• Android 16 Beta für Pixel-Smartphones verfügbar, alles Infos hier.
[ROM][KK][KOT49H][4.4.2] Cataclysm Rom for Nexus 4 (Mako) [Dez-12-2013]
  • 497 Antworten
DasKnuffel112
DasKnuffel112
Stamm-User
256
Cataclysm Rom for Mako
Android 4.4.2 KitKat
Build: KOT49H
Ich möchte euch hier eine Rom von Atl4ntis von XDA vorstellen, ziemlich genial...
Galaxy Nexus, Nexus 4/5: Cataclysm Rom [Rom Review][german] - YouTube
Dies ist ein neues Konzept für Roms. Die Stabilität des Google Stock-Roms mit den nützlichen Funktionen und der Power von AOSP. Dies ist meine Vorstellung wie ein Stock-Rom aussehen sollte.
Features:
Smart Radio: "Gimme moar juice!"
- Automatically manage your 2g/2g3g connection:
- It auto switch to 2g when 3g is not needed and switches back when needed.
- When 3G is "needed" you can also choose to switch to 2G on screen OFF and back on Screen ON.
- Now it automatically switch on Low Battery and when charging aswell.
- Optional Force 3G Only network mode.
- More features and details here.
InCall Blocker: "This is a phone afterall..."
- You can silently block incoming calls for:
- ALL
- RESTRICTED
- UNKNOWN
- NON CONTACT
- ALL CONTACT
- SINGLE CONTACT
- You can choose Pickup/Hangup mode instead of normal Reject.
- Blocked Calls appear in Call Log.
- White list mode.
- Optional StatusBar Icon, Notification and associated QuickToggle.
- AutoHide your phone number to Non Contacts.
- More details here.
Quick Toggles ™: "The original ones..."
- You can enable/disable/resize/rearrange any toggles, including system and temp ones;
- Optional 4 columns layout;
- You can remove text labels and enable haptic feedback;
- Pull Quick Toggles with just one finger if no ongoing or no clearable notifications, or from left/right.
- Wifi : onClick ON/OFF ; onLongclick wifi settings;
- Bluetooth: onClick ON/OFF ; onLongclick bluetooth settings;
- Mobile Data: onClick ON/OFF ; onLongclick data usage;
- 2G3G: onClick 2G/2G3G ; onLongclick Smart3G settings; Optional Force 3G Only network mode;
- Screen Suspend: onClick alwaysON/OFF ; onLongclick display settings;
- GPS: onClick ON/OFF ; onLongclick location settings;
- NFC: onClick ON/OFF ; onLongclick nfc settings;
- Hot Reboot: onLongClick Hot reboot; (requires SystemUI as root)
- Sync: onClick ON/OFF ; onLongclick sync settings;
- Wifi Hotspot: onClick ON/OFF ; onLongclick Tethering settings;
- Torch: onClick ON/OFF ; onLongclick Brightness popup;
- Rotation Lock; onClick Locked/Unlocked; onLongclick force Landscape/Portrait;
- Force USB Fast Charge;
- ADB over Wi-Fi: onClick ON/OFF ; onLongclick developer options; (requires SystemUI as root)
- Ringer Mode: Silent/Normal/Vibrate;
- Screenshot: onClick Collapse + Screenshot; onLongclick Screenshot;
- InCall Blocker: onClick goes through all the blocking modes; onLongclick InCall Blocker settings;
- Hide NavBar: onClick Hide/Unhide the Navigation Bar;
- USB Tethering: onClick ON/OFF ; onLongclick Tethering settings;
- Volume: onClick Volume slider; onLongclick Volume settings;
- Ime: onClick input method selection;
- System Monitor - Cpu speed/temp - Battery temp;
- Network Speed Monitor;
More Features:
- Softkeys Fade Mod
- Custom Lockscreen Wallpaper (normal/dimmed)
- % Textbattery + Icon / Text Only / Circle battery / Hide
- Nfc polling mode (S-On Locked/S-On Unlocked/S-Off). Disable Nfc sounds (vibrate instead)
- Expandable Volume Overlay + unlink notification volume
- Remember Volume levels when plugging Headset and auto-adjust them
- Navigation Bar resizable (portrait/landscape or portrait only)
- Full screen caller - consistent Answer with SMS
- Custom Lockscreen Targets
- Clear all recents and Sleep Button (longpress for PowerMenu)
- Speaker volume boost
- Keyboard customization (size and rows) (QWERTY only)
- Sim Toolkit (Stk) Compatible
- Volume Rocker Wake (VolUp + VolDown if music is playing)
- Volume Rocker Music Control
- Volume Rocker Cursor Control
- Longpress Back to kill foreground app
- Optional vibration on remote call connect/disconnect
- Mms with Unicode support - Inverted version available
- Longpress Home to app drawer (Currently supports Nova, Holo, Holo HD, Aphex)
- Quick PIN Unlock
- Led notification support for missed calls. Led pulse shortened to 3sec.
