O
		opee
Nö nicht mal annähernd... Noch nie davon gehört und ich nutzte die Rom schonewig"!
as promised here's a nightly snapshot to be flashed on top of 7 sept release.
http://d-h.st/4kt.
Treat it as nightly/beta as i won't push a full rel till 4.4 and it's not extensively tested as full build.
Don't flash any old theme on it as it's obviously not compatible.
Sep 30, 2013: Misc: disable low battery warning.
Sep 30, 2013: Show low battery dialog/sounds only while screen is off.
Sep 30, 2013: Expanded desktop: added option to hide only statusbar.
Sep 30, 2013: Fix wallpaper not covering whole screen on stock launcher and expanded desktop mode.
Sep 29, 2013: Added delete button on screenshot notification.
Sep 29, 2013: Misc: enable upside-down rotation.
Sep 28, 2013: Misc: disable phone wake when (un)plugged.
Sep 28, 2013: Optional shows StatusBar on full screen apps using configurable one or two fingers gesture.
Sep 27, 2013: InCallBlocker: Block/Allow all rules will deactivate others and viceversa.
Sep 27, 2013: Improved code, mem friendly.
Sep 25, 2013: SystemUI: added 2 lines layout on statusbar date. Also fix wrong Quicksettings button positioning.
Sep 24, 2013: QuickToggles: new gps tile icons to differentiate between location temp one.
Sep 24, 2013: QuickToggles: prevent disable location while gps is active.
Sep 21, 2013: Fix Contacts app rotation FC.
Sep 10, 2013: Fix Sleep Button layout.
