78643bf25759351e01
Date:   Tue Aug 13 16:42:09 2013 +0200
    In contrast, according to the docs [1], FLAG_CANCEL_CURRENT is. Also
    keep track of the notifications on a per-device basis.
    [1]
    http://developer.android.com/reference/android/app/PendingIntent.html
    Change-Id: Ie04f60cde6a4332178373ce6be073e04036676c0
commit 42b1727b5268363659ea1d8843452a33dc1f7c7b
Date:   Tue Aug 13 16:36:20 2013 +0200
    Fix coding style.
    Change-Id: I520b16f1c9a927a93d9e1bd4f7e712769d341e58
commit 0eb753d302374d73e16ace1db3417de9440c44d4
Author: Pradeep Panigrahi <pradeepp@codeaurora.org>
Date:   Mon Mar 25 17:54:05 2013 +0530
    Bluetooth : Remove out of range devices after ScanComplete
    Change to remove device from UI when Bluetooth of remote
    device is off or not discoverable anymore. Without this
    change a device that discovered previously is available
    in available devices list always, though the remote device
    is not discoverable anymore. The current change updates
    available devices list on scan complete removing the
    devices that are available in cached devices and are not
    disvorable anymore.
    Change-Id: I97809fcafd904271121e26741e50a9b61f0e0664
commit 6269f41a1076627f8cbc8a85e898ea2e99038d8e
Author: Ashwini Munigala <AshwiniM@codeaurora.org>
Date:   Wed Jul 24 19:28:45 2013 +0530
    PBAP: Fix device name update on authorization prompt from Notification.
    Use FLAG_ONE_SHOT for Notification PendingIntent to launch
    authorization prompt and display the updated device name for
    every new PBAP connection request.
    Change-Id: Ic9cbed92e2856ed2d2f4f807f7f8c39df7f98762
    CRs-fixed: 515221
commit ba3d67ae7b0208da40ec8f0d1e694d829ef02e78
Merge: 4c4b308 bd3611d
Date:   Wed Aug 14 01:00:02 2013 +0000
    Merge "fs_mgr: add support for "sync" mount flag" into cm-10.2
commit 7d5bb0c38572b08f1ac07a72741d2e5a1c2b0901
Author: Oleg Drokin <green@linuxhacker.ru>
Date:   Tue Aug 13 15:31:35 2013 -0400
    Do not print misleading completion messages on trim failure
    I/fstrim  (  124): Invoking FITRIM ioctl on /rom
    E/fstrim  (  124): FITRIM ioctl failed on /rom
    I/fstrim  (  124): Trimmed 18446744073709551615 bytes on /rom
    Yeah, right!
    Change-Id: I9996d15ced97da0ade576dfc9a059b2591504af1
Reaktionen: Alex0901, bjoerniko und DasKnuffel112
Hab mir gerade das erste offiziellen Nightly installiert. Beim installieren der gapps fiel mir auf, dass PhotoSphere nicht mehr unterstütz wird mit der Stock-Cam. Wie kann ich das wiederherstellen? Focal ist hier leider noch nicht so weit, so dass ich gerne die Stock-Sphere-Funktion nutzen möchte.
AraldoL
klaust
klaust
AraldoL
