[ROM][JB][JWR66Y][4.3] Cataclysm Rom for Nexus 4 (Mako) [Oct-09-2013]
  • 156 Antworten
DasKnuffel112
DasKnuffel112
Stamm-User
256
Cataclysm Rom for Mako
Android 4.3 Jelly Bean
Build: JWR66Y
Ich möchte euch hier eine Rom von Atl4ntis von XDA vorstellen, ziemlich genial...
Dies ist ein neues Konzept für Roms. Die Stabilität des Google Stock-Roms mit den nützlichen Funktionen und der Power von AOSP. Dies ist meine Vorstellung wie ein Stock-Rom aussehen sollte.
Features:
Smart3G: "Gimme moar juice!"
- Automatically manage your 2g/2g3g connection:
- It auto switch to 2g when 3g is not needed and switches back when needed.
- When 3G is "needed" you can also choose to switch to 2G on screen OFF and back on Screen ON.
- Now it automatically switch on Low Battery and when charging aswell.
- Optional Force 3G Only network mode.
- More features and details here.
InCall Blocker: "This is a phone afterall..."
- You can silently block incoming calls for:
- ALL
- RESTRICTED
- UNKNOWN
- NON CONTACT
- ALL CONTACT
- SINGLE CONTACT
- You can choose Pickup/Hangup mode instead of normal Reject.
- Blocked Calls appear in Call Log.
- White list mode.
- Optional StatusBar Icon, Notification and associated QuickToggle.
- AutoHide your phone number to Non Contacts.
- More details here.
Fake Call: "No panic"
- Fake/Spoof Incoming Calls at your will.
- Due to being coded at system level, fake calls are basically identical to real ones.
- You can choose from who, delays, pic, ringtone and much more.
- Uses own QuickToggle to trigger the timer to start the incoming fake call.
Quick Toggles ™: "The original ones..."
- You can enable/disable/resize/rearrange any toggles, including system and temp ones;
- Optional 4 columns layout;
- You can remove text labels and enable haptic feedback;
- Pull Quick Toggles with just one finger if no ongoing or no clearable notifications, or from left/right.
- Wifi : onClick ON/OFF ; onLongclick wifi settings;
- Bluetooth: onClick ON/OFF ; onLongclick bluetooth settings;
- Mobile Data: onClick ON/OFF ; onLongclick data usage;
- 2G3G: onClick 2G/2G3G ; onLongclick Smart3G settings; Optional Force 3G Only network mode;
- Screen Suspend: onClick alwaysON/OFF ; onLongclick display settings;
- GPS: onClick ON/OFF ; onLongclick location settings;
- NFC: onClick ON/OFF ; onLongclick nfc settings;
- Hot Reboot: onLongClick Hot reboot; (requires SystemUI as root)
- Sync: onClick ON/OFF ; onLongclick sync settings;
- Wifi Hotspot: onClick ON/OFF ; onLongclick Tethering settings;
- Torch: onClick ON/OFF ; onLongclick Brightness popup;
- Rotation Lock; onClick Locked/Unlocked; onLongclick force Landscape/Portrait;
- Force USB Fast Charge;
- ADB over Wi-Fi: onClick ON/OFF ; onLongclick developer options; (requires SystemUI as root)
- Ringer Mode: Silent/Normal/Vibrate;
- Screenshot: onClick Collapse + Screenshot; onLongclick Screenshot;
- InCall Blocker: onClick goes through all the blocking modes; onLongclick InCall Blocker settings;
- Hide NavBar: onClick Hide/Unhide the Navigation Bar;
- USB Tethering: onClick ON/OFF ; onLongclick Tethering settings;
- Volume: onClick Volume slider; onLongclick Volume settings;
- Ime: onClick input method selection;
- System Monitor - Cpu speed/temp - Battery temp;
- Network Speed Monitor;
More Features:
- Softkeys Fade Mod
- Custom Lockscreen Wallpaper (normal/dimmed)
- % Textbattery + Icon / Text Only / Circle battery / Hide
- Nfc polling mode (S-On Locked/S-On Unlocked/S-Off). Disable Nfc sounds (vibrate instead)
- Expandable Volume Overlay + unlink notification volume
- Remember Volume levels when plugging Headset and auto-adjust them
- Navigation Bar resizable (portrait/landscape or portrait only)
- Full screen caller - consistent Answer with SMS
- Custom Lockscreen Targets
- Clear all recents and Sleep Button (longpress for PowerMenu)
- Speaker volume boost
- Keyboard customization (size and rows) (QWERTY only)
- Sim Toolkit (Stk) Compatible
- Volume Rocker Wake (VolUp + VolDown if music is playing)
- Volume Rocker Music Control
- Volume Rocker Cursor Control
- Longpress Back to kill foreground app
- Optional vibration on remote call connect/disconnect
- Mms with Unicode support - Inverted version available
- Longpress Home to app drawer (Currently supports Nova, Holo, Holo HD, Aphex)
- Quick PIN Unlock
- Led notification support for missed calls. Led pulse shortened to 3sec.
