c@p
Dauer-User
- 977
Ja genau den, hab ich jetzt auch auf dem N5
kufikugel (XDA) schrieb:so new build is up guys
a lot lot lot changes under the hood:
- a lot kernel optimizations and features Josue did
- tons of dalvik, skia, bionic and system core fixes changes and improvements
- activated SlimCenter for now (it will follow on a later point a SlimPlayStore which can manage the trds apps and gapps updates automatically)
- say hello to slims new file manager SimpleExplorer
- support for all shortcuts features if the user disables or uninstalls an binded app
- fix for 3dot menu button dissapears after disabling navbar
- a lot smaller fixes here and there
- and a small surprise I do not say where it is....lets see who discoveres it lmao
all in all I got major speed and battery improvements on my hammerhead (I do not really like benchmarks but I do them sometimes under same conditions several times to get a feeling if it is better or not....at least for me several antutu benchmarks show about 5k more compared to before.....30k to 32k is no problem now). So test it deeply please. Dirty flash should be fine....but due of the tons of changes it is possible that it is needed to clean flash. So if you have any weird behaviour clean flash please. Dirty worked for me though I just needed to wipe wikipedia app data lol
Whatever...last note the published build is completly untested!!!!!!!!!!!!!!!!!!!! Do a backup before please!!!!!!! No mako owner from us is currently awake so I complied for you guys.
have fun report back and cheers
c@p schrieb:Hab gerade mal diesen Moto-X Dalvic Patch ausprobiert. Ergebniss: Amazing!
Faux 29m Kernel, also Standard Frequenzen, Intellidemand, Simple
increpidix schrieb:Wie bekomme ich eigentlich die Statusleiste transparent? Oder wird das derzeit noch nicht unterstützt?
DickenAc schrieb:Im Patch Keller... Spasshier http://forum.xda-developers.com/showthread.php?t=2537299
Don't use the attached ZIP on odexed ROM as you will end up in a bootloop.
so changelog:
- massive surfaceflinger and hwcomposer updates
- fixed googles bad patch on last update which broke backupservice
- added quiet hours
- added lockscreen targets and shorcuts which is much improved to the 4.3 version and has finally as well the small glitches fixed. A lot recoded work went into this
- added quick unlock feature
- added rotation settings
- again a lot fixes on google code and some on our code
- fix navring works now without google now as well
- fix navring stays now till really a target is selected
- gallery2 received 30 patches of fix google stuff
- mako kernel got a huge update
- hammerhead kernel minor updates
- maguro kernel lean got sorted out and is working now flaweless
- a lot small stuff
have fun and report back![]()
cheers kufi
@gapps still the 1.3 gapps are up to date