- Extended Power Menu
- Expanded Desktop Mode with and without StatusBar
- onClick and onLongClick actions to StatusBar Clock/Date
- H+ UI Support
- Rom settings backup support
- 3G Only network mode
- Go Home after a phone call
- Forces phone to sleep after a missed call
- Announce caller over earphones/headsets (tts).
- Allow only one lockscreen widget to avoid bars/plus/swipe
- National data roaming only
- Lockscreen rotation
- Optional CRT animation - Landscape animation
- Center statusbar clock - AM/PM Style - Disable StatusBar clock
- Longpress recents go to last task
- One click default app picker
- Hide incoming sms/mms text subject/body on statusbar notification
- Start lockscreen widgets maximized
- Disable lockscreen camera
- Disable proximity sensor in call
- Disable Safe Headset volume warning
- Disable beep on volume adjust
- Disable Ime Switcher
- Disable USB Debugging notifications
- Disable GoogleNow swipe gesture
- Deodex, ADB Root, init.d support
- Custom 4.3 Kernel:
- Stock kernel with some useful features, aimed to be stable.
- No SoD or reboots with this one. Source GIT.
- Color Control (Ezekeel)
- Sound Control (Ezekeel)
- Fsync Control (Ezekeel)
- Row i/o sched (Qualcomm)
- Optional WiFi PM Fast
- Fast Charge (Chad Froebel) Toggle / Widget
- Improved Fast Charge (doesn't disable usb mtp) (Joshua Wise)
- Voltage Control (Michael Huang)
- Slightly overclocked GPU
- CIFS
- Compatible with Trickster MOD and PGM
Changelog seit letztem Build:
Dec 12, 2013: Sources updated to android-4.4.2_r1. Cataclysm Dec 12, 2013 release.
Dec 12, 2013: Fixed immersive mode confirmation popping sometimes for a moment.
Dec 12, 2013: Added option to show touches while screen recording.
Dec 12, 2013: (Re)Added ability to open AppOps from outside.
Dec 12, 2013: More consistent screen recording notification with dedicated stop button and elapsed time.
Dec 12, 2013: Screen recorder max limit bumped to 30 min.
Dec 12, 2013: Fixed lag when powering off torch after screen timed out.
Dec 12, 2013: More consistent reboot menu / high res clear recents pic.
Dec 12, 2013: Removed force sleep after missed call being obsolete in 4.4.x
Dec 12, 2013: InCallBlocker: fixed pickup/hangup mode showing the call for a moment.
Dec 12, 2013: Fixed Google dialer not showing nearby place pictures.
Dec 06, 2013: Sources updated to android-4.4.1_r1.
Dec 06, 2013: Google dialer: incoming call ui revamped with bigger picture.
Dec 06, 2013: Google dialer: answer with text more consistent.
Dec 06, 2013: Misc: disable fullscreen landscape keyboard, better implementation.
Dec 06, 2013: Fixed bottom portrait keyboard gap on immersive mode.
Dec 06, 2013: Misc: added statusbar brightness control.
Dec 06, 2013: Exposed App Ops in Cataclysm settings.
Dec 06, 2013: Added screen recorder toggle.
Dec 06, 2013: Added delete and share action to screen recorder notification.
