[ROM][KK][4.4][KRT16S] Official - CyanogenMod 11 Build - Milestone - Nightly
  • 1.185 Antworten
klaust schrieb:
Hier das angepasste updater-script, damit CM12 auch im MultiROM installiert werden kann. Einfach im Zip austauschen.
Code:
assert(getprop("ro.product.device") == "mako" || getprop("ro.build.product") == "mako" || abort("This package is for device: mako; this device is " + getprop("ro.product.device") + "."););
mount("ext4", "EMMC", "/dev/block/platform/msm_sdcc.1/by-name/system", "/system", "");
package_extract_file("system/bin/backuptool.sh", "/tmp/backuptool.sh");
package_extract_file("system/bin/backuptool.functions", "/tmp/backuptool.functions");
set_metadata("/tmp/backuptool.sh", "uid", 0, "gid", 0, "mode", 0755);
set_metadata("/tmp/backuptool.functions", "uid", 0, "gid", 0, "mode", 0644);
run_program("/tmp/backuptool.sh", "backup");
unmount("/system");
mount("ext4", "EMMC", "/dev/block/platform/msm_sdcc.1/by-name/userdata", "/data", "");
package_extract_file("system/bin/otasigcheck.sh", "/tmp/otasigcheck.sh");
package_extract_file("META-INF/org/cyanogenmod/releasekey", "/tmp/releasekey");
set_metadata("/tmp/otasigcheck.sh", "uid", 0, "gid", 0, "mode", 0755);
run_program("/tmp/otasigcheck.sh") != "31744" || abort("Can't install this package on top of incompatible data. Please try another package or run a factory reset");
unmount("/data");
show_progress(0.750000, 0);
block_image_update("/dev/block/platform/msm_sdcc.1/by-name/system", package_extract_file("system.transfer.list"), "system.new.dat", "system.patch.dat");
delete("/system/bin/otasigcheck.sh");
unmount("/system");
show_progress(0.020000, 10);
run_program("/tmp/backuptool.sh", "restore");
delete("/system/bin/backuptool.sh");
delete("/system/bin/backuptool.functions");
unmount("/system");
show_progress(0.050000, 5);
package_extract_file("boot.img", "/dev/block/platform/msm_sdcc.1/by-name/boot");
show_progress(0.200000, 10);
@stothez: Das "Erweiterte Neustartmenue" läßt sich mit CM12 noch nicht konfigurieren...habe auf den ersten Blick jedenfalls nix gefunden. Aber für Screenshots gibbet ja Power+Vol-, da brauch man das im Neustartmenue ja nicht wirklich....
Erst mal danke für die Mühe! Ich habe allerdings keine datei namens updater-script gefunden :( könntest du das kurz näher erläutern? :) Edit: Jetzt doch gefunden :D
Sag Bescheid, wenn es geklappt hat :thumbup:
Anbei ein Screenshot vom Diff. Sind nur ein paar Zeilen (rot markiert) die entfernt werden müssen. Vllt hilft's ja dem Einen oder Anderen beim rumspielen mit verschiedenen ROMs :winki:
Reaktionen: xess1
Ich vermute da fehlt eine weitere Änderung.
"Error executing updater binary in zip '/tmp/mr_update' "
"Failed to install ZIP"
Ich habe die Datei mittlerweile zweimal herunter geladen und die Datei und das updater-script in einer Linux Distribution geöffnet und angepasst.
Einmal habe ich den Inhalt des Script komplett ersetzt und das zweite Mal die nicht benötigten Zeilen nur entfernt.
Benutzt habe ich die Editoren KWrite und gedit. Das ganze ist ja eine Sache von wenigen Augenblicken. In
einer Windows Umgebung habe ich mein Glück ebenfalls versucht. Danach brach die Installation unter MultiRom mit dem Fehler ab, dass er das updater-script nicht finden konnte. Windows hat vermutlich die Rechte dieser Datei verändert.