- Extended Power Menu
- Expanded Desktop Mode with and without StatusBar
- onClick and onLongClick actions to StatusBar Clock/Date
- H+ UI Support
- Rom settings backup support
- 3G Only network mode
- Go Home after a phone call
- Forces phone to sleep after a missed call
- Announce caller over earphones/headsets (tts).
- Allow only one lockscreen widget to avoid bars/plus/swipe
- National data roaming only
- Lockscreen rotation
- Optional CRT animation - Landscape animation
- Center statusbar clock - AM/PM Style - Disable StatusBar clock
- Longpress recents go to last task
- One click default app picker
- Hide incoming sms/mms text subject/body on statusbar notification
- Start lockscreen widgets maximized
- Disable lockscreen camera
- Disable proximity sensor in call
- Disable Safe Headset volume warning
- Disable beep on volume adjust
- Disable Ime Switcher
- Disable USB Debugging notifications
- Disable GoogleNow swipe gesture
- Deodex, ADB Root, init.d support
- Custom 4.3 Kernel:
- Stock kernel with some useful features, aimed to be stable.
- No SoD or reboots with this one. Source GIT.
- Color Control (Ezekeel)
- Sound Control (Ezekeel)
- Fsync Control (Ezekeel)
- Row i/o sched (Qualcomm)
- Optional WiFi PM Fast
- Fast Charge (Chad Froebel) Toggle / Widget
- Improved Fast Charge (doesn't disable usb mtp) (Joshua Wise)
- Voltage Control (Michael Huang)
- Slightly overclocked GPU
- CIFS
- Compatible with Trickster MOD and PGM
Changelog:
Changelog:
Oct 07, 2013: Added FR translation. (Gawayne)
Oct 07, 2013: Added BG translation. (DiDk070)
Oct 05, 2013: Optional hide statusbar/navbar on lockscreen only .
Oct 05, 2013: Lockscreen wallpaper: landscape wallpaper is now sized correctly.
Oct 01, 2013: Shows StatusBar on full screen lockscreen aswell using configurable one or two fingers gesture.
Oct 01, 2013: QuickToggles: use expanded volume for volume toggle.
Sep 30, 2013: Misc: disable low battery warning.
Sep 30, 2013: Expanded desktop: added option to hide only statusbar.
Sep 29, 2013: Added delete button on screenshot notification.
Sep 29, 2013: Misc: enable upside-down rotation.
Sep 28, 2013: Misc: disable phone wake when (un)plugged.
Sep 28, 2013: Optional shows StatusBar on full screen apps using configurable one or two fingers gesture.
Sep 25, 2013: SystemUI: added 2 lines layout on statusbar date.
Sep 24, 2013: QuickToggles: prevent disable location while gps is active.
Sep 21, 2013: Fix Contacts app rotation FC.
Sep 10, 2013: Fix Sleep Button layout.
Sep 07, 2013: Revert Dark Theme, available as flashable zip.
Sep 06, 2013: Fix Sleep Button layout.
Sep 04, 2013; Added EL translation. (jolas)
Sep 04, 2013: Added ZH-simplified translation. (wasdf)
Sep 04, 2013; Added PL translation. (Timsgo)
Sep 03, 2013: Misc: crt animation is now optional.