Dec 06, 2013: Added screenrecorder service and native lib (0xD34D). Power + volUp to start/stop recording.
Dec 06, 2013: Text inside circle battery is now centered correctly.
Dec 06, 2013: Disabling SmartRadio will reset radio to default power mode.
Dec 06, 2013: Longpress backilling an app will remove it from recents most of the time.
Dec 06, 2013: Disabled internal OTA receiver.
Nov 26, 2013: Fixed recent button lag.
Nov 26, 2013: Clear recents button will place itself correctly with no navbar or when immersive mode is active.
Download Rom:
Cataclysm KitKat release Dez 12 - 2013 @ Dev-Host
Cataclysm KitKat release Dez 12 - 2013 @ Goo.im
Google Apps sind in der Rom enthalten.
Installation:
1. Cataclysm.zip auf den Internen Speicher packen.
2. In das Recovery booten.
3. Factory Reset durchführen.
4. Install zip from SD-Card und die Cataclysm.zip auswählen.
6. Reboot ins System
Wer den neuen Google Experience Launcher nutzen möchte, der kann sich die apk hier herunterladen und manuell installieren.
Ich empfehle eine Nutzung der Rom mit dem hells-Core. Eine zusammenarbeit von Rom und Kernel habe ich in dieser Form noch nicht gehabt. Einfach unschlagbar!
Vielen Dank an Atl4ntis für seine Arbeit.
Ich möchte diese nur mit diesem Thread bei uns im deutschen Raum würdigen.
XDA-THREAD
Reaktionen: Colt Steele, Toll, Emsholgi und 13 andere
So wer testet? Ich hab im Moment die Stock odexed drauf........
Hab sie druff. Alles gut. Funzt sogar schon alles.
Nachteil: Er hat GEL nicht vorinstalliert. Aber sonst perfekt
Reaktionen: Predo
Wo bekommt man GEL her?
Danke
Kann ich mein Catac-Einstellungen-Backup unter 4.4 wieder einspielen?:confused2:
Schon einer probiert?
Also Atlantis empfiehlt es nicht. Könnte Fehler geben da ein paar funktionen nun auf eine andere Basis aufbauen.
Reaktionen: DC_Spongebob
Reaktionen: DasKnuffel112
Jepp, denn benutz ich auch!
Die Screens vom Opener sind aber nicht von der letzten Version, oder??
>Nein, die Screens sind noch von 4.3. Ich mache heute noch neue ;)
Der ursprüngliche Beitrag von 19:28 Uhr wurde um 20:28 Uhr ergänzt:
Habe mal im opener einen Dropbox-Mirror hinzugefügt da Dev-Host mal wieder überlastet zu sein scheint...
Reaktionen: mschortie, opee und privat75
Kann es kaum erwarten...
Google Apps sind ja in der Rom, sind die wenigstens abgespeckt?
Ps,: Danke für neuen Screens.
Von 4.3 einfach wechseln mit Factory Reset möglich?
Du muss glaube ich erst mal auf 4.4 Stock. Kann mich aber irren :-$
Sehr schönes ROM, aber leider ist die Batterieanzeige bei der Einstellung nur Text etwas zu klein geraten - im Verhältnis zur Uhr - das gefällt mir so nicht wirklich! Aber mal sehen, was so die nächsten Tage bei der ROM passiert.
Meine Geschwindigkeit im WLAN lässt auch zu wünschen übrig... habe bereits Bootloader und Radio aktualisiert und im Anschluss dieses ROM installiert.
Welchen bootloader und welche Radio hast du benutzt? Ein Flashen der beiden ist aber nicht zwingend notwendig oder?
gibt es schon eine hellscore version für die Rom als Kernel :)
Offiziell leider nicht. Man kann aber die JSS Version mit Deprimator nutzen.
ist das empfehlenswert? =) wenn Ja bitte mal ein Link dazu will nur ungern was falsches drauf flashen.
Was ist diese funktion Smart 3G? dieses Use 3g instead of LTE?
The_King
The_King
The_King
Volle
Volle
Volle
AraldoL