Ich denke mal du hast nicht die goldene Idee auf Lager wo mein/der Fehler liegt? Auf jeden Fall danke für deine bisherigen Mühen.
mfg
Habe es probiert leider erfolglos :/ ich warte einfach auf die erste m-built und flashe es dann ohne mutirom :)
Mmh...merkwürdig...ich gucke es mir nachher mal genauer an.
Ich bin doch erstaunt wie ausgereift stabil die erste nightly zu CM12 bereits läuft. Und das obwohl ich dirty vom letzten CM11 M-Build umgestiegen bin. (natürlich mit Nandroid) :thumbup:
Kann eine klare Empfehlung aussprechen, es mal zu probieren.
Hier ist mein Zip mit dem angepassten updater-script: cm-12-20150108-NIGHTLY_kth-mako.zip
Könnt ihr ja mal probieren. :cool2:
Nicht wirklich. Vielleicht die Art wie du das Zip, die Datei bearbeitet hast...keine Ahnung.
Ich packe das Zip immer komplett aus und editiere das Script mit Notepad++ (Unix-Format(?)). Dann mache ich wieder ein neues Zip daraus. Hat bisher immer geklappt...
Reaktionen: andreas2305 und xess1
"Insufficient storage space available in system partion"
Beim installieren der PA GAPPS. nur ich?
Danke Klaust, ich lade gerade dein File. Schon seltsam das ganze. Mfg
Gibt es zu dem cm12 nightly's irgendwo Changelogs ? Beim Updater lädt er sich zu tode & ich muss die nightly's über den PC saugen & dann in den cmupdater-Ordner auf der SD-Karte packen, damit er mir die Updates anzeigt, über den Updater findet er garkeine Updates....
MfG - J.D
Danke! Hat Super geklappt! :)
Andreas, bei dir funktioniert die angepasste ZIP Datei von Klaust?
Bei mir läuft die Installation laut Anzeige durch, starten lässt sich diese Rom dann allerdings nicht. Das MultiRom Logfile ist wenig informativ. Gut das ich nun den Fehler auf mich und mein Gerät einschränken kann. Danke!​
Der erste Start dauert auch richtig lange..... :huh:
Ich kann allerdings mit TB keine Sicherung zurückladen. Das Laden startet, kommt aber nicht zum Ende! Ansonsten funktionieren die root-Apps die ich habe aber problemlos.
Edit:
Habe cm's root ausgeschaltet und SuperSU installiert. Jetzt klappts auch mit TB :)
Update: cm-12-20150109-NIGHTLY_kth-mako.zip
Ja hat geklappt, allerdings nicht beim ersten mal. Habe die Rom einfach gelöscht und wieder mit (pa)gapps installiert. (beim ersten mal ging die Installation durch aber das nexus ist trotz mehrmaligen reboots immer beim google logo stehengeblieben.
kleiner Tipp: die interne Updatefunktion klappt (zumindest bei mir) im Moment nicht. Also immer schön von Hand gucken atm =)
E: hat schon jemand die Verschlüsselung getestet? Funktioniert sie? Kann man updates machen mit aktiver Verschlüsselung?
Hallo Freunde,
leider habe ich ein Problem. Ich komme von CM12 und habe dann per Toolkit ein Factory Reset auf 4.4.4 gemacht um mir wieder CM 11 Snapshot 12 zu flashen. Jetzt kommt im TWRP die Fehlermeldung "Error updating binary in zip.
Ich habe doch den sauberen Weg über das Factory Image gemacht. Wo liegt der Fehler. Könnt ihr mir da eventuell weiterhelfen?
Grüße
Matze
Was soll denn das 4.x'er Factory Image mit CM11/12 zu tun haben? Bzw. warum dieser Umweg?
Hast du denn jetzt überhaupt ein Custom-Recovery drauf? Das aktuelle TWRP?
denke du wirst den bootloader fürs 4.4 wieder flashen müssen?!
gruß
Der Bootloader ist wurscht.... ;)
