[ROM][KK][4.4][KRT16O] Paranoid Android - Alpha Build [16.11]
  • 32 Antworten
Anti_
Anti_
Android 4.4 Kitkat AOSPA 4.0 Test Build: Dev-Host - pa_mako-4.0-ALPHA-20131112.zip - The Ultimate Free File Hosting / File Sharing Service
Remove optional "Home Sample" Launcher.
Rooted
New AOSPA 4.0 bootanimation
Busybox built in
Screenshot Delete
Advanced PowerMenu
Fix for Location Services (Thanks to DJLaMontagneIII)
Make navbar translucent for all devices on lockscreen
Add PA version to about phone
Add ModdedPA version into about phone.
init.rc: Add missing permissions and fix existent ones for interactive
vold: use blkid to detect filesystem type
vold: add support for ext4 media
vold: Support external non-emulated storage
libhardware: Disable rotation animation on External
Feature - Settings: Forward port Performance settings (Credit: CyanogenMod)
Feature - Added cpu info and memory info to About Phone Settings
Feature - Developer settings: add CPU info overlay
Feature - Display options: allow configuration of wake on plug behavior
Feature - Add support for adb over network
Feature - Safe headset volume option (2 of 2)
Feature - Slims ElectronBeam (CRT Animation) (Credit: SlimRoms)
Feature - Add scale down crt animation - thanks a ton to xploidwild
Feature - Clear Recents Button
fb: fix google observer derp
additional Fix for Location Services
Set audio volume steps from 15 to 30
WifiDisplay: Add an HDCP toggle
dalvik: fix a bug in redundant branch elimination
Fix for framework reboot on format of SD card
services: Fix the bug in NFC shutdown logic
frameworks/base/: Fix black wallpaper issue when home pressed.
Audio: Fix abnormal keytone playback during silent mode changing
UPDATE vom 16.11.2013!
Download: http://d-h.st/Efl
Changelog:
Latest AOSP build (KRT16O)
New feature -Volume Rocker wake & music control
New feature - Add battery level around unlock ring, in security settings as well (Credit: xplodwild)
New feature - Lockscreen: See through in Settings > Security
New feature - Quick unlock (Allows unlocking of the device without pressing enter for passwords and pins)
Improve AOSP Download/Upload animation
Improve scrolling cache
Build with SaberMod 4.8
Reaktionen: Andi-Roid
hab ich mir schon geladen aber überlege gerade ob ich es überhaupt testen soll... jemand schon nen Test gemacht?
Ich nicht, ich warte bis ne PA 4.4 kommt...aber lass euch trotzdem an den ganzen 4.4 ROMs teil haben ;)
Reaktionen: 4NDR345
Bin gerade dabei. Aber wie wäre es denn einfach mit #MultiROM :confused2:
gibt es irgendwelche screenshots?
Reaktionen: 4NDR345
Ja wäre ich auch für
Gibt keine, ist ne ganz gewöhnliche AOSP ROM mit den paar Zusatz Features ;)
Also noch immer nicht viel von pa mit drin :)
Das Factory Image ist ja noch nicht mal draußen. Erst wenn das erscheint, können die ja erst richtig loslegen. Wird denke ich mal noch ne Weile dauern. Aber lieber warten und ne gute Rom. ist mir lieber als irgendwas halbfertiges.
Reaktionen: 4NDR345
Ja komisch das für die beiden 7ner und das 10 schon verteilt wird. Warum nicht auch unser n4. Ob da wohl doch mehr Änderungen gemacht werden müssen... Abwarten
Ja klar, es kriegen ja momentan nur die Wifi Devices das Update.
Mit PA-Features?
Nein, Hybrid Engine geht noch nicht...
Reaktionen: androiduser44
Lol
androiduser44 schrieb:
Hatte ich schon bei cyankang oder paar omni builds. Scheint aber nix schlimmes zu sein...
UPDATE von heute!
Download: Dev-Host - pa_mako-4.0-ALPHA-20131116.zip - The Ultimate Free File Hosting / File Sharing Service
Changelog:
Reaktionen: 4NDR345
Das haben wir schon gestern geklärt ;)
AraldoL
Haeretik
  • Haeretik
PPM-Droid
PPM-Droid
AraldoL