Sep 02, 2013: Added crt landscape animation.
Aug 31, 2013: Misc: left menu button is now optional.
Aug 30, 2013: Fixed possible FC on statusbar date click.
Aug 30, 2013: QuickToggles: added "Left", "Right", "Always" pulling modes.
Aug 29, 2013: InCall Blocker: added 4th flagged contacts tab in People app.
Aug 29, 2013: Misc: added lockscreen rotation.
Aug 26, 2013: FakeCall: schedulers and timers will stick upon reboot.
Aug 26, 2013: QuickToggles: network speed in byte/kbyte/mbyte accordingly to fit 4 columns layout.
Aug 26, 2013: Clear All Recents: bigger button clickable area.
Download Rom, Fixes und Themes:
Goo.im Downloads - Browsing NEW_RELEASE_MAKO
Verfügbare Downloads:
- Inverted SMS/MMS App
- Theme Basic Dark (Black UI)
- Contacts Fix
Google Apps sind in der Rom enthalten.
Installation:
1. Cataclysm-jb-mr2-JWR66Y_Oct-09-2013_MAKO.zip und ggf. Themes auf den Internen Speicher packen.
2. In das Recovery booten.
3. Install zip from SD-Card und die Cataclysm-jb-mr2-JWR66Y_Oct-09-2013_MAKO.zip auswählen.
4. Falls man will kann man nun noch die Themes hinterherflashen
5. Reboot ins System
Aus eigener Erfahrung empfehle ich den hells-Core in der Stockversion zu dieser Rom. Eine fantastische Zusammenarbeit von Rom und Kernel. Eine solche Smoothness und Akkulaufzeit habe ich bei keiner anderen Kombination erlebt bisher!
Vielen Dank an Atl4ntis für seine Arbeit.
Ich möchte diese nur mit diesem Thread bei uns im deutschen Raum würdigen.
XDA-THREAD
Reaktionen: S7rik3r, sierra35, Mikey160984 und 9 andere
4 Navbuttons wären sehr geil! ;-)
Reaktionen: vogi
Kann bestätigen, dass die ROM perfekt läuft.
Reaktionen: DasKnuffel112
Perfekte ROM
Wir bei Zeit mal getestet, sieht viel versprechend aus :beer:
Bin zu Gnex Zeiten leider nicht dazu gekommen die Rom zu testen. Ist sie Alltagstauglich wie z.B Paranoid?
Mehr als das! Einfach saubere Arbeit ohne schnickschnack! Es lohnt sich... War schon auf dem GN mein daily...
Ist eine echt graziöse Rom. Eben deshalb wollte ich sie auch hier posten, damit ihr so eine Rom nicht missen müsst. Ist ja nicht jeder von uns auf XDA. :scared:
Ohne opee hätte ich sie wahrscheinlich auch nie entdeckt. :flapper:
Gruß Denis
Dann werd ich ihr gleich mal einen Tag auf meinem N4 geben und parallel auf dem Gnex meiner Frau laufen lassen
Kann ich in der rom dis navbar komplett ausblenden, wegen lmt?
Ja geht wohl, besser mal richtig gelesen :D
Ja geht definitiv. :thumbup:
Die Rom ist mal fett :D lange gewartet und es hat sich gelohnt und alles was man braucht ist drin. Bombe :D:D:thumbup::thumbup:
Danke an die macher und vorsteller..
Mit dem hellscore einfach unschlagbar....
Das ist ja mal nice denn grade heute hat mich die Lust gepackt mal wieder ne neue Rom zu testen! Passt ja :D
Wird wohl nicht beim testen bleiben...:D
Moin gibt es in der Rom ein Theme chooser
Auch von mir gibt es nur Lob für die Rom. Schön schlicht und fix. Werd mal den Thread bei XDA nach Bugs durchsuchen, aber bis jetzt ist alles spitze.
Keine änderbar Navbuttons?
Nein aber ein Black UI Theme das per zip flashbar ist oder halt das Stocktheme was standard drin ist.
Hej,
wie sind denn die idealen smart3g Einstellungen?
The_King
The_King
The_King
Volle
Volle
Volle
AraldoL
